phee
I got the Shifts
close
- Join DateOct 2007
- Age37
iTrader Positive Feedback100
iTrader Feedback Score(5)
Liked:231 Times in 164 Posts
Thanks for the reply. So how deep should I go when sanding the paint? Down to the primer? Or am I just roughing up thr surface and straightening the body before priming?
Moderator Alumnus
teranfon
Moderator Alumnus
close
- Join DateOct 2004
iTrader Positive Feedback0
iTrader Feedback Score(0)
Liked:196 Times in 99 Posts
Hi phee
You need to make sure there is a good bite on the existing surface. If the paint is original and in good shape, then sanding down to the primer isn't necessary. Of course you will in places, but generally you'll be only be scuffing and smoothing the original surface.
If the car has been repainted previously, you may want to remove most of the previous coat of colour, otherwise it will may become too thick in places. Also remember that steel is never perfectly straight (even in flat areas), and it will be common to have low spots where more material will be present. Not really a big deal as long as the surface is correctly sanded.
phee
I got the Shifts
close
- Join DateOct 2007
- Age37
Thank you for your help. One last question: would you suggest replacing the doors if the panels are wavy? I have no idea how I would get them straight otherwise.
Moderator Alumnus
teranfon
Moderator Alumnus
close
- Join DateOct 2004
Hi phee
I guess it depends on how far you want to take the bodywork. It looks as if to me you're looking for a well sorted driver that you can enjoy. Replacing doors, or especially skins, isn't that easy. If you can live with a bit of waviness or don't have access to the proper tools to do the repair, it may be easier to live with them as they are now. You should also consider the colour of the car: black will show every imperfection or poor repair, while lighter colours tend to mask imperfections to a certain degree.
phee
I got the Shifts
close
- Join DateOct 2007
- Age37
I may leave the doors to a body shop. I will focus on the rest of the panels. But I absolutely want to have the car straight.
phee
I got the Shifts
close
- Join DateOct 2007
- Age37
small update
i have finally sourced all the AC lines and parts to retrofit an r134 system into the car. i had originally purchased all new r12 parts by accident so you can imagine my surprise when my a/c lines did not fit.
i managed to keep the D series (original) compressor with my B series block by using the CR-V compressor bracket. turns out that the 99 CR-V has a b series engine and a D series compressor.
only spent $20 dollars at the junkyard (honda wanted 120)
I have also installed HID headlights and replaced the broken foglight lenses with glass ones.
only spent $20 dollars at the junkyard (honda wanted 120)I have also installed HID headlights and replaced the broken foglight lenses with glass ones.
Aman
Your Friendly Canadian
close
- Join DateDec 2007
- LocationToronto, Ontario
- Age33
Liked:1,506 Times in 1,057 Posts
Did you do a projector retrofit with the HIDs?
rockstar143
close
- Join DateSep 2008
iTrader Feedback Score(6)
Liked:20,202 Times in 14,633 Posts
Money sounds like it's tight for the build, I was going to go ahead and GUESS that you didn't do a retrofit.
PS, car is looking great, I am really admiring your drive to get the body straight, man. There's something about a car that is nearly "antique" license plate status, looking like it just rolled off the line. There's no shortage of EG's rolling around with shitty paint, dented panels, waves, cheap poorly DIY painted rims and slammed undriveable with a fartcan exhaust....IMO, no pride.
Or no cash, maybe I'm a snob.
phee
I got the Shifts
close
- Join DateOct 2007
- Age37
another update. car now has retrofitted r134 air conditioning. I really wanted to keep the original r12 lines and all but the compressor failed and the r12 ones are hard to find.
I also found out why my back seats would bow into the trunk when weight was put on them, apparently the center bracket was cut off by the previous owner. had to go to a junk yard and cut one off another civic then weld it into my car.
I also replaced the rear set belts and clips for the seatbelts along with the magic seat snap clips. interior is almost fully done and mechanical is completely done.
Aint Doing Sh*t
Phee I have a few parts left over from my build that never went anywhere. ill pm you a list when I get a chance. I started doing a mini-me so I alot of parts related to that. I also have a rear brake conversion.
civicdrivr
close
- Join DateJul 2008
- LocationVA
iTrader Feedback Score(9)
Liked:8,746 Times in 5,159 Posts
Hows the body work coming along?
phee
I got the Shifts
close
- Join DateOct 2007
- Age37
i had refinished the fender but then this happened and i ruined my fender and some other parts...
i am just now starting the work again and i am going to purchase some new (used oem) fenders in the next couple of weeks.
i already replaced the drivers door with one that is straight (no waves)
civicdrivr
close
- Join DateJul 2008
- LocationVA
Is that a Rota?rockstar143
close
- Join DateSep 2008
Wow...that's a good picture to post when people say that rims are rims and quality is all the same.
I'm sure that was scary if you were doing anything over 15mph...glad to hear you're getting everything figured out!
phee
I got the Shifts
close
- Join DateOct 2007
- Age37
I was doing about 30 mph too. I couldn't contain my laughter when I saw the barrel rolling down in the grass about 30 feet from my car.
civicdrivr
close
- Join DateJul 2008
- LocationVA
I wish someone wouldve caught that on tape.Did you hit a bump or something? Or did it just shatter all on its own?
SuperTrooper169
In the Mid-South meow
close
- Join DateAug 2006
- LocationMusic City
iTrader Feedback Score(2)
Liked:2,298 Times in 1,141 Posts
Sweet I knew my lame meme I made would come in handy someday!
rockstar143
close
- Join DateSep 2008
wow...that's scary sh*t..shoulda gone with motegi!
Aman
close
- Join DateDec 2007
- Age33
Holy eff, I didn't know wheels did that.
civicdrivr
close
- Join DateJul 2008
- LocationVA
Quote:
Well, they shouldn't. But......Rota.Originally Posted by Aman
phee
I got the Shifts
close
- Join DateOct 2007
- Age37
Quote:
this is exactly what came to mind when it happenedOriginally Posted by SuperTrooper169
civicdrivr
close
- Join DateJul 2008
- LocationVA
Da fuq?
Aman
close
- Join DateDec 2007
- Age33
Say what?
civicdrivr
close
- Join DateJul 2008
- LocationVA
Soooooo....what are you driving now?
civicdrivr
close
- Join DateJul 2008
- LocationVA
Something.........midori green?
rockstar143
close
- Join DateSep 2008
Green...hmm...a charger is the first thing that comes to mind.
The Dumb One
Rockstar21
The Dumb One
close
- Join DateAug 2008
- LocationBaton Rouge, LA
- Age38
iTrader Feedback Score(1)
Liked:373 Times in 249 Posts
Quote:
while i agree quality is not all the same..Originally Posted by rockstar143
a broken wheels is most certainly not contained to knockoff wheels. although i would bet the AMOUNT of abuse they each take is different.
BBS wheel.
The Dumb One
Rockstar21
The Dumb One
close
- Join DateAug 2008
- Age38
well they arent Linea Corse, thats the only LM knockoff to my knowledge that is even close...
their is usually an imprint that borders the lug dish that makes them easily distinguishable, but there is a large portion of that missing in the pic.
the end of the spokes and dish around the lug holes say BBS to me.
but their are several pics of other high end brand wheels severly broken or cracked.. i just used the first one that popped up.
Costco
close
- Join DateJun 2006
Liked:3,489 Times in 2,089 Posts
Yea I dunno if those are actually BBS.... hard to believe even if so.
came on the car, then came off the car
someone made me an offer I couldn't refuse
