My '93 Civic CX build
#83
#84
woke up today to another non start... turns over and will not fire up.
distributor terminal resistance is at a solid .8 ohms (in spec)
secondary resistance from the coil to the main terminal is 17.8k ohms. (in spec)
voltage from the ICM to the neg battery terminal is 11.72V @30 degrees today (also in spec)
i pulled the plugs and they were fuel soaked, dried them off and let the cylinders air out.
put them back in and still no start. now my battery is dead and i have no one who can help me ;/
any other ideas? i want to test for spark but i cant crank the car and be under the hood at the same time
#86
Stock B18? if you don't have some "serious" mod on it. then you beat the driver not the car.
phee (02-22-2012)
#91
I drive a Subata.
Do a video going up to 110! I'm not familiar with these engines at all.
#93
Whats up with RDX owners?
We need to run.
#96
I drive a Subata.
I drive a Subata.
2003 CL-S 6MT? Mod?
Just curious.
Just curious.
#99
Too much.
Id post my build thread(s), but they info is so scattered, plus I had them locked.
#100
I drive a Subata.
Just list the performance mods!
#101
Basics - 3.6l stroker, equal length, long tube headers, 80mm tb (soon to be replaced ), 3" exhaust, full PnP. Some other things are coming within the next month, at which point Ill start a new build thread. Currently sitting at 295/275 at the wheels. Hopefully will be about 330whp NA by April.
#102
I drive a Subata.
That sounds freaking fun. Have you hit the drag strip?
#103
I drive a Subata.
god your avatar
#104
I drive a Subata.
Last two pics are gone.
EDIT - Now theyre working.
#110
Looks good phee!
#113
#114
#117
Your Friendly Canadian
Received 1,492 Likes
Mm, hawt fender.
phee (02-28-2012)
#119
No way man. The new thing is raising it up as high as it'll go.
#120
Hi phee
Generally, sanding down to metal is not required. In fact the vast majority of body shops do not do this. Removing all the paint/primer and resurfacing the steel is done in situations where metal replacement was necessary, potential contamination of various products, or the work is of a very high standard.
If you were to take the car down to metal, be aware that there will probably be additional expense to sand the metal smoothly, the application of an etch primer, the application of primer, and finally the two stage finishing product.
If the car is in good shape with no need of body repair or doesn't need to be laser straight, then applying a quality product over a properly prepared original surface would probably be the way to go.
n1njai (07-05-2012)
