MAF issues with 94 LS400 HELP!
Old Jun 25, 2006 | 07:31 PM
FutureBagdA4's Avatar
My buddy has a 94 LS400 with about 138k on the clock. Yesterday I pulled out his MAF and cleaned it with cleaner meant for MAFs. We took the car out, and it started to spratically idle and a check engine light came on, eventually the car stalled. I took out the sensor again and let it dry and it put it back in and we drove it around, and once again after a few starts, the same problem came again, cleaned it thoroughly one last time, no issues.
Today he calls me up telling me that all was fine until he went to use the AC at which point it idled sparatically as before, and stallled. Any ideas as to what it could be? Could the sensor be so old that it was just too sensitive to handle anything? Would resetting the battery do anything with the ECU as to maybe resetting it? Any help is much appreciated!!!
Old Jun 25, 2006 | 09:23 PM
fuzzy02CLS's Avatar
Some MAS sensors don't like being cleaned, Many older Ford ones are this way. You try to clean them & they die. I'd read the codes first. That should point to the MAS, TPS, or IAT sensors. Then go from there.
Old Jun 25, 2006 | 09:27 PM
S A CHO's Avatar
That was uncalled for...
I would suggest unplugging the battery for about 5 minutes, then plug it back in, and turn the car on, in the first minute, turn on the lights, turn on the A/C, turn on/ up the radio, open the doors, turn on the headlights/ highbeams, push the brakes a couple times. This will let the computer learn all of the loads that it needs to relearn.
My guess is that somehow the computer got a little messed up, and during the first 5 minutes of relearning everything, the A/C was not turned on, therefore the computer doesnt know how to make up for the extra load...
Give it a shot...
Old Jun 25, 2006 | 09:37 PM
iTimmy's Avatar
dɐɹɔ ǝɥʇ ʇɐɥʍ
Old Jun 25, 2006 | 10:10 PM
Thanks for all the help guys. I will def try unplugging the battery tonight, and if that doesn't work, I'll just assume he needs a new MAS. I'll get it scanned in the morning, but either way, its about damn time that thing is replaced. Any further insight is still welcommed!
heykosal
1G RDX DIY & FAQ
Nov 16, 2020 03:59 PM
TheWrench116
25
Nov 1, 2015 12:24 PM
heykosal
1G RDX Problems & Fixes
Sep 21, 2015 09:41 AM
Big mo
4G TL Problems & Fixes
Sep 12, 2015 07:22 AM
DDTsx06
Sep 8, 2015 06:56 PM
