M2: El Ban's guide to owning a BMW and not becoming a douche!
#41
^^^ PM AckTL05
#42
Road Racer / Solo Addict
Most of the pics in the original posts were dead so let me update a bit..
Imported the car from PR to FL months ago and got pulled over on the weekend for the tint on the front window.. This is Florida Legal.. Think its darker than what I had but its not full in front so I guess thats the legal part..
Test fitting my OEMs on my buddies 2012 Civic, looks beefy with the 245's.. While at it I removed the plastidip they had which I was always too lazy to remove.. Blasted them with goo gone and it started melting. Then just hit them with high pressure at the car wash..
Rolling the rear getting it ready for the rim/tire setup
Waiting for the rims to be shipped..
#43
Received 6,470 Likes
#45
In for the final pics....
#46
The tires arrived at the install shop today.. Shipped them there via Tire Rack.. But had a mix up with the rims, picked the wrong address in Paypal, thank God caught it quick and they had not left the warehouse yet or they would have ended up overseas at PR..
They sent out today.. Should be here next Friday says UPS..
Need to see how the car sits with the rim/tire size using the Eibach Pro Kit.. Might stick with it or get some FF Coilovers..
#47
Trouble cranking over.. Battery giving out.. Had to get a new one.. Its the 4th battery in its life..
3 previous ones.. The OEM plus two installed by the dealer under warranty.. Last one seemed to last longer.. Was there from 8/2011..
Any of you guys had to run thru multiple batteries?
#48
Looks good, Ban!
EL BAN (07-26-2014)
#50
Love the fitment.. running 245/40/18 Dunlop Direzza DZ101
Rota centers are the flat ones, don't clear the center.. seller is looking to send some dome ones..
Now just waiting on the Roof Spoiler which should arrive Monday..
Comments welcome..
Will definitely clear some 255's or some 265 even.. will consider them for the next set of tire..
Really happy with the outcome..
Comments welcome..
96SC4 (07-27-2014)
#53
looks great! congrats
#54
Great new shots!
#56
Damn, excellent progress! The new wheels look great
#57
i demand type S rear sidemarkers...
#60
Are those the smoked ones? Never looked into them!
I have a question for all you savy guys on suspension setups..
I run a pretty aggresive setup on the track car but on the TL being a daily I would think it would be best to try to get it as close as to 0 in camber and keep toe at 0..
The car was aligned locally just to be sure it was not too off until I get it down to a buddy in Orlando to get it in the exact specs..
Being that said, I know our cars stock come with some negative camber already..
This is how my car ended up this weekend, is this setup pretty good our should I look at having some more camber in the back to be closer to OEM specs? I would think if I could bring it to almost 0 camber it would be better..
Any feedback will be appreciated..
#61
2008 WDP Base TL
off topic but did you order your wheels from a-spec or did you just use the pic? if you did, was he an easy guy to work with? about to order his ready-to-mount package soon
on topic, your car looks great! loving all the OEM parts dude and those Rotas you picked are sweeeeet
#62
Give them a call if you have any questions, they are very helpful. Ask for Aaron, tell him Esteban sent you, he is a great guy and answers emails quickly also, i had an issue with my order because I picked the wrong paypal address and he helped all the way to clear it up..
Thanks for looking at the thread, I debated so much on which rims to pick but I am very happy I picked these! Now just need to sort the center so it fits!
#63
Yes, if you look at a Type S, the rear side marker matches the fronts.
Would look great on your color car. Plus, they're easy to swap(from inside trunk).
I have a feeling I know what your next purchase will be now
Can't help with your alignment. Sorry.
I do know I'd be happy with those toe settings though!
Strange they couldn't adjust camber at all, but I'd rather have my toe spot on anyways ...
#64
With the alignment I understand our cars don't have adjustment OEM and the modification my old alignment guy did requires the part he modified to be removed and adjusted and then re-installed, so the guy doing the alignment during the weekend was not going to go thru that effort, but I wasn't going to argue with him, I was just looking to get it in check so it would get verified by my friend over in Orlando..
But I understand this setup shouldn't hurt..
#65
EL BAN (07-29-2014)
#67
And regarding your question as how its riding, the answer is perfectly just as when new, specially with the new tires.. I have about 70k miles on the Eibachs with the OEM struts and it still rides as stock, thats why I dont want to mess around with it too much..
In any case I might get some Koni Yellows down the road and call it a day
Will be installing all the 105k maintenance parts and all the engine/tranny mounts this Friday, basically will have an almost brand new car again come weekend \o/
TurnerDan (07-29-2014)
#68
Exciting news! Good luck on the 105k install. I'm so glad that I work at Honda and can get it done for cheap but if I didn't, I'd most certainly do it in the garage.
I might have missed it, but did you say your fenders were rolled or no?
#69
any more suggestions, just let me know. Will be glad to help you spend your $
edit: spoiler looks great!
#70
And yes, I rolled my rear fenders, I do fender rolling every now and then for my friends and also for friends of friends by word of mouth mostly.. Still have the roller so to be on the safe side I did them a couple weeks ago..
yeah, a lot of peeps do the depot due to cost. But they don't fit as nicely, and you'll have to swap front and rear so they match perfectly. rear depot and OEM fronts will look off...
Thanks for the comment on the spoiler, i like how it came out!
#71
-------Tim-------
Car Looks Great!
Type-s Rear sidemarkers diagram and part #'s (13 & 14 of diagram)
http://www.acuraoemparts.com/delray/...All&vinsrch=no
#13 33650-SEP-A11 (LIGHT ASSY., R. RR. SIDE MARKER 001 2008 TL 84.77 $63.58)
#14 33655-SEP-A11 (LIGHT ASSY., L. RR. SIDE MARKER 001 2008 TL 84.77 $63.58)
EL BAN (07-29-2014)
#72
Car Looks Great!
#73
The rear spoiler looks perfect!
EL BAN (07-30-2014)
#74
Thanks Steven
These are some shots I loaded onto the Ebay lip and roof spoiler thread that someone asked for some more pics but from a bit further back..
Attachment 105597
Attachment 105598
Attachment 105599
Attachment 105597
Attachment 105598
Attachment 105599
vietxquangstah (07-30-2014)
#75
Looks very good. When I decide to order a new one for my TL, this V style might just be the replacement.
I currently have this one by bmwoemshop
http://www.ebay.com/itm/PAINTED-ACURA-TLIII-B92P-SEDAN-REAR-ROOF-SPOILER-04-08-TOP-QUALITY-/291171951571?pt=Motors_Car_Truck_Parts_Accessories&fits=Make%3AAcura%7CModel%3ATL&hash=item43cb3363d3&vxp=mtr
It's been on the car for almost 3 years and the paint on it took a shit.
How long did it take for you to receive it after ordering it? I remember mine took about 2-3 weeks...
#76
I heard many good things from bmwoemshop and the M3 Style but I was always looking for a seller with the combo of the roof and trunk lip until I stumbled on to the Trunk Lip OEM really cheap on Ebay a few years ago and I never got the roof..
Now with the rims on I decided it was time to get it so looking again I found that V Type style..
With regards to the transaction, the seller was really quick..
I bought on Sunday 20th and specified color on the Paypal payment
Same day i received an email confirming they received the payment and confirming the color I requested and telling me it would take them 5 days to prep, paint and ship..
Friday 25th I received a follow up email saying it was ready and had been shipped including a tracking number from UPS..
Monday 28th it was at my door, roughly a week.. I would say damn fast!
#77
So yesterday we had our work cut out for us.. 105K maintenance time.. in addition I wanted to install all the OEM engine supports since they were not feeling solid anymore..
Nothing like OEM parts..
My buddy started the breakdown on the passenger side to start doing the timing belt..
Meanwhile I had fun with the Spark Plugs..
Removing this mount was such a PITA.. but got it..
Front mount was pretty worn out..
Laid out most plastic covers to give them a good scrub.. when importing the car they require the engine to be cleaned and they bathe it with WD40 then it just grabs all the dust quickly :/
Almost back together..
Car feels solid.. just like brand new again.. just pending now changing the air filter which was pretty dirty and the cabin filter.. was about to pull the trigger on the AEM V2 but read so many reviews and different threads on it that I just decided to replace the filter with an OEM for now and wait a bit longer before deciding if I want a CAI or not..
#78
On another note, took the car to my buddy to get it aligned today.. not sure if its possible to manipulate the alignment machine output but apparently the print out I received from the place that installed the rims last week must have been modified or something..
They gave me a print out showing numbers pretty much in spec and my buddy verified and it was completely off everywhere.. it is not possible that I lost a full alignment in 7 days.. probably they did not touch the rear and just printed a random output.. not sure really just thinking out loud..
Thoughts?
Measurements as it came in to the shop today.. this is exactly a week after getting a full alignment at the shop that installed the rims..
How it left after getting aligned by my friend..
Thoughts?
#79
Congrats!
EL BAN (08-13-2014)
#80
