Schnitzel and Tea & Crumpets
After six years of babying this great car, I'm finally going to put in some work in.
Just purchased a Comptech Supercharger Kit today!!!! The previous owner was kind to throw in some goodies too; see parts list below: CT S/C w/ 7lbs pulley Greddy E-manage Blue AEM Water/Meth Kit AEM C.A.I CT Headers Thanks to the IRS & tax returns :thumbsup:, I have some funds to play with it and ordered additional parts from www.horsepowerfreaks.com; see below: Ralco RZ Aluminum Pulley Kit Aasco Lightweight Flywheel Unorthodox Sport Pro Unsprung 6 Puck Clutch Kit Tanabe NF210 Springs Ordered a short shifter kit from JTC Customs (http://www.jtccustoms.com/store/show/CL%202SS) I'll start posting pics this weekend to document the entire project from package deliveries to turnkey test drive. Something tells me my wife isn't going to like this! Lol Stay tuned! :rave: |
Good luck.
(Post 13933046)
Good luck.
Just noticed the second list.
You cant run an unsprung clutch disk on the lighweight flywheel. |
(Post 13933382)
You cant run an unsprung clutch disk on the lighweight flywheel. Thanks for the heads-up civic. In other news, I picked up my new battery (51R) from Advance Autoparts for the install tomorrow. Surprised at how much smaller it is versus the stock spec. Spent $139 on it, but I'll get $13 back when I return the old one. That's $13 to offset that restocking fee :whyme: |
Are you sure that clutch would have even fit your car? Says on the site 2.2-2.3 only and ive never heard of anyone on here running one
Good catch.
Originally Posted by AnthraciteTypeS
(Post 13933771)
(Post 13933777)
Good catch.
I only have $2.4k left to play with... considering tuning & suspension that is still needed, I can't afford any more errors on my part. Suggestions are greatly appreciated! :) |
Horsepower Freaks still says its for the 2.2/2.3l engines. If the CSR steered you towards that clutch, fight for the full amount back. They fucked up.
Unorthodox does not have a clutch for the J series. |
Good luck and i really mean it
Hey, where in FL are you? I would love to compare notes as i just recently S/C'd my 3G TL.
Aventura to be exact.
I'm usually at SoFlo Motorsports in Davie; greatest tuner shop ever! |
Bummer, i'm in Orlando area
recently saw your videos. Look good. Did you go straight into the high boost pulley or did you run the std pulley first?
Let's see some updates!
Originally Posted by MAS
(Post 14628515)
Dove right into the HPB with tune. A couple months later, I ordered the 3.2" pulley from South Florida Pulley. Others here went with the 3.3" s/c shaft pulley & 3.275 alternator configuration. I went with the 3.2" to gain back the [slight] pressure loss due to the IC piping. As of now (depending on weather), I'm seeing +/- 9 to 10lbs on the gauge... Typically in the early morning when it's cool out & there aren't any cars on the road, wheels break loose in 2nd at WOT. Which speaking of, I need new / better stickies :annoyed: The meth plays a bigger role than many would think; the intake manifold along with the IC piping is ridiculously cold to the touch... like really cold... to the point with it gets sweaty lol You're some what local; I'm down to meet up one of these days to check out your whip :) http://i3.photobucket.com/albums/y62...ps4b413bb0.jpg http://i3.photobucket.com/albums/y62...ps46a0082e.jpg |
Originally Posted by gnuts
(Post 14628517)
looks clean! I've been contemplating a meth kit. do you have to have tuning to run it?
in for videos! |
(Post 14651598)
in for videos! The kit comes with two led injection status lights which tells you if: low fluid, staging, initial, & full spray. See kit details below: Snow Performance Stage 2 Meth Injection Kit |
Originally Posted by Richkid1102
(Post 14651561)
Thanks Mas.
Dove right into the HPB with tune. A couple months later, I ordered the 3.2" pulley from South Florida Pulley. Others here went with the 3.3" s/c shaft pulley & 3.275 alternator configuration. I went with the 3.2" to gain back the [slight] pressure loss due to the IC piping. As of now (depending on weather), I'm seeing +/- 9 to 10lbs on the gauge... Typically in the early morning when it's cool out & there aren't any cars on the road, wheels break loose in 2nd at WOT. Which speaking of, I need new / better stickies :annoyed: The meth plays a bigger role than many would think; the intake manifold along with the IC piping is ridiculously cold to the touch... like really cold... to the point with it gets sweaty lol You're some what local; I'm down to meet up one of these days to check out your whip :) http://i3.photobucket.com/albums/y62...ps4b413bb0.jpg http://i3.photobucket.com/albums/y62...ps46a0082e.jpg By the way......i am not 100% percent sure as i am not an expert in this type of modding but i believe you will want to mount that solenoid really close to the injection point on the intake pipe for 2 reasons. 1) when you finished flooring it the solenoid closes and the rest of the line from the trunk to the engine bay is still filled with meth and it gets sucked in which is the reason to have the solenoid in the first place. 2) when you do floor it again now you will be waiting for the pump to fill that part of the line downstream of the solenoid before it actually reaches the intake pipe nozzle. If you place it really close the to injection point (i had to redo mine as well) then the meth injection will be more immediate with less lag because the lines will already be primed and you will not be sucking it and wasting meth once your done flooring it. Once again i'm not a meth kit expert but i am an engineer and that is the only way it makes sense to me. Also i used the wiper tank as my meth tank and i love it because everything is in the engine bay and no lost trunk space. Something you may want to look into if you are already moving the solenoid up front to. I've got pics and info on using the wiper tank if your interested too. So back to the HBP, just bought mine. Not ready to install yet because i need to resolve a CEL that gives me a slight studder during closed loop but once i get that resolved HBP should be going on. Lets see how it goes. Anyways, lets try to get together and compare notes. |
(Post 14651598)
in for videos! Looking good Cel :thumbsup: |
Regarding tuning for meth....ideally you get it tuned to:
1) to make sure meth is kicking in the right amount (make sure ur using the right nozzle size per kit instructions) and to make sure it is being triggered at ideal time for optimum power. 2) theoretically your tuner can now squeeze out a little more power (advanced timing and such) because you have the meth kicking in to eliminate knock potential. All that being said, you dont HAVE to get tuned again is you are satisfied with how its running and feel no issues or power loss. PS----my "I'm not an expert" disclaimer still applies :tomato: |
Yeah I forgot to add the part about the timing, good point, although the ECU can auto-adjust that based on what it detects. Since he mentioned the manifold is now cold due to the intercooler and water/meth, I'd be surprised if he's not getting the most out of the timing, but I could be wrong. I think some tuning software can also active it based on rpm vs psi...
Originally Posted by CL-Future
(Post 14651733)
I dont think you need tuning with a meth kit as it just detects the boost pressure and sprays when it reaches a certain psi. Some tuning software can give you more control though, although I dont think it's needed.
(Post 14651744)
1) to make sure meth is kicking in the right amount (make sure ur using the right nozzle size per kit instructions) and to make sure it is being triggered at ideal time for optimum power. 2) theoretically your tuner can now squeeze out a little more power (advanced timing and such) because you have the meth kicking in to eliminate knock potential. All that being said, you dont HAVE to get tuned again is you are satisfied with how its running and feel no issues or power loss. PS----my "I'm not an expert" disclaimer still applies :tomato: I've since installed the correct nozzle (175ml/min - 250 to 375hp). In regards to when to start spraying, the tuner assisted with that. Do note there is not software for this particular meth kit. It's either on or off (initial & or full disbursement of course). Regarding the timing, this particular piggyback does not advance, it can only retard :annoyed: As the Emanage unit is dated and limited in it capabilities, it works for the current application with no issues which is add & remove fuel when needed. |
(Post 14651955)
http://i3.photobucket.com/albums/y62...ps26a18f54.jpg |
I was reading about the snow meth kit and it talks about the benefits of spraying before the blower on our type of supercharger. any thoughts on this?
if you use the windshield reservoir, can you put in a small reservoir somewhere to still have some washer fluid? |
(Post 14675100)
if you use the windshield reservoir, can you put in a small reservoir somewhere to still have some washer fluid? IMO I don't believe spraying before the blower would be beneficial as it could very well lead to actually damaging it... I haven't read anyone on here ever doing that, so I couldn't tell you? :shrug: Regarding the windshield reservoir, you could totally do that if you find the space... it's super tight in there to begin with :ugh: We located the battery below the the blower; easily accessible to give or get jumped ;) How your build coming along? |
I read in the FAQ section on the snow meth site about spraying before the blower. I was just curious. I'm thinking about doing a meth kit in the spring but we'll see. The car drives great right now and needs nothing. But I'm getting that itch again. HBP and meth? :)
(Post 14680758)
:drool:
before your intercooler, did you make an intake for the supercharger? if so, what bends did you use?
(Post 14685835)
http://i3.photobucket.com/albums/y62...123_192609.jpg |
Probably a stupid question, but why are the turbine part of the superchargers sometimes black while others are silver?
Like this car: http://www.autocarparts.com/images/Comptech/928_3.jpg |
Originally Posted by Karanx7
(Post 14686293)
Do you remember what bends were used? Trying to make a parts list. Looks like a 90 silicone coupling, 90 bend and a 45? That pic alone helps a lot, thanks!
I believe you are correct. Also, you can't see it from the angle in which the picture was taken, but there's piping connected to the throttle body, which connects to the 90 coupler bend.
(Post 14686293)
Right now im using a custom ram air type that came with the blower and all it does is suck hot air in. Was planning on makeing a custom one
I was going to go with 3.5 inch. ..Any reason you went with 4" richkid? Was going to get the silicon and aluminum tubing off this site siliconeintakes.com |
Do you think those ridges on the ends of the pipe will affect anything? I think all you'd need is a silicone 90, an aluminum 90 (1foot), and a two foot aluminum 90, couplings and filter.
(Post 14686266)
Yup; removed the Comptech Icebox along with the stock resonator and replaced with a custom 4" CAI; see below.
