Schnitzel and Tea & Crumpets
#481
Rawr.
Thanks Marco!
This should be pretty straight forward as there's no fabrication needed. SoFlo Motorsports will be installing the kit; not worried at all.
They built the CL
They built the CL
#483
seizure force field!
The two biggest pieces are gonna be cooling and solid tune. Are you planning on adding methanol? Will you be running 93 octane or ethanol? A ported cylinder head would be very beneficial to you to increase flow and decrease heat.
I've read a lot of bad things about the "Full Access" Bytetronik not being very full access, I hope your tuner gets enough access to the tuning tables.
#484
My mazdaspeed 3 had mad torque steer that was only 265hp
How do you feel about putting so much power down in fwd with this ? Will you upgrade clutch and trans?
#485
I drove a stroker MINI with 270whp, it had a Cusco diff.. applying full throttle mid-corner while in 2nd gear on a right-hand turn was pretty uneventful other than the car pulling like a freight train.
The following 3 users liked this post by v6cord2k5:
#486
Rawr.
Not worried about cooling; going to run the front mount... we'll throw meth on there if need be.
Bytetronik was part of the kit from the previous car. I'm told the car ran with no issues for 3 years. Owner upgraded to a F56JCW; parted everything from the car... hence the sale of the kit.
My plans are still to run Vipec since the tuner is familiar with it. I'll more than likely post the byte for sale.
Marcelechka (10-08-2015)
#488
Rawr.
OS Giken clutch and diff should fix it right up. Jan has built cars with 300+ wheel horsepower and torque steer was a non-issue. Some dude out of Colorado is going bat shit crazy with a stroker+turbo build, hes using OS Giken stuff. The trans is good for 500hp.
From what I've read and vids that I've seen; I'll be fine with a very supportive wife, low boost, & conservative tuning.
Not my first dance with a boosted car... I don't have an ordinary Mini... this is so going to happen
#490
Rawr.
Don't get me wrong, the Mrs does freak out when she sees FedEx/UPS boxes lying around with car parts in them.
Wife: "Oh no...no...no... not again!"
Me: "I loooooooooooove yooooooooooooooooou!"
#492
The following 3 users liked this post by 2012wagon:
#494
In the Mid-South meow
My wife's face every time I mention a supercharger is priceless (and terrifying).
#496
While I enjoy poking the bear from time to time, the bear will eventually bite your head off and poop your remains onto the forest floor. Tread lightly my friend. Tread lightly.
The following 7 users liked this post by SuperTrooper169:
00TL-P3.2 (10-09-2015),
D's Up (01-21-2016),
gatrhumpy (01-26-2016),
JS + XES (10-09-2015),
Marcelechka (10-09-2015),
and 2 others liked this post.
Flipster23 (10-13-2015)
#500
Happy life = no wife
#502
Purse controlling bitches come in all genders
Marcelechka (10-12-2015)
#509
Rawr.
Change of plans -
Just had a LONG conversation with Jan; he'll be here next month and can tune the car then. Cool ass dude!
With my turbo specs, his recommendation was to pull the blower off and boost no more than 18lbs; it'll make 300 to the wheels safely on the Vipec system, every pull, all day long.
Making those numbers on the twincharger is doable, but run the risk of things going south easier with more components involved... not recommended if I want to keep the car around.
Those numbers to the wheels are alright with me!
He just purchased another R53GP by the way; he now has two of them.
#510
Sounds like the logical thing to do. BTW the car looks awesome! I sooooo love it!!
So there's no way to modify the stock SC to give more boost, either through tuning or pulley? Just curious as to why the turbo's the better way of going.
Marcelechka (10-13-2015)
#511
At that time, guy out of Denver (on Mini forums) used to do "pulley parties"
He used to come out, do a pulley/tune to get some more power out of the cars.
However, 350HP (as OP wants), its all turbo, sir.
#513
Rawr.
The blower can only churn out so much air before over rev'ing / heating to where it's no longer efficient. Doing the conversion from s/c to turbo will get me the power gain I'm looking for within budget versus spending more on engine parts such new head, pistons, rods, cam, pulley, etc.... running +/- 5k
I'm good at 300 as a daily driver; 350 is a wee bit much for my use.
Consider it done mon ami!
rockstar143 (10-13-2015)
#514
Sounds like a fun project. But I'd miss the SC scream.
I remember test driving an '04 Indi Blue S that had some work done to it, a little over the top as the SC whine was quite noticeable at cruise around 70mph, but it screamed at WOT.
#519
Change of plans -
Jan is a super stand up dude. Glad you got in contact with him.
Did Jan end up getting that GP with the blown motor? Colin tipped me off on it too, but I don't have the coin/time to move all my parts to another chassis.
#520
Rawr.
He mentioned the motor was toast, but planned on rebuilding and possibly reselling since he already has one.
You should totally hop on it!
Spoke for quite a bit; very knowledgeable dude. Kudos to him and all the innovation RMW has provided to the Mini community. Only downside to it all is that he is basically a one man band and primary projects prevent him from wrapping up side projects such as the RMW turbo or Rotrex kits... Either way, they'll both be awesome products once completed.
Look forward to meeting him next month and getting this kit tuned.
