Looking for tierods, which category is it?
I cant seem to find them, any help would be appreciated
http://www.acuraoemparts.com/delray/...FQVfFQodbV1Nhg
System / Component
A/C COMPRESSOR (2) HEATER BLOWER
A/C CONDENSER HEATER UNIT
A/C COOLING UNIT HOOD
A/C HOSES-PIPES IGNITION COIL
A/C REAR HOSE-REAR PIPE INNER PANEL
A/C SENSOR INSTRUMENT PANEL
ACCELERATOR SENSOR INSTRUMENT PANEL GARNISH
ACCESSORIES - ELECTRICAL INTAKE MANIFOLD (2)
ACCESSORIES - EXTERIOR INTAKE MANIFOLD COVER (2)
ACCESSORIES - INTERIOR INTERIOR LIGHT (2)
AIR CLEANER (2) KEY CYLINDER KIT
ALTERNATOR (DENSO) KNUCKLE
ALTERNATOR BRACKET (2) METER COMPONENTS (2)
AT ACCUMULATOR BODY ( 03-06) MIDDLE SEAT (L.)
AT CLUTCH (2ND) ( 03-06) MIDDLE SEAT (R.)
AT CLUTCH (3RD) ( 03-06) MIDDLE SEAT COMPONENTS (L.) ( 02-06)
AT CLUTCH (4TH-5TH) ( 03-06) MIDDLE SEAT COMPONENTS (R.) ( 04-06)
AT CLUTCH (LOW) ( 03-06) MIRROR
AT COUNTERSHAFT ( 03-06) MOLDING
AT DIFFERENTIAL ( 03-06) NAVIGATION SYSTEM (2)
AT MAIN VALVE BODY ( 03-06) OIL PUMP-OIL STRAINER (2)
AT MAINSHAFT ( 03-06) OUTER PANEL-ROOF PANEL
AT OIL LEVEL GAUGE-POSITION SENSOR ( 03-06) P.S. GEAR BOX
AT REGULATOR ( 03-06) P.S. GEAR BOX COMPONENTS
AT SECONDARY BODY ( 03-06) P.S. LINES
AT SECONDARY SHAFT ( 03-06) P.S. PUMP-BRACKET (2)
AT SENSOR-SOLENOID ( 03-06) PARKING BRAKE
AT SHIFT FORK ( 03-06) PARKING BRAKE SHOE
AT THIRD SHAFT ( 03-06) PEDAL
AT TORQUE CONVERTER CASE ( 03-06) PILLAR GARNISH
AT TRANSFER ( 03-06) PISTON-CRANKSHAFT
AT TRANSMISSION CASE ( 03-06) PROPELLER SHAFT
ATF COOLER KIT RADIATOR (DENSO)
AUTO AIR CONDITIONER CONTROL RADIATOR HOSE
AUTO RADIO (1) RADIO ANTENNA-SPEAKER
BATTERY REAR BEAM-CROSS BEAM
BRAKE LINES (VSA) (2) REAR BRAKE
BRAKE MASTER CYLINDER -MASTER POWER (2) REAR CYLINDER HEAD (2)
BREATHER TUBE (2) REAR DIFFERENTIAL
BUMPERS REAR DOOR LINING
CAMSHAFT-TIMING BELT REAR DOOR LOCKS-OUTER HANDLE
CANISTER (2) REAR DOOR PANELS
COMBINATION SWITCH REAR DOOR WINDOWS-DOOR REGULATOR
CONSOLE REAR DRIVESHAFT
CONTROL UNIT (CABIN) (2) REAR HEATER UNIT
CONTROL UNIT (ENGINE ROOM) (2) REAR SEAT
CONVERTER ( 03-06) REAR SHOCK ABSORBER
CYLINDER BLOCK-OIL PAN REAR STABILIZER-REAR LOWER ARM
CYLINDER HEAD COVER (2) REAR WINDSHIELD-QUARTER WINDOWS
DRIVESHAFT-HALF SHAFT REAR WIPER
DUCT RESONATOR CHAMBER
ELECTRICAL CONNECTOR (2) ROOF LINING
EMBLEMS-CAUTION LABELS ROOF SLIDE COMPONENTS
ENGINE ASSY.-TRANSMISSION ASSY. SEAT BELTS
ENGINE MOUNTS (2) SELECT LEVER (2)
ENGINE WIRE HARNESS (2) SIDE LINING
EXHAUST PIPE (3) SIDE SILL GARNISH
FLOOR MAT SLIDING ROOF
FLOOR PANEL SRS UNIT (3)
FOGLIGHT (2) STARTER MOTOR (MITSUBISHI)
FRONT BRAKE (2) STEERING COLUMN
FRONT BULKHEAD-DASHBOARD STEERING WHEEL (SRS) (2)
FRONT CYLINDER HEAD (2) SWITCH (2)
FRONT DOOR LINING TAILGATE
FRONT DOOR LOCKS-OUTER HANDLE TAILGATE LINING
FRONT DOOR PANELS TAILLIGHT
FRONT DOOR WINDOWS-DOOR REGULATOR THROTTLE BODY (2)
FRONT FENDERS TIMING BELT COVER
FRONT SEAT (L.) TOOLS-JACK
FRONT SEAT (R.) TORQUE CONVERTER
FRONT SEAT COMPONENTS (L.) TPMS UNIT
FRONT SEAT COMPONENTS (R.) (POWER) TUBING (2)
FRONT SHOCK ABSORBER (2) VALVE-ROCKER ARM (FR.) (2)
FRONT WINDSHIELD VALVE-ROCKER ARM (RR.) (2)
FRONT WINDSHIELD WIPER VSA MODULATOR ( 03-06)
FUEL INJECTOR (2) WATER HOSE (2)
FUEL PIPE (2) WATER PUMP-SENSOR (2)
FUEL TANK (2) WATER VALVE
GASKET KIT WHEEL
GROMMET WINDSHIELD WASHER
HARNESS BAND WIRE HARNESS
HEADLIGHT (2)
HEATER BLOWER
HEATER UNIT
HOOD
IGNITION COIL
INNER PANEL
INSTRUMENT PANEL
INTAKE MANIFOLD (2)
INTERIOR LIGHT (2)
KEY CYLINDER KIT
KNUCKLE
MIDDLE SEAT (L.)
MIDDLE SEAT (R.)
MIRROR
MOLDING
P.S. GEAR BOX
P.S. LINES
PARKING BRAKE
PARKING BRAKE SHOE
PEDAL
PILLAR GARNISH
PISTON-CRANKSHAFT
PROPELLER SHAFT
RADIATOR (DENSO)
RADIATOR HOSE
REAR BRAKE
REAR DIFFERENTIAL
REAR DOOR LINING
REAR DOOR PANELS
REAR DRIVESHAFT
REAR HEATER UNIT
REAR SEAT
REAR SHOCK ABSORBER
REAR WIPER
RESONATOR CHAMBER
ROOF LINING
SEAT BELTS
SELECT LEVER (2)
SIDE LINING
SIDE SILL GARNISH
SLIDING ROOF
SRS UNIT (3)
STEERING COLUMN
SWITCH (2)
TAILGATE
TAILGATE LINING
TAILLIGHT
THROTTLE BODY (2)
TIMING BELT COVER
TOOLS-JACK
TORQUE CONVERTER
TPMS UNIT
TUBING (2)
WATER HOSE (2)
WATER VALVE
WHEEL
WINDSHIELD WASHER
WIRE HARNESS
System / Component
GASKET KIT WHEEL
HEADLIGHT (2)
HEATER BLOWER
HEATER UNIT
HOOD
IGNITION COIL
INNER PANEL
INSTRUMENT PANEL
INTAKE MANIFOLD (2)
INTERIOR LIGHT (2)
KEY CYLINDER KIT
KNUCKLE
MIDDLE SEAT (L.)
MIDDLE SEAT (R.)
MIRROR
MOLDING
P.S. GEAR BOX
P.S. LINES
PARKING BRAKE
PARKING BRAKE SHOE
PEDAL
PILLAR GARNISH
PISTON-CRANKSHAFT
PROPELLER SHAFT
RADIATOR (DENSO)
RADIATOR HOSE
REAR BRAKE
REAR DIFFERENTIAL
REAR DOOR LINING
REAR DOOR PANELS
REAR DRIVESHAFT
REAR HEATER UNIT
REAR SEAT
REAR SHOCK ABSORBER
REAR WIPER
RESONATOR CHAMBER
ROOF LINING
SEAT BELTS
SELECT LEVER (2)
SIDE LINING
SIDE SILL GARNISH
SLIDING ROOF
SRS UNIT (3)
STEERING COLUMN
SWITCH (2)
TAILGATE
TAILGATE LINING
TAILLIGHT
THROTTLE BODY (2)
TIMING BELT COVER
TOOLS-JACK
TORQUE CONVERTER
TPMS UNIT
TUBING (2)
WATER HOSE (2)
WATER VALVE
WHEEL
WINDSHIELD WASHER
WIRE HARNESS
