Interesting artcile on use of aluminum in cars
October 22, 2006
Technology
Aluminum Is Striving for Mass Appeal, but With a Lot Less Mass
By KEVIN CAMERON
ANY expectations that technology would only march forward were dinged, if not quite dashed, when Audi revealed details earlier this year of the 2008 TT, the second generation of its stylish sports model, which goes on sale next spring. A proponent of all-aluminum cars, Audi seemed to be stepping backward by building the framework in a blend that was nearly one-third steel.
The move was not a retreat — after all, the outgoing TT had a steel chassis — but an acknowledgment that an all-aluminum structure, while economically feasible for a luxury-class car like the company’s flagship A8 sedan, may not be the best choice for a car that costs half as much. As is the case with other advanced technologies, costly features arrive first at the top of the line.
Chevrolet, Ferrari and Jaguar, among others, make extensive use of aluminum frames to save weight; Audi has built more than 150,000 cars with aluminum space frames. It is now 16 years since Honda introduced the NSX sports car (sold in the United States as an Acura), the first production car with an all-aluminum unibody.
Many other makers are using aluminum in body panels like hoods and doors, a practice embraced by Land Rover in the 1940’s, to achieve specific weight goals. Aluminum chassis and bodies are the next big step after the long process of adopting aluminum in engines, transmissions and brake calipers — displacing cast iron in each case.
Autos have been made of steel for a long time — and for good reason. Steel has been available in quantity since 1860, so there are many grades and the material is well understood by engineers. It is inexpensive, can be stamped into complex shapes and can be readily joined by welding.
Even so, automakers have turned to aluminum as a way to reduce vehicle weight. A major goal is lower fuel consumption, and another goal is improving performance; other factors being equal, lighter cars are quicker in acceleration and stop in shorter distances.
Substituting aluminum for steel to make a vehicle lighter is not as intuitive as it may seem. Though a given volume of aluminum weighs about one-third as much as steel, it also has only about one-third the stiffness, which seems to imply that an aluminum car would have to weigh just as much as a steel one. How does the lighter metal save weight?
Automobile chassis and bodies are mostly made of steel sheet, formed into shapes that make it stiff, just as rolling cardboard into a tube stiffens it. To reduce weight, sheet metal thickness can be reduced, but there are limits to how much.
This limit is set not by the strength of the material, but by its ability to retain its shape by resisting buckling. If you bend a cardboard tube, it does not break — it buckles. Auto-body steel may be as thin as about .040 inch, but below that, buckling becomes more likely and stamping it without wrinkling can be difficult. Similar rules apply for chassis structures.
At equal weights, a square foot of aluminum sheet would be three times as thick as a steel sheet, and this greater thickness gives the aluminum greater resistance to buckling. Therefore it is possible to reduce the thickness of the aluminum to something like 1.5 times that of the original steel (and half the weight), yet still have equal resistance to buckling. This allows aluminum structures to be lighter than steel yet still adequately stiff and strong. The space frame of an Audi A8 — a design that looks like a cage of aluminum beams — weighs 548 pounds, some 46 percent lighter than it would in steel. The aluminum chassis of the Chevrolet Corvette Z06 weighs 285 pounds, a weight saving of more than 30 percent compared with an equivalent steel structure.
The attachment of suspension parts or engine and transmission mounts to a steel chassis requires the alignment and welding of many small stampings. This is simplified in aluminum structures by substituting a single casting — a process called parts consolidation. Recent developments in aluminum casting yield parts nearly as strong as if they were forged.
Switching to an aluminum structure is more complicated than just opening the computer files for the frame designs, erasing the word steel and typing in aluminum. Aluminum forms quite differently from steel — if too sharply bent, it can crack, and it also springs back more than steel when stamped in a die. The cost per pound is several times that of steel. Partly offsetting this are new methods of aluminum fabrication. Aluminum structures can be designed for computer-controlled laser welding along the seams, replacing many thousands of spot welds that normally hold a steel chassis together.
Other methods of aluminum fastening include structural adhesives and rivets that need no predrilling to install. When one operation replaces many, assembly costs fall. Five years ago the cost penalty of an aluminum frame was estimated at about $500 but experience has steadily reduced that disadvantage. Projects like the one that developed the aluminum structure of the Acura NSX offer valuable experience; similar construction techniques were later used in the Honda Insight hybrid.
Steel is fighting back. Auto engineering magazines carry advertisements for specialized steels. The 1980’s heartbreak of body rust — all but dropping the windshield in your lap at 80,000 miles — has been largely eliminated by antirust treatments.
Much of the steel versus aluminum debate centers on crashworthiness — the ability of a vehicle’s structure to absorb crash energy gradually as it crushes in a controlled manner. If the vehicle were perfectly rigid it would stop instantly in a barrier crash, subjecting its occupants to huge and probably nonsurvivable deceleration loads. The goal is to dissipate crash energy in the controlled wrinkling of the structure.
Heinrich Timm, senior executive of Audi’s lightweight materials laboratory, explained that the A8’s chassis directed crash energy “to go into many small folds” in the metal. After such a crash, these elements look much like a long sock that has fallen down to one’s ankle.
What about repair? Mr. Timm notes that designing for easier repairs is the key — making body panels replaceable by attaching them with bolts, not welds. If damage exceeds what can be corrected in this way, the job must be done at an Audi-authorized repair center. In the event of serious damage that compresses the crash energy-absorbing elements, the bolted front structure that incorporates them can be replaced.
Corrosion is another issue. Rust attacks any exposed steel, but many aluminum alloys are naturally corrosion-resistant. Aluminum recycles especially easily, Mr. Timm notes, because it is clean and has a lower melting point than steel.
Enthusiasts know that auto racing spent little time with aluminum construction — instead leaping straight from classic tubular steel chassis to carbon-fiber composites. So why not abandon metals altogether?
Production and tooling costs give the marching orders here. Currently, carbon-fiber composite fabrication requires much hand work with costly materials. This is followed by a curing process in a vacuum at elevated temperatures — not an ideal process for mass- production vehicles.
Aluminum, on the other hand, can be worked with less than a total revolution in methods and is also much less expensive than composites. That makes it attractive as an affordable, useful step toward lighter, less fuel-hungry and more capable automobiles.
Technology
By KEVIN CAMERON
![](http://graphics8.nytimes.com/images/2006/10/21/automobiles/22alum_graphic1400.jpg)
kixo
09-05-2015 08:54 PM
Mugen TSX
Eastern Canada
09-01-2015 11:11 PM
Mugen TSX
Eastern Canada
09-01-2015 11:05 PM
