Help diagnose this IS300 clicking noise..
I can't figure it out. The sound is coming from the rear. It appears to be left rear. It comes and goes. It's annoying. It's embarrassing. Do you know what it could be?
http://www.youtube.com/watch?v=qyUuA...ature=youtu.be |
Sounds like it happens on acceleration. Maybe the axle? Check the axle nut.
Recently, my Honda clicked but in a higher pitch sounds from the front. I was able to fully isolate the sound by jacking the front up and letting the wheels spin without load. Even without any load, there was a clicking sound. I was able to isolate the sound to a bad bearing. I replaced the bearing and no more annoying click click click sound.
Do you hear this sound going straight or only on turns or all the time? |
Originally Posted by SpiderX1016
(Post 13824368)
Originally Posted by Mongolian
(Post 13824379)
might be a cracked axle or from the spring. My old v6 Accord had a bent rear axle, and that noise was annoying as hell. Had to replace it.
That car and my accord are pretty old just wear and tear. Hope it aint too serious. |
check the axle... get the rear up on some stands and run it without load... get another person to safely look and see if the clicks still happen...
Originally Posted by CAgine
(Post 13824393)
Originally Posted by KaMLuNg
(Post 13824928)
When the car was in the air on the lift, it didn't make the sound. |
First thing popped in my head when I heard that noise was axle.
So if this is the axle, is there anything visually that I could look for?
Originally Posted by ACCURATEin
(Post 13825698)
It probably didn't make the sound cause there was no load on the drivetrain up in the air.
Sounds like a bad CV joint, kinda rare for a CV joint to go up on a RWD vehicle. But look for ripped/torn CV jont boots and grease most probably on the outer joints.
axle or rear diff
Did anyone click on my link? I think it's the axle nut :)
Any last predictions before I tell you what they replaced?!
(Post 13841301)
http://2.bp.blogspot.com/_aBSy9hytUa...l+Bearings.jpg It's all ball-bearings these days. |
Well I know it wasn't the diff
Read something about a pin in the caliper somewhere else
... Wonder it it applied here. |
I'm putting my money on the axel nut. My MS6 has a slight click as well under load and that's what the MS3 guys have narrowed it down to.
Hey, Ding Dong OP how about ending the suspense? :bored:
:tomato: |
(Post 13841301)
RSB? link?
Since he isn't posting I will. It was the axle. I believe it was fully replaced with a new one and the problem is now gone.
They replaced the drivers side axle. I'm not sure what was wrong with it. Wish i could have looked at it in person to see exactly what was making all the noise.
Thanks for everyone's input. A lot of you guys were right! :thumbsup: |
:cheers:
(Post 13848773)
Thanks for everyone's input. A lot of you guys were right! :thumbsup: Glad it worked out, it sounded like a CV joint (which are part of the axle) in your video. Sometime they go bad even without a torn boot. |
