Gone very far to the Dark Side - Cobra Kit
Old 02-10-2014, 10:25 AM
  #41
Getting it Done
ineedmyfixofacura's Avatar
Wow, I LOVE those wheels, very very nice choice.
Also your 335iS looks sooooooooooooooo good, very nice.
Car arrived on my birthday, this will be one hell of an awesome car, you better believe that! :P.
update us with some pics, keep it up!
Old 02-16-2014, 03:08 PM
  #42
BEAR-AvHistory's Avatar
Received 2,600 Likes on 1,581 Posts
2/16 Body came off today & was dropped at my daughters house for storage while the chassis work is being done. Starting to photo & number the interior sheet metal before stripping it out.
Old 02-17-2014, 04:55 PM
  #43
2/17 Car is stripped naked will start on the front suspension tomorrow.
Old 02-18-2014, 08:57 PM
  #44
2/18 Official Start. "F" panels test fitted with clecos
& front suspension work started.
Old 02-20-2014, 03:36 PM
  #45
2/20 Upper & lower control arms, coil over shocks & spindles installed. Trying to do 2 hours a day.
Old 02-28-2014, 02:54 PM
  #46
Completed assembling & installing calipers. Nice touch was the inclusion of braded SS brake lines in the kit. On the fence about installing drilled & slotted disks. Test fitted splash shield which will get painted black then un der coated.
Test fit of 245X45X17 tire & wheel clearances with suspension members.
Old 02-28-2014, 03:19 PM
  #47
Your Friendly Canadian
Aman's Avatar
Received 1,492 Likes on 1,050 Posts
Would be cool to see some pics of progress.
TylerT (02-28-2014)
Old 02-28-2014, 04:50 PM
  #48
Be a slow process for awhile, garage is pretty cold. Overall its about 250 man hours to build it & don't expect to have a drivable unpainted car till into the summer. As the weather gets warmer will spend more time on it.
Old 02-28-2014, 05:06 PM
  #49
takin care of Business in
swoosh's Avatar
Received 4,732 Likes on 4,064 Posts
that is awesome....a close friend of mine up in STL got his Cobra kit car and did all the work himself....
here are some pix (I dont want to hijack the thread and hence am only posting links )
Let me know if you run into any road blocks and I can introduce you guys and hopefully he will be able to help you out
work in progress
https://fbcdn-sphotos-a-a.akamaihd.n...68860577_n.jpg
finished product
https://scontent-b-iad.xx.fbcdn.net/...91951921_o.jpg
the cobra club meet in Missouri
https://scontent-a-iad.xx.fbcdn.net/...38873660_o.jpg
https://scontent-a-iad.xx.fbcdn.net/...20742460_o.jpg
Old 03-01-2014, 09:48 AM
  #50
No problem. Its always good to see what others are doing & have done. We have a lose group of about 30 guys in the Raleigh Area that meet the 3rd Sat of every month at a local Hardies, big parking lot.
There is also a very good info exchange at http://www.ffcars.com/forums/ which is a great place to lurk for anyone considering buying one of these kits. Its a pretty good sized investment & should be realistically scoped out before getting into it.
In my personal opinion anyone who can follow directions, book is 481 pages, should be able to successfully build one of these things.
Old 03-01-2014, 11:31 AM
  #51
swoosh's Avatar
481 pages
do most of the pages have full page pics?
Old 03-10-2014, 10:59 PM
  #52
Originally Posted by swoosh
481 pages
Lots of pictures but lots of steps
3/10 After a week of poor weather & no production the sun came out its 70 degrees & the build got restarted.
Pedal box & brake hydraulic cylinders assembled & installed. Front & rear brakes are on separate circuits as a fail safe. Clutch cable quadrant installed.
First sheet metal riveted in & front suspension/brakes finished.
Old 03-11-2014, 10:21 AM
  #53
The following 2 users liked this post by BEAR-AvHistory:
Aman (03-11-2014), justnspace (03-11-2014)
Old 03-11-2014, 05:55 PM
  #54
Sorry for the double post had a old farts moment & ran out of time to delete one of them
Old 03-13-2014, 07:07 AM
  #55
swoosh's Avatar
moaarrr pics naoooo
Golfe .:R (04-02-2014)
Old 03-13-2014, 12:18 PM
  #56
moaarrr pics naoooo
Dead day today, new door going on the garage. That said this might be of interest my car is exactly spec'd to the red one in the vid. Although it will be painted gelcoat is now red.
F23A4 (03-13-2014)
Old 03-13-2014, 08:25 PM
  #57
runnin a little boost
Hi speed's Avatar
It this the color you are planing to use? These cars are a lot of fun, both to build and drive. We had trouble with the Ford racing crate engine we bought during the build, hope the Coyote is better quality. These builds get expensive quick with all the upgrades and other little pieces from Factory 5, but the end result as you can see is really amazing.
Old 03-13-2014, 09:43 PM
  #58
Looks like it, is that a Corvette paint?
This one was my goal target. Will be close except for solid heat shields on the sidepipes. twin rollbars & just quick jacks.
Old 03-14-2014, 07:28 PM
  #59
Hi speed's Avatar
I doubt it, the owner is a die hard Ford fan. I think is a older Ford color, not sure of the exact name.
Old 03-14-2014, 10:10 PM
  #60
Saw a newer Mustang today that looked in range the driver said it was called Ruby Red Metallic.
Been keeping a list of all the red paint in the color range that I like. Will get to the hard part in the fall. Started on the cockpit sheet metal today.
Intend to mock it all up with clecos before I start to bond & rivet it. One of the guys warned me not to rivet the rear cockpit wall till the trunk was done or I would be #$@*^ a lot.
Old 03-20-2014, 05:27 PM
  #61
3/20 Sun came out garage warmed up & I got some work done. Fitted & drilled the passenger footbox & cleco'd it in place.
Next step will be to pull the panels clean them with MEK, put on 2000 degree heat barrier on the engine compartment side, Truck Bed Liner the bottom piece. Then they will be bonded, sealed & riveted in place.
Near the end of the project the insides will get a two sided aluminum insulation sandwich over laid with black carpeting.
Old 03-20-2014, 05:40 PM
  #62
swoosh's Avatar
i am sooo ecstatic for this build...
in to see some videos
Old 03-20-2014, 07:02 PM
  #63
Afraid it would be in slow motion. Punched & drilled about 160 holes today. Sheet metal to sheet metal go fast. Sheet metal to steel framing take a bit longer & eat up drill bits.
Old 03-21-2014, 12:03 AM
  #64
Majofo's Avatar
Received 11,843 Likes on 8,574 Posts
Hey F23A4! You should move this thread to Car Talk.. I can't believe this gem is hidden in the TL Racing Sub-forum.
Awesome build Bear.. How much did the crate coyote and trans cost? Sorry if you said already, didn't catch it.
Old 03-21-2014, 12:26 PM
  #65
$10K delivered from Summit Racing. Ready to run with ECU, wiring harness, TKO-600 trans, HP clutch + mods for fitting to the FFR chassis like Moroso custom oil pan, pulleys, belts etc.
No problem in moving the thread. Was posted here in response to a question someone had.
Old 03-21-2014, 01:01 PM
  #66
Majofo's Avatar
$10k.. not bad.. so you're saying it came with ecu and wiring harness too? That's pretty good.
Old 03-21-2014, 09:03 PM
  #67
Was package deal designed for the FFR roadster. Both have gone up beginning of this year so think its now $12K but still a good deal with the other stuff in the package cheaper than a la carte.
Also did well on a 50% off deal for all regular production options on the car, saved about $5K
Old 03-21-2014, 11:33 PM
  #68
Majofo's Avatar
What kind of rear diff are you going to run? You sticking with the live axle or go independent rear suspension?
Old 03-22-2014, 01:05 PM
  #69
Yonkersracing's Avatar
Can't wait to see the complete build.
Old 03-22-2014, 07:41 PM
  #70
Black powder coated Ford 8.8 rear with a Traction Lok differential & 3:55 gears. 3 link suspension with fully adjustable upper & lower control arms, Koni coil overs & Wildwood brakes. Running Nitto 555R 315X35X17 rears.
The same suspension used in the FFR racing series. The IRS is a comfort version primarily for the street.
Car will be tri-purpose. Street, some drag racing at Rockingham & club days at VIR.
Aman (03-22-2014)
Old 03-22-2014, 09:31 PM
  #71
Majofo's Avatar
This is pure awesomeness..
Old 03-22-2014, 09:50 PM
  #72
Aman's Avatar
Coming along great.
Old 03-30-2014, 04:01 PM
  #73
3/30 Installed steering rack, steering shaft pillow blocks, steering shaft & tie rod ends. Also finished fitting the foot box sheet metal.
Applied the heat shielding to the foot boxes & undercoated the floor panels. Am finally #1 on the list for the custom rear axle & hope to get it in late this week.
Will continue to fit & cleco in the remaining sheet metal to keep busy.
Also to further improve my darkside image ordered a Black/Black 435M-Sport to replace the 335is.
00TL-P3.2 (03-31-2014), VR1 (03-30-2014)
Old 03-30-2014, 04:06 PM
  #74
Majofo's Avatar
Old 03-30-2014, 05:21 PM
  #75
Conan O'Brien's Avatar
ok so i have always wanted to do something like this. call it a "bucket list" thing. I have limited mechanical knowledge but with proper instructions and time...is this possible for a shadetree mechanic?
Old 03-30-2014, 05:29 PM
  #76
Majofo's Avatar
High attention to detail, patience, space and $
Old 03-30-2014, 05:44 PM
  #77
One on the right for me
subinf's Avatar
This is awesome. I've played with the idea of approaching a build like this for about 10 years. Someday I'll actually do it.
Old 03-30-2014, 07:22 PM
  #78
crazyasiantl's Avatar
Old 03-30-2014, 07:32 PM
  #79
Stage 1 Audi S5
1StGenCL's Avatar
Received 1,197 Likes on 695 Posts
Incredible, look forward to the progress and glad this was moved.
Old 03-30-2014, 07:39 PM
  #80
Its not a hard build if you stay with a basic car just takes a lot of time. Anyone who can follow directions, use basic hand tools & has patience can do this. Things can get weird when adding stuff like A/C, power steering etc.
Thing to remember these are replica's of what was effectively a street legal race car, not a boulevard cruiser.
I took the easy way & went no donor parts so all the parts are new & clean which can be used right away without restoring or reconditioning. Kit was originally designed to use a Mustang as a donor.
It costs more to go no donor but I don’t believe its that much more if you don’t go crazy with what you are buying.
Quick Reply: Gone very far to the Dark Side - Cobra Kit
