Originally Posted by 03tLsNBP
(Post 14792068)
Source: myself and two colleagues, 4+ years each in Mechanical Engineering field
Originally Posted by Majofo
(Post 14792125)
23 years old - 5 years.. Are you claiming school as Mechanical Engineering field :rofl:
I know other fields are not like this, but MEs actually come out of school with some useful knowledge :dunno: |
Sorry to hear, Morgan. :ugh:
At least you owe nothing out of your pocket...well, not really, there is the time involved. :bored |
Now that all of that's out, looking forward to where you go next with the car.
Damn Morgan, keeping the car is new to me, glad you are though, and I'm happy you're happy driving it still. :)
(Post 14790609)
did not expect that....so quickly.
(Post 14790609)
I'm sure this will lead to awesome new things for you and the car. I'm sure you haven't seen, but I ended up getting an S2000 as a weekend car. Watched some comparison vids on youtube between it and the FRS and thought of you.
Love, J.
(Post 14790690)
Hopefully down the road you can try something difference, like a motor swap.
Originally Posted by swoosh
(Post 14790751)
so when do we expect a rebuilt and boost? :)
Originally Posted by JS + MS3
(Post 14790983)
Is this a known problem for this engine?
(Post 14791081)
^^^That's what I gathered. I wonder if there's any difference to the BRZ motor? More robust?
Originally Posted by Costco
(Post 14791480)
Apparently the new Forester XT comes with a 2.0T, a turbocharged version of the FA20 in the GT86 twins. But :dunno: if there are any differences between the N/A variant.
(Post 14792068)
Those connecting rods buckled under compression, not tension. The amount of tension on a connecting rod is nothing compared to the compression it sees. The elongation of the wrist pin hole is not a clear indicator of tension, because the same thing could happen under too much compression. There is also no "necking" on the rod, meaning the rod would have gotten thinner at the break point. It looks like it just sheared/buckled under compression.
My theory is that after the connecting rod buckled. The piston was free to shoot back out and hit the valves (you can see the imprints on the piston head). The piston was then was blasted back in towards the broken rod and crankshaft, shattering the connecting point for the rod on the bottom of the piston, and finally cracking the piston head outwards. Simply put, you put too much boost through an engine that was clearly not designed for it. There's a reason people swap in forged internals before going forced induction. Now this doesn't change what happened, but I wanted to bring this to your attention so you don't go around telling everyone you "stretched" a connecting rod. Good luck with the car. Hope everything works out in the end :thumbsup: Source: myself and two colleagues, 4+ years each in Mechanical Engineering field I do have a few quick notes: -The rod sheared; it did not bend or buckle - I really wish I got a p -The engine saw 9psi only only 9psi (data logged). The FA20 has been able to support a sustained 18psi without popping. -This particular engine has shown issues on that same cylinder, prior to boost (I know, I know, why did I boost it then.....) Ultimately, I really appreciate your engineering point of few on this. I wish I had the entire motor here so I could take it apart and photograph it bit by bit, but I don't have that option.
Originally Posted by fuzzy02CLS
(Post 14792123)
We're good for something :D
Originally Posted by Yumcha
(Post 14792191)
^ Damn. Given the luck you've had lately, I think you are due...buy a lottery ticket? Maybe you'll be almost as rich as BoostedJack/Altegris soon! :wish:
The jackpot is ~$600m....:ponder:
586 Million...
I'd LITERALLY be happy with the amount you rounded that up. Forever. and :hug: thanks, man. I'm very happy with it. J. |
Some dumbshit like potroast is going to win it, buy a supra and die. :iopinky:
(Post 14795827)
(Post 14795838)
If you win $600M...can you buy me a Pagani Zonda? :wish:
Long story bro. Sorry to hear about your boost related sadness.
(Post 14796107)
How about this - I will buy myself a Zonda and wear a twig costume when I drive it. :thumbsup:
Meanie. :cry: |
Is there any particular reason why you went with that supercharger? I've been lurking on ft86 forum, there's like 20 brands that make pretty good turbocharger/supercharger kits for FRS/BRZ.
Crazy. I'm interested in AVO turbo kit. It's like $3800. Seems pretty good for what it is. |
(Post 14805739)
Originally Posted by ttribe
(Post 14805762)
Just be ready for http://www.nhra.com/UserFiles/image/..._CN1/sat13.jpg when the engine loses a rod.
(Post 14805762)
Obviously, I'm ready. :O |
(Post 14805765)
Well, if that happens for Kimchi here, there's DEFINITELY no resale value... :D
(Post 14805769)
Won't matter. He'll kill the resale value with a ghetto tint job.
:rofl: That's for sure. I need to get it tinted soon. Rims are coming off this Saturday morning. :woot:
(Post 14805773)
(Post 14805739)
Crazy. I'm interested in AVO turbo kit. It's like $3800. Seems pretty good for what it is. I didn't want to go turbo due to stress. The centrifugal supercharger slowly builds boost and rpms increase, while the AVO kit (which I honestly really liked) builds boost low and puts a lot of stress on the internals. There have been some talk here and there about the oil pump in this engine being variable rate depending on RPM; which, if true, could be problematic when additional stress is introduced at lower rpms. Then again, looking at the motor the wrong way could be problematic as well :rolleyes:
Originally Posted by 05TLdcc
(Post 14806018)
What about the lift? :D
So, I washed it for the first time since "The Incident". The taillight has had condensation in it since Thanksgiving and I was tired of dealing with the dealership for replacements. So I went a different direction.
http://farm8.staticflickr.com/7363/1...501024b7_h.jpg I ordered the Tom's clear USDM tails back in November, they were sitting around waiting for me to get off my ass to install, which I finally did last Sunday. http://farm4.staticflickr.com/3714/1...7b0f5dfc_h.jpg http://farm8.staticflickr.com/7412/1...07f5e799_h.jpg Here they are in action compared to stock. In order of appearance - brake light; turn signal and brake light; turn signal, brake light and running light; turn signal and running light; running light. I also ordered these JDM 86 replica headlights in December, but after installing the taillights, I'm thinking about going with the BRZ headlights instead as they have a similar light tube look that the tails do. http://farm8.staticflickr.com/7354/1...2cebc297_h.jpg Thoughts? |
Wow came out better than I've expected.
I love it, especially the running light. Yup would match perfectly with BRZ headlights :nod: |
Holy shit those tails are hawt :drool:
tails are the tits.. :mizouse:
Very nice. :toocool:
Woah! I thought those tailights are solid red outside!?
That looks really good on your color! I'm going to get a solid red one for mine. Quoted 450 shipped from one of the vendors at ft86. Looks awesome! |
Love the tails. If I were you I'd throw in LED license plate bulbs, just to complete the rear end lighting.
Is there a significant performance/output difference between the replica 86 and the BRZ headlights? |
Love the taillights. Glad to see you back moding the car again. Come down to NC for a trip.
(Post 14811868)
Originally Posted by Aman
(Post 14811869)
Is there a significant performance/output difference between the replica 86 and the BRZ headlights? Performance wise, the BRZ headlights are better. For one, they are HID from the factory and use the same bixenon projectors that are used in the RX350; which, after a lens swap, are an amazing projector (I have a pair that were going into the CL). The replicas are halogen and made to be plug and play with the FR-S - so my plan was to swap the RX350 bixenons into them. And since they aren't exact replicas (the housing is all chrome vs certain areas being black), my plan was to paint them while they were open. But, take a look at the light tube in the BRZ headlights. It's a perfect match to the Tom's tails, so I'm going to sell the replicas and source a set of BRZ lights. Unfortunately, it won't be an immediate thing as the BRZ lights are still expensive :bored:
(Post 14811981)
Tails look great!
I really like the lights. Nice upgrade!
Morgi, I love them lights....
I local guy has the same lights and I was hoping you would go that route but I didnt know if that was the ricer in me talking and I guess it wasnt ;) Looks SICK brothaa |
Wow, what a difference those tails made - nice choice.
What's next? :ninja: |
(Post 14812296)
Originally Posted by TylerT
(Post 14812465)
(Post 14812541)
:shrug: I've got another mod that I need to stop being lazy and install....
Looks great, Morgan. Solid choice.
Now that you're not going to need the 2 oem fishtanks, you think about cutting them open or having Bruce cut them open to see about oem tail modding potential? |
(Post 14812545)
Will it, also, result in the destruction of the engine? If so, I encourage you to do it sooner, rather than later.
(Post 14812559)
