'check emissions system'
Hey
Absolutely adore my 06' TSX - milano red!
Took her in on June 5th for oil change, emissions & inspection.
Last Fri the 13th [go figure] the 'check emissions system' indicator light comes on. Service was closed so I called Sat morning and was told to just tighten the gas cap and light would be off in 100 - 200 miles. I ALWAYS click my gas cap multiple times to ensure there are no issues.
Needless to say, light is still on and I'm taking her in tomorrow. Has anyone had this issue???
Any suggestions on what it might be?
Big up ya self, BO!
Yeah, could be many things. The gas cap can go bad, too. Happened on my 04' Tundra work truck. Bought a new one, and the check engine light went away.
dɐɹɔ ǝɥʇ ʇɐɥʍ
Originally Posted by SakiGT
If youve tightened the gas cap, unhook the battery to reset the PCM/ECU whatever manually and see if it comes back.
Originally Posted by iTimmy
I would suggest not doing this, have the codes pulled by a code scanner, many parts stores offer this service for free. If you reset the computer with out knowing what triggered it to come on in the first place your just chasing your tail. As a whole Honda's have very reliable emission control devices, chances are high it is something very simple and/or covered under warranty.
I just had the same exact problem on my 06 TSX and it turned out to be the coolant sensor. My advice is to take it to Autozone and get the code read for free, and if it's not something that's easily fixed, take it to the dealer, will most likely be covered under warranty.
mada51589
05-03-2022 08:54 PM
cycdaniel
12-17-2019 10:58 AM
