CEL on!
dɐɹɔ ǝɥʇ ʇɐɥʍ
Check your oil, it may just be low. That is a VTEC code, right now you probably don't have VTEC. Could be 1) VTEC oil pressure switch, 2) PCM, 3) VTEC Solenoid Valve, 4) Loose or broken wire or connector in the circuit. At least this gives you a place to start, but check the oil first, if the car senses low oil pressure(from a lack of oil) it will cause this problem.
hey
i ask questions because it can happen to anyone. some tl guys and accord guys have the problem. i checked the oil and its perfect. so on to the 2 valves i need to check which i have no idea how to check. just need to replace em
