Brake Upgrade
Wye-Ey-Fore Sicks-Spd
Brake Upgrade
So my buddy wants to upgrade his stopping power without breaking the bank, and he's not sure where to start. Was hoping someone could chime in with some info. He has a '96 Civic with stock rotors, pads, rims, etc. What would you reccomend, and where could I find it?
Mods: My apologies if this is in the wrong forum, being it's Honda, but I was not sure where to post.
he should start with sport pads and stainless steal lines. Anything more is a waste on a stock setup.
Replacing stock sized rotors with cross drilled or slotted rotors will only make your brake setup worse because you are decreasing the amoutn of surface area to dissipate heat buildup which is one of the reasons why you upgrade to a big brake kit along with increased caliper size and increasing the number of pistons.
so, getting larger calipers + rotors is a good idea then?
that makes sense. i just don't know how/where to search for larger calipers/rotors for that car.
Your friend should be prepared to upgrade his rims if he wants to get some larger rotors/calipers possibly with the use of some spacers depending on the rim offset and caliper size.
1 Post
There aren't many options for upgrading rotor and caliper size for the civic/integra primiarly because it's hard to fit a larger rotor/caliper in the stock 15" rim. I'm not saying it's not possible, I just haven't heard of any solutions after researching stuff for my Integra.
Yea, good pads and SS lines are probably his best bet, anything other than that you're going to really start talking serious $$$$$$
oh ok! and you just replace the short section that flexes out to the calipers in the wheel well, right? isn't that the only section you can replace?
1 Post
I don't know the procedure or what else is involved (bleeding et).
GWEEDOspeedo
01-15-2016 10:39 PM
lanechanger
10-13-2015 10:56 AM
