Boost in MPG & HP w/ Acetone?
goldmemberererer
Check
http://pesn.com/2005/03/17/6900069_Acetone/ for details
and
http://peswiki.com/index.php/Directo..._Fuel_Additive for individual results
Here's a close-to-home example from the second link:
2004 Honda Pilot AWD 3.5 v-6. Preliminary report from just miles since adding acetone; reports mileage going from 20 to 25 mpg with mixture of 3 oz per 10 gallons of fuel; significant increase in horsepower.
Individual Reports
March 28, 2005
I just tried acetone in my 2004 honda pilot AWD 3.5 v-6. I have only put 50 miles on it since adding the acetone but I topped off again this morning and my mixed driving mpg has gone from 20 to 25 mpg! I am mixing 3 oz per every 10 gallons of fuel. I have already noticed a significant increase in horsepower as well. It takes very little throttle to climb the same steep hills that normally takes quite a bit of pedal. I am exited about acetone and report back when I get more measured miles under my belt. Ken
Mods: I thought this involved a little bit of science, politics, and plain ol' WTF to go in Car Talk, but move at your will.
and
Individual Reports
March 28, 2005
goldmemberererer
Interesting points from that first link:
for every gallon of acetone used, you save $54.00 (as of this writing [March 31, 2005]).
xtrampg.com (http://www.xtrampg.com/) - It's acetone! They advertise 30% increase in mileage with their additive, which they sell for $30/a case of 10, for 20 fill-ups.
Received 2,787 Likes
interesting, anyone heard anything about that tornadofuelsaver thing, saw an ad for that on speed channel
does absolutely nothing
dang that hunk of metal is sure expensive for doing absolutely nothing (i think it was like $200?)
Not Asian
Originally Posted by 1998CL3.0
hhmmm... that aceone thing sounds interesting, whos gonna be the first to try and post results!!
My Work is Done Here
1 Post
whatever you say Mr Scientist.
i'm more interested in the mpg gains, does that seem feasible?
http://pesn.com/2005/03/25/6900071_Acura_Acetone/
IMO, this guy's experiment has a few flaws. But take it as you will. His results are statistically insignificant. And the short time period and small amounts of fuel means a bigger margin of error.
I might have to try this out myself.
Where is my super sauce?
Originally Posted by SpeedyV6
I believe it's a ketone. And considering that it's partially oxidized [(CH3)2C=O] I can't see how more energy can be obtained by burning it. It may have some antiknock properties because theat ketone group may promote smoother oxidation, but that's it.
i've got 3.5oz in my ~17 gallon tank right now. i was getting an average of 18-19mpg, and my last fillup of 15.5 gallons and 290 miles on the odometer yielded 18.7mpg. let's see what this puppy will do. btw, i followed some of the advice about pre-mixing the acetone...i.e., i mixed the 3.5oz with 2 gallons of gas first before pouring it down the filler tube. don't want the pure acetone to potentially eat/burn away at the rubber.
I remember some people in the 70's putting 100% acetone in their tank. After about 5 or 6 locked up engines the idea kinda went away.
Doing that raised the cyl. temps unbelievably to where the rings welded themsleves to the cylinder wall.
acetone also eats the shit out of anything that is not metal or nonreactive plastic...itll make permanent marker dissolve like dry erase and eat glues pretty quickly too
its pretty caustic stuff and although it might help your economy, it will probably weaken everything that is reactive on its way to the engine. probably would take quite some time, but its still faster than if it wasnt there
Originally Posted by Gilgamesh
Yeah...everyone tries to get turbulence OUT of their intake stream and this guy is gonna put it back in?
Originally Posted by dallison
you'll spend more on the acetone, so your savings go down the tubes
at any rate, i'm just testing right now...results to follow.
at such minor levels, it's hard to fathom any real damage being caused. you have to remember that gasoline is pretty strong stuff also, and acetone is actually one of the weakest solvents. just do the pre-mix thing, where you mix the acetone with a couple gallons of gas first, so that when you pour it down the filler tube, it's not acetone only.
Bagged hybrid
at those levels, acetone shouldn't do much to your fuel lines. rubber seals are generally okay I believe, toluene eats those much faster. being that acetone is miscible in water and has a relatively high vapor pressure, it will absorb any water in the fuel and vaporize at a lower temp (b.p. = 56-57C) than with hydrocarbons/aromatics alone. as a vapor, acetone pulls oxygen out of the air and thus increasing the amount of oxygen in your fuel.
i put some methanol or acetone in my water injection system to use the solvent to cool the intake charge temps and bring back any displaced oxygen into the intake.
1999 Acura 3.2 TL
Just yesterday I filled up about 6.8 gallons, 91 Chevron. I poured in about 1.8OZ of acetone, took it for a spin and took a few hard turns to mix up the acetone with the gas in the gas tank. And later that night, took a long trip to Pomona, partied, and came back home. I was on Empty, came out that I got 23.7 miles per gallon. I was surprised. Usually my car, all highway, would only get me around 17-19 miles per gallon. That`s pretty freakin` horrible. In conclusion, I will be using Acetone as an MPG booster until I swap out my spark plugs to NGK, to see if there is a change in my MPG. If not, back to Acetone. Oh yeah, I don`t have to spend any money on Acetone, my family owns a nailshop and they use Acetone there to remove nail polish, I get them for free ^__^
1 Post
did you notice a difference? Let us know.
i've only filled up twice, and each time has been at or slightly above 19 mpg. so, it does appear initially to have helped a bit. BUT, there could be many factors involved...i could be inadvertantly driving less aggressively, less traffic (stop/go), etc.
without having a set driving test with many constants, i.e. point a to point b, straight line, no traffic, cruise control...it would be nearly impossible to give credit to the acetone for the added increase.
the good news...the car hasn't blown up yet.
Originally Posted by ccannizz11
Not quite the 35% increase that the original article said was possible... meh, I'm getting 21mpg right now, I can't complain too much.
btw, the 19mpg is on a toyota highlander V6 AWD, not an acura.
NBP_BALLER
09-23-2015 08:18 PM
