Best way to attach balancing weights to wheels.
What are the options to attach balancing weights to wheels?
Problem is I balanced wheels at pepboys 2 years ago. They used some double sticky shit to hold weights to the wheels. Well I am only noticing now that they have been falling off. Water and snow wash Thst double sticky stuff off.
Traditionally I think weighs were held by some steel bracket. Can weights always be put on the inner side of the wheel? I don't like when those weights are on the outside.
The Third Ball
Received 5,079 Likes
Jizz mixed with salty tears.
The following 2 users liked this post by Sarlacc:
1killercls (12-19-2016),
Chief F1 Fan (12-19-2016)
The three ways to mount the weight are clip on, double sided tape, and duck tape. The first two are use for normal street application and the latter is use in racing.
The best place to mount the weight is on the outer edge by the clip on style fastener. However, this is usually use on steel wheels because it's asthically unappealing on alloy wheels.
The 2nd best place to mount the weight is on the back side of the wheel as close to the outer edge as possible. This is usually done with double sided tape on alloy wheels because it's asthically appealing. You don't really notice the weight unless you are looking for it. This is an accepted standard practice for balancing alloy wheels.
3M is the standard. The weights come pre taped so the weights are stuck on as is, not 3M. However, that's not the issue. The issue is the tech didn't do a thorough enough job of cleaning the dirt/brake dust from the area that the weights were affected to. It doesn't take much for the weights to stick because the weights are heavy for it's size and with the additional pressure of centrifugal force pressing the weights into the wheel, adhesion is not really a problem. Unless the tape itself deteriorated, in that case the 3M tape would make a difference.
YeuEmMaiMai (12-22-2016)
I drive a Subata.
Just take it to the shop! Cheap anyway.
Spending money on rebalancing is no problem. I just don't want to deal with weights falling off again. Just because it's a specialized shop it does not mean that those who work there know what they are doing. I have an alignment guy who I trust and know he is not gonna fuck up my car. But most shops fix one thing and fuck up elsewhere in the process. That's main reason I do diy a lot. Not to save few $.
Also have small clearance between brake caliper and the rim. So if weights are in the middle.. or inside of the rim that would help. It's not exact opposite of the valve and tpms sensor..
Or they use some unknown tape that came with weights and I need to tape weights on 3m tape
extensive experience with working on used cars with repairs done by previous owner. Stripped threads.
Claiming they own specific tool required to do bmw alignment and instead banging with a hummer on powder coated trailing arms. Can give exact addresses of those fuck ups.
Extra charge on "had to use heat" during alignment is very common. I mean if u just redone entire suspension. . And that dick head is saying he had to use heat. .
Improper control arm install.. often ull see one bushing twisted to shit because shop did not lower the car before tightening that bolt. I can go on and on.. there are diligent mechanics who actually fix
But most just want to get paid and roll your car out of garage.
Or they just scam..engine blew. U need new radiator to get this car going. Client pays for radiator that he does not need. Car is still fucked
A friend just left his vw at a shop for clutch replacement. He is busy with his business. No time for clutch jobs well those idiots installed new starter from autozone..they did not Cal him because they did not want to bother him. Well it was the wrong starter. Vw had couple of starters with different teeth count. So car made a loud high pitched sound when starting. The guy was like what the fuck did u do with my car? It's clearly fucked. Why are u giving me the keys to a fucked up car. And he had the right starter . Original. Made in germany. In Massachusetts I have 2 confirmed shops that either fuck up your car or scam u
Clean the wheels (where the weights are) with a good wax/tar remover before getting them balanced.
3M double sided tape works great on a clean surface, even better when applied warm.
Nothing but anecdotal evidence. No hard data.
Thought so.
Thought so.
its not anecdotal. . Anyone i talked to and I am sure u talked to is very skeptical of a random mechanic.
Basically if u are a woman. Or someone who has no clew of what's going on your chances of getting screwed are about 90%. I only bring my car to alignment and I watch mechanics every move.
bring your car to
320 Watertown St, Newton, MA 02458
I am sure ull have had to use heat charge. And they'll use a hummer all over your subframe and suspension. But the reviews are excellent.. 4.5/5. Who writes these reviews? I'd say shop owner and his friends.
Oh yes.. and pepboys weight stickers.. should not fall off. Meh. Some things in life are very common sense. Searching for "hard data" is waste of time and findings will mislead u.
bring your car to
Tig weld
"3M is the standard. The weights come pre taped so the weights are stuck on as is, not 3M."
I need to clearify about the 3M tape being the standard. What I meant was 3M is the best double sided tape hands down... The standard where all other double sided tapes are compared to is the 3m double sided tape. Not as in the standard double sided tape being use on wheel weights is 3M.
Received 3,858 Likes
That being said if it is two years since you last had them done you really should have them rebalanced at this point anyways if it is a daily driven vehicle. I get them rebalanced 3-4 times a year whenever I have my tires rotated since its free of charge. I also get at least two alignments a year at a minimum as it just helps the car drive smoother.
fsttyms1 (12-19-2016)
