AAA study shows premium fuel is not always worth the price in certain cars
#41
You certainly don't have to buy anything I say. I simply post what I've experienced.
I've sent several sets of injectors from s2000's that have only seen premium fuel. 98% is the least flow compared to rated I've ever seen back.
Conversely I've sent several sets of injectors from 4g civic's/2g crx's that only ran regular. 80% is the least flow, and I've never seen as high as 98% on any from them.
Always sent off around 75k, +-5k
This is not a scientific test with controlled environments by any means. However, it's what I've seen in my experience, so it's meaningful to me. For everyone else take it for what it's worth, just another internet opinion to add to the millions of others out there.
Premium does have more detergents.
Very old news segment...
http://www.youtube.com/watch?v=J2d6_CIwaNE
From their analysis, they found that some companies (Shell, Speedway) put double the amount of detergents in premium vs regular while with others (Mobil) it's a negligible difference. Things may have changed since then though.
Regular:
vs Premium:
Regular:
vs Premium:
Yes I know this is yet another data point in the vast sea of the internet but at least it's some sort of actual spec to compare against.
Of course. This is how they get the best performance but it isn't required to run the engine.
#42
when I pulled my heads, I found carbon deposits on the pistons. at that time, I had extensivley used Premium fuel, but from Sam's club.
would your experience lend towards different tiered fuels?
Since then, Ive switched to Shell...(no difference in perceived performance or fuel economy.)
but would be interesting to pull the heads to see if any carbon buildup
At the end of the day, it's the Walmart of gas...so...yeah. Costco gas IS top tier certified and I've never had an issue with it.
#43
Latent car nut
Received 2,006 Likes
@SamDoe1, unless you're talking about an engine which features direct injection, how do you explain and qualify "carbon buildup"?
#44
I guess I'm not entirely sure about if it's carbon build up but definitely crud in there.
#45
Latent car nut
- Fuel of any type will have no affect on valve springs, that's the job of the oil to keep clean.
- I have never once seen a valve, injector or the port area in the spray zone which had even a single spec of dirt or carbon, or anything else for that matter except shiny metal on a healthy head. One exception here, if an intake valve is burned then all bets are off, but once again, this is a very different issue.
- The fact is, the fuel companies and the auto manufacturers are in almost constant communication regarding which additives need to be in fuel to keep the fuel system of modern cars in top condition for the life of the engine. To be quite honest, I don't think you can buy gasoline anywhere in the U.S. or Canada where the fuel isn't sufficiently supplied with additives.
#46
Sam's club has never used Top Tier gas. I've had actual issues with their gas causing clogged injectors and carbon build up when I used it in my old Accord years ago. I haven't used it since and don't plan on it but it may have changed in recent years.
#47
Just to clarify, top tier standards just have minimum requirements across all grades of gasoline including regular. That's important for a car running regular gasoline, but for a car running premium, just because a brand isn't top tier, that doesn't mean that their premium blend doesn't meet or most likely exceed top tier standards.
#48
Ahhh, you not ever having never pulled a head I understand. I've pulled hundreds of heads and here are a few comments in context:
#49
Can't think of any name brand gasolines who's premium blend who didn't when I read about this years ago, but i did remember initially that Chevron, and Shell were first, and others like Mobil, and BP took awhile to catch up. Their premium blends were fine, but their regular blends only met EPA standards which weren't high enough for top tier status. It's been awhile since I have owned a car that hasn't required premium,so I've always been covered, and never go to those mom and pop gasoline stations.
Theres a complete list here to check whichever stations are near you.
https://en.wikipedia.org/wiki/Top_Ti...rgent_Gasoline
