6 speed MT vs Dual Clutch Automatic transmissions
2006 NBP TL MT6/ 02TL-S
Does a manual transmission still have an advantage in horsepower at the wheels over the new dual clutch transmissions?
Lets say in some magic land far away, they make a dual clutch version of a TL exactly like my 06 TL 6MT. Give the dual clutch version as many speeds as would be normal, like 8 or something.
What would be differences in performance, etc. ??
no difference in power put down.
DCT will shift faster then you could ever imagine shifting your 6MT. If power was equal, DCT would walk your ass.
The following 3 users liked this post by TacoBello:
Scroll down to the DCT section. All will be answered.
Transmissions explained: Manual v Automatic v Dual clutch v CVT v Others
Turd Polisher
I'd say similar performance.
Having owned a 6MT Accord & CLS-6, I felt the 6 speed was geared perfectly for the J3x engine.
The 6MT has 12-15% drivetrain loss respectively .. I wonder what the new 8AT produces?
To what car are you comparing your 6MT to? and who said anything about AT? Are we reading the same initial post? I'm confused. Where am I? And where are my pants?
Turd Polisher
Whoops, should have said 8 DCT - not AT. Mah bad bruh.
Honda's new 8 DCT has a torque converter - wonder what kind of drivetrain loss it produces vs the 6MT?
There's only so much power more gears can extract from a 230whp engine
Haven't most designs of DCTs eliminated the torque convertor and are more or less a direct hookup like in a manual?
And I was really meaning differences in the 2 trans in cars in general, I just used my car as an example
Turd Polisher
That said, give me a manual all day every day.
Most, yes. But Honda uses the torque converter to smooth out starts (rather than using a clutch) and then locks it up shortly after the car gets moving. This not only smooths out starts but also helps with clutch life because it prevents slippage during starts. A traditional AT will use the torque converter through every gear and only lock it up after reach top gear and/or at cruising speed.
AlanW (02-25-2016)
not all DCTs are the same.
you make zero reference into what you are comparing.
MOST DCTs will have the same losses as a MT.
Turd Polisher
While some of that is true, it's not exactly cheap replacing gear sets or synchros either
Your Friendly Canadian
Received 1,484 Likes
Does this torque converter have the ability to completely decouple the transmission and engine? If not, does that increase wear on the synchros?
manual all day, nothing more satisfying than actually shifting the gears and getting a perfect rev matched downshift. Might not be as fast as a DCT/Auto but way more satisfying. Why even buy a car if it isn't fun to drive.
If I'm understanding this right, DCT is a bit of a misnomer for Honda's application since it uses a torque converter instead of a clutch.
For the new S4, Audi gave up their S-Tronic/DSG (DCT style) in favor of a conventional automatic.
The interest of DCT over conventional is now marginal. I spent 1600km in the Alps with a DSG/Diesel and I was surprised how rough it was.
And that is a big reason honda put a torque converter in. It is there to smooth out the slow speed roughness a DCT exhibits.
D's Up (03-02-2016)
Elite
I am still amazed that my TL is faster, quite a bit faster actually, in auto vs sport shift. The computer does a great job with shift points In relation to what I'm doing with the gas pedal. I cannot do better, or even break even technically.
Latent car nut
Received 2,005 Likes
...but still slower than an otherwise identical car with a 6MT.
AZ Community Team
Holy thread revival!!
