2002 6 speed Maxima dyno (sheet inside)
#41
Originally posted by scalbert
Now we are getting somewhere. Based on the numbers from this site and the V6Performance site I had made a rough calculation of 3400+ with driver. It appears that this was off or the numbers are being dropped by a noticeable margin which tends to lend support for the claim.
If the car is severly lightened and is running a wheel/tire combo which is also lighter and shorter (lowering the overall geraing) then it would be possible. But not with the numbers I was originally looking at. Any chance to get it on the scales?
With the car gutted these where the numbers:
LF= 962 RF= 946
LR= 586 RR= 546
Total= 3041
add driver which is around 240-250 and it comes to about 3300. These weights were done with over a half tank of gas also just for reference.
Do you happen to have any of your all motor dynojet runviewer files or know who does? I just want to see the difference in area under the curve which seems to be getting overlooked.
Matt
#43
Originally posted by fastvtecCL
WOW i didn't mean to start a war... ok first off i have seen this maxima first hand run 13.5@106, 13.4@106 (all motor) at the rock. i understand it is hard for everyone to believe but it did happen.... trust me guys i wouldn't have post about this if it wasn't a true story
#44
WOW i didn't mean to start a war... ok first off i have seen this maxima first hand run 13.5@106, 13.4@106 (all motor on street tires) at the rock. i understand it is hard for everyone to believe but it did happen.... trust me guys i wouldn't have post about this if it wasn't a true story
#45
No one thinks this, just discussing.
#46
I agree, area is often overlooked; but so is the area most often used. From the onset the VQ makes considerably more total power. But when the area used after the initial shift is highlighted this delta becomes minimal.
Let’s assume the two cars have very similar gearing, which they do. I'll use my last NA dyno and compare it to the one supplied here. However, I will only use numbers from 4400 and up as the car will always be in that range under WOT after the first 60 - 100 feet. I will use the torque values in 200 RPM steps to determine total power, or area under the curve.
My Old NA Dyno
And the data:
Code:
RPM J32A2 VQ35 4400 208 240 4600 208 242 4800 209 238 5000 210 235 5200 211 233 5400 210 230 5600 210 225 5800 211 220 6000 212 216 6200 213 210 6400 210 203 6600 200 198 6800 190 7000 180 Sum 2882 2690
#47
speaking of track times, when are you going to get your ass to the track :P
Seriously, pretty soon as I don't want to run in July or August. I have had quite a bit on my plate lately and there is no sign of it letting up with the recent plans I unveiled.
#48
Originally posted by JZ
With all of those mods I would have thought it would have put up bigger numbers than that. The torque is pretty good, but the HP numbers are nothing to brag about.
Also this is an '02 Maxima which IIRC did not have the same output 3.5L V6 the '03s got.
#49
Nope, just the plots on my site. I'm on vacation right now with my wife and daughters so I have limited access to all of my data.
My Old NA Dyno
And the data:
As shown above, from 4400 and up the J32A2 has more total power because it makes power longer. However, it is lower on torque which gives it a disadvantage off the line. But once moving the ability to make torque longer helps to limit its torque deficit. In addition, this would allow it to run more aggressive gearing negating the torque deficit.
My Old NA Dyno
And the data:
Code:
#50
6 Speed Maxima HP Calculations
4000 - 170.11
4200 - 186.34
4400 - 199.07
4600 - 211.03
4800 - 217.45
5000 - 224.85
5200 - 230.27
5400 - 235.78
5600 - 240.83
5800 - 246.16
6000 - 248.20
6200 - 247.37
6400 - 246.40
6600 - 247.32
This was done 100% accurate using dynojet runviewer to calculate the rpm rev points to get the exact numbers. I just started at 4000 and went to redline which shut off at 6582. Using SAE correction and smoothing factor of 5.
Matt
4000 - 170.11
4200 - 186.34
4400 - 199.07
4600 - 211.03
4800 - 217.45
5000 - 224.85
5200 - 230.27
5400 - 235.78
5600 - 240.83
5800 - 246.16
6000 - 248.20
6200 - 247.37
6400 - 246.40
6600 - 247.32
Matt
#51
Hey Blu, arent our Maximas redlined at ~6200rpm (or pretty much right at the point on the dyno where the TQ spread=~0)??
I'd like to see HP numbers as well, in order to further quantify the acceleration on both.
#52
Matt
#53
As far as the 6MT, what's the optimal shift point for the quickest acceleration??
From what I've seen, Nissan's typically dont benefit (in acceleration) from +redline upshifts unlike Hondas, in which some motors have about 1k rpm headroom (read: B18C, B16A).
#54
As far as the 6MT, what the optimal shift point for the quickest acceleration??
#55
any chance to do the numeral power numbers for HP like you did with the torque? The area under the curve torque is quite a bit different,
HP = RPM / 5252 * TQ
#56
Code:
Sim HP Dyno HP 201 199 212 211 218 217 224 225 231 230 236 236 240 241 243 246 247 248 248 247 247 246 249 247
#57
This is what I came up with eyeballing scalberts dyno HP numbers
Maxima
4000 - 170.11
4200 - 186.34
4400 - 199.07
4600 - 211.03
4800 - 217.45
5000 - 224.85
5200 - 230.27
5400 - 235.78
5600 - 240.83
5800 - 246.16
6000 - 248.20
6200 - 247.37
6400 - 246.40
6600 - 247.32
CLS
4000 - 160
4200 - 170
4400 - 175
4600 - 178
4800 - 182
5000 - 198
5200 - 208
5400 - 212
5600 - 220
5800 - 230
6000 - 244
6200 - 245
6400 - 246
6600 - 242
6800 - 235
7000 - 235
I was just wanting to show the area under the curve difference to show why he is trapping quite a bit higher even though the peak numbers are almost identical. I was just wanting to see the graph for HP like you made the one for torque thats all.
Matt
Maxima
4000 - 170.11
4200 - 186.34
4400 - 199.07
4600 - 211.03
4800 - 217.45
5000 - 224.85
5200 - 230.27
5400 - 235.78
5600 - 240.83
5800 - 246.16
6000 - 248.20
6200 - 247.37
6400 - 246.40
6600 - 247.32
CLS
4000 - 160
4200 - 170
4400 - 175
4600 - 178
4800 - 182
5000 - 198
5200 - 208
5400 - 212
5600 - 220
5800 - 230
6000 - 244
6200 - 245
6400 - 246
6600 - 242
6800 - 235
7000 - 235
Matt
#58
But IMO and based on what I have heard, the high trap speed presented was not a result of power or torque per say. It was through weight reduction and overall gearing changes.
For the area under the curve for the above presented numbers; the J32A2 still has an advantage (no chart available as I didn't feel like uploading another, DU in this condo bites). But here is the side by side comparison with the sum of the values:
Code:
RPM VQ35 J32A2 4000 170 160 4200 186 170 4400 199 175 4600 211 178 4800 217 182 5000 225 198 5200 230 208 5400 236 212 5600 241 220 5800 246 230 6000 248 244 6200 247 245 6400 246 246 6600 247 242 6800 235 7000 235 Sum 3151 3380
#61
Originally posted by mrsteve
What would the Max run with full interior and street tires then?
#63
Higher trap speed is normally indicative of good top end power. Obviously both cars have similar top end power with the J32A2 having a slight advantage in being able to make the power longer. Lower ETs are a good indication of torque and getting off the line well. Obviously the VQ35 has a significant advantage here.
Nevertheless, that car is impressive and it is obvious the owner has put considerable thought into getting the ETs low.
Code:
#64
Originally posted by mattg
what mods for you to run that time?
was it really cold out?
With the current setup with headers and same mods minus the y pipe which was replaced on the header setup my best with full interior in 75 degrees is 13.90@100.96 also on street tires. Same day I ran a 13.62@101.5 on the 22" slicks.
Matt
#65
interesting.
the quickest i've run n/a is 14.16@99.11
intake
headers
pulleys
stock 17's w/ 235/40-17
full interior
50 degrees
no auto cl-s has broke into the 13's n/a. then again i've never gutted my car and tried.
intake
headers
pulleys
full interior
50 degrees
#66
interesting.
intake
headers
pulleys
full interior
50 degrees
interesting.
intake
headers
pulleys
full interior
50 degrees
#67
If you totally gutted your car you'd be there no problem. I mean if we took out the passenger seat, rear seat, spare tire, jack, tools, stereo, speakers, interior trim panels, we'd lose close to 500lbs.
#70
Nah not trying to be sarcastic.
How much is the interior of the Max stripped? Are the speakers still in, sound deadening (sp?), trim panels, etc? I've seen some cars at the track REALLY stripped out.
#71
Originally posted by Maximized
Have you guys ever tried to run at another track? The track you guys run at seems to be pretty quick.
#72
With the A/C, Seats(front/rear), spare/jack, floor mats and trunk carpet it weighed in at 3041.
So a weight savings of 181lbs removing whats listed. All the sound deading, door panels, speakers, radio etc was still in tact.
#73
interesting.
intake
headers
pulleys
full interior
50 degrees
interesting.
intake
headers
pulleys
full interior
50 degrees
Type-R's 3.2 with 3.5 block has gone into the 13s. No NOS, no S/C, no turbo, and no CH[size=1l]3[/size]NO2
#75
he said 3025lbs in the other thread.
so the max weighs ~250lbs less from the start.
imo, the powerplants are equals, it's the weight difference that makes the difference at the track. that and more people are experimenting w/ the max. with the work scalbert is doing, that gap will start to close.
#76
Originally posted by EricL
I presume you mean no 3.2L n/a auto has broken into the 13s.
silly to leave that out, since the j35 is a better match to the vq35.
TypeR has run a 13.7, on street tires w/ full interior i believe.
#77
The numbers dont add up IMO. The car is making ~50 less whp than a stock LS1 C5, but traps roughly the same, with similar weights.
#78
of course.
of course.
#79
similar weights? His Maxima 3300 MAX with him in it, LS1 weighs approx 3500lbs without the driver... Not even close unless my math is different than yours
#80
Yea trap speed is based on top end power but the area under the curve(4600-5800 20+hp differences) is a huge determining factor as well. Look at the top end IE: last 1000 rpms is almost identical. With a raised rev limit the Maxima would be right with the numbers of the CL for the last 400rpms. If the cars weighed exactly the same who would trap higher just based on the HP differences? Im just saying its not all weight reduction with full interior he would still trap 104-105 in decent conditions.
If the cars weighed the same and were making the power shown here I suspect that it would be very close and both cars would trap within 1 MPH. The difference would probably be made in the launch at it does have an impact on terminal speed.
IMO, his high trap is not just from weight reduction but also from the overall gearing changes. I would like to see how much of an impact his slicks played in this. Do you know the diameter for the stock wheels/tires and for the slicks?? Also, what was run on the dyno??
