1999 Ford Ranger Grill Removal?? help
I have no idea, but if it's similar to most newer Ford grills, lift the hood and observe the dozen or so screws on top of the grill surround. Remove the screws. After doing so there should be about six to eight clips around the grill surround (inside of grill). Gently lift the tops of the clips lightly (too much and it will break) until loose.
That should be it. Advice caveat emptor. Never had to remove the grill on a Ranger before.
Terry
Terry
You can also go to the nearest library and get the Haynes, Chilton or whatever shop manual to see what it says.
If it was a Chevy, it would just fall off on its own, right?
