07 TL-S 3.5 cams in the 3.2 heads?
I know someone already tried the RL cams and they were too long I believe, but how about the new TL cams, I even read on Acuras website that these cams are hollow just like the Evos cams
part numbers for these cams are different then those of the RL but I wonder what the specs are They seems relatively cheap too since the RL cams are $250 a piece.
www.acuraoemparts.com
001 14100-RDB-A00 CAMSHAFT, FR. 2007 TL $177.35 $141.88
002 14200-RDB-A00 CAMSHAFT, RR. 2007 TL $177.35 $141.88
More info
From www.hondanews.com
http://www.hondanews.com/CatID3014?m...58678&mime=asc
So apparently the VTEC lobes are the same as the non type S which I assume are already similar to our 3.0/3.2 cams that came out in the earlier models. However the cams are hollow which should be a nice bonus for those wanting to reduce rotational mass especially in the valvetrain.
Originally Posted by Honda News
VTEC(R) (VARIABLE VALVE TIMING & LIFT ELECTRONIC CONTROL)
Acura's VTEC(R) (Variable Valve Timing and Lift Electronic Control) gives the TL and TL Type-S engines strong low speed torque and throttle response while enhancing high-rpm power.
At low speeds, the intake valves have lower lift and are open a comparatively short period of time during cylinder filling. At high rpm where breathing is critical, the valves switch to high-lift, long duration mode to deliver the best volumetric efficiency possible.
Both engines continue to use the 3-rocker VTEC system, which allows each of a given cylinder's intake valves to be controlled by its own low-speed cam lobe. (By comparison, with 2-rocker VTEC, both intake valves in a given cylinder are controlled by a single low-speed cam lobe). With different low-speed cam profiles for each intake valve, 3-rocker VTEC allows for staggered valve opening and lift, which promotes swirl in the combustion chambers, thereby improving efficiency. With better mixing in the cylinders, burn speed and combustion stability are improved.
When engine rpm reaches 4700 rpm (4950 rpm in the TL Type-S), the powertrain control module (PCM) triggers the opening of an electric spool valve that routes pressurized oil to small pistons in the intake valve rocker arms. These pistons slide into position to lock together the three intake rockers in each cylinder, which then follow a single high-lift, long-duration cam lobes. With the engine's intake valve lift and opening duration continuously adjusted to suit the operating engine speed, the TL benefits with a broad torque curve and superior peak power. The two engines feature different cam profiles, with the Type-S sharing the same higher lift and longer duration.
Registered Member
Ford was using hollow cams 8 model years ago in the 2000 SVT Contour, and perhaps even as early as '98 for the same machine. So this is not new technology by a long shot. And the SVT Contour had beehive valve springs as well. Only thing it didn't have was a form of VTEC.. which would have been nice.
Alright...
Didn't ask for a history lesson nor did I say we were the first or second ones to do this just that it could be a good idea.
Anthony3 (07-19-2012)
Originally Posted by Accord_V6_400m
Alright...
Anyway, if the RL cams are too long, wouldn't the TL-S cams be too long also? IIRC they're the same engine, save for the different exhaust system.
'Big Daddy Diggler'
I would think that the cam would be longer since the block is based off the rl's block. My question is how much power could the cam upgrade give without anyt tuning. Or can the engine compensate for such a small bump in duration and lift.
You could stand to gain some low end from these and reduce reciprocating mass, that is if it fits
Originally Posted by I Go To Costco
Was that necessary? If you didn't find SouthernBoy's response necessary, then just don't say anything. I'm sure you'll garner a lot of positive responses if you act like this in the future.
Originally Posted by sbuswell
i am intrigued by the cam swapping idea but i doubt there would be enough benefit without swapping the whole crankshaft.
ChairmanMaoSaysRTFM
Accord_V6_400m - as you mentioned, using the RL cams had been tried and much more was involved than just swapping the cams. to see if these are just a dead swap you will probably need to find out if any of the other part numbers in the valvetrain match the tl part numbers. if not then they are most likely all RL parts and it wouldn't be a direct swap. this is just an initial guess though.
SSTS
Originally Posted by SatinSilverTypS
ford was also using the hollow cams in their late model taurus SHO {3rd gen SHO, from 1995 or 1996 (can't remember which it was now) to 1999 when they finally killed it}. they had NOTORIOUS problems with the cams snapping and spliiting in the SHO V8. i wonder if they ever fixed it. regardless, i'm sure the acura cams will be much better.
SSTS
SSTS
Sadly this is only a dead swap for the 04+ TL everything else uses wider pulleys and belts. The only other car that matches the part numbers are the 7th gen. Honda Accords.
ChairmanMaoSaysRTFM
Just checked out the part numbers for all the TL's and all of the other parts are the same! Only the cams are different
SSTS
well, i guess that it's a start. anyone who does the 3.5L upgrade for their 2nd gen has something to look forward to
SSTS
SSTS
Registered Member
Alright...
The 2000 SVT Contour was a peice of work with some outstanding components. I think Ford tends to be one of the better innovators when it comes to putting magic into street machines.
This in no way takes away from the Acura TL. The only real fault I see with the engine is the fact that Honda can't seem to pull itself away from belt-driven cams and interference engines. This is not rocket science and is not the best way to go.
Registered Member
SSTS
SSTS
All manufacturers at some time, use some part(s) that cause problems and leave a lot to be desired. Remember the mid-80's small block 305 CID Chevy engines used in the SS coupe and the camshaft problems with that engine? The lobes were getting worn significantly in less than 40,000 miles.. something that just should not happen.
Registered Member
Question. Does anyone know if the '07 TL-S heads will bolt on to the TL engine block? Also, do the heads on the '07 TL-S preclude the use of headers like the '04-'07 TL engine does?
Yep you'll have to use the close coupled pre cat header.
Already have a 7th gen Accord trying this out on vperformance.net so hopefully we'll get his impressions soon.
'Big Daddy Diggler'
The difference between the type s torque and the regular is mostly due to the displacement being bumped up on the type s. The cams will probably help with off line feel and throttle response, but i think the work involved with putting them in is not worth the minimal gain.
'Big Daddy Diggler'
Not a history lesson, friend.. just a point of interest. All manufacturers at one time or another come out with some great ideas that make there way into production machines. These ideas most frequently come from racing technology.
Anyway we'll see how they work in a 3.0V6 within a few weeks.
ChairmanMaoSaysRTFM
Originally Posted by fsttyms1
Only if they change blocks and dont reuse the Stock 2nd gen motor.
SouthernBoy - yeah ford was using their own v8 in the SHO for the 3rd gen models for 96 through 99. (circa the "bubble design" taurus). that's why they sucked. the 89 through 95 SHOs had the yamaha v6s in them. fantastic engines those were. tell your friend to check out shoforum.com if he hasn't allready. there are alot of smart people over there. god knows he'll need them if he has as many problems with his SHO as i had.
'Big Daddy Diggler'
Natuarally, however don't forget that for some the appeal of hollow cams and reducing valvetrain mass is very inticing.
ChairmanMaoSaysRTFM
I think some head work, and larger valves would benefit the 3.2 more then the hollow cams.
Registered Member
I had an SVT Contour before i got the TL in 99. I loved the SVT more than the TL. It was cheaply made, but the little touches that made the SVT stand out and the rarity made me love it. Not to mention it was stick and oh so fun to drive. With full bolt ons and a 100 shot, i was running mid 12's and could out handle many a rear driver in the twisties.
Other that this "feature" the car was incredible to drive. A .92g 200 skid pad in box stock condition is nothing to sneeze at.. especially with a front driver.
So you were running mid 12's with a 100 shot. Were you ever concerned about cooking your valves?
Registered Member
yeah true. i forgot that little fact.
ChairmanMaoSaysRTFM
I think the only problems he's had have been clutch (he doesn't operate one like I do) and his A/C compressor. He has an after-market exhaust.
mlody
12-04-2019 02:11 PM
MetalGearTypeS
08-29-2016 08:28 PM
Pham Alvan
03-16-2016 09:17 AM
navtool.com
31
11-16-2015 08:30 PM
