Cameras & Photography Because there aren't already enough ways to share photos...
what tripod do you use?
Old Oct 31, 2008 | 02:40 PM
  #121
waTSX's Avatar
Have camera, will travel
Originally Posted by jupitersolo
How tall are you? Are you sure that either one will be tall enough, when using a tripod you don't want to be bending over to use them, you want them to be eye level. The tallest you'll get from either is 5.3 ft, then add four inches for the ballhead and then another three for the camera body. That would be just at 6ft, I'm 6'5" and would want another few inches to get it to my eye.
I'm 6'1" jupiter. My eye level is right at 68", so yes both pods are a tad on the short side from that point of view, but my current set up is similar and it hasn't been a huge issue.
The column on both pods raises that level to whatever height I'll need. I've avoided raising the column on my aluminun pod because it compromises stability a bit, but I think that'd be less of an issue with the CF models. To get a tripod that extends that high without the column extended, I'd have to go to one of the larger models (larger than the 3531) and I don't really want to do that.
Old Oct 31, 2008 | 02:43 PM
  #122
waTSX's Avatar
Originally Posted by Billiam
The 2.5 pounds difference in weight doesn't sound like much but I personally think that's a huge difference if you ever plan on hiking with the setup. Also, I think if you get something that will suffice for your 70-200/2.8 IS, then I think that same setup should work equally well for a 300 prime.
Good point Billiam. The BH40 is suggested for the 300 f/4, but RRS suggests the BH55 for the f/2.8 due to handline concerns. I think I'm definitely going to want to hike with the setup at some point, so your info helps.
Old Oct 31, 2008 | 02:53 PM
  #123
waTSX's Avatar
Originally Posted by Dan Martin
The 3531 is overkill. It's really a 300mm f/2.8 or 500mm f/4 tripod.
I think the 2531 would be just about perfect for the needs you've mentioned. As billiam mentioned, you don't want to be carrying too much weight if you're going hiking. It's still easily going to support a 400mm f/5.6 or 300mm f/4 or 100-400. Take the money you'd save from the 3531/bh-55 combo and buy some other goodies that will make your life easier. Do you have a 2-axis bubble level for your hotshoe? How about a TC-80N3 timer remote or a Wimberley Plamp?
Dan that's awesome. Just the kind of input I needed. I was kind of getting that gut feeling about the 3531, but this helps me make the decision. I don't have any of the accessories you mentioned, but since the BH-40 doesn't come with a level, I like the idea of 2-axis level.
Thanks for the great suggestions!
Old Oct 31, 2008 | 03:43 PM
  #124
waTSX's Avatar
Alright, she's done. I just ordered the GT-2531, TC-80N3 timer and a 2-axis hotshoe level from B&H, and the BH40 ballhead with the lever release clamp and an L plate for my 40D direct from RRS. All of it should be here next week.
Thanks to Dan, Billiam, jupitersolo, wndrlst and hrj. All the input helped make the decision easier, and this particular decision was not easy, due to all the choices and the cost involved, and being unable to get my hands on this stuff before buying. All that said, I feel good about this purchase and that I significantly upgraded my support system.
There's a ton of photography websites out there, but I still come here for a lot of info. I think we've all been posting here long enough and seen enough of each others work that we at least know where each other is coming from.
Thanks again!
Old Oct 31, 2008 | 04:23 PM
  #125
jupitersolo's Avatar
nnInn
More money flowing into the economy, I think it's photogs that keep it going when times are slow. I know I'm doing my part.
Yes, this is a pretty kewl little corner that we have here.
When it comes to getting a tripod set up going, it's hard as hell. I know it took me months to figure of what I really wanted and even then I've made a change and will be making a couple more even though I didn't do it wrong the first. All I did was buy what Dan posted he bought, turned out pretty good.
Old Oct 31, 2008 | 04:30 PM
  #126
nnInn
Just got a RRS catalog in the mail.
Old Oct 31, 2008 | 05:33 PM
  #127
waTSX's Avatar
Lol! WWDD?! What would Dan do? Buying this tripod setup was harder by far than any other camera gear I've purchased. With lenses and bodies you usually have a pretty good idea what you want going in, or at least what you'dike to have.
Tripods are a whole different animal. A lot of choices and each setup has its compromises. After all this research, I've come to the conclusion that having two tripod setups is probably ideal, but that's for another time. I learned a lot (hey, I know the Gitzo model codes now!) and look forward to using the new rig.
And anything to help this economy. Glad to do my part!
Old Oct 31, 2008 | 05:35 PM
  #128
waTSX's Avatar
Sweet. So is a BH55 going to be on the way soon?
Old Oct 31, 2008 | 05:39 PM
  #129
wndrlst's Avatar
Earth-bound misfit
Congrats! Good choice! I really only experience any creep if I'm lazy. When I crank it down, there's no problem. I know it's just a spirit level that the BH40 has, but it's better than nothing. I've found it useful a time or 2, though honestly, I usually just go with my eye. I'm not a very technical shooter.
Great set-up!!
Old Oct 31, 2008 | 06:02 PM
  #130
waTSX's Avatar
Thanks 'lust! Casey at RRS says the BH 40 is guaranteed not to creep with the 70-200, so I always have that to fall back on!
I'm actually looking forward to using the remote release Dan talked me into buying also.
Old Oct 31, 2008 | 08:24 PM
  #131
Dan Martin's Avatar
Photography Nerd
That's going to be an awesome setup! Post pics when you get it.
Old Oct 31, 2008 | 09:18 PM
  #132
wndrlst's Avatar
Earth-bound misfit
Must hint at stocking stuffer....
I actually can't believe I still haven't bought one for my 40D. I had the IR & the cord remote for the XT. I suck.
Oh, and I fixed my legs tonight!
Last edited by wndrlst; Oct 31, 2008 at 09:19 PM. Reason: because maybe I don't suck...
Old Oct 31, 2008 | 09:49 PM
  #133
nnInn
Hold off before you do something, I have a Phottix Cleon that I won't really need soon. Hell really don't need now.
http://www.youtube.com/watch?v=ycPGfnndTZ4
Old Nov 1, 2008 | 01:03 AM
  #134
waTSX's Avatar
Will do!
Old Nov 1, 2008 | 01:16 AM
  #135
waTSX's Avatar
Sweet!
Old Nov 1, 2008 | 06:43 AM
  #136
wndrlst's Avatar
Earth-bound misfit
Sold! Let me know how much & I'll pick it up next photonerd dinner. Or whenever... The lens, too, if you've decided to sell.
Old Nov 1, 2008 | 07:52 AM
  #137
redmercer's Avatar
I bought a sunpark 6601 ut for $60 and it works great.
Old Nov 1, 2008 | 12:23 PM
  #138
stogie1020's Avatar
Needs more Lemon Pledge
You mean $30 right?
http://www.amazon.com/Sunpak-6601UT-.../dp/B00007E8D2
Old Nov 1, 2008 | 01:58 PM
  #139
hrj's Avatar
hrj
Congrats with the new combo, I'm sure you'll love them. It will be a joy using them on the field.
I use a similar setup, 2530 and Acratech GV2 w/ RRS quick lever-release clamp.
Old Nov 1, 2008 | 09:10 PM
  #140
JLatimer's Avatar
Creepy guy in the mirror.
I have a ghetto setup compared to everyone here.
Manfrotto 724B (simple ball head, no QR)
I recently added a 680B monopod with a 234RC QR head.
The best thing is that they were a really good price... Free
My bro-in-law works for a distributor and when returns come in broken they end up on a shelf and he builds complete units from the pieces on the shelf.
I really would like a better tripod head than what the 724 has, but I promised myself until I start taking more photos - no more spending $$$.
Old Nov 1, 2008 | 10:08 PM
  #141
stogie1020's Avatar
Manfrotto 190xprob - legs
Manfrotto 486RC4 - head
Old Nov 5, 2008 | 03:51 PM
  #142
waTSX's Avatar
Just an update, I received the RRS BH-40 yesterday and it is definitely one beautifully machined piece, and I'm confident that it will be perfect for my lenses. The L plate is sweet too and fits the 40D perfectly. It's going to be nice to be able to go to portrait orientation without flopping the camera over. It's an ingenious design that I will put to good use. I'm glad I chose this over their regular quick release plate.
The precision and clamping power of the ballhead blows my Manfrotto head away, and I could not budge it even with it just moderately tightened. The BH-55 must be an absolute monster. I'm already happy with this purchase and will be looking at other RRS products as I need them.
The Gitzo will be here tomorrow and I'll post pics of the whole setup then.
Old Nov 9, 2008 | 08:10 PM
  #143
waTSX's Avatar
As promised, here's a few quick and dirty shots of the Gitzo 2531 tripod and Really Right Stuff BH-40 ballhead I just purchased.The tripod is as advertised, beautifully made and light, and like I mentioned above, the RRS head is also extremely well made and has a precision feel I did not have in my previous Manfrotto head. The clamping power of the head is tremendous and the controls are easy to use. I also picked up the RRS L plate, which you see in the pics. This is a great piece of kit, and allows you to switch between portrait and landscape orientation without flopping the camera over. Awesome feature, which I look forward to using. I rarely did this with the Manfrotto because it made the whole rig unstable. It also has flanges which prevent the camera from rotating on the plate.
The tripod is also very solid, even with the center column up, and stands taller than my Manfrotto 3001 Pro, while being lighter. The Gitzo is also more solid with the center column extended, which is nice. It also sets up pretty quickly, even though the locks take a bit of getting used to after using the flip locks on the Manfrotto.
It is entirely possible that Gitzo tripods are over-priced, especially given brands like Feisol that are now on the market, but make no mistake, it lives up to its advanced billing.
I had been waffling on this set-up and a larger one, but after playing with this for a while, I'm very happy I went this route. No doubt the 3 series + BH-55 would have been more solid, but at the price of being more cumbersome and heavier. I think this rig strikes a nice balance. Thanks again to forum members for their input.
Fully extended with the center column down, 40D + EF-S 17-55 and RRS L plate:
Fully collapsed:
And the ballhead:
Old Nov 9, 2008 | 08:34 PM
  #144
Dan Martin's Avatar
Photography Nerd
Very nice kit... Now go get it dirty!
Old Nov 9, 2008 | 08:36 PM
  #145
waTSX's Avatar
Old Nov 9, 2008 | 08:52 PM
  #146
waTSX's Avatar
BTW, Dan, the lighting book is excellent also. Thanks for that recommendation.
Old Nov 9, 2008 | 09:17 PM
  #147
Dan Martin's Avatar
Photography Nerd
Oh good, I'm glad you like it. I'm going to read it a second time this week. It's time for a refresher.
Old Nov 10, 2008 | 06:21 AM
  #148
Billiam's Avatar
Big Block go VROOOM!
Looking good! If you're like me, you won't even bother attaching the tripod to your backpack. The setup is light enough that it's no big deal to just carry it.
BTW, I also have a print from Nicholas Watts. Good choice there as well.
Old Nov 10, 2008 | 09:19 AM
  #149
synth19's Avatar
I'm pretty happy with my Manfrotto 725B. Didn't break the bank either.
http://www.amazon.com/Manfrotto-725B...1582221&sr=1-2
Old Nov 10, 2008 | 09:36 AM
  #150
waTSX's Avatar
Lol. Yeah, I love that print. It's a flyer from the Monaco GP from about 7-8 years ago.
Old Nov 14, 2008 | 04:01 PM
  #151
nnInn
Got a GT3531 today, going tomorrow and see if I can get a Wimberley Gimbal Head for it.
Old Nov 14, 2008 | 05:14 PM
  #152
Dan Martin's Avatar
Photography Nerd
Sweet! Man, you're on a gear rampage these days.
I played with a GT3541 yesterday and I was surprised by how tall it was. The 4 section legs were still very stable, but I would buy the 3 section like you so it's faster to set up.
Old Nov 15, 2008 | 03:30 PM
  #153
nnInn
Yeah dropping the $$$, thankfully things are selling close to what I paid for them. In two cases more than. Got the gimbal, but they didn't have plates today.
Old Nov 15, 2008 | 05:17 PM
  #154
LKLD's Avatar
I've been Canonized ;)
I'm using a Manfrotto 055XPROB w/ an Amvona pistol grip. This has worked well for me.
Old Nov 16, 2008 | 12:03 PM
  #155
waTSX's Avatar
So, after all you said about being tall, you went with the 3531, which is actually 2 inches shorter than the 2531 with the column down. How is it now that you have it? And I'm guessing it's pretty much rock solid also?
Congrats BTW.
Old Nov 16, 2008 | 12:28 PM
  #156
nnInn
I needed the weight capacity, I wanted to go with a higher one, but this after the column is up with the gimbal, so be good enough.
Old Nov 16, 2008 | 12:34 PM
  #157
stogie1020's Avatar
What are the gimbal heads used for? Sports/Action shots with long lenses?
I was just reading about special head for Panoramic shots. This stuff gets complicated!
Old Nov 16, 2008 | 12:52 PM
  #158
nnInn
<object width="400" height="225"><param name="allowfullscreen" value="true" /><param name="allowscriptaccess" value="always" /><param name="movie" value="http://vimeo.com/moogaloop.swf?clip_id=2050875&amp;server=vimeo.com &amp;show_title=1&amp;show_byline=1&amp;show_portr ait=0&amp;color=&amp;fullscreen=1" /><embed src="http://vimeo.com/moogaloop.swf?clip_id=2050875&amp;server=vimeo.com &amp;show_title=1&amp;show_byline=1&amp;show_portr ait=0&amp;color=&amp;fullscreen=1" type="application/x-shockwave-flash" allowfullscreen="true" allowscriptaccess="always" width="400" height="225"></embed></object><br /><a href="http://vimeo.com/2050875">Demo of Wimberley Gimbal Head With Sigma 300-800 Lens</a> from <a href="http://vimeo.com/scottbourne">Scott Bourne</a> on <a href="http://vimeo.com">Vimeo</a>.
Old Dec 8, 2008 | 12:51 PM
  #159
nnInn
Well I sent the GT3531 back, I got a GT3541XLS. I know it's a four section tripod, but it's the perfect height when I don't extened the fourth leg. It's a level base, not center column. I'll feel better using it with the larger lenses and the gimbal head.
Old Dec 8, 2008 | 01:16 PM
  #160
waTSX's Avatar
Thanks for posting the vid on the Wimberly head. I'd never seen one used before. It looks massive, but perfect for shooting action subjects like sports, etc. I'm not sure how my BH-40 will do for that (or any ballhead), but I'll probably end up getting a good monopod for that.
How're you liking the BH-55 so far?
