Sony: News, Rumors and Discussion Thread
#842
Received 2,773 Likes
#843
That’s a sexy bitch, bout time Sony
#845
Don't update your A9, some glitches were found with the update.
Sony suspended the firmware update for the Sony A9: https://esupport.sony.com/. If you click on download this warning appears:
It was confirmed that some products that updated to Ver.3.00 may not operate properly in some cases.
Distribution will be suspended until we can inform you of modified version.
#846
Hmmm some high level A7SIII rumors
Source 1 (with a track of sharing 5 correct rumors out of 6)
4K HDR 60P
The sensor is Exmor RS
The number of pixels is unknown.
Sony is nervous about information leakage, it is difficult to obtain detailed specifications.
But according to sources, the A7S III is amazing, it is really amazing.
Source 2 (with a track of sharing 4 correct rumors out of 4)
The sensor of a7sIII would be new stacked CMOS sensor with integral memory
which means a7sIII would have 4KHDR/60P.
The sensor is technically superior to a9/fs sensor.
4K HDR 60P
#847
If this is gonna be a more video serious camera, sony is gonna need internal 10-bit 4:2:2 recording, Higher bit rates & Intra-frame compression?
XAVC-I?
XAVC-I?
#848
RX100 VA announced for the USA
Basicaly it's the RX100V with some updated stuff from the VI. Namely updated buffer, LSI and autofocus.
Sony US launched the new RX100VA in the USA:
Preorders: RX100VA at Bhphoto,
Press text via Explora:
Tweaking an already stellar pocket-sized camera, the Cyber-shot DSC-RX100 VA Digital Camera from Sony improves the existing RX100 V by increasing the buffer size to 233 images, reducing display lag time in the electronic viewfinder, and adding several small features over other aspects of the camera. With the 20.1MP 1″ Exmor RS BSI CMOS sensor, the RX100 VA can output detailed images at sensitivities up to ISO 12800. The Fast Hybrid AF system has 315 focal-plane phase-detection points that cover 65% of the image area of the sensor and can achieve focus in as little as 0.05 seconds. That autofocus system is also capable of tracking subjects across the frame, even while shooting at high speeds. Sony’s BIONZ X processor enables continuous shooting up to 24 fps with the aforementioned buffer size of 233 JPEG images and improved High Frame Rate recording times.
Like the RX100 V, the RX100 VA can shoot HD video at 960 fps in High Frame Rate Mode and UHD 4K video at 30/24 fps. But a new feature of the RX100 VA is dual video recording, where the camera simultaneously records two video files at once. Also carried over from the RX100 V is Gamma Display Assist, which provides a more contrasty image while using a flat S-Log2 gamma, and the Photo Capture mode for pulling 8.29MP stills from your movies.
The RX100 VA keeps the same physical design as the RX100 V to keep compatibility with all accessories. A Zeiss Vario-Sonnar T* lens still graces the front of the camera with an equivalent zoom range of 24-70mm and a fast f/1.8-2.8 maximum aperture that provides incredible flexibility in a wide range of shooting scenarios. A pop-up 0.39″ 2.36m-dot OLED Tru-Finder EVF and 3.0″ 1.23m-dot tilting LCD give you crystal clear previews of what you’re shooting. The RX100 VA also keeps the same lens control ring, built-in ND filter, and customizable buttons as its predecessor. It also has Wi-Fi and NFC capabilities for connecting to a smartphone.20.1MP 1″ Exmor RS CMOS Sensor & BIONZ X Image ProcessorThe 20.1MP 1″ Exmor RS CMOS sensor of the RX100 VA can deliver outstanding image quality at up to ISO 12800 with incredibly fast performance. This sensor stacks the pixel area, a high-speed signal processing circuit, and memory to increase data throughput by over five times and deliver features such as 40x super slow motion, an Anti-Distortion shutter, UHD 4K video, and more. The sensor also has focal-plane phase-detection AF points for faster, more precise focusing in as little as 0.05 seconds.
This sensor is paired with the BIONZ X image processor and front-end LSI that improves the speed and throughput of the entire imaging system, enabling continuous shooting with AF/AE at up to 24 fps. An expanded buffer makes continuous shooting possible for longer bursts, up to 233 JPEGs. The front-end LSI is also able to improve overall quality of the images, especially at higher sensitivities.
Zeiss Vario-Sonnar T* LensWith a 24-70mm equivalent zoom range, the integrated Zeiss Vario-Sonnar T* lens lends itself to a wide variety of shooting situations. The wide angle to short telephoto range is a favorite among photographers and it is further befitted by the bright aperture range of f/1.8-2.8. This enables solid low-light performance and excellent control over depth of field.Twoaspherical lens elements are incorporated into the lens design, minimizing chromatic aberrations and ensuring clear images. Zeiss’ premium multi-layered T* coating also reduces ghosts and flare caused by light reflecting.Fast Hybrid AF System with 315 Phase-Detection PointsThe RX100 VA is equipped with an on-sensor phase-detection AF system that provides increased autofocus speed for both stills and video. The camera uses a hybrid system with 315 phase-detection points that covers 65% of the frame along with a contrast-detection system to provide fast, accurate focusing in a range of situations. The RX100 VA also benefits from reduced blackout for easier tracking when using the EVF or LCD.UHD 4K Video RecordingThe RX100 VA is a video powerhouse, delivering up to 5-minute UHD 4K movies with exceptional clarity. By using a full pixel readout without binning, the camera collects about 1.7x the information needed for 4K output. Oversampling helps to increase clarity while reducing the effect of moire and jaggies. Fast Hybrid AF is available during movie shooting for ensuring accurate, fast tracking using phase-detection AF points. The camera also offers Sony’s advanced XAVC S format for recording a high bit rates up to 100 Mbps.
Picture profiles and image controls are also available, including the S-Log2 gamma that can help expand the dynamic range by recording a flat image. Gamma Display Assist helps users view a more natural image when shooting with S-Log2. Other options such as timecode, zebras, peaking, and more are present for making shooting and editing easier. When recording internally, users will record video with a 4:2:0 sampling at 8-bit, but the RX100 VA can output via HDMI to an external recorder. This allows users to capture 4:2:2 uncompressed video and save in an edit-ready format.The camera also has a Photo Capture function, which allows shooters to quickly save an 8.29MP still from their UHD 4K movies. Additionally, the camera is NTSC/PAL switchable, making it usable around the world.
High Frame Rate and Slow Motion ShootingSpeed is a huge advantage of the RX100 VA, and in video users will benefit from advanced High Frame Rate shooting and super slow motion. In Full HD, shooters will have access to a standard 120 fps setting that will enable outstanding slow motion when placed in an editing software. In addition to this, the camera also offers a dedicated HFR mode which will boost the cameras frame rate to up to 960 fps. Videographers will have the option of recording in Quality Priority and Shoot Time Priority modes, depending on preference. The camera will output a Full HD file from slightly lower resolutions to produce high quality images at all frame rates. Additionally, an end trigger mode enables users to record 4 or 6 seconds before the record button is pressed so the perfect moment isn’t missed.Body Design and Wi-Fi Connectivity
- Pop-up 0.39″ XGA OLED electronic viewfinder offers a resolution of 2.36m dots for crisp, clear imagery. The EVF also uses a Zeiss T* coating to ensure clarity from corner to corner.
- The rear 3.0″ Xtra Fine LCD screen can tilt upwards 180° and downwards 45° for shooting at different angles or for composing the perfect selfie. The screen sports a resolution of about 1.23m dots and WhiteMagic technology has been applied to the LCD’s design to increase effective brightness for easier viewing in bright lighting.
- A manual control ring surrounds the lens and features a smooth, click-less design for quick and quiet changing of settings. The ring can be assigned to control a variety of features, at different values, such as zoom, aperture, and Picture Effects.
- Custom button and other programmable buttons can be set to one of over 40 functions for quick access to commonly used settings.
- A built-in 3-stop neutral density (ND) filter is available to enable working in bright light with wider aperture settings.
- Pop-up flash will help illuminate subjects in dimly-lit scenes.
- A redesigned menu makes flipping through settings easier.
- Built-in Wi-Fi connectivity enables instant transferring of imagery to mobile devices for direct sharing online to social networking, via email, and to cloud storage sites. NFC (Near Field Communication) is also supported, which allows for one-touch connection between the camera and compatible mobile devices, with no complex set-up required. Once connected, the linked mobile device can also display a live view image on its screen and, using Smart Remote Control, remotely control the camera’s shutter release. Additionally, the RX100 VA can now connect to a smartphone using a QR code for faster access.
- Anti-Distortion electronic shutter can enable completely silent shooting as well as the ability to work at shutter speeds as fast as 1/32000 second. This shutter also keeps rolling shutter effects to an absolute minimum and enables photographers to work in bright light with wider apertures.
- Step Zoom lets you quickly change between five common focal lengths (24, 28, 35, 50, or 70mm) by rotating the control ring.
- Clear Image Zoom allows users to enlarge the center of the still or movie frame being shot by up to 5.8x equivalent when using optical zoom as well.
- Eye AF in AF-C mode will lock on and tack a subject’s eye, even as the face moves.
- Users can set a minimum shutter speed when using ISO AUTO to help minimize shutter blur.
- Creative Style settings: Standard, Vivid, Neutral, Clear, Deep, Light, Portrait, Landscape, Sunset, Night Scene, Autumn Leaves, Black & White, and Sepia (all with +/- 3 step contrast, saturation, and sharpness adjustment).
- Picture Effect modes: Posterization (Color, B&W), Pop Color, Retro Photo, Partial Color (R/G/B/Y), High Contrast Monochrome, Toy Camera, Soft High-Key, Soft Focus, HDR Painting, Rich-Tone Monochrome, Miniature, Watercolor, and Illustration.
- Adjustable Picture Profile parameters: Black level, Gamma (Movie, Still, Cine1-2, ITU709, ITU709 [800%], S-Log2), Black Gamma, Knee, Color Mode (Movie, Still, Cinema, Pro, ITU709 Matrix, White & Black, S-Gamut), Saturation, Color Phase, Color Depth, Detail, Copy, and Reset.
#849
From what I've read the auto pop out EVF from the VI wasn't added. The monitor doesn't tilt down 90°. No touch screen.
Also no HLG picture profile.
#850
Will be an announcement tomorrow.
SAR says it's likely just some new P&S cams
https://www.sony.com/electronics/ifa
#851
We told it to you yesterday and today Nokishita confirmed it: Tomorrow Sony will only announce two new fixed lens compact cameras, the DSC-HX 95 and the DSC-HX 99. Here are the specs:
- ZEISS Vario-Sonnar T * 24-720 mm zoom lens
- BIONZ X processor with front end LSI
- 4K video
- RAW compatible
- Tilt liquid crystal which can be taken by turning 180 degrees
- Improved grip
- Newly support “touch focus” and “touch shutter” (DSC-HX99)
- Overseas release date: September 2018
- DSC-HX 95: 499 euros
- DSC-HX 99: 519 euros
#852
Current rumor recap.
https://www.sonyalpharumors.com/sony...and-photoplus/
im curious about this high end APS-C camera and new APS-C lens
Before Photokina:
(SR3) Sony A7sIII with 4k60p, 10bit 4:2:2, 5.6 million dot EVF
(SR4) 24mm f/1.4 GM
(SR3) 135mm f/1.8 GM
(SR4) Sigma 70-200mm f/2.8 FE lens
(SR4) Sigma 50mm f/1.4 APS-C E-mount lens
(SR3) Zeiss fixed lens camera?
(SR4) Zeiss 40mm Batis
Before Photoplus (could be earlier too):
(SR4) New “mini-A9” High End APS-C E-mount camera. Not a direct A6500 successor but a new line! 4k60p and 20fps.
(SR3) New APS-C E-mount lens.
(SR4) 24mm f/1.4 GM
#853
Leaked pics of the DSC-HX 95/DSC-HX 99
nice that it's got a pop up EVF like the RX100.
actually looks similar to the RX100 series.
#854
I guess Sony didn't want to be left out of the fun.
they just announced a last minute (as in yesterday) they are having a press conference September 25th.
they also have 2 more scheduled. 1 on September 14th. The other around September 18th.
rumors are as follows:
higher end APSC camera - aka mini a9
A7Siii
24mm f1.4 GM
135mm f1.8 GM
APS-C e-mount lens
A7Siii
24mm f1.4 GM
135mm f1.8 GM
APS-C e-mount lens
is300eater (09-06-2018)
#855
#856
I see Apple likes Sony cameras
#857
Rumored announcement tomorrow between 8-10am PST.
Supposedly it will be a replacement of the A5100 but the body of the A6000.
#858
#859
Rumors recap (copied from SAR):
The upcoming weeks we expect multiple E-mount related announcements from both Sony and third party manufacturers. I made a list of Facts, Patents and Rumors about the future Sony and other third party gear:
Sony Cameras:
FACT: Sony registered a new RX0 camera model which should be announced within the next few months (article here)
FACT: Sony confirms professional APS-C cameras are on their roadmap (article here).
RUMOR: One more E-mount camera will be announced in Q1-Q2 (90% reliable – article here)
RUMOR: Sony A7sIII not going to hit the market in first half 2019 (70% reliable)
RUMOR: Sony 8k sensors and new codes specification (90% reliable – article here).
Sony Lenses:
PATENT: Sony patented new 100mm f/1.4, 135mm f/1.8, 500mm f/4.0 and 600mm f/4.0 FE lenses (article here and article here).
RUMOR: Next Sony E-mount lens announcement before the WPPI show in February (80% reliable – article here).
RUMOR: 135mm f/1.8 to be announced within Q1-Q2 (70% reliable)
RUMOR: New APS-C lens to be announced within Q1-Q2 (70% reliable)
RUMOR: New 35mm f/1.8 FE lens is on the roadmap (70% reliable – article here)
RUMOR: New 200-600mm FE lens is on the roadmap (50% reliable)
Third party lenses:
RUMOR: Tamron might announce a new 70-200mm f/2.8 FE lens within Q1-Q2 (50% reliable – article here)
RUMOR: Samyang FE autofocus lens announcement within the next weeks (90% reliable)
RUMOR: Sigma will soon be ready to launch their first FE zoom lenses (70% reliable)
RUMOR: Sigma will launch the first proper mirrorless designed FE lenses in 2019 (70% reliable)
RUMOR: Yongnou is working on the first FE autofocus lenses and some info might be spilled out in March (90% reliable – article here)
RUMOR: New 50mm f/1.0 FE lens being developed by a chinese manufacturer (90% reliable – article here)
One more thing:
PATENT: Sony patented a new drone camera (article here).
Sony Cameras:
Sony Lenses:
Third party lenses:
One more thing:
#860
#861
$1900; for a one point EIGHT?
#862
#863
#865
The A7RIII is crazy good. I didn't think it would be this much better than Canon. I am using the Sigma MC-11 adapter which works great with the Sigma lenses I have - I shot an entire fashion shoot with the 150-600 Sport and it did marvelous. Tried it with a few Canon lenses and the performance is noticeably not as good with focusing and such. And sometimes it just stops communicating with the lens. Next move will be to pickup a couple Sony mount lenses.
Mizouse (05-03-2019)
#866
My first Avatar....
#867
First time shooting an event with it over the weekend - dinner party type of fundraiser event - shot it with the Canon 85mm 1.8 and Sigma MC-11 - the thing was straight beast mode.
pttl (06-10-2019)
#868
at ISO 3200 which is a standard spec for indoor events - I don't even really *have* to apply any NR - I put on a little, but not really any need.
pttl (06-10-2019)
#869
FE 200-600mm f5.6-6.3 G OSS & FE 600mm f4 GM OSS announces.
https://www.sony.com/electronics/cam...ses/sel200600g
https://www.sony.com/electronics/cam...el600f40gm?SAR
#870
Ohh wtf... dammit whole post got edited.
#871
Great price on that 200-600 - I would have expected it to be much higher.
#872
My first Avatar....
Does anyone know if the RX100 VI cameras shoot RAW?
#873
I shoot people
#874
Announcement scheduled for July 17th.
Rumors are pointing to the following:
a6500 replacement.
FE 35mm f1.8
1-2 APSC lenses if the a6500 replacement is announced.
https://www.sonyalpharumors.com/sr5-...nt-on-july-17/
a6500 replacement.
FE 35mm f1.8
#875
It’s finally here.
FE 35mm f1.8 announced.
https://www.sony.co.uk/electronics/c...nses/sel35f18f
The compact dimensions and lightweight of this full-frame, large-aperture lens provide mobility and convenience for shooting a wide range of subjects, such as everyday snapshots, food photography, landscapes, night scenes and more. The new lens provides outstanding corner-to-corner image quality, while its quiet autofocus and tenacious tracking performance make it a great choice for both stills and movie shooting. Additionally, its compact form makes it an appealing choice for both APS-C body users, offering a 52.5mm equivalent focal length on APS-C cameras.
“Our E-mount lens lineup now includes 34 full-frame models and 52 lenses in total,” said Neal Manowitz, deputy president of Imaging Products and Solutions Americas at Sony Electronics. “The new 35mm prime combines outstanding corner-to-corner sharpness with a compact design, making it an ideal choice for a wide range of shooters. Sony will continue to develop and expand its imaging lineup, giving creators more options than ever before to realize their vision.”
Product Highlights:
High-resolution and large-aperture, full-frame performance in compact and lightweight lens
The FE 35mm F1.8 will ship in August 2019 for approximately $750 US and $800 CA and will be sold at a variety of Sony’s authorized dealers throughout North America.
Sony Electronics Boosts Full-frame Lens Line-up with Introduction of FE 35mm F1.8 Lightweight Prime
SAN DIEGO — July 9, 2019 — Sony Electronics Inc. today announced the latest addition to its E-mount full-frame lens line-up with the introduction of the FE 35mm F1.8 wide-angle prime lens, model SEL35F18F.The compact dimensions and lightweight of this full-frame, large-aperture lens provide mobility and convenience for shooting a wide range of subjects, such as everyday snapshots, food photography, landscapes, night scenes and more. The new lens provides outstanding corner-to-corner image quality, while its quiet autofocus and tenacious tracking performance make it a great choice for both stills and movie shooting. Additionally, its compact form makes it an appealing choice for both APS-C body users, offering a 52.5mm equivalent focal length on APS-C cameras.
Product Highlights:
- Large F1.8 maximum aperture, weighing in at just 280 grams and measuring 65.6 mm (diameter) by 73.0mm (length); this new lens sets a new standard for portability
- Advanced optical construction, including an aspherical element to suppress aberration and deliver high resolution throughout the entire image frame; 9-blade circular aperture enhances beautiful bokeh
- Minimum focus distance of 0.22m and maximum magnification of 0.24x offer easy access to the world of close-up photography
- Conveniently placed, customizable focus hold button and a focus mode switch for instantaneous switching between auto and manual focus
- Linear Response Manual Focus for fine, responsive manual focus control
- Dust- and moisture-resistant design add to the versatility and reliability of this new lens and invoke a feeling of confidence in the user
- Fast, precise and quiet linear-motor AF drive system for both stills and continuous focus control
#876
How is this different, other than being more expensive, than the FE 35mm 1.8 on the market today?
#877
I shoot people
Mizouse (07-09-2019)
#878
There has not been a FE 35mm f1.8 until now.
its the first FULL FRAME 35mm f1.8 for Sony by any manufacturer.
there have only been f1.4 and f2.8 lenses.
the 35mm f1.8 OSS I assume you are talking about is an APSC lens.
#879
Ah crap, I was thinking of the 2.8. Sorry guys, false alarm.
#880
New toys coming soon.
announcement scheduled for 10am EST on 7/16 or 7am PST.
supposed leaked pic of the new camera.
