Nikon issue new firmware for D40 and D80
![Exclamation](https://acurazine.com/forums/images/icons/icon4.gif)
Nikon has today issued firmware updates for the D40 and D80 digital SLRs. The D40 update contains a range of new features and fixes including issues with flash exposure and Auto ISO, the D80 update includes fixes for a retouching mode crash and improvements to long exposure NR. These updates can be downloaded and installed by owners.
just updated my d40 with no issues thus far.
Originally Posted by MrChad
what where the "new" features, Nikon never really said...
- The product will be "Certified for Windows Vista".
- Support for the new USB Media Transfer Protocol (MTP) has been added.
- The PTP option in the setup menu's USB item will be modified to MTP/PTP. The icon will also be modified.
- The range of possible settings for the Date option in the setup menu's World time item will be changed to 2000-2099.
- An issue that caused the ISO auto feature to be disabled, when a two-button reset operation was performed with ISO sensitivity set to any option other than ISO 200, has been resolved.
- When attempting to edit images, which had already been edited using a computer, with options in the D40's retouch menu, the camera sometimes froze. Therefore, images that have been edited using a computer can no longer be edited using the camera.
- An issue that prevented accurate recording of flash output value when manual flash photography was applied with use of the Nikon Speedlight SB-400 has been resolved so that flash output value is accurately recorded.
- Errors in English, Polish, Swedish, and Traditional Chinese menus have been corrected.
- When white balance is fine-tuned, "+" or "?" will be displayed with the following icons:
White balance mode icon in the shooting information display
White balance mode icon in the shooting menu.
- When the mode dial is set to a Digital Vari-Program and the AF-area mode setting is changed, the AF-area mode setting will no longer revert to the default setting when the camera is turned off.
- Monitor and exposure meters turn off automatically (auto meter off).
- The electronic analogue exposure displays will flash in the viewfinder and the shooting information display when:
The brightness of the subject exceeds the range that can be controlled by the camera, whether too bright or too dark;
While in P (Programmed Auto) exposure mode with the built-in flash raised.
and for the D80:
- The electronic analogue exposure display will be displayed in the viewfinder when the brightness of the subject exceeds the range that can be controlled by the camera, whether too bright or too dark, in the following shooting modes:
Shutter-priority auto (S) or Aperture-priority auto (A) exposure modes with the built-in flash up
Programmed auto (P) exposure mode.
- Effects of processing performed when the Long exp. NR item in the shooting menu is enabled have been improved.
- When attempting to edit images, which had already been edited using a computer, with options in the D80's retouch menu, the camera sometimes froze. Therefore, images that have been edited using a computer can no longer be edited using the camera.
snorf
11-04-2019 06:44 AM
visiter555
04-09-2016 12:56 PM
