Canon: News, Rumors and Discussion Thread
#1121
By late to the party I mean on some of those features. The 6Dmk1 is on par (in terms of feature set) with the A7mk1. I hope it ends up being good though, Canon really needs a win with this one. I had been waiting for the 6D2 forever before I switched to Sony, this has been a long time coming.
#1122
Received 2,773 Likes
Sooooon!
Canon EOS 6D Mark II Specifications (Google Translated)
Read more: More Detailed Specifications for the Canon EOS 6D Mark II
- Number of effective pixels: 26.2 million pixels (total number of pixels: 27.1 million pixels)
- DIGIC 7
- 45 points AF – All Crosstype
- Dual pixel CMOS AF
- 7560 pixels RGB + IR metering sensor
- Viewfinder: 98% coverage
- Viewfinder magnification: 0.71x
- Continuous: Up to 6.5 frames / sec (up to about 4 frames / sec when servo AF is set for Live View shooting)
- Standard ISO: 100 – 40000 (extended ISO: 50 [L], 51200 [H 1], 102400 [H 2])
- Shutter speed: 1/4000 to 30 seconds
- Sync Speed 1/180
- Video: Full HD 60p
- 5 Axis Electronic Image Stabilization
- Time lapse movie (4K output)
- Anti-flicker
- Wi-Fi
- Bluetooth
- NFC
- GPS
- Electronic level
- Battery: LP-E6N / LP-E6
- Number of pictures per charge: Approx. 1200 pictures (when viewfinder shooting)
- Media: SD / SDHC / SDXC card (UHS-I card compatible)
- Size: 144.0 x 110.5 x 74.8 mm
- Weight: 685 g (body only), 765 g (including battery and SD card)
- Kit lens: “EF 24-70mm f/4L IS USM”, “EF 24-105mm f/4L IS II USM”, “EF 24-105mm f/3.5-5.6 IS STM”
#1123
Bummer about 98% viewfinder.
was hoping for 100% since the 80D is 100%
#1124
wait, so it has 4K output for time lapse movie but not for regular??? Ok, that's very dumb. lol
#1125
My GoPro hero 4 silver is the same.
can't record video in 4K but it can generate 4K time lapse movies
timelapses are created with still images so it kind of makes sense
#1126
oh ok. buuuut if it has DIGIC 7 (5D4 has 6+) then wouldn't it indicate it has the horsepower to do full 4K video....
#1127
They're obviously not adding 4K so as to not hurt sales of their 5D4/C series cameras etc
#1128
For my use, I don't need nor care for 4K.
But yea that said, it's 2017. Even my iPhone can shoot in 4K
#1129
Rebel SL2 specs
Canon EOS Rebel SL2/200D/X8 (Google Translated)
Read more: Full Specifications for the Canon EOS Rebel SL2
- Number of effective pixels: 24.2 million pixels (Total number of pixels: 25.8 million pixels)
- DIGIC 7
- AF Points: 9 points – Center Cross-type
- VF Coverage: Approximately 95% up / down / left / right
- Viewfinder magnification: 0.87 times
- Back Liquid Crystal: Touch Panel Compatible Vari-angle Liquid Crystal (3.0 inch, 1.04 million dots)
- Continuous: Up to 5 frames / sec (up to about 3.5 frames / sec when servo AF is set for Live View shooting)
- Standard ISO: 100-25600 (extended ISO: 51200 [H])
- Shutter speed: 1/4000 to 30 seconds, Valve, strobe synchronization Maximum shutter speed 1/200 seconds
- Video: Full HD, 5 axis electronic image stabilization
- Wi-Fi
- Bluetooth
- NFC installed
- Battery: LP-E 17
- Images per charge: 840 pictures (when viewfinder shooting)
- Size: 122.4 x 92.6 x 69.8 mm
- Weight: 406 g (body only – black), 453 g (including battery and SD card), 407 g (body only – white), 409 g (body only – silver)
- UK price: 579 pounds body (black), 18-55mm III kit (black) 649 pounds, 18-55mm f/4-5.6 kit (black, white and silver) 679 pounds
#1130
Wow canon, really 9-point AF?
seems the same as the AF on the 20D which came out in 2004!
#1131
Pricing for 6D
body only price is $100 cheaper than when the 6D was announced
- Canon EOS 6D Mark II Body $1999
- Canon EOS 6D Mark II w/24-105 f/3.5-5.6 IS STM $2599
- Canon EOS 6D Mark II w/24-105mm f/4L IS II $3099
- Canon BG-E21 Battery Grip $300
#1132
Pricing for SL2
- Canon EOS Rebel SL2 Body $549
- Canon EOS Rebel SL2 w/18-55mm f/4-5.6 IS STM $699
#1133
Should be announced tonight.
Mizouse (06-29-2017)
#1135
From DPReview:
Read more: Canon EOS 6D Mark II Dynamic Range Talk & Sample Images
….it seems the benefits that appeared in the sensors used in the EOS 80D and EOS 5D IV have not been applied to the latest EOS 6D II, and the new camera has less dynamic range than we’ve become used to. Graphs plotted by regular DPR collaborator Bill Claff illustrate this pretty clearly. In this article, we’re taking a look at what this might mean for your images. Read the full test
#1136
Canon PowerShot G1 X Mark III Specifications:
- 24mp APS-C Sensor (The PowerShot G1 X Mark II was 1.5″ sensor)
- Dual Pixel AF
- DIGIC 7
- 24-120mm lens (35mm equivalent)
I wonder how pocketable the G1X is.
I was considering a Fuji X70 as an everyday carry camera. I like that the X70 has an APSC sensor and 28mm FF equivalent lens.
#1137
Assload of Tilt Shift lenses coming out and a 85mm f1.4 IS.
Canon EF 85mm f/1.4L IS USM Specifications (Google Translated)
Read more: Specifications & Images of the Upcoming Canon Lenses
- Lens construction: 10 groups 14 pieces (1 aspherical lens)
- Coating: ASC, fluorine coating
- Number of diaphragm blades: 9 (circular diaphragm)
- Shortest shooting distance: 85 cm
- Maximum shooting magnification: 0.12 times
- Filter diameter: 77 mm
- Maximum diameter × length: φ88.6 × 105.4 mm
- Weight: Approximately 950 g
- Image stabilization effect: about 4 steps
- Ring type USM
- Lens construction: 7 groups 11 pieces (2 UD lenses)
- Coating: SWC, fluorine coating
- Shortest shooting distance: 48.6 cm
- Maximum magnification: 0.5 times
- Filter diameter: 82 mm
- Maximum diameter × length: φ88.5 × 139.1 mm
- Weight: Approximately 1,110 g
- Lens construction: 9 groups 9 pieces (UD lens 1 piece)
- Minimum focusing distance: 39 cm
- Maximum diameter × length: φ86.9 × 116.5 mm
- Weight: Approximately 915 g
- Lens construction: 9 groups 12 pieces (2 UD lenses)
- Coating: SWC, ASC, fluorine coating
- Shortest shooting distance: 27.3 cm
- Maximum diameter × length: φ86.9 × 114.9 mm
- Weight: Approximately 945 g
#1138
Canon EOS M100 Specifications
Dual pixel CMOS AF
Video engine: DIGIC 7
ISO sensitivity: 100-25600
Continuous shooting performance: 6.1 frames / sec
Video: Full HD
Rear liquid crystal: 3.0 type tilt type touch panel monitor
Wi-Fi · Bluetooth installed
Recording medium: SD / SDHC / SDXC card
Battery: LP-E 12
Size: 108.2 × 67.1 × 35.1 mm
Weight: 302 g
An announcement looks to be coming next week.
Read more: Here is the Canon EOS M100 [CR3]
Dual pixel CMOS AF
Video: Full HD
Battery: LP-E 12
Weight: 302 g
#1139
Announced
EF 85mm f/1.4L IS USM: $1,599.00
TS-E 50mm f/2.8L Macro: $2,199.00
TS-E 90mm f/2.8L Macro: $2,199.00
TS-E 135mm f/4L Macro: $2,199.00
EOS M100 & EF-M 15-45mm f/3.5-6.3 IS STM lens: $599.00
EOS M100 & 15-45mm and EF-M 55-200mm f/4.5-6.3 IS STM lenses: $949.00
MT-26EX-RT Macro Twin Lite: $989.00
#1140
If I remember ill update with links
#1141
Does that new mirrorless take EF lenses? It'll be interesting to see how it compares with the A6000...
#1142
#1143
Did more reading, you're right. A6000 is going to kick it's ass even though it was introduced more than 3 years ago. This thing looks like a total afterthought and not really worth the R&D time to develop it.
#1144
Only thing going for the M100 is the touchscreen and that adapted canon EF glass will focus quick on it.
Ohh and I guess the price
#1145
Man the tilty flippy screen is nice
#1146
G1XMark III specs and leaked pics
Canon PowerShot G1 X Mark III (Google translated)
Read more: Images & Specifications For the Canon PowerShot G1 X Mark III
- APS-C CMOS sensor (22.3 x 14.9 mm)
- Lens: converted 24-72mm f/2.8-5.6
- DIGIC 7
- Full HD 60p
- Continuous shooting: about 9 frames / sec, servo AF about 7 frames / sec
- ISO speed: 100-25600
- Minimum shooting distance (from the lens tip): 10 cm (W), 30 cm (T)
- EVF: 0.39 type 2.36 million dots
- Back side liquid crystal: 3.0 type 1.04 million dot touch panel Bali angle angle liquid crystal
- Wi-Fi · Bluetooth · NFC installed
- Battery: NB-13L
- Number of storable pictures: 200 pictures, in eco mode 250 pictures
- Recording medium: SD / SDHC / SDXC card
- Size: 115.0 x 77.9 x 51.4 mm
- Weight: 375 g (body only), 399 g (including battery and SD card)
#1147
Rumored price is $1299
also still no 4K
also still no 4K
#1148
Images removed as they were fake.
#1149
Canon EOS M50 leaked images and specs.
EOS M50 Specifications: (Google Translated)
Read more: Leaked: Canon EOS M50 Image & Specifications
- 24.1 Megapixels APS-C CMOS (New sensor? EOS M5 is 24.2mp)
- DIGIC 8
- 4K Video
- Standard ISO: 100-25600 (extended ISO: 51200)
- Continuous: Up to 10 frames / sec (at servo AF: up to 7.4 frames / sec)
- EVF: 2.36 million dot organic EL
- 3 type 104 million dots Bali angle touch panel liquid crystal
- Supports the next-generation CR3 RAW format and the new C-RAW compression format
- The C-RAW format is 40% smaller in file size than conventional RAW, and it corresponds to in – camera RAW
- Development and digital lens optimizer
- The body is available in black or white
- Preorders start on February 27, 2018
- Pricing? We’ve been told it’s around the current EOS M6 prices.
- This is not a camera above the EOS M5.
#1150
Updated EOS M50 specs and new pics.
Here is a more detailed list of specifications for the Canon EOS M50 that we expect to be announced on February 26, 2018 in most places on earth.
Canon EOS M50 Specifications:
Read more: Canon EOS M50, More Images and Specifications
- DIGIC 8
- Dual pixel CMOS AF with greatly improved performance
- AF area is enlarged by about 38% with corresponding lens (100% vertical × 88% wide in live view image display range)
- The selectable AF point is a corresponding lens with a maximum of 143 points (99 points for non-compatible lenses)
- Pupil detection AF
- Dual Sensing IS
- Silent mode
- DLO in camera
- RAW development in camera
- Video: 4K 25p / 24p, FHD 60p, HD 120p
- Frame cutout from 4K movie is possible
- 5 Axis Electronic Image Stabilizer · Combination IS
- EVF: 0.39 type 2.36 million dot OLED
- 3 type 104 million dots vari angle touchscreen LCD
- Wireless remote controller BR-E1 compatible
- HDMI HDR output compatible
- The C – RAW format is 40% smaller in file size than conventional RAW, and it corresponds to in – camera RAW development and digital lens optimizer
- Battery: LP-E 12
- Size: 116.3 x 88.1 x 58.7 mm
- Weight: 387 g black, 390 g white (including battery and memory card)
- Color: Black / White
#1151
Man those specs look nice on paper! 4k 24p and FullHD 120p??!?!
pretty much a vloggers camera.
i wonder what codec they will use for 4k.
8bit 4:2:2 MJPEG like the 5D4,1DXII & 6D2 4k timelapse?
#1152
Some more specs
- Dual Sensing IS is a body- The information of the lens and the information of the gyro sensor of the lens are used to correct camera shake and improvement of the effect of 0.5 stops
- The new silent mode can shoot without any shutter sound
- Auto Improvement of lighting optimizer
- Improvement of high brightness side gradation priority function
- 4K / full HD time lapse function
- Microphone jack stereo microphone DM – E1 compatible
- Distance between moving subject and background Improvement of AF accuracy during tracking of moving subjects using information
- 2 Axis Electronic Level
- Supports HDR output from HDMI when playing RAW images
- Read more: Canon EOS M50, More Images and Specifications
#1153
Rumors say this camera sits below the M5 but above he M6.
That would mean the price is between $979.99 and $779.99. So... $879.99?
#1155
Yup and they work quite well.
I hear the 3rd party adapters work as well as the canon EF-EFM adapter which costs like $200
#1158
with mirrorless camera they don't have a mirror box, so the distance between the sensor and mirrorless lens can be much smaller.
what the adapter does is increase that distance back to what it would be if there was a mirrorbox.
The term is flange focal distance.
with canon EF & EF-S; the distance is 44mm
with canon EF-M (mirrorless lens) the distance is 18mm
so the adapter makes up that difference of 26mm
brian2 (02-22-2018)
#1160
