No time for new NSX or RWD but here's a Plane
#81
Originally posted by ClutchPerformer
LS430 (4.3L): 290 HP/320lb-ft, 18/25mpg, ULEV
LX470 (4.7L): 235HP/320lb-ft, 13/17mpg, LEV (the TSX is a LEV)
Note that these are the largest/heaviest vehicles these two engines are offered in. Others get better mileage numbers. I don't think those numbers are that bad. I certainly wouldn't call them "big gas guzzling V8s".
Honda would get a great "return on investment" if they made a V-8/RWD RL that competed with Lexus LS430 and Infiniti QX45 in more than just size. Until then, they'll be laughed at in the marketplace. "Almost as much power out of a V-6 (and not nearly as much torque)" might work in Japan, but it won't cut it with US consumers.
Honda might go to a front biased AWD system in future but most likely not RWD. Audi did the same thing at one point. They decided the over all costs weren't worth the return so they chose to stick with FWD and offer AWD.
#82
Originally posted by phile
Perhaps the part of Honda that is developing the jet does not adhere to the same "limitations" as the part of Honda that develops cars? I mean they make V8 engines for their racing cars too, so for them to say it's not cost effective does seem a little odd. But maybe that's only the case when you're talking about Honda automobiles.
#83
Originally posted by AcuraFan
.....Says you. You don't know how much it will cost Honda to develop such a platform, how much it would cost them to build new factories or retool existing ones.....,
You're not a accountant...you're only going on what you would like to see
#84
#85
Yes they are. All engines must adhere to the same emissions standards in grams of NOx, uHCs, and CO per unit time. They're not measured per displacement, or per power output, but in absolute terms. So these V-8s are exactly as clean as the Civic or 4-cylinder Accord with the same emissions ratings.
I will not argue about this.
#86
You're right. I don't know how much that will cost. But what I DO know is that this cost must be less than developing a platform, factory, and ALL-NEW tooling for a gas turbine engine, since they've never made anything remotely close to that before.
You're right on the first part, at least. I'm a mechanical engineer, but what I'm "going on" is what the arguments were that justified Honda not making a V-8 (cost) and what it will take to make a gas turbine (more cost).
#87
....And I think Honda decided the ROI on a Jet engine will be positive whereas the ROI on a RWD V8 would be negative or negligible
...but that's just an assumption.
#88
Yes they are. All engines must adhere to the same emissions standards in grams of NOx, uHCs, and CO per unit time. They're not measured per displacement, or per power output, but in absolute terms. That means that bigger engines which meet the same emissions standards are relatively cleaner than the smaller engines. So these V-8s are exactly as clean as the Civic or 4-cylinder Accord with the same emissions ratings.
http://www.epa.gov/greenvehicles/E-LEXUS-LS430-04.htm
An Acura MDX, also ULEV rated, is: 5.3-6.3 pounds of smog-forming pollution per 15,000 miles, 8 out of 10 in most states.
A Honda Accord 4-cylinder is rated at 0-1.0 pounds of smog-forming pollution per 15,000 miles, 8 out of 10 in most states.
How can you possibly say the Lexus LS430 is exactly as clean as the 4-cylinder Accord based on these numbers?
It even says on the epa site: "The emissions/air pollution score contains an absolute scale from 0-10 that can be used to compare all classes and model years of vehicles against each other. It is designed to give the most complete information in an easy-to-understand format."
This numerical rating is the rating that can be compared across all vehicles, not the ULEV or LEV ratings.
I'm not arguing, just pointing out some things that need clarification.
#89
I hope you can see that this statment is illogical.
So you're allowed to make assumptions and I'm not? That's unfair...:P
When did I say you can't make assumptions?
#90
... When did I say you can't make assumptions?
Says you. You don't know how much it will cost Honda to develop such a platform, how much it would cost them to build new factories or retool existing ones, how much they might lose in image, etc vs how much more they might make off this proposed platform. You're not a accountant...you're only going on what you would like to see...and that's not going to pay the corporate bills.
#91
Thats the key right there. US customers, which for the record comprise over 50% of Honda Auto sales. Wake up and smell the V8 fumes Honda !!!
#92
Well I still think that if Acura wants a model more expensive than the RL to compete with the Lexus LS430, Audi A8L, BMW 745 or M-B S430, they would need a V8. But I don't think the RL needs one, nor do any of the models in the Honda lineup, including the Pilot.
#94
The NSX is hard for me to say. One part of me wants it to be a V8, even a V12 just for bragging rights. But if Honda can make it a V6 and do 0-60 in under 4 seconds and handle like a surgeon's knife using lightweight body panels and frame, I'd rather have that.
#95
Thanks.
Thanks.
What I'm getting at is you seem to essentially be saying is: "they should make these changes because it's what people in the US want...and look, they're making airplanes, they have the money to do these thing." And all I'm saying is: "It's not about having the money it's about making the numbers work first." Honda has gotten to be the size they are by making the right decisions...I'll give them the benefit of the doubt here.
That's all.
#98
.... Honda has gotten to be the size they are by making the right decisions....
#99
Um....This will never happen. Sorry.
#100
You never know, Honda could do it with IMA for instance.
Originally posted by Colin
They make V-8s and V-10s because the formula requires it. This is the only reason. IRL (and CART before) require a V-8 in a purpose built race engine, and F-1 dictated that all engines will be N/A V-10 several years ago to help curb costs.
#101
Originally posted by EuphratesTheAlmighty
You know... I can't wait until every honda has IMA... and then every car has a problem with battery leaks, ruining the whole "green image".
#102
So why race in those formulas in the first place? Wouldn't it just be cheaper to make a bid to enter stock car racing?
As for Stock Cars, are you talking about Nascar? Do you know anything about Nascar? I'm certainly not a fan, so someone correct me if I'm wrong but ................
The cars are anything but stock, and if I remember correctly all the cars are using the SAME template now. This is to negate any aerodynamic advantage one manufacturer could gain by making a more aerodynamic car (I'm talking the real car that consumers buy). Nascar also requires that you have a OHV V-8 in production that you can use as a "basis" for the racing engine. The reality is that the engines are all purpose built racing engines BUT since Honda does not make a V-8 they cannot enter. I'm not sure if the requirement that your production engine be OHV still applies since I here Toyota wants to go Nascar and if memory serves me, none of their V-8s use OHV.
#103
OK, well apparently Honda has been researching the plane since 1986:
Honda has been researching compact business jets since 1986, when it began by using and studying the engines of other manufacturers. More than 15 years later, Honda has no jet on the market to show for itself. Only now, in the HondaJet, has it paired a Honda aircraft with a Honda engine--and the HondaJet is an experimental prototype with no production plans and only one test flight under its belt.
http://www.forbes.com/2003/12/23/cx_dl_1223vow.html
rockyboy
01-25-2016 06:00 PM
