McLaren: W1 News
McLaren: W1 News
https://www.netcarshow.com/mclaren/2025-w1/
The new McLaren W1 is the ground-breaking successor to two of the greatest supercars ever - the McLaren F1 and McLaren P1TM - and elevates the McLaren '1' car lineage to new heights in every aspect of performance.
The Ultimate expression of a real supercar, the new W1 has been created according to the McLaren ethos of class-leading performance, informed by the core principles that underpin every McLaren supercar: epic power applied through cutting-edge aerodynamics and lightweight chassis technologies; the highest levels of dynamic excellence and the purest driver connection; the perfect driver environment, for all driving situations; and awe-inspiring visual and aural drama.
All of McLaren's significant and renowned expertise in lightweight engineering and aerodynamic performance, inspired by years of racing innovation and the company's World Championship mindset, was applied to W1. The engineering team behind the new McLaren Ultimate model have between them contributed to 16 McLaren Formula 1 World Championship titles across driver and constructor categories. This expertise as part of a bigger team has resulted in the most focused supercar that McLaren has ever built, but also one with a huge breadth of capability.
McLaren W1 is a supercar for all occasions; more than any other McLaren, it is equally at home on road and track and as the fastest-lapping and fastest accelerating McLaren road-legal supercar yet, is exhilarating to drive whatever the circumstances.
The spine-tingling driver enjoyment ensured by the W1's revolutionary new high-downforce, low-drag, ground-effect aerodynamics design is further enhanced by the unique transformation process from Road mode to Race mode for track driving: W1's ride height lowers (by 37mm at the front and 17mm at the rear) and a heave system stiffens the suspension. Front and rear active wings are deployed, with the McLaren Active Long Tail extending rearwards by up to 300mm to assist in generating the 1,000kg of downforce available in W1.
The all-new MHP-8 4.0-litre twin-turbo V8 engine that debuts in W1 is coupled with a power-dense E-module to deliver scintillating speed. The epic power of this all-new 1275PS High-Performance Hybrid powertrain and McLaren's relentless dedication to lightweight engineering has resulted in levels of performance previously only attainable by track-only supercars and race cars.
Just as the W1 name celebrates McLaren's World Championship mindset, the date of the public reveal of the car was also chosen with this in mind: October 6th 2024 is the 50th anniversary of Emerson Fittipaldi sealing McLaren's first Formula 1 Drivers and Constructors World Championships.
Epic performance from V8 High-Performance Hybrid powertrain with pure RWD
At the heart of W1 is an all-new High-Performance Hybrid powertrain, comprising McLaren's all-new MHP-8 V8 combustion engine, an all-new E-module (integrating a radial flux electric motor and motor control unit), and an 8-speed transmission with E-reverse. Power and torque are to the rear wheels only, through an E-differential.
The 928PS of the new V8 and 347PS of the E-module combine to produce 1275PS, giving W1 the highest-ever power output of any McLaren and putting it above all core competitors. Engineered for epic power delivery and breathtaking performance, the powertrain combines with a vehicle weight of 1,399kg to deliver an astonishing power-to-weight ratio of 911PS/tonne for W1 - the highest-ever for any road-legal McLaren and more importantly, best-in-class.
This huge amount of power, together with total torque of 1340Nm and instant throttle response from the E-module, gives W1 astonishing acceleration figures: 0-100km/h takes 2.7 seconds, 0-200km/h (124mph) is possible in just 5.8 seconds and 0-300km/h (186mph) can be achieved in under 12.7 seconds.
McLaren has challenged convention by choosing to retain the purity of a rear-wheel-drive chassis in a car with this much power and torque, at a time when competitors are turning to front-wheel-drive assistance. Only McLaren could successfully achieve acceleration of this magnitude with dynamic performance to match in a rear-wheel-drive supercar, thanks to its extensive heritage in Formula 1 which exclusively deploys power through the rear wheels to reach the pinnacle of performance and ultimate steering precision.
McLaren's all-new MHP-8 flat plane crank 90-degree V8 engine is central to the delivery of the W1's epic power. Designed from the outset to be at the centre of the very best electrified powertrains, the twin-turbocharged 3,988cc unit has a lightweight block, cylinder heads and pistons in aluminium and showcases McLaren's expertise in engineering combustion engines that set new standards - for example, plasma spray coated cylinder bores are employed to allow engine speeds of up to 9,200rpm.
A 350bar Gasoline Direct Injection (GDI) system and port fuel injection extend the performance scope of the MHP-8 engine without adversely affecting emissions, enabling the highest-ever specific power output in a McLaren - a massive 233PS per litre.
The twin-scroll turbochargers in McLaren W1 are optimised to deliver higher peak power and torque than previous components, available throughout the rev range and improved response from as low as 2500rpm.
The exhaust features tubular manifolds that are engineered to maximise driver engagement as well as performance, with long, equal-length runners tuned to build sound to a crescendo as the engine speed approaches its 9,200rpm electronic rpm limit.
The motorsport-derived E-module that works in combination with the combustion engine is mounted to the side of the transmission and contributes up to 347PS. Comprising a radial flux E-motor and integrated Motor Control Unit - an engineering approach similar that taken in IndyCar racing - the E-module is a masterclass in maximising efficiency while minimising package volume and weight, The whole unit weighs just 20kg and further advantages include reducing coolant volume, low-voltage and high-voltage connections and seals. The sealed unit improves serviceability with a dry interface outside of the transmission unit.
The E-motor element is capable of spinning up to 24,000rpm has a specific output of 23PS/kg, which is directly comparable to Formula 1 E-motors.
The E-module is powered by a 1.384kWh battery, which together with the management unit and power distribution unit is enclosed on a structural carbon fibre floor housed within a cavity in the carbon fibre monocoque, located as low as possible to benefit vehicle centre of gravity.
The motorsport-derived battery cells are designed to prioritise high power outputs to the E-module, increasing throttle response and boosting overall power to the levels needed to deliver the eye-watering levels of performance that W1 reaches. Even with this focus on maximising power, the W1 can be driven in zero-emission, electric-only mode for up to 2km (1.6 miles).
The battery state of charge is managed to maintain a minimum level of charge to crank the engine on vehicle start-up, power for the reversing function and a reserve for when the car remains parked for extended periods.
In line with McLaren's commitment to minimising weight, the total weight of hybrid components has been reduced by 40kg compared to the McLaren P1TM while delivering almost double the electric power. Further weight is saved by the absence of engine ancillaries including the alternator, starter motor and additional pipework required for a conventional HVAC system.
Born from Formula 1-inspired ground-effect aerodynamics
McLaren has been synonymous with aerodynamic innovation and excellence since its very beginnings, with Bruce McLaren himself always determined to push for any advantage offered by new ways of managing airflow to balance lift and drag in the most efficient way possible. The 1967 championship-winning McLaren M6A Can-Am racecar employed ground effect aerodynamics with great success and while it was another decade before the technology came to Formula 1 - and the 1990s before the McLaren F1 showed how effective it could be in a road car - ground effect remains a significant advantage as part of an overall aerodynamic package for those car makers who can master it.
It is no surprise then that the new McLaren W1's striking design is defined by aerodynamic requirements, with McLaren's engineers focusing on combining the high downforce and low drag that ground-effect innovations provide to the foundations for the new Ultimate McLaren's extraordinary abilities.
The aerodynamic platform of McLaren W1 is the most advanced ever in a McLaren road car, the result of 350 hours of wind tunnel sessions with 5000 points tested. The concept begins with the Aerocell monocoque, which is shaped to facilitate full ground effect aerodynamics. Featuring integrated seating - which saves almost 70mm in wheelbase requirement - and raised footwells with an adjustable pedal box and steering to ensure the optimum driving position, the Aerocell is unique to W1, which also features the highest number of aerodynamic and active surface areas of any McLaren.
The Aerocell also incorporates fixings for McLaren's first-ever Anhedral doors. The decision to adopt this door concept was dictated by aerodynamic requirements demanding a door design that is hinged only from the roof. In conjunction with the reduced-size side window drop glass, the McLaren Anhedral Door allows optimisation of airflow from the front wheel arches into the high temperature radiators, providing extra cooling space that allows the size of the radiators required to cool the powertrain to be reduced, optimising packaging and saving weight. The fact that the door shape is reminiscent of the bodyside of the McLaren MCL38 Formula 1 car is also a neat visual signature.
The W1 builds on the Formula 1-inspired aerodynamic innovation that first distinguished the McLaren P1TM from its competition and has been honed in subsequent McLaren cars. The attention to aerodynamic requirements in W1 even extends to the powertrain, which is inclined by 3 degrees to accommodate the car's high-downforce rear diffuser.
The key to W1's duality of dynamic character - offering a sublime driving experience on road and track alike - is McLaren Race mode. When deployed, this engages shape-shifting aerodynamic technologies to enable world-best, radical 'road to track' character transformation. Uniquely in W1, much of the downforce is achieved using all of the underbody for ground effect, with this maximised when Race mode is selected.
The lowering of ride height - by 37mm at the front and 17mm at the rear - and deployment of active front and rear wings is not just theatre: in Race mode W1 is capable of generating up to 350kg of downforce at the front and 650kg at the rear, giving total downforce of up to 1000kg in high-speed corners.
The active front and rear wings and a roof-mounted air flow diverter W1 are among the most advanced aerodynamic features ever in a road-legal McLaren. The revolutionary McLaren Active Long Tail rear wing - arguably visually the single most dramatic element of the new W1 - is absolutely integral to the aerodynamic performance of the car. McLaren's first association with a 'longtail' name dates back to the 1997 F1 GTR, but in the case of this new Active Long Tail wing it is an essential part of the strategy for management of drag, lift and downforce.
Actuated by four E-motors and moving up, down, and - depending on whether the W1 is in Road mode or Race mode - also 300mm rearwards and adjusting in pitch, the McLaren Active Long Tail extends the working area of the rear diffuser in Race mode and is key to the generation of downforce. It also operates in DRS and airbrake configurations as required to help optimise aerodynamic balance.
The front wing is actuated by two E-motors and swings through an arc to create a full-width lower frontal area, feeding air under the car in Race mode via a Formula 1-style T-tray and keel. The two wings work in conjunction with each other and other elements of the design to allow fast and accurate management of aerodynamic requirements.
For road driving the Active Long Tail wing sits over the rear bodywork and front and rear wing deployment is optimised for this environment, with the front wing sitting higher at low speeds to avoid damage from speed bumps. W1's vehicle lift system further reduces this risk.
The design of the front suspension also contributes to aerodynamic efficiency, with the lower wishbones of the pushrod and inboard damper system raised significantly to keep the channel of air flowing cleanly towards the rear of the car. Other components have an optimised aerodynamic profile to further assist. Conditioning airflow at the rear of the car is less of a priority since the diffuser manages this function, meaning outboard springs and dampers are the optimum solution.
Dynamic genius without compromise, driven by McLaren DNA
McLaren's philosophy of Lightweight Engineering and the use of bespoke carbon fibre structures deliver a vehicle lightest dry weight of just 1,399kg for McLaren W1, which is key to the requirement for outstanding performance, everywhere - whether on road or on track.
The all-new McLaren Race Active Chassis Control III suspension with McLaren Race mode ensures huge breadth of capability, from road-legal compliance to fastest lap performance and pure driver connection.
The Comfort handling setting gives the occupants a smooth ride quality with increased body control at medium and high speeds, while Sport provides a more engaging, connected setup with focus on body control and agility at all speeds. When Race mode is selected a stable aerodynamic platform is prioritised, with an active heave element deployed for superior track dynamics and consistent downforce.
McLaren W1's suspension system works in combination with the front and rear active aero features integrated into a unique underfloor design delivering ground affect aerodynamics. This allows the required levels of load and grip to deploy the torque through the driven axle, mitigating the need for all-wheel-drive and therefore the additional weight required on the front axle. The ability to manage such a high level of torque on rear axle only is a key enabler to preserve McLaren's best-in-class McLaren Hydraulic Performance Steering feedback and feel on the front axle.
Continuing the Formula 1 influence, the front suspension setup also includes titanium torsion bars and an active heave element crosslink, while the rear has a Z-bar with active droplinks to control heave. In the relentless pursuit of light weight, 3D printing was used for the front uprights and wishbones of the advanced suspension system.
Braking on W1 is a further advance on McLaren's renowned high-performance hydraulic system, enhanced to meet the differing demands of flawless road and track response and feel while delivering Ultimate stopping power. W1 will come to a standstill from 100km/h in 29 metres and from 200km/h in just 100 metres.
The front brakes are activated with 6-piston calipers and the rear by 4-piston calipers, both of a forged monobloc design. The 390mm discs in the McLaren Carbon Ceramic Racing+ (MCCR+) system are unique to W1, featuring an additional ceramic layer compared to previous carbon ceramic discs. This provides greater durability while allowing for a more aggressive brake pad and higher friction levels to further increase braking efficiency.
Brake performance is further optimised with aerodynamic features to keep the system cool. Directly inspired by Formula 1-style ducts, these have been designed to also increase downforce and radiator cooling by managing the wake of the tyres, while the brake lines have been routed to minimise airflow disruption under the car.
The electronic parking brake is integrated on the rear calipers, saving weight while at the same time improving component stiffness.
The fastest lapping and fastest accelerating road-legal McLaren ever
Bettering even the super-lightweight and track-focused McLaren Senna - by an astonishing 3 seconds a lap at McLaren's Nardo reference circuit - W1 is also the fastest accelerating road-legal McLaren ever. Hugely impressive in isolation, these two parameters are even more incredible when you consider that you need both high downforce and very low drag to achieve them.
Inspired by the work of generations of Formula 1 Race Engineers, McLaren's Race mode gives a choice of two suspension settings - Race and Race+, with the latter being the firmest available. This allows drivers to select settings according to whether they are on undulating, bumpy tracks where consistent aerodynamic downforce is needed, or flat, smooth surfaces on which the ground effect platform is optimised.
Powertrain options in Race mode are a 'GP' setting for consistency over a longer track session, or 'Sprint' for maximum performance and E-module deployment over one lap. Two buttons on the steering wheel, ergonomically positioned within easy reach of the driver's thumbs, give the driver further options: 'Boost' instantly deploys full E-module power available - the same principle as employed in Formula 1 - to give the driver everything for overtaking on track or additional speed out of corners as desired. This can be combined with the Aero button for an on-demand Drag Reduction System (DRS) effect from the rear McLaren Active Long Tail wing.
Tyre performance is intrinsic to mechanical and aerodynamic grip and McLaren W1 features three 265/35 front and 335/30 rear tyre options from McLaren's technical partner, Pirelli. To fit the car's extreme requirements, the Pirelli P ZEROTM Trofeo RS road legal track tyre is the standard fitment. The tyre has a compound specially developed to maintain the highest performance and consistent grip over a track session. Pirelli P ZEROTM R and Pirelli P ZEROTM Winter 2 tyres - again both bespoke to W1 - are also available, the former being a road-focused solution and the latter delivering outstanding cold weather performance.
The perfect supercar driving environment
The excitement of driving W1 begins with the McLaren Anhedral Doors opening upwards to reveal recesses in the roof and the front lower opening that help to provide access to the innovative and comfortable cabin. The doors also feature a sculpted concave section on the inside to maximise occupant space.
As is core to the McLaren DNA, W1 has unmatched supercar ergonomics and best-in-class visibility, with remarkably spacious cockpit room for both driver and passenger. Glazed sections in the rear three-quarter view and optionally in the upper doors provide an airy feel to the interior. Forward vision is exceptional, with the W1 incorporating McLaren's narrowest A-pillars yet. Even the sun visors are designed with lightweighting in mind; made from carbon fibre, they are just 3mm thick.
Seating is uniquely integrated into the McLaren Aerocell carbon fibre monocoque, directly connecting the driver - and passenger - to the chassis. Both seats are fully upholstered for optimal support and comfort and provide a driving position that is more reclined than usual, with a high level of thigh support.
The pedals, steering wheel and primary controls move to fully embrace the driver within the cockpit environment, with a perfect driving position easily found by adjusting the floor-mounted aluminium pedals, which have a unique adjustment action. The unique-to-W1 wheel is smaller and flatter than previous McLaren steering wheel designs. Integral shift lights that prompt the driver to select the next gear as the 9,200rpm redline approaches, are optionally available.
True to the McLaren supercar principle of a pure driver-focused interface, the only two buttons on the steering wheel are Boost and McLaren Aero Deployment controls. Inspired by Formula 1, these have been ergonomically designed to be easy to reach and activate by the driver moving their thumbs and not their hands from the wheel.
Chassis and powertrain modes are adjusted via rocker controls on the instrument binnacle, which moves with the steering column to allow mode adjustments within easy reach of the wheel. The W1's driver display has been engineered to ensure the full screen remains visible to the driver despite the smaller steering wheel and even doubles as an aerodynamic flow diverter for air from the compact HVAC system - which efficiently provides cool or warm air as desired in all driving modes, including EV-only operation.
Further theatre is provided by overhead start/stop, gear selection and Race mode switchgear together with the window controls. These are housed by the digital rear-view display; designed to resemble a conventional rear-view mirror for driver familiarity, the camera position and angle is deliberately placed to discreetly display a small section of the Active Long Tail wing in order to give context and perspective to the driver's rear view to ease vehicle positioning in traffic and low-speed manoeuvring including parking.
Further information and adjustments can be found on the high resolution 8" touch screen McLaren Infotainment System (MIS II) located between the driver and passenger. This has Apple CarPlay with USB C connectivity, with USB A also provided for device charging and storage access.
Between the fixed seats there is a storage area with a sliding cupholder, while there is a second area for small items behind the armrest. The W1 also has a luggage stowage shelf behind the seats, accessible by moving the headrests, which fold flat forwards to provide a loading platform. With up to 117 litres of storage space, two weekend bags or two crash helmets can be accommodated.
Visually arresting engineering
McLaren's Performance by Design strategic approach centres on the five key principles of McLaren's design DNA - Epic, Athletic, Functional, Focused and Intelligent - and the new W1 clearly meets this brief. The heavily sculpted form - with almost every panel made from carbon fibre - is immediately recognisable as a McLaren supercar and a bold visual demonstration of the W1's duality of character, the smooth, flowing upper surface contrasting with the extreme and uncompromising ground effect underbody.
The front aspect of McLaren W1 showcases its aerodynamic brilliance, with a large amount of lower bodywork layering designed to condition the flow of air towards aerodynamic surfaces heading towards the rear of the car. The upper nose section features intakes around the lights and upper wheelarches, with a large single nostril in the centre of the bonnet. At the rear of this is an aerodynamic blade that lifts to reveal the EVSE charging port, brake and washer fluid reservoirs. Visible carbon fibre aerodynamic structures and exposed suspension components are also a theme that echoes throughout the car.
The side aspect of W1 is influenced by Formula 1 sidepod design, with a wide cut-out for the convex-shaped door that creates space for air to exit the front wheel arch via two outlets - through which the front suspension arms can be seen - and two large intakes ahead of the rear section. The most prominent of these, which feeds the high temperature radiators, is triangular in shape and provides an undercut in which the second intake is located ahead of the rear wheel and features a channel that feeds the rear diffuser and brake ducts. Even the side mirrors have been designed with aerodynamics in mind; they are placed as far outboard as possible on a support blade and are shaped to direct their wake away from the rear of the car so as not to disrupt efficiency of the radiators or the Active Long Tail wing.
The heavily-haunched rear bodywork includes an intricately detailed engine cover that sits below the flow diverter, which also houses the shark fin audio and navigation antennae and sits above and forward of the central stop light and rear-view camera. This directs clean air towards the twin-element Active Long Tail wing, which sits above the large twin centre-exit exhaust. Completing the muscular rear section is the prominent multi-fenced rear diffuser.
Seen from above, McLaren W1's form is remarkably clean for an aerodynamically-led design, with a pronounced hammerhead-shaped nose and tight teardrop cabin form, which then opens up to the McLaren Active Long Tail wing. This is contrast to the strikingly complex lower bodywork, which is intentionally detailed to fully optimise ground effect.
Exceptionally individual and uniquely desirable
Virtually unlimited bespoke personalisation is available through McLaren Special Operations, giving owners freedom to create their very own unique supercar. A range of luxury and innovative interior materials are available, including the world-first use of McLaren InnoKnit, an infinitely flexible and super-lightweight material tailored to seamlessly integrate interior surfaces and components. This material is knitted to fit, removing any wasteful cutting or sewing requirements.
InnoKnit can be tailored to many and multiple colours, textures and shapes with precision patterns and has also been integrated into audio and visual elements, with the use of graphic elements to diffuse and project ambient cabin lighting. The material can also be incorporated into the speaker grilles of the W1's high-specification Bowers & Wilkins bespoke audio system.
The McLaren W1's exterior details, including the use light and dark body surfaces partly inspired by its aerodynamic styling but also current Formula 1 livery design, also creates limitless opportunities for customers to personalise their own car with McLaren Special Operations (MSO) using visualisation tools including virtual reality and augmented reality to create their own unique W1.
Epic performance
The W1 features the McLaren High-performance powertrain with an all-new V8 engine, E-module unit and transmission designed for epic performance. McLaren's relentless approach to light weight engineering has produced a system that is power-dense, contributing to W1's astonishing output and power-to-weight ratio.
The combined output of the HPH powertrain is 1275PS and 1340Nm, with instant throttle response from the torque of the E-module. This translates to 0-200km/h (186mph) in 5.8 seconds and 0-300km/h in under 12.7 seconds. W1 is also capable of zero-emissions driving on electric power alone.
The attention to aerodynamic requirements in W1 extends to the powertrain, which is inclined by 3 degrees to accommodate the rear diffuser. A key focus of the powertrain development programme has been optimising cooling requirements with the aerodynamic concept of the vehicle to deliver sustained, high-performance in track conditions. The car runs three separate water glycol circuits running at different temperatures: a high temperature circuit cools the engine with four radiators, two at the front and two in the middle of the car. A low temperature circuit is used for charge cooling for maximum performance with the front centrally-mounted radiator. A dedicated hybrid cooling circuit is used to cool the E-module, high voltage battery, charger and DC/DC converter. The transmission is cooled by a thermostatically-controlled oil-to-air radiator for maximum cooling on track. Including HVAC, engine oil cooling and battery dielectric cooling a total of 10 heat exchangers are used in the cooling system.
W1's Powertrain modes have been set up to optimise driving in all environments. In addition to an Electric mode for near-silent EV running, Comfort mode - default on startup - provides relaxed cruising for town and motorway driving using the E-module for torque infill only. In Sport mode, the E-module is fully deployed for full hybrid power with ignition cut gear shifts and a more engaging throttle response. Race mode offers a Sprint setting for maximum power from the E-module and combustion engine, while Grand Prix focuses on consistent performance over a whole track session, balancing E-module deployment and harvesting.
The fact that the new McLaren W1 is rear-wheel drive-only when such astonishing levels of power and torque are available is tribute to McLaren's incredible heritage in racing, where successfully developing vehicle platforms able to deploy large amounts of torque to the rear axle is essential. At a time when competitors are turning to front-wheel-drive assistance, McLaren's Formula 1 knowledge and expertise - in combination with meticulous engineering attention to lightweighting, weight distribution and finely tuned vehicle dimensions and kinematics - provided the competitive advantage to deliver the rear-wheel drive solution that is true to supercar principles and only McLaren could deliver.
All-new, next generation V8 engine
The McLaren W1 debuts the all-new 4.0-litre twin-turbo flat plane crank V8 engine that will, alongside the M630 V6, power the next generation of McLaren hybrid supercars. Like the V6, it has been designed to be extremely power-dense and is capable of much higher outputs than the previous generation M840T.
The McLaren designed MPH-8 90-degree V8 has a lightweight aluminium engine block, cylinder heads and pistons. It features direct injection with fuel port injection and spray plasma coated bores, which at 92mm, allow higher engine speeds, with a stroke of 75mm for a total capacity of 3,988cc.
In extending the engine speed range, valve actuation uses sliding finger followers with a Diamond-Like-Carbon (DLC) coating. To reduce the loads in the system the new engine also uses hollow intake valves enabling the use of a lighter, single valve spring per valve arrangement in addition to sodium cooled hollow exhaust valves.
Due to the higher speeds and loads of the all-new engine, a novel approach has been taken for the crankshaft torsional damper. Unlike conventional road car engines that use external dampers, the new V8 has an internal viscous damper where the viscous fluid is actively oil cooled through a labyrinth cooling channel.
Lubrication is through an electronically controlled variable displacement vane oil pump. The dry sump is scavenged by a four-stage pump that uses gerotors rather than gear pumps for improved mechanical refinement. The scavenge pump feeds an oil tank which has been specifically developed for the extreme G-loads that W1 can generate.
As a result the engine is capable of revving to 9,200 RPM - more than any previous road-legal McLaren - generating 928PS, a specific output of more than 233PS per litre. Total combustion output alone is an astonishing 103PS more than the McLaren Senna GTR, which is the most powerful application for the previous-generation M840T V8. A wide band of torque peaks at 900Nm as the power builds to a crescendo approaching the 9,200 RPM redline. Despite the higher output, the MPH-8 is also marginally lighter than the M840T series and 55mm shorter.
The exhaust manifold feeds large capacity twin-scroll turbochargers. The turbine and compressor have been optimised to deliver higher peak power and a significant increase in torque throughout the speed range compared to the M840T. Up to 30% greater torque is available giving instant response from as low as 2500rpm. The compressors feed the engine through charge coolers, with low-volume intake manifolds connected directly to the intake ports to maximise performance and transient response.
E-module and battery
The all-new V8 engine has also been designed from the outset to be centre of the very best electrified powertrains and W1's E-module has been designed to boost power and torque and provide acceleration and response times appropriate to the V8's extremely high output.
W1 uses a motorsport-derived E-module mounted to the side of the transmission that contributes up to 347PS. The E-module consists of a radial flux E-Motor capable of spinning up to 24,000rpm with a specific output of 23PS/kg, which is directly comparable to Formula 1 E-motors. This is combined with an integrated Silicon Carbide Motor Control Unit (MCU), which converts the high-voltage DC current of the battery to AC current. Combining the two units maximises efficiency and minimises package volume and weight; the whole unit weighs just 20kg. Further advantages include reducing coolant volume, low-voltage and high-voltage connections and seals. The sealed unit improves serviceability with a dry interface outside of the transmission unit.
The E-module is powered by a 1.384kWh battery, which is conditioned using second-generation dielectric immersion cooling, transferring heat into the dedicated electric drive cooling circuit through a heat exchanger for increased cooling during sustained track running. The battery, management unit and power distribution unit is enclosed within a fireproof cover and mounted on a structural carbon fibre floor. It is housed within a cavity built into the carbon fibre monocoque - located as low as possible to benefit centre of gravity - and is further shielded from impact by the engine, transmission and rear structure.
The battery cells are also motorsport-derived and specifically designed to prioritise high power outputs to the E-module to increase throttle response and boost overall power.
The battery state of charge is managed to maintain a minimum level of charge to crank the engine on vehicle start-up, power for the reversing function and a reserve for when the car remains parked for extended periods. McLaren W1 has an onboard charger that supports EVSE connection, allowing the battery to be replenished to 80% in just 22 minutes.
The total weight of hybrid components has been reduced by 40kg compared to the McLaren P1TM while delivering almost double the electric power. Further weight is also saved by the reduction of engine ancillaries including the alternator, starter motor and additional pipework required for a conventional HVAC system.
All-new eight-speed transmission
The W1's transmission is an all-new 8-speed DCT with a much higher torque capacity than previous McLaren transmission systems. The E-module torque is fed into the transmission downstream of the clutches allowing the W1 to deliver combined torque from the V8 engine and E-module of 1340Nm at the input shaft.
The hybrid power is transmitted via an all-new hydraulic E-differential to the rear wheels for heightened driver involvement. The purity of driver connection from rear-wheel drive has long been recognised as one of the principles of supercar engineering, the benefits to vehicle balance under power which the driver can adjust to influence lateral movement. In conjunction with McLaren Hydraulic Performance Steering uncorrupted by driven wheels, this allows drivers to fully engage with their car to bring maximum enjoyment, on track or on road.
With McLaren W1's powertrain delivering 1275PS, the level of sophistication in the transmission, the suspension system, the steering, the brakes and the tyres needed to be equal to this epic power delivery. And while drivers have the option to disengage electronic controls, the levels of precision and freedom these simultaneously offer is testament to the expertise McLaren has brought to W1. Acceleration from standstill to 200km/h in just 5.8 seconds in a rear-wheel drive only supercar - the most powerful in its class against core competitors - is simply astonishing.
The W1 builds on the Formula 1-inspired aerodynamic innovation that first distinguished the McLaren P1TM from its competition and continued with subsequent Ultimate models and supercars. While the McLaren P1 TM race mode was designed to maximise downforce, the W1 takes this to the next level, using the most active surface areas of any McLaren and full ground effect to transform into a track-only supercar at the touch of a button.
The W1's Race mode allows the vehicle to be more capable on track than any other road-legal performance car but without the compromises associated with track-capable supercars.
The W1 is capable of running a stiffer spring and damping setup in Race mode, with ride height also lowered substantially - by 37mm at the front and 17mm at the rear - to take full advantage of the chassis' inbuilt ground effect aerodynamics. But the most dramatic - and effective - feature is the active aerodynamics. The centre portion of the front wing feeds air downstream of the car up to the keel, whilst the outboard sections of the front wing generate front downforce.
Under braking, the front wing deploys to reduce front downforce by backing off the outboard sections while protecting brake cooling. The centre line sees a reduction of air further reducing front downforce to shift the aero balance rearward providing braking stability. At the rear, the McLaren Active Long Tail wing is capable of moving 300mm rearward to extend the working area of the diffuser, generating up to five times more downforce than in road configuration.
The McLaren W1's front wing has a level of performance comparable to rear wing on most supercars and activates through an arc to trim downforce to balance the car, reduce the stall effect in order to optimise powertrain cooling or simply working with the vehicle lift to aid ground clearance. At its most extreme in Race mode, it works as a full width wing to maximise front downforce.
The frontal area of the car also contains a variety of air intakes designed to condition the flow of air for cooling and aerodynamic effect to the rear of the vehicle. The front of the chassis is raised to optimise this airflow with the inboard front suspension - which includes a high-mounted aerodynamically-shaped lower suspension wishbone - helping to guide air. The monocoque features a narrow waist and in combination with a Formula 1-inspired underfloor T-Tray and keel, air is directed to the rear surfaces. The latter also generates vortices that are conditioned to control the wake from the front wheels, pushing this out from the underfloor airflow.
The structural rear diffuser is the most extreme to be incorporated in a McLaren road car and begins to curve upward - expanding the air to create downforce - from behind the cabin section and ahead of the rear axle line. In order to accommodate this large element, the powertrain has been inclined by 3 degrees and the high temperature radiators and rear lower suspension wishbones have been raised to accommodate the underfloor space. The diffuser itself is shrink-wrapped to the powertrain and intricately detailed with prominent fences, working with the Active Long Tail wing to maximise downforce.
The Active Long Tail wing is aided by a roof-mounted flow diverter device that controls air to the rear of the car, keeping it connected to the rear deck and wing. This allows the Active Long Tail wing to work at a lower height, reducing aerodynamic drag and, in Race mode, to extend the diffuser effect. In this mode it moves 300mm rearwards through a 180-degree arc; in this position the wing leading edge sits behind the diffuser trailing edge effectively becoming an extension of the underbody. The added benefit relative to a conventional high mounted wing is that instead of the rear bodywork being lifted by the wing's suction effect, it is now being pushed down due to stagnation of the air on the upper surface of the wing. Another first for a McLaren car is the use of E-motors on the active front and rear wings, with six actuators allowing a greater degree of accuracy and speed of movement.
Comprised of two elements to maximise overall curvature, the Active Long Tail wing's supports have been aerodynamically profiled and each features a slot gap to improve performance in crosswinds.
The front wing and Active Long Tail rear wing are tuned to constantly adjust according to the driver's steering, accelerating and braking inputs and the vehicle's speed. Under straight line acceleration the Active Long Tail wing will tilt to reduce drag, while the front wing will trim accordingly to optimise vehicle balance without compromising on steering feel or the flow of air for brake and powertrain cooling. Under braking, the Active Long Tail acts as an airbrake while the front wing swings up to significantly reduce pitch sensitivity. In cornering situations both wings will set to their optimal position to balance downforce according to the vehicle speed.
The McLaren W1 is heavily influenced by Formula 1 aerodynamic advances. This includes heavily undercut side intakes that echo sidepods and aerodynamic appendages that carefully manage the wake with the front wheels at the straight ahead or under steering lock, the latter yielding the highest gains. Even the side mirrors are placed as far outboard as possible and shaped to flow air away from the rear of the car so as not to disrupt efficiency of the Active Long Tail wing.
Given this level of detail, it is no surprise that the engineers spent a lot of time in half-scale and full-size wind tunnels, with at least 350 hours and 5,000 points tested across many iterations and conditions carried out during the research process in addition to over 3,000 CFD simulation runs. This is comparable with Formula 1 and sports-prototype race car development and has resulted in several patent applications in areas relating to the McLaren Active Long Tail rear wing, front active wing, monocoque, flow diverter, underbody aerodynamics, tyre wake-deflecting systems and the heave damping system.
The result is a car that can generate up to 1000kg of downforce, but without the aerodynamic drag penalty associated from conventional upper body aerodynamic devices. W1 generates 20% less drag than a McLaren Senna with its rear wing in DRS configuration.
At the heart of every McLaren road car is a carbon fibre structure, but the W1's McLaren Aerocell central structure differs in two attributes. Firstly, it is constructed using pre-preg carbon fibre. This method, also used in the Solus GT track-only car, is more commonly used in low-volume motorsport applications. The carbon fibre is pre-impregnated with a resin system that simplifies the curing process and pressure treatment is then applied in the mould, which gives the Aerocell higher structural strength. This allows for a lighter structure - the Aerocell is pound-for-pound McLaren's lightest monocoque yet - and the high uniformity of finish from the process negates the need for additional bodywork in some areas. The chassis has a 3K gloss finish with surfaces visible from the exterior and interior of the car.
Secondly, the Aerocell has been designed to integrate W1's extreme aerodynamic focus. With sections of the chassis finished to a high standard, the shape has been designed to save further weight with integrated exterior and interior surfaces. The exterior also contains aerodynamic surfaces that have been achieved by raising the floor of the monocoque by 65mm, which has lifted the footwell position and rising to 80mm towards the front of the Aerocell. At the same time, to reduce the length of the Aerocell - and of the overall vehicle - the decision was taken to fix the seat position and incorporate seating into the monocoque. Reducing the wheelbase by almost 70mm, this also has the added benefit of saving further weight - the seats are the lightest yet in a McLaren.
With the front of the Aerocell being positioned higher than the monocoques in other McLarens, the lower-front suspension mountings are integrated into the central structure. This higher positioning optimises high-energy air flow under the car and also means no subframe is needed, contributing further weight-saving.
One challenge arising from there being no front subframe was the mounting of the steering rack - which is higher than is usually the case - requiring a bespoke solution. This is resolved with a cut-out on each side of the monocoque, enabled by designing the structure to efficiently transfer the loads around it, made possible by McLaren's mastery of carbon fibre engineering. The resulting position of the steering rack, closer to the centre of the road wheels, enables McLaren W1 to run in either of the two ride height settings linked to the Road or Race modes, with optimal steering geometry maintained in both positions.
The Aerocell also incorporates fixings for McLaren's first Anhedral doors. The decision to eschew the traditional Dihedral door design that began with the McLaren F1 three decades ago has brought aerodynamic benefits. This allows optimisation of airflow extracted from the front wheel arches into the high temperature radiators, providing an extra 100mm of cooling space, enough to reduce the size of the radiators required to cool the powertrain.
The Anhedral door design also aids ingress and egress from the vehicle, in conjunction with offsetting the A-pillar as it meets the chassis. This creates more space at the lower front of the opening for stepping into the raised footwell.
The aerodynamic focus of the chassis relies heavily on ground effect, an area that is maximised in Race mode, when the car is dramatically lowered. Airflow conditioned by the lower body interfaces with the structural diffuser - which is shrink-wrapped to the powertrain - that has been constructed using Intermediate Modulus Carbon Fibre (IMCF). Another first for McLaren, this method produces a material with a higher strength for this type of application and is more heat resistant as well as being lighter than conventional carbon fibre structures. Further weight is saved since the diffuser's strength and stiffness removes the need for a cross car structure linking the suspension pick-up points and this solution also allows significant diffuser volume.
The rear diffuser also forms part of the crash structure, acting as a rear bumper. W1 also incorporates a new rear frame that adds significant stiffness by tying into the upper part of the Aerocell. It is made from a box-section aluminium hollow casting, which is lighter than a more conventional 'I'-shaped section.
The W1 is the first McLaren road car to employ pushrods; these link to inboard dampers which, in conjunction with the use of wishbones, torsion bars and heave dampers is directly inspired by Formula 1. The front of the car utilises this concept to optimise aerodynamic efficiency, with an optimised aerodynamic profile of some components helping to keep the channel of air flowing cleanly towards the rear of the car. At the rear, where conditioning airflow is less of a priority, traditional outboard springs and dampers are employed.
Continuing the Formula 1 influence, the front suspension setup also includes torsion bars and an active heave element, while the rear has a Z-bar with active droplinks to control heave. In the relentless pursuit of light weight, 3D printing was used for the titanium front uprights and wishbones of the advanced suspension system.
This is achieved by dramatically lowering the ride height, increasing ride stiffness and engaging the heave springs, which are designed to control vertical movement. This creates a more aerodynamically stable platform and more predictable dynamic behaviour at speed, optimising overall downforce and increasing driver confidence on high-speed tracks.
The default Race mode is set up with a degree of compliance for undulating or uneven track surfaces. The additional Race+ setting for flat, smooth surfaces gives tighter control of the chassis to optimise aerodynamics.
Braking uses the McLaren Carbon Ceramic Racing+ (MCCR+) system. With an additional ceramic layer the 390mm brake discs have superior durability, while allowing for a more aggressive brake pad and higher friction levels. The front brakes are activated with 6-piston calipers and the rear by 4-piston calipers, both of a forged monobloc design. Further weight is also saved by integrating the electronic parking brake on the rear calipers, which also improves stiffness of the system.
Brake performance is further optimised with wheel aerodynamic appendages to keep the system cool. The most extreme design yet in a McLaren and directly inspired by Formula 1-style ducts, these have been designed to also increase downforce and radiator cooling by managing the wake of the tyres, while the brake lines have been re-routed to improve airflow under the car.
Overall stopping performance is sensational; McLaren W1 will stop from 200-0km/h in just 100 metres and 100-0km/h in 29 metres.
With a history of performance benchmarks that includes the P1TM and various LT models as well as the track-focused McLaren Senna, W1 has been designed to be the most engaging McLaren yet but also a supercar capable of the fastest lap time of any road-legal McLaren car.
Areas of intense dynamic focus includes the Formula 1-inspired inboard front suspension concept and its aerodynamic placement, which is new to a McLaren road car. The ground effect aerodynamics have also been fine-tuned to work on both smooth and bumpy circuits to ensure a stable platform for the driver.
This process has meant an expansion in the range of driver-adjustable chassis and powertrain modes. Powertrain defaults to Comfort, which deploys the E-module for torque infill at low revs only and an Electric mode for near-silent EV driving can be selected, while Sport gives full hybrid power, adding theatre to gear shifts and a more engaging throttle response. The Comfort Handling setting gives the occupants a smooth ride quality with increased body control at medium and high speeds, while Sport provides a more engaging, connected setup with focus on body control and agility at all speeds.
With its fixed seats and raised footwells, McLaren W1's driving position would appear more akin to a sports prototype racing car - but in practice is tailored towards superior occupant comfort. The anhedral doors feature with a sculpted concave section on the inside to maximise occupant space, with a cantilevered door fin blade that appears to float away from the occupants - minimalist yet beautiful and functional.
The pedals, steering wheel and primary controls move to fully embrace driver within the cockpit environment, with a perfect driving position easily found by adjusting the floor-mounted aluminium pedals, which have a unique adjustment action. Smaller than the previous design, the flattened wheel gives the driver the best view of the road ahead of any McLaren as the steering wheel rim and binnacle both sit low. The flatter bottom of the wheel also aids leg clearance. The steering rack has been repositioned closer to the centre of the wheel to better maintain geometry in road and Race modes and has the distinctive McLaren Hydraulic Performance Steering feel. Integral shift lights that prompt the driver to select the next gear as the 9,200rpm redline approaches, are optionally available.
Chassis and powertrain modes can be adjusted via rocker switches on top of the instrument binnacle. Designed to move with the steering column to allow mode adjustments to be made within reach of the wheel. The W1's driver display has been engineered to ensure the full screen remains visible to the driver despite the smaller steering wheel.
The binnacle is also designed to be aerodynamically efficient - it doubles as a flow diverter providing the driver with a cool or warm stream of air as desired from the cabin-wide diffuse air vent. This works with four adjustable fascia vents to optimise the compact HVAC system - which efficiently provides cool or warm air as desired in all driving modes, including EV-only operation.
Between the fixed seats there is a storage area with a sliding cupholder, while there is a second area for small items behind the armrest. The McLaren W1 also has a luggage stowage shelf behind the seats, accessible by moving the headrests, which fold flat forwards to provide a loading platform. With up to 117 litres of storage space, two weekend bags or two crash helmets can be accommodated.
McLaren's design DNA is expressed in compact dimensions and an athletic body form, by visible functional features and respect for aerodynamic principles.
The W1's heavily sculpted form epitomises McLaren's performance-led design yet displays its aerodynamic excellence with elegance and flair. It is also a clear visual demonstration of its duality of character, with a smooth, flowing upper surface that contrasts with the extreme, sculpted ground effect lower body.
Almost every panel is made from carbon fibre, the exception being the composite roof centre panel and flow diverter. Construction of these elements differ simply to allow the audio and navigation antennae - which is mounted in the flow diverter - to operate efficiently, a prime example of McLaren's desire to create an extreme car for all occasions.
The front aspect of W1 showcases its aerodynamic brilliance, featuring a wide front active plane wing, which moves in a swing arc and a large amount of bodywork layering designed to condition the flow of air towards aerodynamic surfaces heading towards the rear of the car. The upper nose section is cleaner in design, but features intakes around the lights and upper wheelarches, with a large single nostril in the centre of the bonnet where hot air can escape from the front radiators. At the rear of this is an aerodynamic blade that lifts to reveal the EVSE charging port, brake and washer fluid reservoirs.
The side aspect of W1 is dominated by a wide cut-out for the convex-shaped door which creates space for air to exit the front wheel arch via two outlets - through which the front suspension arms can be seen - and two large intakes ahead of the rear section. The most prominent of these, which feeds the high temperature radiators, is influenced by Formula 1 sidepod design. Its triangular shape provides an undercut in which the second intake is located ahead of the rear wheel and features a channel that feeds the rear diffuser. Even the side mirrors have been designed with aerodynamics in mind; they are placed as far outboard as possible on a support blade and are shaped to direct their wake away from the rear of the car so as not to disrupt efficiency of the radiators or the Active Long Tail wing.
The heavily-haunched rear bodywork includes an intricately detailed engine cover that sits below the flow diverter, which also houses the shark fin audio and navigation antennae and sits above and forward of the central stop light and rear-view camera. The flow diverter directs clean air towards the twin-element Active Long Tail wing, which sits above the large twin centre-exit exhaust. Completing the muscular rear section is the prominent multi-fenced rear diffuser.
Seen from above, W1's form is remarkably clean for an aerodynamically-led design, with a pronounced hammerhead-shaped nose and tight teardrop cabin form, which then opens up to the McLaren Active Long Tail wing. This is contrast to the strikingly complex lower bodywork, which is intentionally detailed to fully optimise ground effect.
The sense of drama to W1's design is heightened by the anhedral doors, a departure from McLaren's traditional dihedral operation. Highly intricate, these open upwards with recesses in the roof and at the lower front opening helping to provide access to the compact, yet spacious cabin, which is designed to make the most intelligent use of space in a McLaren yet.
Leather and Alcantara® can also be specified, which can incorporate perforated sections for audio and visual elements. Other luxury materials can also be integrated into the cabin, including 1K carbon fibre interior jewellery for switchgear.
Ultimate warranty provision with servicing and maintenance to match
Every McLaren W1 comes as standard with a comprehensive warranty [4-year/unlimited mileage vehicle; 6-year/75,000km HV battery] and a 4-year inclusive service plan that complements a unique ownership experience.
The new hybrid powertrain has been developed to a maintenance cycle similar to the V6 hybrid powertrain and the service schedule for W1 will follow a 12-month cycle. This is in line with McLaren series production supercars rather than schedules of many track-focused cars which have reduced service intervals based on the number of hours of running.
With the 399 examples of W1 that will be built all allocated.
Epic performance
Looks great. Love the active long tail.
Love it, would love to have one, will never be able to afford one.
Those black seats look like someone already shit their pants in those seats hahaha.
03-20-2011 01:40 PM
