Lotus: Evija News
Lotus: Evija News
https://www.netcarshow.com/lotus/2020-evija/
At first known only by its Lotus Type number - Type 130 - the car has been christened the Lotus Evija (pronounced 'E-vi-ya'). As a name it is derived from variations of Eve, and means 'the first in existence' or 'the living one'. It is highly appropriate; Lotus has an unquestionable reputation for its pioneering approach in both automotive and motorsport.
As the first all-electric British hypercar, the Lotus Evija continues that story of innovation. It also signals the start of an exciting new chapter for Lotus under the stewardship of Geely, the fastest growing automotive group in the world.
Lotus Cars CEO Phil Popham said: "Evija is the perfect name for our new car because it is the first all-new car to come from Lotus as part of the wider Geely family. With Geely's support we are set to create an incredible range of new cars which are true to the Lotus name and DNA."
A stunning exterior inspired by nature
The most striking element of the Lotus Evija is its exterior. From every angle the full carbon fibre bodywork is stretched taut, appearing shrink-wrapped over the mechanical components. Crouching low to the ground, with a ride height of just 105 mm, the pronounced muscular haunches envelop the teardrop cabin that sinks between them.
Taking inspiration from the aeronautics industry, the exterior is a perfectly proportioned blend of fluid forms and crisp lines. This is clearly illustrated by the gently curved but sharp leading edge of the bonnet, which is reminiscent of so many classic Lotus road and race cars.
Cues for the Lotus Evija's surface language was also taken from nature. Russell Carr, Design Director, Lotus Cars, commented: "During the initial design stage we spent many hours studying images of geological forms - rocks that had been carved by nature over the centuries. We believe we've captured these beautiful, intriguing and elemental lines within the Evija."
True to Lotus founder Colin Chapman's core belief that every component should serve multiple purposes, the exterior design is also exceptionally efficient on every level. The most obvious example of this - and unquestionably the most dramatic element of the exterior - is the Venturi tunnel which pierces each rear quarter. Inspired by Le Mans race cars, they optimise air flow by directing it through the bodyshell.
Aside from creating a breath-taking presence, this design concept - known as 'porosity' - aids the delivery of high-energy air flow to the rear of the car. This in turn counteracts the low pressure behind the car to reduce drag. Furthermore, the Venturi effect inside the tunnels pulls air through the rear wheel arch louvres, maintaining air quality in the diffuser.
When viewed from the rear of the car, each tunnel is edged with a red LED to create a striking ribbon-style light signature. The result is a stunning visual effect that's akin to the afterburners on a fighter jet, especially when seen at night. As an extra detail, an LED hidden within each tunnel illuminates its interior.
The directional indicators are incorporated into the corners of the ribbon, while the reversing light is provided by the illuminated 'T' of the 'LOTUS' wordmark above the integrated charging flap.
Another key feature of the Evija's sophisticated aerodynamic system is the bi-plane front splitter. It's another illustration of form and function working perfectly in tandem. Designed in three sections, the larger central area provides air to cool the battery pack - mid-mounted behind the two seats - while the air channelled through the two smaller outer sections cools the front e-axle. Lotus aficionados may notice a respectful nod to the iconic Type 72 Formula 1 car, with its square front central section and two side wings.
Active aerodynamics for exceptional downforce
The Lotus Evija is the first Lotus road car to ever feature a full carbon fibre chassis. Moulded as a single piece for exceptional strength, rigidity and safety, the full length of the underside is sculpted to optimise downforce. It includes an integrated air diffuser which extends from under the B-pillars to the rear.
Active aerodynamics are deployed in the form of a rear spoiler, which elevates from its resting position flush to the upper bodywork, and an F1-style Drag Reduction System (DRS). Both are deployed automatically in Track mode, though can be deployed manually in other modes.
The absence of traditional door mirrors plays a part in reducing drag. Cameras integrated into the front wings are electronically deployed on unlock, while another camera built into the roof provides a central view. Images are displayed on three interior screens.
Advanced pure EV powertrain means record-breaking power
With target figures of 2,000 PS of power and 1,700 Nm of torque, the Lotus Evija is the world's most powerful production road car. Key to that exceptional power output is the 2,000 kW lithium-ion battery, supplied with its management system by Williams Advanced Engineering (WAE) as part of a joint venture with Lotus to collaborate on advanced propulsion technologies. WAE won a 2018 Queen's Award for Enterprise for translating its EV expertise from the race track to road-going vehicles.
The battery pack is mounted centrally behind the passenger compartment, and its cover is visible through the glass rear screen. This positioning delivers significant advantages in terms of styling, aerodynamics, packaging, weight distribution, occupant comfort and dynamic handling. It also supports fast and convenient servicing and maintenance. Furthermore, the set-up has been designed so that in the future alternative battery packs - for example, to optimise track performance - can be easily installed.
Power is fed from the battery pack to a bespoke in-line axial arrangement of two high-power density e-motors. These feature integrated silicon carbide inverters and epicyclic transmission on each axle of the four-wheel drive powertrain. The motors and inverters being supplied by Integral Powertrain Ltd.
Four exceptionally compact, extremely light and highly efficient single-speed, helical gear ground planetary gearboxes transfer power to each driveshaft. Measuring a mere 100mm in depth, each gearbox comes packaged with the e-motor and inverter as a single cylindrical Electrical Drive Unit (EDU). With a target power of 500 PS per e-motor, this is the most efficient and elegant engineering solution to deploying so much power with precision.
Torque-vectoring, enabled by the four e-motors, provides exceptional dynamic response and agility on the road. This fully automatic, self-adjusting system can instantly distribute power to any combination of two, three or four wheels within a fraction of a second. In Track mode the ability to add more power to individual wheels enables the radius of corners to be tightened, potentially reducing lap times.
The Lotus Evija is equipped with ESP stability control to ensure safety in all road conditions, with further grip provided by the four-wheel drive system. A pure steering feel - a vital ingredient of every Lotus - is assured via an electro-hydraulic system.
The car is built on a one-piece motorsport-inspired carbon fibre monocoque chassis. It is supplied by CPC, the Modena, Italy-based world-leader in composite technology. Constructed from multiple carbon plies, the manufacturing process is identical to that of an F1 chassis, and ensures the lightest, stiffest, safest and most technically advanced Lotus road car platform ever built. The total weight of the monocoque tub is a mere 129kg.
This chassis, coupled with innovative engineering and clever packaging throughout every element of the Lotus Evija's powertrain, has contributed to the class-leading target weight of 1,680kg in its lightest specification.
Precision performance guaranteed
As with every Lotus, the Evija is 'For The Drivers' and its searing pace is delivered in one seamless, sustained surge. The 0-62 mph (0-100 km/h) sprint is completed in under three seconds, while the top speed is in excess of 200 mph (340 km/h).
These headline statistics only tell part of the car's performance story. Matt Windle, Executive Director, Sports Car Engineering, Lotus Cars, explained: "The Lotus Evija has astonishing acceleration at higher speeds. It takes less than nine seconds to reach 300 km/h which is better than any other direct competitor."
Further performance figures include acceleration from 100-200 km/h in less than three seconds, and 200-300 km/h in less than four seconds.
Power can also be delivered over a sustained period. The car's advanced aerodynamics and four-radiator cooling package keep the battery at an optimum temperature. It means that the Lotus Evija is capable of being driven flat out with no derate for at least seven minutes in Track mode.
Matt Windle continued: "With the Lotus Evija we have an extremely efficient electric powertrain package, capable of delivering power to the road in a manner never seen before. Our battery, e-motors and transmission each operate at up to 98% efficiency. This sets new standards for engineering excellence."
As part of the development and validation process, Lotus and Williams Advanced Engineering have conducted thousands of hours of virtual testing and digital analysis. This comprehensive programme will ensure the car's meets its performance targets and exceeds customers' expectation.
As a pure EV the Evija will be ultra-quiet at low speeds. During this time regulations require that it emits a digitally created sound - transmitted via a front-mounted speaker - which will alert pedestrians to its presence.
While the flowing lines create a very organic look, Russell Carr, Design Director, Lotus Cars, believes that it is important that the car visually conveys its technical achievements. "When you look through the rear glass, you can see the battery pack cover and the in-board suspension. This link between the human and the precision engineering is essential for a Lotus. We want people to have the sense that they are engaging with the power and performance of the car. We refer to it as technology with soul."
A revolution in charging
Not only does the Lotus Evija feature the world's most powerful automotive drivetrain, it also boasts the world's fastest charging battery. Thanks to the partnership with Williams Advanced Engineering, the battery has the ability to accept an 800kW charge. Although charging units capable of delivering this are not yet commercially available, when they are it will be possible to fully replenish the battery in just nine minutes.
Using existing charging technology - such as a 350kW unit, which is currently the most powerful available - the Evija's charge time will be 12 mins to 80% and 18 mins to 100%. The car's range is 250 miles (400 km) on the WLTP Combined Cycle, or 270 miles on the NEDC Combined Cycle. Lotus is in discussions with external suppliers on a charging solution for customers.
The CCS2 charging socket is hidden behind a vented flap at the rear of the car. In the same location is a small plaque, reminding customers of the Britishness of the Evija.
Motorsport-inspired interior is a technical tour de force
The interior of the Lotus Evija is as dramatic as the exterior. Inspired by the technical precision of race car engineering, the dominant characteristic of the cabin is the 'floating wing' dashboard which can be glimpsed from outside through the windscreen. The design also echoes the porosity of the exterior.
"The shape is inspired by the company's prototype racing cars of the late Fifties and early Sixties," explained Russell Carr, Design Director, Lotus Cars. "It has a beauty and an elegance to it, and represents a typically Lotus approach because it performs multiple functions. It houses the instrument panel and air ducts, and is also an integral structural support. It reinforces Colin Chapman's cast-iron rule that no Lotus component goes along for a free ride."
Access to the cabin is through the two dihedral doors. Handle-free to preserve the sculpted exterior, they're operated via the key fob. It's the first time Lotus has used such doors, and while they make for a moment of dramatic theatre they also provide maximum space for getting in and out.
An exceptional attention to detail - as people would expect from Lotus - is at the heart of the interior. For example, visible carbon fibre surfaces enhance the sense of light weight, while a thin metal band - engraved with the words 'For The Drivers' - runs centrally through the squab of both seats.
Once in the car, a switch in the roof console closes the doors. The location aids the minimalist layout of the main control panel and prevents them being activated accidentally. Russell Carr, Design Director, Lotus Cars, explained it's in tribute one of the most iconic Lotus cars, commenting: "Versions of the Lotus Esprit Turbo featured a huge roof console in the late Seventies and early Eighties. It's not something you might expect on a contemporary hypercar but Lotus fans will love the connection."
Inside, the cabin strikes the perfect balance between the precise functionality of a track car and the comfort of a road car. The driving position is fully adjustable to accommodate the greatest range of occupants. The elegant carbon fibre shell seats are hand-trimmed with thick Alcantara-finished pads, and feature manual fore / aft adjustment plus electric back operation. The steering column is manually adjustable for both rake and reach. Three-point seatbelts are fitted as standard, with four-point harnesses an option. Built into the bodyshell, close to the occupants' hip point, are two bespoke storage areas.
The design of the steering wheel, similar to that found in an LMP or F1 car, further reinforces the Evija's sporting intentions. The outer ring is finished in Alcantara as standard with leather available as an option. Buttons are grouped in an intuitive manner and govern functions including phone use, cruise control and DRS deployment.
Mounted centrally at the base of the wheel's hub is the mode controller. There are five modes - Range, City, Tour, Sport and Track - with various of the car's performance features activated or deactivated depending on which is selected.
Ahead of the steering wheel is a state-of-the-art digital display, providing the driver with key information such as mode, battery charge and remaining range. It is the car's only screen, putting all necessary information in one place. The screen displays essential functions only, with information appearing as required when the appropriate button is pushed, then fading when no longer needed.
Further controls are located on the floating 'ski slope-style' centre console, which features touch-sensitive haptic feedback buttons. Each is integrated in hexagonal recesses to help guide the driver's fingers. As the light plays over the surface it creates an almost organic visual effect. The driver can also interact intuitively with the car's technology via a control wheel. The honeycomb design of the buttons is replicated on indicator stalks and on the surface of the aluminium foot pedals.
The Evija's cabin has been deliberately designed so that the occupants feel they are at one with the vehicle. "At the core of the appeal of any Lotus is that the driver is in sync with the car at all times and almost feels as if they are wearing it," said Russell Carr, Design Director, Lotus Cars. "Looking out from behind the wheel, it's a wonderfully emotional moment to be able to see the bodywork outside, both in front and behind you. That's something we hope to enhance in future Lotus models."
Climate control and a premium infotainment system are fitted as standard. Customers can seamlessly integrate their smartphones via Apple CarPlay and Android Auto, accessing their own music and navigation.
Extreme track performance and on-road comfort
Calibrated to provide the optimum blend of extreme track performance and on-road comfort, the Lotus Evija's motorsport-derived suspension features three adaptive spool-valve dampers for each axle. Two are corner dampers with a third to control heave. These are mounted in-board to optimise the aerodynamic performance. They are manufactured by Multimatic, specialists in developing high-performance suspension technology for on-road, off-road and motorsport applications including Formula 1.
Magnesium wheels provide optimum lightness and strength, and are sized 20 and 21 inches at the front and rear respectively. They are shod with Pirelli Trofeo R tyres, developed specifically to achieve ultimate performance. To deal with the Evija's extreme performance, the car is equipped with a forged aluminium AP Racing braking system with carbon ceramic discs front and rear.
Technology: World-first laser lighting
The Lotus Evija is the first production road car in the world to feature laser lights for both main and dipped beams. Produced by Osram, the lighting modules are very compact and will provide an outstanding view of the road or track ahead. The strikingly thin vertical headlamps provide the perfect balance of crystal-like beauty and a highly technical design. Inside the lenses, unique 'wing-like' elements form the daytime running lights and directional indicators.
Technology: Connected to the cloud
The Lotus Evija is the first Lotus to provide drivers with a full suite of digital connected infotainment, which will benefit from over-the-air software updates. A powerful on-board modem enables communication to the cloud, and the driver can interact with that data through a Lotus smartphone app. The app will enable drivers to monitor their Evija from anywhere in the world, for example, to check the battery charge status and driving range. It will also support remote use of air-con, to heat or cool the cabin ahead of the next drive.
The Evija's infotainment system includes a chronograph to allow the driver to record their lap times. Connection to the cloud means they can view their performance while at the track and recall previous sessions through the app.
The ultimate in personalisation
Lotus will offer Lotus Evija customers an unparalleled level of personalisation, enabling them to specify the car exactly as they wish. This will include the opportunity to select unique paint finishes, interior trims and detailing.
Marquetry-style badging will provide further bespoke opportunities. Lotus has developed the ability to inlay metal elements directly into the carbon fibre bodyshell, so that the badge sits completely flush with the bodywork. Currently the Evija carries a partial Union Flag badge on the C-pillar, signifying its status as a British-built hypercar. However, this could be another flag, a family crest or personal logo.
"This marquetry-style badging is similar to that associated with traditional cabinet-making, where you inlay different colours of wood," explained Russell Carr, Design Director, Lotus Cars. "On the Evija it's really is up to the customer to choose whatever materials and designs appeal to them."
Lotus is also developing a comprehensive programme of bespoke experiential activities for Lotus Evija owners. These will include VIP track days and other high-performance motorsport opportunities.
Putting the customer first
The Lotus Evija has been designed and engineered at Lotus' historic home in Hethel, UK, and production will begin in a new dedicated on-site manufacturing facility during 2020.
A maximum of 130 examples will be built, guaranteeing exclusivity to match the stunning looks, ground-breaking technology and world-beating performance. They will be sold directly to customers by Lotus, with the global network of 220 retailers in support. Plans to service and maintain the car for each owner are currently in development.
The Lotus Evija is priced from £1.7m plus duties and taxes. A £250,000 deposit secures a production slot.
Built in Great Britain, great for Great Britain
The UK is already recognised as a world-leader in high-performance automotive production. Lotus has been at the heart of that success for 71 years. The Lotus Evija will further cement the global status and reputation of this important UK industry sector, and its associated and diverse supply chain.
However, as the first all-electric hypercar from a British car maker, the launch of the Evija sees Lotus deliver an opportunity for new and exciting expansion of the sector. Increasing consumer awareness and demand for the astonishing performance available through EV powertrains means new growth and new skills, and Lotus intends to be key player in that revolution.
A true Lotus in every sense
The Lotus Evija is faithful in concept and detail to the pioneering principles which company founder Colin Chapman used to build his first car in 1948. In common with every new Lotus, the Evija has been seen by members of the Chapman family. At a private viewing of the Evija, Hazel Chapman - Colin's widow - commented: "It's very beautiful and I can't wait to see it on the road."
As with every Lotus, the Evija features the initials ACBC (Anthony Colin Bruce Chapman) in its badge. Chapman guided the company to astonishing levels of success on the road and track before his untimely death in 1982, aged just 54. Seven Formula One constructors' championships and six Formula One drivers' titles tell only a small part of the story. His pioneering approach to engineering led to an incredible range of world-first technical innovations.
- Type 14: the world's first composite monocoque production road car (Elite, 1957)
- Type 25: the world's first fully-stressed monocoque F1 car, and the first Lotus to win F1 world championship (1963)
- Type 72: the most successful F1 car of all time and the blueprint for F1 car design for many years (Championship winner in 1970, 1972 and 1973)
- Type 78: the world's first 'ground effect' F1 car (1977)
- Type 88: the world's first carbon fibre F1 car (1981)
- Type 92: the world's first active suspension F1 car (1983)
- Type 111: the world's first aluminium and bonded extrusion construction production car (Lotus Elise, 1995)
- Type 130: the Lotus Evija, the first fully electric British hypercar (2019)
https://www.netcarshow.com/lotus/202...paldi_edition/
The world's most powerful production car - the stunning Lotus Evija hypercar - now delivers even more exclusivity and desirability. Inspired by the past to enhance the future, Lotus has unveiled the Evija Fittipaldi, a tribute to one of the greatest car-and-driver pairings that Formula 1 has ever seen.
That driver is, of course, Emerson Fittipaldi, the young Brazilian racer who joined Lotus and became a legend, cementing his place in F1 history in 1972. Behind the wheel of the now-iconic Lotus Type 72 and winning five of that season's 11 races, Fittipaldi secured the Drivers' Championship for himself and the Constructors' Championship for Team Lotus.
Exactly 50 years on, the Lotus Evija Fittipaldi is a fitting celebration of that partnership. Just eight examples of the all-electric two-seater are being hand-built at Hethel in Norfolk, UK - the global HQ of Lotus sports car design and manufacturing - and all are sold. Customer deliveries will begin early next year. It is the latest project from Lotus Advanced Performance, the bespoke design and experiential division of the business launched earlier this year.
Showcasing the world-famous black and gold colour scheme - also 50 years old in 2022 - the hand-painted exterior and numerous other unique design features have been created to commemorate this amazing collaboration. They include a hand-tinted plan view of the Type 72 etched into the exposed carbon fibre roof, and Fittipaldi's signature hand-stitched into the dashboard.
And perhaps the most emotive detail of all is the rotary dial on the floating central instrument panel. It has been hand-crafted from recycled original Type 72 aluminium, ensuring a genuine piece of the iconic F1 racer is part of each Evija Fittipaldi.
Such a special car deserved a special world premiere; customers, their families and other VIP guests have taken part in an exclusive, once-in-a-lifetime experience day at Hethel to celebrate the launch of the new car and the iconic Type 72.
Guest of honour was Emerson Fittipaldi himself, who said: "It's fantastic to be back at Hethel for such a special occasion. I've really enjoyed being a part of this project and it's been a wonderful experience revealing the car to some of the new owners. Having the opportunity to drive both the Evija Fittipaldi and my championship-winning Type 72 Formula 1 car on the test track at Hethel has been an incredible experience."
Other highlights of the day included the first time in history that all eight surviving examples of the Type 72 - hence the number of Evija cars being built - were brought together in one place and run on the Hethel test track.
Simon Lane, Director, Lotus Advanced Performance, commented: "The word 'legend' is often overused, but this project has brought together the Lotus Evija hypercar, Emerson Fittipaldi, the Type 72 race car and our brand's celebrated Formula 1 heritage. No argument, that is four legitimate legends, all collaborating to deliver a truly unique hypercar and a world premiere that was a real 'pinch yourself' moment."
He added: "Production of the Evija has commenced at Hethel, and these eight cars are a very special celebration of this important moment in our history."
The bespoke specification of the Lotus Evija Fittipaldi starts with its unique paint finish, which includes its designation written on the body work in gold lettering to the side of the rear window. Complementing it are black and gold 'Type 72' wheels complete with anodized centre lock surrounds - red on the left side of the car and green on the right - as well as black and gold brake calipers.
Decals that celebrate the Type 72's race victories from the 1972 season are presented on the active rear wing, while a number 8 has been applied to the B-pillar. Fittipaldi raced with that number on his car during the 1972 season, including for his win at the British Grand Prix. A carbon and gold Lotus nose badge completes the exterior styling.
Inside, the theme of luxury and bespoke design continues. Black leather interior with gold contrast stitching can be found throughout the cabin, along with exclusive roof liner stitching, plus gold finishes to the air vent surrounds, centre rotary dial, start/stop button and pedals.
The car has been developed with the generous support of Classic Team Lotus, the historic motorsport business run today by the family of Lotus founder Colin Chapman to maintain and operate Lotus F1 cars. Also based in Hethel just across the road from Lotus, it hosted the gala dinner at the launch event.
Clive Chapman, Managing Director, commented: "Emerson Fittipaldi and my father enjoyed a very special relationship, and their spectacular success was a brilliant team effort by the dedicated designers and mechanics at Team Lotus. One of motorsport's most admired drivers, it is always emotional whenever Emerson is reunited with the Lotus Type 72, which he describes as the greatest car he ever raced."
He added: "Bringing together the Lotus Evija, the Lotus Type 72, the black and gold livery and Emerson Fittipaldi, all in celebration of his World Championship victory 50 years on - need I say more?"
Despite its incredible power and performance, the driver remains at the centre of the Lotus Evija experience, just as it was for the Emerson Fittipaldi and the Type 72. The technical specification and performance figures of the Lotus Evija Fittipaldi are truly astonishing; more than 2,000 PS makes it the most powerful series production car in the world, creating more than 1,700Nm of torque. The 0-62 mph (0-100 km/h) is completed in under three seconds, and 0-186 mph (0-300 km/h) takes nine seconds from a standing start. The limited maximum speed is 217 mph (350 km/h). The full technical specification is detailed in the table below.
From one world champion to another, earlier in the week Jenson Button visited Lotus to test drive the Evija and Emerson's Type 72 on the famous Hethel test track. It was the first time Jenson had seen the Evija in production and took one out on track to give it a shake down before the launch of Evija Fittipaldi. Quickly getting up to speed Jenson drove the car around the 2.2-mile test track, testing the car's ride, handling and performance. He was also seen unleashing the power in several standing starts. Full of praise when he jumped out of the driver's seat of the world's most powerful production car. Jenson commented: "It sounds like a jet engine! You think of an EV as quiet but it's not. The torque is astronomical. It's amazing, it puts a big smile on your face. It feels like a spaceship, the drivability and direction in the steering certainly lets you know you are driving a Lotus; I am amazed by the agility of it. Itt is a Lotus of the future and I can't wait to drive my own Evija."
Jenson also got the chance to turn back the clock and drive Emerson's 1972 Lotus Type 72. The car that helped Emerson clinch his first driver's championship. Jenson Button added: "It's lovely to get into a bit of racing history. There isn't a lot of space, but everything is in the right position. It was easy to heel and toe. It's a real privilege to drive such a special car."
A stunning piece of contemporary automotive design - the work of a team led by Lotus Design Director Russell Carr - the Evija features a dramatic Venturi tunnel through each rear quarter, giving it a truly breath-taking presence. This 'porosity' means optimised airflow, with air channelled not just over, under and around the Evija but through it, maximising downforce while minimising drag. Its front splitter aids grip while channelling cooling air to the battery pack, E-motors and brakes, and active aero features such as a Formula 1-style DRS (Drag Reduction System) bestow the Evija with cutting-edge performance. With driving dynamics overseen by the team of Gavan Kershaw, the world-renowned Vehicle Attributes Director for Lotus, the Evija is a car like no other.
The first Lotus road car to feature a one-piece carbon fibre monocoque chassis, the cabin - from the fully adjustable race-style seats to the multi-function steering wheel - is the very pinnacle of motorsport-inspired road car design and technology.
Just as the Lotus Evija is defining a new era of pure electric performance, so the Lotus Type 72 remains the most successful racing car not just of its day, but in F1 history. In 2019 Autosport magazine named it the greatest ever F1 car. A revelation both on the drawing board and on the track, the Type 72 was the first racing car to incorporate aerodynamics as part of its initial design. The integrated rear wing and front splitter were designed specifically to allow the car to slice through the air while also creating vital downforce.
The Type 72's air intake was relocated above the driver's head, ensuring undisturbed and clean air could be sucked straight into the engine, while its radiators were placed in the sidepods of the car rather than the nose. This not only increased cooling efficiency but improved weight distribution - and therefore performance - in the process.
The same approach was also taken for the brakes, mounting them inboard rather than on each wheel to aid cooling as the tops of the discs protruded through the bodywork. The Type 72 was the first of what became the traditional "wedge on wheels" designs that soon inspired every other competitor on the grid.
Lotus Evija Fittipaldi technical specification
- Powertrain: Pure electric, 4WD
- Power: 1500kw (4 x 375kw) / 2,039 PS
- Battery power: 93 kW
- Torque: 1,704 Nm with torque vectoring
- 0-100 km/h (0-62 mph): < 3 seconds
- 0-300 km/h (0-186 mph): < 9 seconds
- Max speed: Electronically limited to 350 km/h / 217 mph
- All-electric range (WLTP Combined): 250 miles (402 km)
- Charging time (350kWh charger): 18 mins
- Weight: 1,887 kg
- Production run: Maximum of 130 cars
- Overall dimensions (L/W/H): 4,459 / 2,000 / 1,122 mm
- Start of Production: 2022
