Notices
Jeep: Gladiator News
Old 11-28-2018, 10:55 AM
Registered Member
Received 1,610 Likes on 1,186 Posts
http://www.trucktrend.com/news/1811-...ckup-revealed/
It’s not a Scrambler, and that’s why the new 2019 Jeep pickup is called a Gladiator. It’s a real truck—not a Wrangler with a bed. The long-awaited Jeep pickup has landed, and it holds a clear competitive advantage. In the midsize truck market, only two manufacturers are currently duking it out—the Toyota Tacoma and the Chevy Colorado/GMC Canyon. The Nissan Frontier is over 10 years old and is no longer a significant contender, and the upcoming Ford Ranger is still a virtual no-show. As always, Toyota’s rugged reputation holds its trucks firmly in the marketplace, and the new ZR2 and the AEV Bison are clearly ahead of the game in off-road ability and towing. But a true game-changer entered the market today—the Jeep Gladiator.
Named for its stellar predecessors from the ’60s and ’70s, the specs on paper alone make the new Gladiator appear to honor the past and blow away the current competition. It is a dedicated, real truck with a separate bed, not just a Wrangler JL with a longer bed tacked on the end like the old-school Scrambler. That was one reason for the name selection—Jeep knew it had to do it right and build a fully off-road–capable Jeep as well as a fully functional truck with four doors and a usable bed—exactly what this current market needs. Of course, it looks like a Wrangler JL, which it is supposed to.
While the cab and forward sheetmetal is the same or similar to a JL, it is decidedly different in every other respect. The frame is specific to the JT, as are the bigger axles, brakes, wheels, suspension, and thankfully, the available 33-inch mud-terrain tires on the Rubicon model. The Falken M/Ts are LT285/70R17 with a C load rating, while the Sport and Sport S get 245/75R17 Bridgestone Dueler HT 685 or A/T RH-S tires and the Overland gets the 255/70R18 Bridgestone Dueler HT 685 or A/T RH-S tires—all interesting choices for an OE-style tire on a Jeep. Even the grille is modified for better airflow due to the cooling requirements of a truck that can actually tow; it’s rated at a 7,650-pound towing capacity and 1,600-pound payload, which out-specs the competition. With a wheelbase of 137 inches and a 5-foot box, the JT is about 400 pounds heavier than a comparable JKU.
The Gladiator is also the only convertible pickup in the market, and it is offered with either a removable hardtop or a soft top, or both. Options mirror the JL line, and there are four trim levels: Sport; Sport S; Overland; and, of course, the top of the line in performance and style—the Rubicon. The rear flare to bed/body looks odd at first, but as an engineer said, “twist happens,” and there is no issue when off the road concerning body interference. The longer rear link arms are set lower for better control and towing ability, as the suspension of the Gladiator is also truck specific—as are the Fox aluminum-bodied 2-inch-diameter shocks available only on the Rubicon. Protecting the body of the Jeep Rubicon model are full-length side bars, and an additional bar for the bed area. Optional steel bumpers are available and a myriad of Mopar add-ons are also ready for tacking onto the Jeep. Of important note is that the bedsides are shorter and lower than a fullsize truck, making loading and unloading cargo easier and more convenient. The tailgate even has a halfway-down option, which allows for hauling 4x8 sheets of plywood in the back for the contractor side of your life.
For towing the JT is equipped with an optional Class 4 receiver and 4- and 7-pin harness plugs. You can still slap a ball on the bumper too, if all you tow are some lightweight toys to the beach. Sadly, there is no integrated brake controller provided—like all other contemporary trucks. A trip to your Mopar dealer can solve this oversight with some cash and time to install it. The same goes for the lack of a key-off live 12V power port in the bed of the truck. Does Jeep not think this will be the next greatest overlanding vehicle? They even named the trim level Overland, yet forgot the 12V port in the back. And while we decry the push-button start, at least it is billed as waterproof—but for Lee Iacocca’s sake, please make the not-key fob smaller than a brick. We certainly think these three items merit Jeep’s attention. Write your congressman and demand the change!
As with any newly introduced vehicle, the JT is awash with over 80 safety and convenience items. Some we love and others need some work. A newly introduced Off Road + button will allow the JT to have enhanced ability off-road by changing the parameters of BTC, and all the other crap in high range for sand running and low range for rockcrawling. This is said to not take away control, such as the dial-selection knob–style of lesser vehicles, as the transfer case lever and optional locker switches remain. In fact, late availability of rear locker access in high-range 4WD is also on the drawing board. Also, holding the + button for 5 seconds is purported to turn the nannies completely off in low range—and maybe high-range 4WD. We will hold judgment until we try it ourselves, but that feature would be truly welcomed and appreciated. Other interior upgrades from the JL include Off-Road Pages for the infotainment screen, where you can configure and fiddle to your tech-geek heart’s content rather than just driving the Jeep. The forward-facing camera is handy, but using your memory to visualize what you just drove over might be a better tactic.
In the power and torque department the current V-6 with 285 hp and 260 lb-ft ratings will be standard, with no mention of a four-cylinder. Of course, the 2020 model should feature the upgraded 3.0L EcoDiesel mill with 260 hp and 442 lb-ft, which is more than enough twisting force to pull a load. The gas engine can be had with a six-speed manual and the six-speed auto, while the diesel only gets the new eight-speed slushbox, and only the Rock-Trac Rubicon and regular Command-Trac transfer cases are available. The Gladiator’s frame is an additional 31 inches longer, while the wheelbase is 19.4 inches longer than the JLU Wrangler. An approach angle of 43.6 degrees, breakover angle of 20.3 degrees, departure angle of 26 degrees, and a ground clearance of 11.1 inches make for a competent wheeler—a true winner we can’t wait to try out.
Top 10 Gladiator Features
It’s a Jeep
It’s a Jeep truck
It’s a Jeep truck with an optional diesel
It’s a Jeep truck with solid axles
It’s a Jeep truck with a manual or automatic transmission
It’s a Jeep truck that rides comfortably
It’s a Jeep truck that has flexible yet sturdy suspension
It’s a Jeep truck with a soft top
It’s a Jeep truck with a removable hardtop
It’s a Jeep truck with a 1,600-pound payload
It’s a Jeep truck with a Class 4 hitch that can tow 7,650 pounds
And Bonus Points for the Rubicon Gladiator:
It’s a Jeep truck available with 33-inch mud-terrain tires, selectable lockers, 4:1 transfer case, electronically actuated antisway bar, and 30-inch fording ability.
00TL-P3.2 is offline
Registered Member
Old 11-28-2018, 11:13 AM
The Third Ball
Sarlacc's Avatar
Received 3,782 Likes on 2,015 Posts
love it
Sarlacc is offline
Old 11-29-2018, 09:31 AM
Registered Member
Registered Member
Old 11-29-2018, 09:32 AM
Registered Member
Registered Member
Old 11-29-2018, 09:54 AM
Received 1,726 Likes on 1,179 Posts
So much want. Too bad this thing will be $55k when optioned out.
SamDoe1 is offline
Old 11-29-2018, 10:51 AM
Registered Member
If not more.
Old 11-29-2018, 12:31 PM
Received 2,213 Likes on 1,316 Posts
I'd only get a 4-door JK or JL, but the the proportions on this are so wacky.
2-door gladiator when?
Costco is offline
Old 12-05-2018, 11:26 AM
Registered Member
https://www.cnet.com/roadshow/news/2...ine-heres-why/
While the Jeep Gladiator and Wrangler share more than a few parts, one thing they won't be sharing is the Wrangler's four-cylinder turbocharged gas engine.
Jeep will not offer its 2.0-liter I4 turbo engine in the Gladiator, The Drive reports. A Fiat Chrysler spokesperson told The Drive that "the 3.6-liter [V6] engine can handle the temperatures seen while towing," intimating that the Wrangler's four-pot might not be able to tow and haul with the best of 'em.
Whereas SUVs may not need to boast big numbers for towing and hauling, trucksare constantly locked in that battle of numbers, so it's best to come out swinging, which is exactly what Jeep did. Equipped with the tried-and-true Pentastar V6, the Gladiator will pull up to 7,650 pounds and haul up to 1,600 in the bed. That towing figure is best in class, and something tells me it'd be hard to match those numbers with the I4, since it doesn't appear to have been built with a truck application in mind.
Now, there's nothing wrong with offering a smaller and possibly less-capable engine in a pickup truck. The only engine on offer for the 2019 Ford Ranger is a four-cylinder, and yet it tows just 150 pounds less than the Gladiator while out-hauling the Jeep by 50 lbs. Chevrolet, Nissan and Toyota all offer I4s in their midsize trucks, as well.
Jeep will eventually expand the Gladiator's lineup to include a diesel engine alongside the V6, but as of this writing, the automaker has made no announcements about offering a smaller gas engine in the Gladiator. The four-cylinder engine, and its 48-volt mild hybrid system, is a $1,000 option on the Wrangler, and Gladiator buyers probably wouldn't be interested in shelling out more money for a truck that ends up being less capable.
Old 01-09-2019, 01:00 PM
Registered Member
https://www.autoblog.com/2019/01/08/...ed-off-roader/
Before the 2020 Jeep Gladiator was revealed, it seemed like there was a never-ending flow of tidbits leaking out about the truck. Now it's out, and while the flow has slowed, there are still interesting reports floating about. The latest comes from Jeep Gladiator Forum, which cites an anonymous inside source as saying there's a high-performance version of the pickup coming designed for fast off-roading similar to a Ford F-150 Raptor or Chevy Colorado ZR2. We reached out to Jeep regarding the possible truck, and a representative said the company had no comment.
That's certainly exciting news if it turns out to be correct, but there are reasons not to get your hopes up just yet. The forum reports that the truck is in the early stages of development, and it's still being decided whether there's enough of a market for it.
From our perspective, such a model is neither a dead end nor a shoo-in. Certainly there are people willing to buy fast off-roaders, as the aforementioned Raptor and ZR2 have shown. Also, Jeep has proven that people are willing to spend a lot on Wranglers, both from the factory and on aftermarket parts, so an even more expensive model wouldn't necessarily put people off. So those are two important points in favor of a fast Gladiator.
Points against a fast Gladiator start with the existing Gladiator Rubicon. While it isn't necessarily designed for bashing dunes, it does come with a huge amount of trail-ready equipment already. It has differential locks and anti-roll bar disconnects, big tires and burly shocks. On slower trails, it may already be as capable as the Colorado ZR2, which would be the closest competitor to the hypothetical high-po Gladiator. And since the Gladiator Rubicon will be available with comparable engines to the ZR2, would something more potent be necessary? It would seem that to further differentiate, the Gladiator might need more power. That's certainly possible by way of a V8 transplant, but that would mean a lot of money spent on getting the engine to fit, making it reliable, getting it emissions compliant, and ensuring the drivetrain is strong enough. All those costs would make it harder to get approved.
We may sound a bit pessimistic, but don't get us wrong, we would be excited to see a high-speed Gladiator, or any other Jeep for that matter. But we also want to be realistic, and there are certainly some significant hurdles to bringing such a truck to market.
Registered Member
With the Rubicon already being $$$ on the pricing, I imagine a Raptor/ZR2 fighter to be ludicrous end.
Old 01-09-2019, 01:12 PM
The Third Ball
Sarlacc's Avatar
Nah...look at5 FCA price structure...assume they actually made a hellcat engined Gladiator (they already did it with a SEMA concept) I'm guessing it would be in the $75k region to start.
Sarlacc is offline
Old 01-09-2019, 07:58 PM
Q('.')=O
imj0257's Avatar
Hey, Jeep built a Hummer. Cool.
imj0257 is offline
Old 01-10-2019, 09:28 AM
Yup. Which is about where the Raptor sits anyway.
SamDoe1 is offline
Old 01-10-2019, 10:21 AM
I feel like it needs black fenders. Blue one looks nice!
That red one posted earlier looked so funky to me, my guess is body color fenders make it look chode-y, exaggerating the very shallow-looking bed.
Costco is offline
Old 01-10-2019, 10:30 AM
Registered Member
The contrast in the fenders does help with the look a bit.
Old 03-20-2019, 02:41 PM
Registered Member
https://www.thedrive.com/news/27060/...t-toledo-plant
After loads of build- and release-date hullabaloo, the Jeep Gladiator pickuphas become a reality as the first production model was built on Tuesday at Fiat Chrysler's Toledo, Ohio plant.
This particular example, a Rubicon painted in Billet Silver with heaps of trick off-road options and doo-dads, marks the first of many Gladiators that'll be built ahead of the truck's rumored June release date. Then, it'll hit dealer lots nationwide and presumably fly off them as quickly as they landed with pent-up demand for the Gladiator reaching its boiling point.
Gladiator numero uno can be seen here driving off the line to applause from those that helped assemble it:
Other posts flooded Instagram Tuesday afternoon with plenty of excitement over the Wrangler-based pickup.
Upon its release, the Gladiator will feature a 3.6-liter Pentastar V-6 as its sole engine option until a 3.0-liter EcoDiesel comes along for 2020. The former will be able to tow 7,650 pounds with the Max Tow Package on Gladiator Sport, trumping the most capable Chevrolet Colorado to make it best-in-class. Oh, and you'll even be able to get it in a six-speed manual—how's that for customer satisfaction?
The looming question mark behind the Gladiator is its price. With no specifics mentioned by Jeep, we expect it to clock in a good deal above the Wrangler it's based on—an already pricey model that can nudge the $60,000 threshold when fully loaded. Dealer markup is a possibility as well, meaning that a top-spec Gladiator could find itself among the luxury half-ton pickups that sit a full class above the Jeep.
Regardless of the finances, though, the curb appeal is real with the convertible adventuremobile. Don't expect price to deter premium buyers from scooping them up as it's not uncommon to see Jeeps of all sorts modified to the high-heavens, costing nearly six-figures in their final form.
Old 04-08-2019, 10:06 AM
Registered Member
https://www.caranddriver.com/news/a2...r-jeep-safari/
Jeep's new Gladiator is only available in one configuration: a four-door crew-cab body with a five-foot bed. And surprisingly, even though Jeep has a long history of pickup trucks, the Gladiator is the first to have four full doors. So to celebrate that history of two-door trucks, for this year's Easter Jeep Safari, Jeep has created this, the J6 concept.
After starting with a Gladiator Rubicon, Jeep created a custom two-door body and fitted a six-foot bed, which is a full 12 inches longer than that of the standard Gladiator. Overall length is 201.0 inches, over a foot shorter than the 218.1-inch Gladiator, while the J6's wheelbase matches that of the standard two-door Wrangler at 118.4 inches. Like the Gladiator and the Wrangler, the J6 has a removable roof—in this case, a hard top.
Mounted in the bed are a custom steel roll bar and a spare tire carrier, the latter of which Jeep calls a "prototype" (meaning it will most likely be made an option in the future). The 17-inch beadlock wheels are also prototype pieces and are painted Brass Monkey with a silver ring, providing contrast with the Metallic Brilliant Blue paint, which was originally offered on the 1978 Jeep Honcho truck. The spray-in bedliner is finished in the same blue color. A two-inch lift kit from the Jeep Performance Parts catalog allows for the 37-inch tires, and the rock rails taken from the Gladiator are augmented by additional tubular bars.
The special exterior mods don't stop there. Another prototype part is the two-inch stinger bar mounted to the front bumper. A total of 10 five-inch LED lights, available from Jeep, are mounted on the bumper, A-pillars, and roll bar. The J6 also gets badging in a retro Jeep script on the fenders and tailgate, which we think looks rad.
That Jeep logo is also applied to the steering wheel, and the awesome blue exterior color is brought into the interior, where it's used on the dashboard and the accent stitching of the leather seats and armrests. The auxiliary switches on the dashboard—an option on production Gladiators—control all the LED lights. Jeep makes a point to call out the trailer-brake-control switch on the dash, so the J6 has at least some amount of towing capability, although no figures are given.
Jeep also provides no hope as to production prospects for the J6, but the truck looks extremely well done and thought out. We wouldn't be surprised to see a two-door Gladiator appear at some point in its production cycle—but there's also the possibility that Jeep could offer a two-door conversion kit through its parts catalog.
Old 06-17-2019, 04:35 PM
Registered Member
https://www.thedrive.com/news/28564/...g-56000-report
Thanks to months of endless hype surrounding the Jeep Gladiator'sspringtime launch, people are apparently comfortable spending a pretty penny on the off-road-focused midsize pickup truck. While it's no surprise that consumers are opting for high-trim versions of the automaker's newest model, the price they're typically paying is undoubtedly staggering. And according to Cox Automotive, the average Gladiator transaction clocks in at a lofty $56,000. For comparison, none of its in-class competitors can even be optioned to that price.
Now, before we jump up and down with raised fists, there's one factor to keep in mind: upon the rollout of a new vehicle, manufacturers often tend to place production priority on more expensive models to drive up profits and therefore fund further manufacturing. This means that, likely, Rubicon-trimmed Gladiators are the most readily available models for customers to get their hands on. The starting price for a Gladiator Rubicon is north of $43,000 and, with the sold-out build slots for the limited Launch Edition raking in $62k per, we quickly land at this seemingly steep average transaction price for the month of May.
Still, when pitted against the Ford Ranger—which is having a far better second quarter than it did Q1—the Gladiator dwarfs the Blue Oval's average of just over $37k.
Volume figures are relatively low for the Gladiator which, again, could be credited to May being its first full month of availability. According to official figures released by Jeep, a total of 2,548 Gladiator pickup trucks were moved last month. That's a bit less than the Honda Ridgeline (2,888) and a decent deficit to the aging Nissan Frontier (7,497). The aforementioned Ford Ranger saw a spike to 7,750 units sold during the same period, and the perennial top-dog Toyota Tacoma saw its 18th consecutive month of improvement at 22,832 trucks sold.
Expect to see the Gladiator's numbers level out over the rest of the year, though the average going rate for the Jeep truck will probably still outrank most of its counterparts.
Old 06-17-2019, 04:51 PM
The 2-door is amazing! Gladiator should be a 2-door and Wrangler looks best as a 4-door
Costco is offline
Old 06-18-2019, 09:08 AM
Registered Member
Or just offer the Gladiator in both configurations
But, I see far more Wrangler Unlimiteds than 2-doors, so I see the case for only offering the Gladiator in 4-door guise.
Old 06-18-2019, 11:47 AM
Yeah, that's what I meant. But I've seen the Gladiator in person a few times now, and it looks very disproportionate. The five foot bed is nothing abnormal, but I think with the cab size and height in relation to the bed height, it looks really off.
Costco is offline
Old 06-18-2019, 02:13 PM
Registered Member
I've seen a couple. Not bad, but I wouldn't buy one new at those prices
I always like the Comanche (XJ Cherokee-based)
Old 06-18-2019, 02:44 PM
Received 14,050 Likes on 10,443 Posts
wait till the shortbed ranger/bronco comes out. now that shit looks weird
justnspace is offline
Old 06-21-2019, 03:48 PM
Rooting for Acura
knight rider's Avatar
Received 1,408 Likes on 675 Posts
Gladiator Rubicon Hellcat 6x6 anyone?
https://www.caranddriver.com/news/a2...at-6x6-pickup/
knight rider is offline
06-06-2012 09:49 PM
10-16-2009 01:30 PM
Msnowdon
Home & Garden
01-29-2006 02:15 PM
ali.ahmed
Ramblings
21
09-01-2005 05:23 PM
gavriil
11-19-2004 05:48 PM
Quick Reply: Jeep: Gladiator News
