Hyundai: Sonata News
#802
My first Avatar....
#803
Acutallt it is worse. TL-S 2G is lighter and narrower car than 2G TSX V6.
2G TSX V6 is 300lbs heavier than 2.0T Sonata and gets similar or better performance despite being hampered by 5AT and non-DI engine.
Just look at GS350 DI engine performance/fuel economny (real test fuel mpg not EPA) on Edmunds test and it is 2006 technology. It is 500lbs heavier car than Hyundai 2.0T. and it blows away it by full 1 second.
Hyundai has long way to go in engine/transmission technology application.
Look at the Rim design and red color. didnot Hyundai red is inspired by Honda?
This red exterior color & red gauges are long associated withy Honda performance models around the world.
#804
You'll Never Walk Alone
I couldn't find stats for the 2G TL-S on Edmunds but they tested the Camry V6 and its quarter mile time and trap speed were almost exactly the same. Couldn't find the observed MPGs but the EPA estimated highway rating on the 2.0T is 3 mpg higher than the Camry V6... gear ratios were probably tuned for highway economy more than acceleration, considering the EPA ratings hardly take a hit from Hyundai's non-turbocharged 2.0 (23/35). This is pretty impressive considering it was developed by Hyundai in house... AFAIK.
In any case, it's has much more power than the TSX, noticeably better performance, and gets better EPA ratings (21/30 for the TSX 5AT vs. 22/34 for the Sonata 2.0T 6AT).
http://www.caranddriver.com/reviews/...take_road_test
"Not so fast. Our test car ran from zero to 60 mph in 6.2 seconds and to the quarter-mile mark in 14.7 at 99 mph. A Camry V-6 cracks six seconds to 60 (5.8) and covers the quarter-mile in 14.3 at 99. A Mazda 6 s Grand Touring sedan with V-6 power hits 60 mph in 6.1. And both V-6 cars with automatics are quicker in the 5-to-60-mph street-start sprint."
My point was that, despite having the 2nd best in-class power to weight ratio, it's actually not THAT fast. Unfortunately, there's no observed mpg for the Camry on C&D's site too. On the other hand, C&D got 21mpg in the TL SH-AWD 6MT (http://www.caranddriver.com/reviews/...take_road_test).
C&D also got 25mpg in the TSX V6:
Curb weight: 3620 lb
C/D TEST RESULTS:
Zero to 60 mph: 6.1 sec
Zero to 100 mph: 15.6 sec
Zero to 120 mph: 28.3 sec
Street start, 5–60 mph: 6.3 sec
Standing ¼-mile: 14.7 sec @ 97 mph
Top speed (governor limited): 131 mph
Braking, 70–0 mph: 188 ft
Roadholding, 300-ft-dia skidpad: 0.85 g
FUEL ECONOMY:
EPA city/highway driving: 18/27 mpg
C/D observed: 25 mpg
Sonata:
Curb weight: 3443 lb
C/D TEST RESULTS:
Zero to 60 mph: 6.2 sec
Zero to 100 mph: 15.1 sec
Street start, 5–60 mph: 6.7 sec
Standing ¼-mile: 14.7 sec @ 99 mph
Top speed (governor limited): 153 mph
Braking, 70–0 mph: 180 ft
Roadholding, 300-ft-dia skidpad: 0.79 g
FUEL ECONOMY:
EPA city/highway driving: 22/33 mpg
C/D observed: 24 mpg
Despite using the outdated J series and the ancient 5AT while carrting an extra 200lb, the TSX V6 actually returned better observed mpg. Obviously, these cars were driven on different days and on different roads. However, I'd imagine with turbo is that good with fuel economy, it should still be much better than the old V6 right?
Also, despite having significantly more torque, especially at the low end, as well as an extra gear, the Sonata is still slower from 0-60mph and 5-60mph.
I also believe the Hyundai's engine is a "world engine" developed by Chrysler, Hyundai, and Mitsubishi together.
#805
Camry V6 is seriously fast for a family sedan. In SE form it's pretty sporty.
#806
Punk Rocker
How the hell did this become a TSX vs. Sonata thread??? The Sonata turbo costs around $25k while the TSX V6 comes in at well over $32k. Its a different segment for gods sakes!
#807
#808
You are right with Edmunds data. I was actually referring to C&D data (for both Sonata 2.0T and Camry V6).
C/D TEST RESULTS:
FUEL ECONOMY:
Sonata:
C/D TEST RESULTS:
FUEL ECONOMY:
C/D TEST RESULTS:
FUEL ECONOMY:
Sonata:
C/D TEST RESULTS:
FUEL ECONOMY:
http://www.caranddriver.com/var/ezfl...0dc8868a2e.pdf
When you look at 1-4 TSX test.
0-100mph is achieved in 18.5 second
0-120mph is achieved in 30.6 second.
It took 12.1 second from going 100mph to 120mph for I-4 TSX
Now when u look at your own data. It takes 12.7 second from going 100mph to 120mph for V6 TSX. Infact slower than I-4 which cannot be right.
The power to weight ratio of V6 TSX is way better and once your in high rpm range. 6MT not matter that much.
#809
M5 is not particular fast car or handles well for the amount of money it charges. M5 has horrible aerodynamic profile for high speed.
you dont need to spend extra $45k to generate extra performance.
how ever you can spend extra $10k over Sonata 2.0T to have better car. and not stuck with car that only pull 0.79g
Sonata 2.0T is not particulary cheap it lacks fully independent suspension for comfort, have low roof line in back. rear seat legroom is not of family car. so if it is not of family car so why not buy a sport sedan. instead of buying this compromise. Above all 2.0T is end of its advancement.
#810
Think harder once you put 6MT/6AT in TSX V6 with DI wish:
#812
R&T has achieved 5.9 Sec for 0-60 TSX V6. with 100mph @14,6 sec mark
#813
If you must reply to SSFTSX, PLEASE don't quote him. Thanks.
- from the 95% of automotive news that has him on their ignore list, which is made superfluous when others quoting him
#814
Actually, this is entirely possible. This shows the drawback with only 5 forward gears. I'm not sure if you have ever driven a J series Honda/Acura with a 5AT before, but 4th gear blows. Using my TL as an example, the 3rd gear takes the car up to around 100mph near the redline. Once the car shifts to 4th gear, the engine speed drops to around 4500rpm (from 7000rpm). It takes a while to get back to the "power" zone. 4th gear is very long. It's technically an overdrive gear since the ratio is lower than 1:1. On the other hand, with the close-ratio 6mt in the tsx, you stay in the vtec zone all the time.
5AT TL-SH-AWD takes only 11 sec going from 100mph to 120mph. So how is TSX V6 is losing speed but TL is not? when both have identical performance.
Fun part is TSX V6 is faster from 0-100 mph than TL but all of sudden TL gets faster after 100mph. Both have 5AT.
http://www.caranddriver.com/var/ezfl...1b15b66cd1.pdf
#815
#816
My first Avatar....
I wonder if he has ever driven a car, or actually seen one in person.
Or, does he just sit in a room pouring over hundreds of pages of magazines and web sites looking for "pearls of wisdom" regarding mirrors, tire width, coefficient of drag, vehicle height etc, etc, etc, so that he can share them with everyone here at AZ?
I know I'm now convinced...Acura is the only vehicle on earth worth spending a dime on. All trust in Acura. All HAIL to the god of automotive engineering...Acura. May Acura reign forever!
All those who will swear their allegiance to Acura, sign up below. Don't be shy now, you know who you are.
1. pttl
2.
3.
1. pttl
2.
3.
#817
#818
Uhh, the color red and Ferraris are synonymous - Honda, not so much.
And it's not like the red "S" is so special anyways. - lol
And oh, only a neophyte would go by the manufacturer's measurements for rear leg room since it all depends on far the front seat tracks go.
The proper way to judge rear seat room is set the front seat for cars in the comparison at a certain measurement - which, in this case, would result in rear seat leg room for the Sonata, Accord and Camry all within an inch or so of each other.
#819
Punk Rocker
#820
Theres fan boys like him on every forum but I havent seen a forum where there are so many people obsessed with trying to prove the fan boy wrong...even the mods are in on this mess...seriously I wouldn't say anything but its almost every thread in Automotive News now.
#821
אני עומד עם ישראל
He's trolling and we're guilty of keeping it going.
#822
My first Avatar....
No other car company has such fore thought and ingenuity such as Honda/Acura. Tires, Mirrors, Cd, ground clearance!
Don't forget it!
#823
SSFTSX, perhaps the the TL SH-AWD 5AT and the TSX V6 don't have identical performance. Check out the following links:
http://www.vtec.net/articles/view-ar...icle_id=783010
http://www.hondanews.com/channels/ac...specifications
The gear ratios are different.
TL AWD 5AT:
1st, 2.697
2nd, 1.606
3rd, 1.071
4th, 0.694
5th, 0.491
Reverse, 1.888
Final, 4.533
TSX V6:
1st - 2.697
2nd - 1.606
3rd - 1.071
4th - 0.694
5th - 0.491
Reverse - 1.888
Final Drive - 4.312
In other words, the engine and tranny in the TSX V6 are exactly the same as the TL FWD. But Acura fudged with the final gear with the TL AWD. With the more aggressive final gear, the TL AWD would have an edge.
Also, the power to weight ratio is better for the TL AWD, 13lb/hp vs 13.14lb/hp. Since you like to get into the details, I thought these numbers might be of interest to you.
Perhaps the combination of better power-to-weight ratio, shorter final gear, and some other small differences were more than enough to offset the burden of the AWD system?
#824
hahaha alright man
TL AWD 5AT:
1st, 2.697
2nd, 1.606
3rd, 1.071
4th, 0.694
5th, 0.491
Reverse, 1.888
Final, 4.533
TSX V6:
1st - 2.697
2nd - 1.606
3rd - 1.071
4th - 0.694
5th - 0.491
Reverse - 1.888
Final Drive - 4.312
TL AWD 5AT:
1st, 2.697
2nd, 1.606
3rd, 1.071
4th, 0.694
5th, 0.491
Reverse, 1.888
Final, 4.533
TSX V6:
1st - 2.697
2nd - 1.606
3rd - 1.071
4th - 0.694
5th - 0.491
Reverse - 1.888
Final Drive - 4.312
How can be Honda CrossTour be faster than TSX V-6 moving from 100 to 120mph. It is only 11.7 second. It is full one second faster than TSX V-6.
What kind of special 5speed automatic and power to weight ratio advantage Crosstour has over TSX V-6?. I am not going into aerodynamics.
http://www.caranddriver.com/var/ezfl...f4c09d9cd0.pdf
TSX V-6 is the fastest production 5speed Auto Acura/Honda. and it is proven beyond doubt from MT/R&T/Edmunds.
#825
relax there buddy I'm not defending anything...just giving some suggestions/opinions...chill out man!
You mentioned about the TSX V6 being the fastest production 5AT Acura/Honda. You know what, I think I agree with that, up to a certain degree. You said that it's been proven at MT/R&T/Edmunds. Well, I got a bit of time on my hand, so I went to MT, and it proves that you are right, the TSX V6 is the fastest, but I can only see prove up to the 1/4 mile. It doesn't say anything about 100mph+ (not that I care....). In fact, the TL SH-AWD also traps at the same speed as the TSX V6. What's after 100mph? Well, the TSX would have to shift to 4th gear. The TL, with its more aggressive final gear, is probably already in 4th gear by now for a while. What does that mean? It probably means that, while the TSX is stuck at around 4500rpm, the TL is probably at 5000rpm in 4th gear, ready to start pulling again. It's the same thing with Road and Track, it doesn't show anything after 100mph. What about Edmunds? Again, it only shows up to the 1/4 mile...it doesn't show anything beyond that.
http://www.insideline.com/acura/tsx/...and-video.html
http://www.motortrend.com/roadtests/...nce_specs.html
http://www.roadandtrack.com/tests/up...-acura-tsx-v-6
So you are right, and I agree with you, that it's been proven beyond doubt that the TSX V6 is the fastest production 5AT Acura/Honda....up to 100mph. C&D might be wrong, and they always make errors. For instance, that link you just posted about the crosstour, the writer wrote down 6 speed AT. So it's possible that they also made a mistake with the TSX V6 number. I just can't find the facts/numbers to also prove that, the TSX V6 is also fastest after 100mph.....but then, why would anyone care?
Crosstour FWD/AWD Gear Ratios:
1st: 2.697
2nd: 1.606
3rd: 1.071
4th: 0.766
5th: 0.612
Reverse: 1.889
Final Drive Ratio: 4.533
As you can see, this is the same tranny as the TL SH-AWD. I'm not sure if you have driven a J series powered car with the 5AT. I can tell you that my car would pull strongly in 1st, 2nd, and 3rd gear. But as soon as it hits 4th....damn....it feels like a corolla would be able to pass me.
1st: 2.697
2nd: 1.606
3rd: 1.071
4th: 0.766
5th: 0.612
Reverse: 1.889
#826
Oh i love a good bout of paper racing in the morning
#831
Hose
Hyundai's eagerly anticipated Sonata 2.0T model has just begun hitting U.S. showrooms, but a small quality issue that cropped up in the first batch of cars is causing some consternation. Conversations have been popping up on internet forums about the issue, and there has been some confusion as to the nature of the problem as well as questions about whether or not a stop-sale has been ordered by the company.
A small rubber hose that feeds oil to the turbo unit in very early 2011 Sonata Turbo models was apparently built to the wrong specification and needs replacement. According to a few user forum reports, some dealers haven't been allowing customers to test drive the vehicles until the correct part has been fitted. Additionally, at least one of the first 2.0T owners informed Autoblog that his dealer actually flat-bedded his car back for service. However, Hyundai officials tell Autoblog that this issue affects very few units, and they want to make it clear that no stop-sale has been issued.
Hyundai spokesman Dan Bedore:
"In about 30 cases, we had to get with customers who already had their cars. We're using the new hose in production and have finished retrofitting those that were built but not sold. We asked dealers to replace the hose before delivery but didn't issue a stop sale. No lost sales, no big disruption, the customer comes first – that's business as usual for Hyundai."
Hyundai's Sonata line has been an extremely strong seller since its introduction earlier this year, quickly moving the Korean automaker into third place in the hotly contested family sedan segment. However, the Sonata has also suffered some early teething problems, including the recall of 1,300 units over a possible door latch malfunction in March and the recall of 139,500 units over steering problems in late October.
#833
Minor.
#835
I shoot people
#836
The sizzle in the Steak
Turbos don't need oil...who cares about the hose.
Thankfully Hyundai has 100k power train warranty.
#838
Awesome.
#840
hail to the victors
C/D TEST RESULTS:
FUEL ECONOMY:
Sonata:
C/D TEST RESULTS:
FUEL ECONOMY:
C/D TEST RESULTS:
FUEL ECONOMY:
Sonata:
C/D TEST RESULTS:
FUEL ECONOMY:
i get less than 20mpg when i beat my civic to death.
This is more accurate mpg IMO.
http://www.insideline.com/hyundai/so...and-video.html
Edmunds observed (mpg) 25.2 worst/32.6 best/26.7 avg (over 1,030 miles)
