View Poll Results: What do you like Better?
Accord Concept Rims and Bodykit
54
73.97%
2004 Acura TL A-Spec Bodykit and Rims
19
26.03%
Voters: 73. You may not vote on this poll
Honda: Accord News
#361
Originally Posted by DEI99662
Front, Side, and Curtain Airbags are now standard on all models of the Accord. Now if only all the carmakers would do this on almost all models.
For MY 06, Honda will have them standard across their entire line.
#363
#364
8th Gear
2005 Accord Sedan Photos
The link has photos of the 2005 Accord Sedan. Can anyone who has an '04 model tell if there have been any changes?
http://www.hondacars.com/models/exte...rDetected=True
#365
http://www.acura-tsx.com/forums/show...ht=2005+Accord
Accord
Illuminated steering wheel controls for audio/cruise functions
Restyled alloy wheels
Side curtain airbags on ALL models
Slightly revised reverse light
Available Hybrid model
Looks like new 16" rims on the Sedan and all red tailights.
We'll keep it to one thread. Closing.
Accord
#367
Originally Posted by biker
Besides always being on the green bandwagon, Honda has decided to jump on the safety one as well.
#371
Boy Genius
I do not like the new taillights - first thing that came to my mind was early 90's Buick Regal. I didn't think they were that bad to begin with, but I really wish Honda had spent some more time on the front end, like the one they sell in the Asia Pacific markets.
#372
I agree that the Asian model looks better with the chrome strip at the grill and the revised bumper and fogs.
However I think theshould have restyled it with the chrome strip and less dramatic headlights (HID preferably) that don't swoop back as much. I think that look is going to get old very fast and not age well. To me, Nissan did the right thing by restyling the Altima's headlights. Honda should follow suit and style the Accords more like the TSX for a crisper look.
I think the EX V6 should come with HIDs.
#374
Old fart
I like those foggies alot better than the ones here..
#375
Originally Posted by TSX 'R' US
Why can't the US Accord look like that? I've seen tons of pics of that on the Aussie Honda website...Looks alot better IMO.
In fact, if the styling were more like in that pic, or like the inspire, I would probably own one right now.
#377
Frozen Wannabe Oracle
'05 Accord Hybrid Specs and Press Release
Originally Posted by vtec.net
2005 Honda Accord Hybrid Specifications
ENGINE
Type: Aluminum-Alloy V-6
Displacement (cc) 2997
Bore x Stroke (mm) 86x86
Horsepower @ rpm (SAE net) 255@6000
Torque (lb.-ft.@rpm) 232/5000
Compression Ratio 10.5:1
Valve Train SOHC i-VTEC
Fuel System PGM-FI
Ignition System Full Transistor High Power
Idle Stop Feature x
CARB Emissions Ratings LEVII-ULEV
EPA Emissions Rating Tier 2, Bin 5
Tune-Up Interval (miles) 105,000
12V Battery 120AH
ELECTRIC MOTOR / GENERATOR
Motor Type: Permanent Magnet Motor x
Power Output (kW / horsepower @ rpm) 12 kW /16 hp @ 840 rpm
Torque (lb.-ft.@rpm) 100 @ 840 rpm
Motor Width (mm) 68
Rated Voltage 144
IMA ELECTRICAL SYSTEM
Type of Battery Ni-MH
Output 144 V (120 cells @1.2 V) 13.8 kW
Rated Capacity 6.0Ah
Alternator (DC-DC Inverter) 144 Volt to 12 Volt
DC-DC Inverter (for Dual Scroll Hybrid A/C Compressor) 144 Volt to 24 Volt
POWERTRAIN
Type: Front-Wheel Drive x
Automatic Transmission: 5-Speed x
Gear Ratios: 1st 2.685
2nd 1.565
3rd 1.023
4th 0.729
5th 0.530
Reverse 1.888
Final Drive Ratio 4.375
CHASSIS
Body Type: Unit Body Unit Body
Suspension (front/rear) Independent Double Wishbone, Coil Spring with Stabilizer
Stabilizer Bar (mm, front/rear) 25.4/14
Steering Type Electric, Power Assisted, Rack and Pinion
Steering System, Overall Ratio 16.25
Turns, Lock to Lock 3.17
Ventilated Front Disk/Solid Rear Disk Brakes x
Anti-Lock Braking System (ABS) x
Disc Brake Diameter (in., front/rear) 11.1/10.2
Electronic Brake Distribution (EBD) x
Traction Control Sysytem (TCS) x
Wheel Size 16x6.5
Tire Size P215/60R16
Shock Absorbers Telescopic, Hydraulic Nitrogen Gas Filled
EXTERIOR DIMENSIONS
Wheelbase (in.) 107.9
Length (in.) 189.5
Height (in.) 57.1
Width (in.) 71.5
Track (in., front/rear) 61.1/61.2
Curb Weight (lbs.) 3501
Weight Distribution (lbs., front/rear) 2143/1358
Gross Vehicle Weight Rating (lbs.) 4453
INTERIOR DIMENSIONS
Headroom (in., front/rear) 40.4/38.5
Legroom (in., front/rear) 42.6/36.8
Shoulder Room (in., front/rear) 56.9/56.1
Hiproom (in., front/rear) 54.6/53.5
Cargo Volume (cu. ft.) 11.2
Passenger Volume (cu. ft.) 102.7
Seating Capacity 5
EPA MILEAGE ESTIMATES**/FUEL CAPACITY
City/Highway 30/37
Fuel (gal.) 17.1
Required Fuel Regular Unleaded
Driving Range 633 miles
ENGINE
Fuel System PGM-FI
Idle Stop Feature x
12V Battery 120AH
Motor Width (mm) 68
Rated Voltage 144
POWERTRAIN
2nd 1.565
3rd 1.023
4th 0.729
5th 0.530
Reverse 1.888
CHASSIS
Wheel Size 16x6.5
EXTERIOR DIMENSIONS
Length (in.) 189.5
Height (in.) 57.1
Width (in.) 71.5
INTERIOR DIMENSIONS
Seating Capacity 5
City/Highway 30/37
Fuel (gal.) 17.1
Originally Posted by Hondanews
All New 2005 Accord Hybrid Uses Advanced Honda Hybrid Technology to Deliver V-6 Performance with Four-cylinder Fuel Efficiency
World's First V-6 Hybrid Boasts 255 Horsepower and 30 city/37 highway EPA fuel economy
Torrance, Calif. 09/17/2004 --
American Honda will debut the all-new Accord Hybrid, the world's first V-6-powered hybrid vehicle and Honda's third hybrid model, at dealerships nationwide on December 3, 2004. The all-new Accord Hybrid utilizes the third-generation of Honda's advanced Integrated Motor Assist (IMA) full hybrid system in combination with new Variable Cylinder Management (VCM) cylinder deactivation technology to deliver the world's best V-6 fuel efficiency - on par with a 4-cylinder, compact class Civic - along with highly responsive and powerful V-6 performance. With the introduction of the Accord Hybrid, Honda now becomes the first company in the world to offer three distinct hybrid models including the world's first V-6 hybrid.
"The Accord Hybrid is the first hybrid vehicle that combines superb fuel economy with truly exhilarating performance," said Tom Elliott, executive vice president of American Honda. "By applying hybrid technology to two of America's most popular vehicles, first the Civic and now the Accord, we are taking hybrids even further into the mainstream."
The Accord Hybrid achieves an estimated EPA fuel economy rating of 30mpg in the city and 37mpg on the highway, an increase of 43 percent over the current Accord V-6 in city driving and 23 percent in highway driving. In addition, the Accord Hybrid delivers 255 horsepower (versus 240hp for the Accord V-6 Sedan) with an exceptionally broad and flat torque curve for outstanding power and driving performance.
Acceleration performance from 0-60 miles per hour and from 50-70mph is reduced by one half second compared with the already powerful and sporty Accord V-6 Sedan.
The new Accord Hybrid also comes equipped with a high level of premium features and equipment including a leather interior, dual zone automatic hybrid climate control, 8-way power driver's seat, XM Satellite radio and 6-disc CD changer. In keeping with Honda's industry-leading 'Safety for Everyone' initiative, all Accord Hybrids also come equipped with a comprehensive list of advanced safety features including driver and front passenger side airbags, first and second row side curtain airbags, four-wheel anti-lock brakes (ABS) and Traction Control System (TCS). An exclusive rear deck lid spoiler and specially designed alloy wheels contribute to the Accord Hybrid's improved aerodynamic performance.
The Accord Hybrid's instrument panel incorporates an exclusive meter display that shows key operating indicators of the IMA system, including the state of the IMA battery charge, the level of IMA motor assist or charge, and a light to indicate Idle Stop mode. There is also an "ECO" light to indicate that the vehicle is achieving a high level of fuel economy and the VCM is operating in 3-cylinder mode.
To further improve overall fuel efficiency and maintain precise and responsive handling, the Accord Hybrid utilizes a number of exclusive weight saving features including a lightweight aluminum hood and bumper beams (front and rear), along with a magnesium engine head cover and dual-stage intake manifold. Other fuel saving features include an Electric Power Steering (EPS) system - like the one used on the high-performance S2000 sports car - and a new more efficient dual scroll"hybrid" air conditioning compressor.
Third Generation IMA System and i-VTEC with VCM
Honda's third generation Integrated Motor Assist (IMA) system is improved in virtually every area including increased motor output, improved battery performance and greater total system efficiency. Compared to the Civic Hybrid, IMA motor torque output is improved by 26 percent during startup and is more than doubled during driving to 100 lb.-ft. from 46 lb.-ft. Also, battery output density increases by 45 percent while battery assist power increases by 20 percent. Regenerative braking efficiency is up 11 percent.
The Accord Hybrid's 3.0-liter i-VTEC V-6 engine has the same 3.0-liter displacement as the regular Accord V-6, but employs a number of unique features including a dual-stage intake manifold and a high-performance lock-up torque converter. A new, more compact 5-speed automatic transmission with an electric oil pump is designed to provide smooth start-up from Idle Stop, and helps allow for packaging of the engine, IMA motor, engine torque converter and automatic transmission. Adding to overall efficiency is a "hybrid" air conditioning compressor that runs on both the gasoline engine and the IMA battery and provides for good air conditioning performance even when the engine is in Idle Stop mode.
IMA, VCM and Idle Stop Operation
The IMA system's 12-kilowatt, high-output, electric motor contributes more than 100 lb.-ft. of torque to the Accord Hybrid's 3.0-liter V-6 engine during hard acceleration and recaptures kinetic energy generated during deceleration and braking for storage in the IMA system's advanced nickel-metal hydride battery pack. When cruising at steady speeds where less engine power is required, the VCM system deactivates the V-6 engine's rear bank of cylinders, closing both the intake and exhaust valves for reduced fuel consumption.
Under light acceleration from a cruising state, the IMA motor can provide power assistance to the engine in three-cylinder mode. When coming to a stop, the IMA system shuts off the vehicle's engine at speeds below 10mph to reduce fuel consumption and exhaust emissions. At the moment the driver releases the brake pedal, the IMA motor instantaneously restarts the gasoline engine.
Honda Hybrid Leadership
Honda has long been at the leading edge of new automotive technologies, especially in the area of improved fuel economy and reduced emissions. With the introduction of the Insight in December 1999, Honda became the first company to sell a hybrid vehicle in the U.S. With an aluminum body, ultra-efficient IMA powertrain and world-class aerodynamics, the Insight has held the title of America's most fuel-efficient car for each of the past five model years (2000-2004). In March 2002, Honda applied its hybrid technology to the Civic, America's best-selling compact car. The Civic Hybrid accounted for half of all new hybrid vehicle registrations in calendar year 2003 and took two of the top five spots on the EPA's model year 2004 fuel economy rankings. Sales of the Civic Hybrid are up 16 percent to 17,805 units through the end of August this year.
Honda Accord History
Since its introduction as a compact hatchback car in 1976, the Honda Accord has earned widespread acclaim as a leader in smart design, superb quality and world-class efficiency. In its 28-year history, the Accord has constantly re-invented itself, going from the original compact hatchback to today's mid-sized sedan and coupe. The seventh-generation Accord, released in 2003, once again raised the bar for performance, safety and value in its class with a highly efficient and powerful 3.0-liter, 240-horsepower VTEC V-6 engine, standard anti-lock brakes (ABS) and standard features such as tilt-telescoping steering, air conditioning, power windows, mirrors and door locks, and an AM/FM/CD stereo. In addition, the seventh-generation Accord was one of the first mid-sized sedans to bring luxury features such as a voice-activated navigation system, XM satellite radio and side curtain airbags to the premium mid-size segment.
Additional media information with technical information and photography is available www.hondanews.com. Consumer information is available at www.hondacars.com.
#380
Thats what I was wondering. Is that 255HP/232lb-ft rating with the electric engine or the output of the 3.0L alone? If its the 3.0L alone, I'd have to wonder why regular V6 Accords wouldn't have gotten the same bump.
#381
They probably didn't bump the regular Accord to give some separation for the numbers people, or the regular V6 is simply under-rated, which isn't that far fetched.
#382
I was going to point that out, but then I checked the ratings for the normal V6...and it produces 240hp at 6,250RPM...which means this engine is producing 15 more hp at 250 less RPM. So I think that's inclusive of the hybrid power.
#383
But I doubt that electric motor will be doing anything when the engine is spinning at 6000 rpm.
#384
I'm the Firestarter
What's the price???
#385
Here a link to all the released info:
http://hondanews.com/CatID2128
#387
Originally Posted by STL
Did anyone else notice the cargo capacity took a noise drive from 14.0 to 11.2 cubic feet -- any that's with the Hybrid loosing the spare tire!
#388
Registered AssHat
Distribution 61.2%/38.8%
Not too bad. I was worried it would become unbalanced.
#390
Registered AssHat
Originally Posted by Dan Martin
I'm surprised they went with a 5AT and not a CVT. I don't know how this is supposed to work but I'd like to drive one to see it in action.
#392
#393
3rd Gear
News Release for Accord Hybrid/ TL competition
Further details were released today for the Accord Hybrid. Honda claims half a second better 0-60 and 50-70 numbers compared to the V6 Accord and of course great mileage numbers. I was planning to get a 2005 TL but have second thoughts. What's your take on it.
Press Release
Source: American Honda Motor Co.
All New 2005 Accord Hybrid Uses Advanced Honda Hybrid Technology to Deliver V-6 Performance with Four-Cylinder Fuel Efficiency
Friday September 17, 11:44 am ET
World's First V-6 Hybrid Boasts 255 Horsepower and 30 City/37 Highway EPA Fuel Economy
TORRANCE, Calif., Sept. 17 /PRNewswire/ -- American Honda will debut the all-new Accord Hybrid, the world's first V-6-powered hybrid vehicle and Honda's third hybrid model, at dealerships nationwide on December 3, 2004. The all-new Accord Hybrid utilizes the third-generation of Honda's advanced Integrated Motor Assist (IMA) full hybrid system in combination with new Variable Cylinder Management (VCM) cylinder deactivation technology to deliver the world's best V-6 fuel efficiency -- on par with a 4-cylinder, compact class Civic -- along with highly responsive and powerful V-6 performance. With the introduction of the Accord Hybrid, Honda now becomes the first company in the world to offer three distinct hybrid models including the world's first V-6 hybrid.
To further improve overall fuel efficiency and maintain precise and responsive handling, the Accord Hybrid utilizes a number of exclusive weight saving features including a lightweight aluminum hood and bumper beams (front and rear), along with a magnesium engine head cover and dual-stage intake manifold. Other fuel saving features include an Electric Power Steering (EPS) system -- like the one used on the high-performance S2000 sports car -- and a new more efficient dual scroll "hybrid" air conditioning compressor.
Press Release
#396
If being green is important to you the hybrid Accord will definitely be a better choice for you than the TL.
The TL will still top the hybrid Accord in terms of performance and luxury (255 HP vs TL 270 HP).
I expect the hybrid Accord to be in high demand like the Toyota Prius, have a long waiting list, and sell at sticker or above (so you may not save a lot of $$ compared to the TL).
#398
Originally Posted by AsianRage
The Accord still look very ugly. They should try it on the TL...
#399
I think that's because the battery packs are located on the back of the backseats. I didn't know it lost the spare tire, though...does that mean it gets runflats?
#400
Take it from a guy who's about to his Accord for the TL, skip the Accord. The current model is not good looking and the 05 model looks worse because of the redone tail lights. I got the Accord cause I thought the TL wasn't worth it. Now everytime I see a TL, I less my Accord less. I'm telling you. Skip the Accord.
