Dodge: Ram News
#161
2013 Ram 2500/3500 Heavy Duty
Press release...
Ram Truck brand now offers the most capable heavy-duty pickups in the segment – the new 2013 Ram Heavy Duty line features best-in-class towing and best-in-class Gross Combined Weight Rating (GCWR). Ram 2500 and 3500 Heavy Duty trucks also add new features, including an all-new interior, next-generation Uconnect Access, Powernet, new frames and new suspension. The new 2013 Ram Heavy Duty further solidifies the long list of leadership claims, including best-in-class total cost of ownership.
“To answer the needs and wants of our customers, Ram Truck has taken a big step forward in capability while improving cost of ownership and efficiency,” said Fred Diaz, President and CEO, Ram Truck Brand and Chrysler de Mexico — Chrysler Group LLC. “The 2013 Ram Heavy Duty allows you to push and pull more than any competitor, and the truck looks great doing it with new exterior design cues and an all-new interior featuring our latest technology.”
ENGINEERING
Frames
For 2013, Ram Heavy Duty trucks feature new frames built with high-strength 50 KSI steel, including eight separate cross-members, hydroformed main rails and fully boxed rear rails for optimal strength and mass efficiency. Wider front frame rails (approximately one inch per side; two inches overall) enable front suspension springs to be positioned slightly outboard, an enabler for generating more positive roll stiffness. A new front suspension cross member is now a two-piece welded component between the front axle and oil pan.
Center frame rail sections are roll-formed, an efficient means for maintaining consistent strength in less complex longitudinal sections. In the rear portion of the new frame, the structure includes fully boxed rear rails and a factory-installed rear axle cross member with provisions for 5th wheel and gooseneck hitches. A new conventional trailer hitch system is upgraded to Class 5 with a 17,000-lb. load capability and 1,800 pounds of tongue weight for use with 2-inch or 2.5-inch receiver hitches.
Suspension
To handle the best-in-class towing and payload capability of the new Ram Heavy Duty, a new front and rear suspension system with advanced geometry builds upon the chassis improvements and greatly improves overall roll stiffness. An advanced three-link front suspension on the Ram 3500 is necessary for the vehicle’s higher GVWR and for use with heavy front loads, including snow plows. Additionally, a newly designed Hotchkiss leaf spring rear suspension on the Ram 3500 offers improved ride and handling while delivering higher towing and payload capability.
Steering
The new premium recirculating ball steering gear, redesigned steering knuckles, ball joints and more robust steering linkages deliver enhanced and precise on-center feel despite the vehicles higher towing and payload capacities.
Body
A number of body improvements have been made to enhance overall noise, vibration and harshness (NVH) and to align with the best-in-class capabilities of the 2013 Ram Heavy Duty. The new truck comes equipped with an updated engine, transmission and body mounts, including pioneering hydro-mounts at C-pillar positions for class-leading NVH characteristics despite the truck’s aptitude for higher payloads and towing.
A new capless fuel filler on diesel applications is a space-saving initiative that enables side-by-side fuel and diesel exhaust fluid (DEF) port configuration. The result is more convenient fuel and DEF re-fill at pump stations.
The Ram 3500 features a factory-installed trailer tow connector in the truck bed, included with the optional 5th wheel or gooseneck tow prep package. New structural support is designed into the body to support the payload increase and improve durability performance. Additionally, new reinforced tie-down points with enhanced strength are designed for heavier loads.
Electrical
The new Ram Heavy Duty now features the Powernet electrical architecture system allowing both high and low-speed data networks to be equipped with as many as 40 individual modules, all designed to improve vehicle performance and enhance the comfort and safety of driver and passengers.
A majority of the commercial truck customers need to tie into the electrical system. A new best-in-class, vehicle system interface module (VSIM) is capable of communicating between aftermarket modules and various factory control modules. The VSIM up-fitter interface module features a total of 72 inputs and outputs, including lighting controls, door position and throttle and transmission position. The class exclusive module acts as a secure gateway to the vehicles’ electrical system.
Additional new features
New for 2013, central locking includes the RamBox cargo management system and tailgate power locks, creating a convenient solution for locking all exterior doors and storage with one push of a button. Auto rain-sensing wipers and SmartBeam headlamps also find their way into the feature availability list of the new 2013 Ram Heavy Duty.
Total cost of ownership and unsurpassed powertrain warranty – 5 years/ 100,000 Miles
Operating costs are of great consideration for owners who use their trucks for work. The 2013 Ram Heavy Duty holds class-leading features in:
Fuel economy with introduction of a new DEF system
Extended maintenance cycle (oil change, fuel filter life)
Brake life with advanced engine exhaust brake and largest brakes in the segment
The 2013 Ram Heavy Duty is backed with an unsurpassed 5-year/100,000-mile Powertrain Limited Warranty. The powertrain-limited warranty covers the cost of all parts and labor needed to repair a covered powertrain component – engine, transmission and drive system. Coverage also includes free towing to the nearest Ram Truck dealer, if necessary. The warranty also is transferable allowing customers who sell their truck during the warranty period to pass the coverage onto the new owner. The standard 3-year/36,000-mile Basic Limited Warranty provides bumper-to-bumper coverage for the Ram Heavy Duty, from the body to the electrical system.
POWERTRAIN
For 2013, the 5.7-liter HEMI® V-8 makes its debut in Ram 3500 Heavy Duty pickup as standard equipment (single rear wheel). Also standard in the Ram 2500 Heavy Duty, the engine produces 383 horsepower at 5,600 rpm and generates peak torque of 400 lb.-ft. at 3,950 rpm. The HEMI V-8 is mated to a 66RFE six-speed automatic transmission.
Dominating the power charts, the renowned 6.7-liter Cummins High-Output Turbo Diesel I-6 is now available in three versions. The first version is paired with Ram’s segment exclusive six-speed manual transmission, which features a wear-compensating clutch for lifetime “like-new” performance and a dual-trunion shift tower to accommodate a compact shift pattern. This combination delivers 350 horsepower at 2,800 rpm and 660 lb.-ft. of torque at 1,500 rpm – a significant boost from the 2012 model-year maximum of 600 lb.-ft.
The second option matches the Cummins to the 68RFE six-speed automatic transmission. The diesel engine cranks out 370 horsepower at 2,800 rpm with an unsurpassed in ¾-ton trucks 800 lb.-ft. of torque at 1,600 rpm.
Finally, an upgraded 6.7-liter Cummins High-Output Turbo Diesel I-6 for Ram 3500 is paired with a new Aisin six-speed automatic transmission (AS69RC), leaving no doubt to Ram Heavy Duty’s capability. In addition to 385 horsepower at 2,800 rpm, the most powerful Cummins generates best-in-class torque of 850 lb.-ft. at 1,600 rpm. The new AS69RC transmission features wide gear ratios that contribute to upgraded shift performance, an approximate 1 percent gain in transmission efficiency and improved driveability when compared to the previous design.
For 2013, all Ram Heavy Duty diesels benefit from an all-new cooling system. A high-efficiency fan, dual radiators, dual transmission coolers and charge air cooler afford 25 percent more heat-rejection capacity. Lower operating temperatures deliver improved performance, durability and lower operating costs.
Diesel-equipped Ram Heavy Duty pickups feature an industry-exclusive Ram Active Air intake system, activated by new monitoring capabilities added to the engine controller. When the intake system senses extreme heat, it draws cool air from the front of the vehicle – a function that also engages at high altitudes for superior throttle response in low oxygen environments. When conditions are wet from snow, ice or water-fording, the system pulls air from an underhood inlet clear from snow packing and water ingestion.
The list of 2013 diesel-engine features does not end there. The Cummins powerplants benefit from a larger exhaust-gas recirculation (EGR) cooler, which complements the debut of selective catalytic reduction (SCR) and accommodates a best-in-class oil-change interval of 15,000 miles. Oil life is increased by reducing soot production and reducing fuel dilution of the oil.
Combined with a 10 percent improvement in fuel economy due in part to the engines’ high-pressure common-rail fuel system, SCR promises a net reduction in Ram Heavy Duty operating costs. The SCR-equipped diesels, which can run on B-20 biofuel, also operate cleaner by lowering greenhouse-gas emissions and better managing soot production than Lean NOx Trap (LNT) technology.
From behind the wheel, the diesels deliver improved cold-start performance and superior refinement from innovations such as the new smart exhaust brake system. Enabled by Cummins’ unique, proprietary sliding-nozzle turbine design, the feature electronically manages best-in-class exhaust braking for smoother downhill driving, regardless of vehicle load.
Cummins’ variable-geometry turbocharger also affords more effortless operation at higher altitudes, greater management of EGR flow rates and improved control over exhaust temperatures to accommodate de-sooting.
For the 2013 Ram Heavy Duty, no detail was too small to consider – an approach that inspired the design of a new fuel filter/water separator. The frame-mounted unit delivers best-in-class, 3 micron particulate filtration and water stripping for improved engine performance and durability.
Capability is high on the priority list for Ram engineers, evidenced by axle upgrades for 2013.
The 2013 Ram 3500 boasts a best-in-class GCWR. A contributor is the 11.8-inch rear axle matched with the diesel engine boasting a 300-mm hypoid gear set, a 4-pinion helical differential and an aluminum ring-gear cover for optimal cooling – and improved aesthetics.
The Ram Heavy Duty also features a segment-exclusive front axle disconnecting system. When conditions warrant, select drivetrain components are disconnected, improving overall efficiency and enabling a gain in fuel efficiency of up to 1 mpg.
DESIGN
The new 2013 Ram 2500 and 3500 Heavy Duty models uphold a bold presence while retaining comfort and styling with exterior design changes. The new Ram Heavy Duty also features an all-new interior and all-new segment-leading technology – every model offers new, specific content.
Exterior
Aligning with all-new grilles, the 2013 Ram Heavy Duty quad headlamp design has improved light spread, pattern consistency and distance. An all-new premium headlamp and lighting system features bi-functional halogen projectors and LEDs for park/turn and tail lamps.
New power folding 6x9-inch outside mirrors help to monitor traffic and obstacles on the side of the truck and allow a better view of the trailer when towing.
A tailgate handle-mounted rear camera back-up system has been upgraded for 2013 with higher definition and dynamic imaging in the 8.4-inch display. Also, a new center high-mounted stop light (CHMSL) camera provides a view of the bed for easier 5th wheel or gooseneck trailers as well as monitoring bed loads.
Ram 3500 models feature new, crafted 18-inch and 20-inch wheel designs that incorporate trim level themes.
Exterior door and fender badges are relocated to a portrait style format from the current landscape format, yielding not only a cleaner appearance but more usable real estate on the door for a commercial customer’s signs and graphics.
The new, wheel-to-wheel, polished stainless steel running boards have a sturdy-looking box cross-section design with a hexagon tread pattern and offer aerodynamic improvements while providing customer’s improved access to the forward portion of the truck bed.
Interior
New Ram Heavy Duty features and technologies create an opportunity for a redesigned interior with material upgrades, improved fit and finish, new colors, HVAC controls and new multi-media systems.
The 2013 Ram Heavy Duty features the next generation 8.4-inch Uconnect system with background screens tailor-made to specific Ram models and themes. To make room for the new big screen, the center stack is upgraded with matching materials found throughout the interior. Complementing the range of Ram Heavy Duty models, the interior design team created new, individualized themes with different colors and materials.
The all-new HVAC controls take lessons learned from other Chrysler Group Uconnect applications and feature simple, improved function meeting the highest Human Machine Interface (HMI) standards. The HVAC system includes a redundant architecture allowing the operator to use either the 8.4-inch touchscreen or manual controls to alter the truck’s environment. Below the upgraded HVAC arrangement is a new switch bank with relocated, easy-to-use controls for a number of features depending on vehicle models and options. The top row is for functional features and includes exhaust brake, tow/haul and electronic stability control (ESC). The bottom row is for comfort controls and includes heated steering wheel, heated seats and ventilated seats. The bottom row also can be optioned as an auxiliary switch bank for all five spots. All buttons in the comfort bank also are redundant in the Uconnect system. Contiguous to the switch bank is a prominently placed adjustable integrated trailer brake control allowing the driver to add or reduce trailer brake function on the fly. The new console center stack includes a 115-volt outlet and new drawer at the base of the stack with a smooth, premium feel tool box-slide action. The new drawer features 12-volt outlets on either side and an optional powered USB on the driver’s side.
New technology also moves to the gauge cluster. Previously only available on premium models, the 3.5-inch vehicle information center screen is now standard on entry level trims and displays vehicle-operating functions. The new thin-film transistor (TFT), 7-inch multiview display is now available on select models and features fully customizable function and configurability. Similar to the 8.4-inch Uconnect system, select 7-inch cluster background screens are tailor-made to specific Ram models.
All Ram Heavy Duty trucks continue to use a column shifter for the automatic transmission. Electronic Range Select (ERS) is now located on the face of the steering wheel, right side, allowing individual gear selection. Diesel models offer a manual six-speed transmission, the only manual transmission offering in the segment.
The center consoles for both the bucket and 40-20-40 bench seat configurations are all-new with efficient storage in mind. The new bucket seat console uses the extra space as additional storage. The bench seat design includes three new cup holders built into the console lid that features a washable rubber bellow lining. Both versions of the console feature two tiers of storage and are available with a new multi-media port with USB, SD card and auxiliary inputs in the upper tier. Additionally, a 2.5-amp USB power port and 12-volt outlet are available to meet device-charging needs.
UCONNECT
The 2013 Ram Heavy Duty lineup offers a truckload of innovative, segment-exclusive technology, adding all-new features to an already best-in-class interior. New for 2013, Ram offers the next-generation radio platform, which features Uconnect Access, a more powerful, in-vehicle connectivity system.
Building upon base radio capability, two new Uconnect systems are offered to provide Ram customers with a range of features and connectivity options to best suit their needs. The Uconnect 8.4A and 8.4AN provide Ram truck owners with a built-in wireless connection allowing vehicle occupants to automatically connect to a variety of new services. Users can remotely lock or unlock doors or start their vehicles from any distance via the web or a smartphone application. The new Uconnect system includes a 911 button on the rear-view mirror for a direct connection to emergency services. An ASSIST button also is integrated into the rear-view mirror to summon help directly from a roadside assistance provider or connect with Chrysler Group’s Vehicle Customer Care Center.
Wi-Fi hotspot capability enabled by Uconnect Access provides in-cabin wireless Internet connectivity via laptop, tablet or smartphone, whether on the move or at the worksite.
Applications are updatable over the air and are downloaded directly to the Uconnect 8.4A and 8.4AN systems, keeping features current. Ram truck owners will be able to continually evolve their in-vehicle connectivity experience by downloading application updates or new applications as they become available.
The new Uconnect Access system features best-in-class functionality, integrating new entertainment content, including the first time Ram has offered HD radio to its customers. Ram owners also will have access to SiriusXM radio, handsfree mobile phone operation, handsfree navigation, handsfree texting with compatible phones and handsfree control of music.
Uconnect Voice Command allows drivers to control their mobile phone, music and navigation system while staying focused on driving. The phone book within a compatible phone is automatically downloaded, synchronizing as many as 1,000 phone book entries, which can then be selected by simply saying a contact name. The feature also allows drivers to switch radio modes, tune to AM, FM, HD and SiriusXM Radio stations and request real-time information (such as fuel prices) from the available SiriusXM Travel Link using natural voice commands.
Uconnect supports Bluetooth-equipped cell phones with Message Access Profile (MAP) advanced text-messaging. This industry-first voice recognition uses the embedded connectivity to access cloud-based voice-recognition and enable advanced text messaging, which converts the spoken word into verbatim text messages. Communication is limited only by the user’s vocabulary.
Filling the gauge cluster in front of the driver is an available 7-inch, color, premium multiview display, featuring a new customizable function that enables Ram customers to personalize information inside the instrument cluster. Ram’s new information display is designed to visually communicate information, using graphics and text, quickly and easily. The multiview display offers drivers a wide range of customization options, from a basic digital speed read out to specific vehicle status information. Operation of the display is clearly communicated to users with easy-to-understand icons and instructions.
The 2013 Ram Heavy Duty offers an audiophile-quality audio system to immerse passengers in premium sound. Alpine high-performance speakers and an advanced digital signal processing (DSP) amplifier are available with the Alpine 10-speaker premium audio system.
SAFETY AND SECURITY
Ram Heavy Duty trucks offer more than 45 active and passive safety and security features, including standard front air bags and seat-mounted side pelvic-thorax air bags with Enhanced Accident Response System, knee bolsters, seat-belt pretensioners, BeltAlert and ParkView rear back-up camera system. The 2013 Ram Heavy Duty trucks also include standard electronic stability control (ESC), a segment exclusive on 3500 Heavy Duty. ESC hosts a number of technologies including all-speed traction control, trailer-sway control, Hill-start Assist and anti-lock brake system (ABS).
The new 2013 Ram Heavy Duty trucks now offer Keyless Enter ’n Go technology, which allows the doors to be unlocked and the truck to be started without having to touch the key fob. Also new for 2013, remote central locking includes the RamBox cargo management system and tailgate powerlocks, creating a convenient solution for locking down the truck with the push of a button. An available remote start feature allows a driver to start their truck from up to 300 feet away. Door controls, illuminated entry, engine immobilizer and panic alert are standard features with the Keyless Enter ’n Go system. Auto rain-sensing wipers and SmartBeam also are new offerings, adding to a long list of content.
Manufacturing
Start of production of the 2013 Ram 2500 and 3500 Heavy Duty is scheduled for the first quarter of 2013 at the Saltillo Truck Assembly Plant in Coahuila, Mexico.
ENGINEERING
Frames
Suspension
Steering
Body
Electrical
POWERTRAIN
DESIGN
Exterior
Interior
UCONNECT
SAFETY AND SECURITY
Manufacturing
#162
The sizzle in the Steak
2014 Ram 1500 EcoDiesel rated at 28mpg
The Environmental Protection Agency has rated Ram's 2014 1500 EcoDiesel at 28mpg on the highway, making it the most fuel-efficient full-size pickup truck on the market today.
The Ram's 3.0L V6 EcoDiesel is also thrifty in city driving, earning a 20mpg rating on the agency's city cycle. The EPA says the Ram EcoDiesel should return 23mpg in mixed driving.
All three marks are good for tops in the full-size pickup truck segment.
"The new Ram 1500 EcoDiesel is truly in a class of it's own with 28mpg and the ability to tow 9,200 pounds," said Reid Bigland, President and CEO of the Ram brand. "To put the Ram 1500 EcoDiesel in context, it gets 6 mpg better fuel economy than the best F150 EcoBoost. Overall the Ram 1500 EcoDiesel has outstanding pick-up truck capability with compact car-like fuel economy."
The 2014 Ram EcoDiesel is powered by a 3.0L turbo diesel sourced from Fiat's VM Motori. The V6 is good for 240 horsepower and a V8-rivaling 420 lb-ft of torque. The diesel engine shifts through Ram's new eight-speed automatic transmission.
Ram will begin taking orders for the 2014 1500 EcoDiesel on February 7. The truck will carry a base MSRP of $24,200 (not including a $1,195 destination charge), or about $2,850 more than a comparably equipped HEMI V8 model.
Including the 25mpg 3.6L V6 1500 model, Ram now holds the top two efficiency spots in the full-size truck segment.
http://www.leftlanenews.com/2014-ram...#ixzz2sO2GWlcp
#164
No more Cummins? Or did they just rename it?
Now where will I put my "I'd rather be Cummin than Strokin" decal??
#165
The Third Ball
Received 4,824 Likes
This is 3.0 diesel you can get in the jeeps now, too.
It also makes the Ram 1500 the ONLY truck in its class to offer diesel and because of that and its performance led it being named motor trends truck of the year for the 2nd year in a row.
It goes up against the F150s EcoBoost...but supposedly performs better with better mpg.
#166
boost MPG numbers versus diesel MPG numbers........diesel are more realistic.....boosted....not so much
#167
The Third Ball
I think the real world numbers for the ecoboost are avg 21-22mpg
#168
The Third Ball
First allocation of Ram diesel 1500s sold out.
8300 units in 3 days!!! I think they were all pre-orders.
To say there was a pent up demand for this engine is an understatement.
#169
Wow. That's pretty amazing.
420lb-ft or torque and 28 mpg will get you some serious demand, that's for sure.
#170
http://www.inautonews.com/ram-unveil...r#.U603q_mx4mg
Ram has officially pulled the wraps off its latest creation, the 2015 ProMaster, as the model in question is coming with some interesting features, such as the familiar design, the new front fascia, the different headlights, the increased height to compensate for the country’s crumbling roads or the strengthened unibody, amongst others. As you probably know by now, the Ram ProMaster is based on the Fiat Doblo and its interior design is getting the 5-inch Uconnect infotainment system with internet and GPS navigation, durable fabric seats and so on.
The Ram ProMaster has a best-in-class payload of 854 kg (1,883 lbs) and a tow rating of up to 907 kg (2,000 lbs). The cargo capacity of the model stands at 131.7 cubic feet. Power to the 2015 Ram ProMaster is being provided by a 2.4 liter Tigersharke four-cylinder petrol burner, which, according to the car manufacturer, is producing a total output of 178 HP (137 kW) and 234 Nm (174 lb-ft) of torque. The engine is connected to a 9-speed automatic transmission. No pricing details have been announced yet.
#174
2015 Ram 1500 Rebel
Press release...
The new 2015 Ram 1500 Rebel brings a one-of-a-kind off-road design to the full-size truck segment.
“Offering an off-road-style package on the Ram 1500 has been on our to-do list for some time but the right combination didn’t present itself until now,” said Bob Hegbloom, President and CEO — Ram Truck Brand, FCA US LLC. “The Rebel drops right into a core segment of the truck market with unique design cues and can-do attitude backed by Ram Truck engineering.”
New exterior design highlights
Rebel features an all-new grille with prominent billet silver “RAM” letter badge. Departing from the brand’s iconic “cross-hair” designs, the blacked-out Rebel grille tops a completely new black off-road front bumper design with a durable powder-coated surface, which incorporates a powder coated, billet silver skid plate, new front tow hooks and new LED fog lamps. Black bezel bi-functional projector headlamps with LED marker lights lie beneath an aluminum, twin-snorkel sport hood.
Rebel’s blacked-out front-end continues on the flanks, where black Power Wagon wheel-arch moldings, flat-black badge, mirrors and lower body panels create a distinctive trail-ready presence. The new trim features a two-tone paint scheme with black as a constant on the lower body, front to rear.
The Ram 1500 Rebel features an all-new 17-inch aluminum wheel. Among the most elaborate designs found in mass production, the new one-piece wheel incorporates matte black painted accent pockets and multi-angled surfaces linked to the Rebel’s off-road bias.
Continuing around to the rearview is a bold new “RAM” stamped tailgate with blacked-out lettering. The “Rebel” and “4X4” badge emphasize the truck’s uniqueness. The rear bumper is also treated with durable black powder coating with flared cutouts around dual chrome-tipped exhausts. Tail lamps incorporate black bezels to match forward lighting.
Rebel includes an optional backup camera, providing a better field of vision when maneuvering. A new tri-fold tonneau cover is embossed with the Ram logo.
The Ram 1500 Rebel will be available in five colors, including: Granite Crystal Metallic, Bright Silver Metallic, Flame Red, Bright White and Brilliant Black. Both monotone and two-tone paint options are offered.
Unique interior detailing
Inside, Rebel is every bit as brawny and rugged as it is outside, featuring dramatic, industry-exclusive seating elements.
High-durability technical grain vinyl seats are finished in Radar Red and Black with Sedoso fabric inserts embossed with the Toyo tire tread pattern, matching the Rebel’s actual footprint. Standard heated front seats feature Light Diesel Gray accent stitching, Radar Red Ram’s head embroidery on the headrests and Black with Light Diesel Gray Rebel nameplate embroidered on upper seat bolsters.
The all-black instrument panel, door armrests and logo-embossed center console armrest cover are topped with two-tone Radar Red and Light Gray accent stitching. The center stack and console are finished in Iron Gray Metallic paint giving a cast-iron appearance. An all-new center console bin incorporates a cellular phone/tablet holder with molded insert allowing for various-sized devices. Radar Red anodized vent rings, door accent rings, door trim spears and center console trim ring add color detail to the interior. The Rebel’s heated steering wheel is wrapped with semi-perforated black leather, accented with Radar Red X-stitches.
The upper glove box door is finished with a Rebel nameplate badge.
Deep all-weather rubber floor mats with contrasting Radar Red Ram’s head help contain dirt, snow and debris.
The interior is finished off with a new black headliner and matching upper pillars.
Performance Updates
The Rebel’s trail-running capability gets a boost with 1.0-inch raised ride height for improved off-road approach, departure and breakover angles.
Bilstein supplies front and rear shocks with unique tuning and a new steering calibration is matched to the Rebel’s increased ride height. A softer rear stabilizer bar provides improved dynamics.
Beefy 33-inch (LT285/70R17E) Toyo Open Country A/T all-terrain tires are mounted to the all-new 17-inch silver and black cast aluminum wheels.
A new tire offering for Ram trucks, the Open Country A/Ts are versatile all-terrain tires designed for rugged good looks, all-season handling and a comfortable ride. Their aggressive tread pattern offers good traction in bad conditions, on pavement or off. They feature a special wavy sipe arrangement for a comfortable ride and improved snow traction; groove bottom siping for more biting edges for increased traction in the snow and an open shoulder that maximizes water evacuation for excellent all-terrain traction and stability.
The Rebel takes advantage of Ram’s exclusive air suspension system with a 1.0-inch factory suspension lift, which not only helps to clear the 33-inch tires but also contributes to additional ground clearance. A modified alignment of the independent front suspension appropriately adjusts tire angle and aluminum lower A-arms absorb the load. The combination of larger tires and a suspension lift yield best-in-class ground clearance of 10.3 inches, and a new stability program calibration takes Rebel’s modifications into consideration.
Rebel is available exclusively as a crew cab model with 5-ft. 7-inch bed length. Both 3.6-liter Pentastar V-6 and 5.7-liter HEMI powertrains are offered, as is a choice of either 4X2 (HEMI only) or 4X4 configurations. RamBox is optional.
Ram Rebel is the 10th member of the Ram truck lineup, which includes Tradesman, Express, SLT, Big Horn/Lone Star, Outdoorsman, Sport, Laramie, Longhorn and Limited.
Rebel goes on sale early in the second half of 2015.
Powertrain
The 3.6-liter Pentastar V-6 engine (Ward’s 10 Best Engines Award winner three years in a row) with variable-valve timing (VVT) offers 305 horsepower, 269 lb.-ft. of torque and best-in-class gasoline fuel economy of 25 miles per gallon (mpg).
The legendary 5.7-liter HEMI V-8 with fuel-saving cylinder shut-off and VVT provide 395 horsepower and 410 lb.-ft. of torque.
HEMI-powered Ram 1500 Rebel trucks are available in 4x2 or 4x4 powertrains with 3.92 or 3.21 gear ratios. When equipped with the 3.6-liter Pentastar V-6 engine, Rebel is available in 4x4 only with a 3.92 gear ratio, allowing the engine to leverage its power and torque.
Both the 3.6-liter V-6 and 5.7-liter HEMI V-8 engines are available with a rear anti-spin differential, which turns both rear wheels in tandem when increased torque is applied – helpful in off-road driving conditions. The design automatically unlocks the differential for normal on-road driving, allowing the wheels to spin independently for improved drivability.
The class-exclusive eight-speed automatic transmission (TorqueFlite 8) – standard equipment with the Rebel’s 3.6-liter V-6 Pentastar and 5.7-liter HEMI V-8 engines, which improves drivability and enhances fuel efficiency.
The 2015 Ram 1500 has established what is unmistakably the most advanced and efficient truck in the light-duty category, as evidenced by:
Best-in-class fuel economy at 28 mpg with 3.0-liter EcoDiesel V-6
Exclusive link coil rear suspension and optional 4-corner air suspension
Only manufacturer in light-duty class to offer diesel, gasoline, and flex-fuel
(E85 capable 3.6-liter V-6) engines
Unsurpassed powertrain warranty – five years/100,000 miles
The 2015 Ram 1500 is backed with a five-year /100,000-mile Powertrain Limited Warranty. The powertrain-limited warranty covers the cost of all parts and labor needed to repair a covered powertrain component – engine, transmission and drive system. Coverage also includes free towing to the nearest Ram dealer, if necessary. The warranty also is transferable, allowing customers who sell their truck during the warranty period to pass the coverage onto the new owner.
The standard three-year / 36,000-mile Basic Limited Warranty provides bumper-to-bumper coverage for the Ram 1500, from the body to the electrical system.
Quality
The 2015 Ram 1500’s quality is scrutinized at the company’s Chrysler Technology Center’s state-of-the-art scientific labs in Auburn Hills, Michigan, including the Noise/Vibration/Harshness Lab, Electromagnetic Compatibility Facility, Wind Tunnel and the Road Test Simulator (RTS).
For example, the RTS recreates the abuse a truck endures at the hands of a 95th percentile driver – meaning someone who drives the vehicle in more severe conditions than 95 percent of all customers. The RTS can put a lifetime of wear and tear on a truck in about one month’s time. The Ram development team is committed to finding and fixing any issues before the customer does.
Manufacturing
The 2015 Ram 1500 is built at the Warren Truck Assembly Plant (Warren, Michigan), which has built more than 12.5 million trucks since it started operations in 1938. Crew Cab and Regular Cab models of the 2015 Ram 1500 are built at the Saltillo Truck Assembly Plant in Saltillo, Mexico.
About Ram Truck Brand
Since its launch as a stand-alone division in 2009, the Ram Truck Brand has steadily emerged as an industry leader with one goal: to build the best pickup trucks and commercial vehicles in the industry.
Creating a distinct identity for Ram Trucks has allowed the brand to concentrate on core customers and features they find valuable. Whether focusing on a family that uses a Ram 1500 day in and day out, a hard-working Ram 3500 Heavy Duty owner or a business that depends on its Ram ProMaster commercial van every day for deliveries, Ram has the truck market covered.
In order to be the best, it takes a commitment to innovation, capability, efficiency and durability. Ram Truck invests substantially in its products, infusing them with great looks, refined interiors, durable engines and exclusive features that further enhance their capabilities.
Moving into the 2015 model year, Ram continues to beat the competition in the two most sought-after titles, fuel economy and towing capacity:
Best-in-class fuel economy with exclusive EcoDiesel - 28 mpg with Ram 1500
Best-in-class towing capability - 30,000 pounds with Ram 3500
Best-in-class payload – 7,390 pounds with Ram 3500
Best-in-class torque – 865 lb.-ft. with Ram 3500 equipped with Cummins
Truck customers, from half-ton to commercial, have a demanding range of needs and require their vehicles to provide high levels of capability. Ram trucks are designed to deliver a total package.
Performance Updates
Powertrain
Quality
Manufacturing
#175
The Third Ball
I was waiting for someone to post this...
1) To those who dont read the article THIS IS NOT A RAPTOR COMPETITOR
2) I hate the grill...and Im not quite sure how that made it through to production. It looks like a giant mustache. If you buy the truck I wonder if they will throw in a huge sombrero for the roof...
#177
Marketing: So guys, how's that Raptor competitor coming along? Should be done by now, we really need to get into that market...
Engineers: Shit man, that truck is really really good and I'm not sure how we can one up it without really raising the price a lot. We do have this other truck that is somewhat close but cheaper though.
Marketing: Perfect, that sounds great. We'll launch that truck and post repeatedly about how it's not a competitor for the Raptor and hope for the best.
2.) +1
#178
The Third Ball
It doesn't compete because it a looks package more than anything. They did nothing to the engine.
The raptor is Baja race ready off the lot. The rebel is not designed for anything g like that.
But because of the attempt at a more aggressive look, people will immediately saying its a raptor fightor. It's nothig close to it.
#179
At least its not ugly like the new Titan.
God I SO badly want a 4 door, crewcab, dually, American truck. I have absolutely 0 use for it.
I keep seeing a Ford, I don't know 450 or 550. Silver. Tinted windows. Lowered on amazing wheels, dually. its fucking HUGE
#180
The Third Ball
Dually and lowered has never computed with me.
#181
#182
The Third Ball
#184
I get that it's nothing close to it but people are going to put it in as a competitor no matter how hard they try to say it's not. It's so obvious that they are trying to compete that it's borderline funny that they go out of their way to say it's not a competitor.
It's like, yup, we made a truck that has upgraded wheels, tires, and suspension with a bunch of really cool offroad stuff just like the Raptor except it's not a competitor.
Sarlacc (01-23-2015)
#187
The Third Ball
It's not just a looks package, it has upgraded wheels, tires, suspension, etc. Everything other than the engine. The Raptor doesn't have an upgraded or unique engine either, it has the same one as the F150 Platinum or whatever the highest one was.
Like Justncrabs said...Yes the Raptor has unique engine.
This Rebel is more along the lines of a Dodge PowerWagon being offered in 1500 form as opposed to 2500.
Yes, the similar looks will draw out comparisons to raptor, and yes I agree its a dumb move on dodges part in many ways. And because of that its going to draw comparisons that it shouldn't.
And you're right it does have suspension upgrades for more off road capability...but its still not in the same league as Raptors off road race suspension.
Raptor = Off Road RACE ready truck from the factory. It is very much a performance variant.
Rebel = More off road capable truck with an aggressive looks package. NOT a RACE truck. NOT a performance variant.
#189
For the 2011 model year, an all-new engine lineup was offered. Two of the engines, a 3.7 L V6 and a 5.0 L V8, both based on the 2011 Ford Mustang engines, both offer E85 flex-fuel capability. The 6.2 L V8 used in the 2011 Ford Super Duty was made available with the F-150 Platinum, Lariat, SVT Raptor, and Harley Davidson editions. Finally, the 3.5 L direct-injected twin-turbo EcoBoost V6 was offered in the F-150 starting in early 2011. All engines were paired with a new six-speed automatic transmission (6R80).[9] Electric power-assisted steering was made available on all engines besides the 6.2. Since 2008, the Ford F-150 has towing and hauling capacity of 11,300 lbs and 3,060 lbs, respectively.
#191
The Third Ball
It can also be asked why would someone buy the Ford over the Dodge other than brand loyalty. (And the ugly mustache grille)
#192
Isn't the new Raptor going turbo replacing the big V8?
#194
That is what I hear.
Maybe I am too old, but to me things like the Mustang or the Raptor is about "in your face american muscle" which to me means V8.
I have owned Turbo cars, and love them, but I guess aside from the GNX, when I think big bad american=v8.
But hey I am sure the Raptor will sell like hotcakes with new motor.
#195
And I agree with your question. though I assume if someone does cross shop and drive both, they'll realize both have VERY different suspensions. Not to mention the different engine options in the Rebel.
Only reason to get the Dodge would be for the ecodiesel option.
#196
The Third Ball
I think the Dodge has a nicer interior, personally.
More capable suspension based on use...Off road race suspension...vs lifted suspension that is capable of off roading...two different feels, not something you can really comment on as one being "Better" than the other.
better engine? Again, matter of opinion seeing as the Rebel comes with 3 options. The 3.6 pentastar is a great everyday engine. The 5.7 Hemi is its own proven engine...and I believe its been shown earlier models of 5.7 Rams are faster than earlier models of Raptors...later models of course upping the HP/tq
So, tell me precisely how your opinions of which one you think is a better truck factor into everyone else buying options?
#197
You realize that is all opinion based, right? (except the ugly grill)
#198
That grille...they should nix the "Rebel" name and call it the "Grumpy Cat Edition."
#199
Agree
I don't like the grille
I don't like hte HUGE RAM lettering in teh back
and the tails look like Pepboys afterhought
Agree
#200
The Third Ball
The big RAM across the back is no different than what Ford is doing.
The tails...yeah dont love them.
