Distributor recalls 6 million Chinese-made tire valve stems
http://www.detnews.com/apps/pbcs.dll.../BIZ/806120481
Thursday, June 12, 2008
David Shepardson / Detroit News Washington Bureau
WASHINGTON -- A distributor of Chinese-made tire valve stems has agreed to recall 6 million valve stems, according to the National Highway Traffic Safety Administration.
Tech International, a Johnstown, Ohio-based distributor of the Chinese-made parts, announced a recall of 6 million TR413 model valve stems, offering free replacements and to pay for any tire damage caused by the defective part, according to a June 2 letter made public on NHTSA's Web site.
But Tech International doesn't know who actually owns tires with the recalled tire valve stems and said it believes just 8,600 of the stems -- or less than 1 percent -- are defective. The valves are manufactured by Shanghai Baolong Industries Co.
"Tech International does not know the identity of any end-users of the TR413 valves and has no realistic method of determining the identity of such individuals. Furthermore, there is no realistic method for Tech International to identify the production dates of any specific TR413 valves," the company said in its letter to NHTSA.
The distributor will notify tire retailers of the recall.
The Chinese manufacturer conducted tests that showed that no valve stem produced after November 2006 was faulty, Tech International said.
In its recall notice, Tech International said that the stems could crack and tires could gradually lose pressure after they had been in use for more than six months. It said it first received notice of "a small number of potential valve stem failures" from a distributor in January.
Safety advocates on Thursday urged motorists to inspect their valve stems for cracks and to check tire pressure.
"Air loss at highway speeds may result in a tire failure and loss-of-control crash," said Sean Kane, president of Safety Research and Strategies.
He said it was questionable whether Tech's estimate of 8,600 faulty valve stems was accurate.
A lawyer for Tech International didn't return a phone call seeking comment.
In a separate move, the National Highway Traffic Safety Administration has opened a preliminary investigation into another 30 million Chinese-made "snap-in" tire valve stems in the wake of a Nov. 11 fatal crash. Those valve stems may have come out of the same Chinese factory that made the recalled vales stems distributed by Tech International, safety advocates said.
NHTSA's investigation follows the death of Robert Monk of Orlando, Fla., who was killed when the right rear tire of his 1998 Ford Explorer failed, triggering a rollover crash.
Kane said the tire failure has been linked to a cracked a Dill TR413 valve stem manufactured by Topseal, a subsidiary of Shanghai Baolong Dill Air Control Products, LLC.
In March, the Monk family filed suit against North Carolina-based Dill Air Control Products, alleging that the defective tire valve stem caused the crash.
"The Monk family wants to get the message out there to ensure that no one else is hurt," said Richard Newsome, an attorney with the Newsome Law Firm in Orlando, Fla.
On April 30, after receiving notice of the Monk crash, Dill officials met with the National Highway Traffic Safety Administration to discuss the problem.
On May 2, Dill sent a Technical Bulletin to major tire retailers advising them that the company had received complaints of surface cracks appearing on the outside of the rubber near the rim hole in several models.
"When the rubber is exposed to high levels of ozone as it is being stressed, surface cracks can appear. High speeds and an unsupportive rim profile allow the rubber valve to flex at a greater angle and may cause these cracks to propagate, leading to a slow leak of air," the bulletin said.
Dill officials told NHTSA that valves -- made from July 2006 to November 2006 -- may leak from cracks caused by ozone exposure.
Brian Rigney, general manager at Dill, didn't return a call seeking comment.
Thank god my car's old!
The Third Ball
Received 4,850 Likes
jesus, can the chinese make anything that doesnt kill, poison, blow up, or maim people?
I disagree with unanimity
_____ like a rabbit
this does all four! and its ugly!!
The sizzle in the Steak
Faulty Tire Valves from China Could Result in Massive Recall
China doesn’t have the most stellar track record for product design or quality, which, unfortunately, is beginning to leak into the automotive industry. Chinese cars are notorious for their poor crash ratings but, thanks to government regulations, U.S. citizens have been protected from China’s four-wheeled death traps. However, Chinese car components are making it to the U.S. market, the most recent of which could result in the recall of 30 million tires.
Following a rollover crash that took the life of one Florida resident, investigators discovered that the accident was the result of a faulty tire valve. The valve was found to crack prematurely, which, as in the case of the Florida accident, could cause the tire to completely fail, according to Consumer Reports.
Investigators tracked the faulty valve back to Dill Air Control Products of Oxford, North Carolina. Although Dill Air distributed the tire valve, the faulty product had actually originally been sourced from China’s Shanghai Baolong Industries Co.
In all, as many as 30 million tires distributed through North America could be affected, prompting the National Highway Traffic Safety Administration to launch an investigation.
However, tracking down the faulty values is no easy task: The values can only be identified by completely removing the tire from the rim. Moreover, tire retails don’t keep records of what valves went on what cars. “Once they are out of the box and on a vehicle there is no tracking for these products so you can’t notify owners,” Sean Kane, president of Safety Research and Strategies, told Consumer Reports.
Anyone who has purchased new tires since July 2006 is urged to have their tires checked by a professional.
Received 2,329 Likes
From what my Acura dealer has told me, there have been numerous complaints about tires losing pressure. I'm not talking about all 4 triggering the TPMS sensors either. Just one tire losing pressure.
I wonder...
I wonder...
I've had prior problems with valves... Had one replaced on the CL about a year or so ago, cause the tire kept loosing air... and the valve would sometimes stay open after filling with air...
I've got another tire that I noticed was a little low lately... hmmm... and I bought a new set of tires 2 years ago...
Time to check...thank goodness I'm in for maintenance on Monday...
where is....
this makes me wonder........i spun out last yr i believe, and the valve stem broke off during a hard turn and it caused my tire to collapse.......
and the tires were the correct size and were all at 30psi, and they were fresh tires about 5months old........
hmm, probably doesn't matter, but the rubber on my valve stems is cracked. It doesn't look cracked until you wiggle it around. at first I didn't think anything of it, but now....
stop buying from China
Liquid Ice
Damn, I just had 4 tires mounted on my S2000 in the Spring, and one of the valve stems on the tires already broke and was replaced. Now I'm worried about the other three ... Time to email the shop that installed them and check if they use these valve stems.
Not necessarily a , but could be merged with the other thread about this topic since it's an update to the problem....
https://acurazine.com/forums/showthread.php?t=395003
Found the thread after using Took a little while to find it.
^^ to superior search skilz
Wow from 6 million to now potentially 30 million
Turd Polisher
One of my fronts was low roughly a month ago from a cracked valve stem ..
Merged.
Do you guys think there would be any chance of my Made in Holland tires having a Chinese valve stem? I hope not....
Although the Chinese manufacturers should take a share of the blame, the problem is more than that.
One needs to know whether there is a design issue, which is controlled by the distributors in the U.S. There is also the quality issue, which the U.S. companies need to check.
It's easy to blame the Chinese for everything, but the American companies are the ones who make money from outsourcing to cheaper manufacturers.
mugen_kid
11-13-2015 10:38 PM
