they love that wheel gap..... :whyme:
I like everything about the new Vette....so the Z06 can only be better!
:agree:
Originally Posted by Maximized
Doesn't matter, since GM provides you with a video on how to setup the car for the track. You can lower the car with simple hand tools.
is this for the standard C6 too? it has ride-height adjustable suspension? if so, geez I read a bit too fast... :sad:
Originally Posted by Sypher
There is a discussion about whether this is a Photoshop or not, but most of the discussion leans towards this being VERY close to correct, especially since it matches the spy photos so well.
Dear Sir, My name is Mike xxxxxxx and I'm the xxxxxxx of Broadcast Communications for General Motors. I've noticed that you have one of GM's embargoed photographs of the 2005 Corvette on your website. Since this image is embargoed until January 10, 2005, I am asking that you remove the image from your site until the embargo is lifted. While I don't expect you to tell me who provided you with the image, I am wondering if you would tell me if you received the image before Noon on Tuesday, November 9. If there is any confusion regarding usage of GM's embargoed images or if you would like to discuss the situation with me, I can be reached through email, or by phone at 313-665-xxxx. Thank you for your help with this matter. Mike xxxxxxxx ---------------------------- Original Message ---------------------------- Subject: C6 Z06 Pics From: robert.xxxxxxx@gm.com Date: Wed, November 10, 2004 4:42 pm To: webmaster@digitalcorvettes.com -------------------------------------------------------------------------- Dear Sir, Please remove the pictures that are part of the following: DIGITALCORVETTES.COM > C6 Corvette > C6 Corvette - Z06 & C6R > Is this it? These pictures are the property of General Motors. Please contact me so we can discuss this issue in further detail. Thanks, Robert xxxxxxxxxxxxxx Securitas Computer Forensic Investigator General Motors Corporate Security Office 313.665.xxxx Cell 313.xxx.xxxx |
I thought this was only done by Toyota, now GM is doing this too, why I keep my digital camera always
2006 Corvette Z06
http://img25.exs.cx/img25/7715/i_importimage.jpg
6-piston front and 4-piston rear calipers • Cross-drilled rotors • Aluminum engine block with 104.8-mm bores and pressed-in liners • Forged steel crankshaft with 101.6-mm stroke • 6-bolt, forged steel main bearing caps • Titanium connecting rods • Cast aluminum flat-top pistons • Racing-derived CNC-ported aluminum cylinder heads with 70-cc chambers • 56mm titanium intake valves • 41mm sodium-filled exhaust valves • 11.0:1 compression ratio • Composite manifold with 90 mm single-bore throttle body • Camshaft with 15-mm (.591-inch) lift • Dry-sump oiling system • 7000-rpm redline WEIGHT: 3130lbs/1420kg 500hp/475lb-ft torque. http://www.z06vette.com/forums/showthread.php?t=70048 :woot: |
zoinks. Not bad for a car that still uses leafsprings and pushrods. I bet those rear tires cost $3k alone. What are those, 335 width?
I'm sure it will be fun to drive, and no doubt the best-performing vehicle under $100k, but I just can't ever see myself in one. Not unless I start wearing Hawaiin shirts with the top 4 buttons undone and doing the 'wink-click' move every time I greet someone. |
Why the hell does that car use leaf springs anyways?
Photochop?
I could swear I recall hearing Bob Lutz promise 500HP and 500lb-ft. |
Does looked photoshopped, but nice none the less.
Still doesn't do it for me. I just can't get excited about the Corvette the way I get excited about a Viper or even a Lotus.
Originally Posted by domn
Photochop?
:drool: me likey.
On the corvette its not like a truck where you have a set of them running in parallel of the car they are a single plastic composite spring that runs parallel of the of the axle and is lighter and more reliable then many other setups.
So while it is carryover technology it is not a solid rear axle with dual leaf springs like you would find on a truck or hot rods of days past. |
I wouldn't mind having it as my 3rd car...
I like it.:drool:
Originally Posted by TSX Hokie
....I just can't ever see myself in one. Not unless I start wearing Hawaiin shirts with the top 4 buttons undone and doing the 'wink-click' move every time I greet someone.
hey why not... :D |
Originally Posted by gfxdave99
Dont forget to stock up on brut and old spice.
But the whole point of a photochop is to make it look real. I call complete :bs: on the pic. I say there's no way the Z06 will have that air inlet in the front. Corvette guys won't go for that type of thing. As for the rest of the pic, it looks just like a C6 which is what the Z06 will look like anyway. |
Originally Posted by joerockt
:drool: me likey.
Looks too much like the viper. Hopefully they got rid of the rear leafsprings
http://www.sportsvisions.com/raylargemetal.jpg |
Interesting. So, should I take the image off of my hosted location? (I didn't link to it on digitalcorvettes.com, I linked to it on my site.) :dunno:
Cool that they confirmed it for us, though. :) |
There's a thread over at A-CL about this...Too lazy to look it up right now :D
And I thought I was lazy... :tissue:
the link to the thread on A-CL...you lazy bastard |
tay-nah duh
New from digitalcorvettes.com (Thanks Gav, for the heads up):
There is a discussion about whether this is a Photoshop or not, but most of the discussion leans towards this being VERY close to correct, especially since it matches the spy photos so well. http://www.sypher.com/images/i_importimage.jpg http://www.digitalcorvettes.com/foru...threadid=25433 :racing: Yes, I think this is very close to the actual from what I heard. |
Okay, no more image, for now.
I'll just look at it in the privacy of my own home. :playboy: |
67k would be way too expensive
So this is pritty much definitly the next z06 then i assume???
Also, whats with the wheels...the back one looks like its deep dish and the back one isnt...kinda odd. Still looks hot though. |
