CCG: customGT news
CCG: customGT news
Press release...
"What turned the customGT into reality was our passion, enthusiasm, dedication, and the steadfast belief in achieving the goal."
With these words, Tom Gerards, Head of CCG automotive GmbH and creative director of customGT outlined the long development time and the persistent advocacy of German TÜV officials. He continues: "The idea to build my own super sports car and bring it onto German streets with the TÜV's blessing started in early 2009".
The basis for this ambitious project is a powder-coated tubular space frame that is made in the USA and re-engineered (homologated) and fine-tuned here in Germany. The outer skin is made from either fibreglass- or carbon fibre-reinforced composites, and toned by specialists in the U.S. CCG makes adjustments to the car's body and optimizes it for the increased demands. The result is a pleasingly low vehicle weight, which, depending on the equipment, weighs in at only 960 kg and 1,040 kg. As
comparison: The ultra-sporty Ferrari 430 Scuderia puts at least some 1,250 kg onto the scale.
The engine is an optimised V8 by General Motors, which has its origin in the Corvette, one of the best recognised U.S. car icons. Thanks to its fine-tuning, the 7-litre engine produces up to 550 hp/405 kW and screams its joie de vivre out of exhaust pipes that are as thick as a man's arm. The engine's power reaches the rear wheels via a manually-operated 6-gear transmission, which was enhanced for use in the customGT. Coilovers were specifically designed and attuned on the 7-post test rig provided by KW suspensions. They ensure to keep the car securely on the pavement and provide the necessary grip in corners and on the racetrack. Countless kilometres of testing on the Nürburgring Nordschleife and Hockenheim bring the extensive development work to a full circle.
The perfect look and feel dominate the car's interior. A mixture of Alcantara and black leather as well as instruments "borrowed" from the racing sport give the interior the look of a sophisticated command center. Besides the outer appearance, the entire interior and the engine can be tailored to the needs of the clientele. Many important and vital components of this vehicle come from German companies and thus, besides the actual production of the vehicle in Germany, it also bears the quality seal "Made in Germany".
But that's not enough: Upon request, CCG equips the two-seater with an LPG (Liquefied Petroleum Gas) system and converts the vehicle into a racy 300 km/h, ultra-lightweight eco-super sports car. "The engine's concept is tailored specifically for LPG use. LPG is a fuel that reduces exhaust emissions to a minimum and its availability is already widespread in many petrol stations. What's more, it is "light on your wallet". The average fuel consumption of the customGT lies by 15 - 20 litres of
gas per 100 kilometres. This is equivalent to 50 cents per litre of gas; just €7,50 to €10,00 for 100 kilometres", said Tom Gerards, Head of the CCG automotive GmbH
In addition, another model, called "competition", is planned for spring 2012. Says Tom Gerards: "When converting the customGT model "competition", we will forgo all luxuries and reduce the weight even more. Weighing in at just below 1,000 kg and by installing additional motor sports components such as sports chassis provided by KW suspension, MOV'IT brakes with racing pads and a special engine mapping, we will optimise the "competition" targeted for use in motor sports".
Performance Characteristics:
2-seater sports car with mid-engine, tubular space frame made of 45 FE steel (material according to FIA standard), double wishbone, KW suspensions, spring damper units with performance tuning for street and/or race track and multiadjustable sports sway bars.
Two-circuit master brake cylinder fitted with a balance beam and MOV'IT 6-piston brake calipers 370 * 35 mm in the front / 4-piston calipers 342 * 28 mm at the rear; Teflon-coated flexible stainless steel brake lines.
Dimensions:
Length 4,356 mm
Width 1,880 mm
Height 1,016 mm (40”)
Wheel base 2,565 mm
Tread width
front/rear 1,536 mm / 1,574 mm
Weight:
Curb weight
(Standard equipment) 1,020 kg (without LPG system)
1,080 kg (incl. LPG system)
Overall weight 1,415 kg
Permissible axle load front/rear 620 kg
Engine:
V8-cylinder Aluminium GM 6.0l, 450 hp / 331 kW at 5,800 RPM, 560Nm/4,600 RPM optionally V8-cylinder Aluminium GM 7.0l, 550 hp / 405 kW at 5,800 RPM, 605 Nm/4,700RPM
Optional: dry sump lubrication, oil cooler optionally with turbo-charging up to 740 hp
Transmission:
Fully synchronized 6-speed manual transmission with single-disc clutch, gear ratio according to the customer's requirements.
Optional sequential gearbox.
Performance:
Engine V8-cylinder Aluminium GM 6.0l
Max. speed variable between 285 km/h and 320 km/h*
Acceleration 0-100 km/h variable approx. 3.5 sec.*
Acceleration 0-200 km/h variable approx. 9.9 sec.*
Engine V8-cylinder Aluminium GM 7.0l
Acceleration 0-100 km/h < 3.3 sec.
Acceleration 0-200 km/h < 3.3 sec.
*) Depending on gear ratio and application
Price starting at:
113.500,00 EUR
(Net plus applicable taxes)
CCG is a specialty shop with focus on classic sports cars. Besides the service,
repair, and restoration of classic cars, its heart also beats for individual and unusual vehicles. Hence, many unique vehicles are created. In addition, CCG offers refinements of the vehicle's interior as well as performance optimization and aerodynamic improvements.
The combination of this expertise and the correct choice of cooperation partners, made what customGT is today. It is the symbiosis of US-American roots and quality work "Made in Germany". Each component has been carefully evaluated and especially designed and optimised for the customGT. CCG cooperates with selected partners and locally based German companies.
Cooperation partners:
- KW suspensions
- MOV’IT
Dimensions:
Length 4,356 mm
Width 1,880 mm
Wheel base 2,565 mm
Tread width
Weight:
Curb weight
Engine:
Transmission:
Performance:
Price starting at:
113.500,00 EUR
- KW suspensions
- MOV’IT
09-25-2015 06:14 PM
