Bulleta Motors: RF22 news
Press release...
It is the goal of the designer to awaken and keep alive emotions. A Vehicle is perceived with one's senses. The RF22 was designed with human and organic lines in mind. It was important not to follow short lived design trends but rather to have a design philosophy with lines that are unique and classic to endure time that are characterized both by technical and emotional intelligence. The RF22 was designed by acclaimed automotive designer Samir Sadikhov.
Unique Design Features
- The nose fin of the RF1 acts as a fin providing downforce for the front of the car
- The side vents of the RF1 are a unique V shaped inspired by the V shaped lines of radar evading stealth fighter aircraft like the F22 Raptor
- Shoulders are a feature of strength and stability. The shoulders of the RF1 are broad, muscular yet smooth.
Carbon Fiber Where It Matters - The Wheels
The wheels of the RF22 are the world's first all Carbon Fiber wheels saving critical unsprung weight and making the RF22 lighter during high performance turns. The Carbon Fiber weaves are engineered in the correct directions, making them the strongest and lightest carbon fiber wheels made. They have been thouroughly tested for high impact, severe bumps and simulated for hundreds of rounds around The Ring.
Standard Carbon Ceramic Disk Brakes
Born from the application of aerospace derived technology and thanks to the extraordinary light weight of carbon-ceramic discs, the car has a better handling, improving performance by making each corner of the car lighter.
Carbon Ceramic brakes resist deformation under heat; allowing predictable and reliable braking under extreme conditions. RF22's Carbon Ceramic Disk Brakes make each corner considerably lighter resulting in better handling.
Light Weight Composite Body
The RF22's composite body is made of GRP Composite (Glass Reinforced Plastic) or optional Carbon Fiber.
Bulleta Designed TVS2300 Supercharger with Eaton Turbine Technology
The Bulleta designed supercharger forces more air into the engine combustion chambers resulting in more power. Larger turbines allow the supercharger spin slower and to remain cooler; keeping overall engine temperatures low.
Mid Engine Layout
The Ideal placement for a performance car's engine is in the middle of the car, behined the driver. The driver is able to feel the engine and as it revs, becoming more bonded to the car.
PERFORMANCE
Engine Power 505 HP
Engine Torque 410 ft-lb
0-60 mph 3.6 seconds
ENGINE
All alloy, 3.5 litre DOHC V6 with Bulleta Designed HTV 2300 Supercharger utilizing Eaton Turbine Technology
Mid Engine, transverse, rear wheel drive
Multi-point sequential fuel injection and direct ignition system
Electronic Throttle Control system
TRANSMISSION
6 speed manual with sports ratios
Optional 6 speed automatic with Sport Paddle shifters
BOSCH Electronic Differential Lock [EDL]
DIMENSIONS
Length 4,348 mm (171.3 in)
Width 1,858 mm (76.8 in)
Wheelbase 2,575 mm (101.4 in)
Height 2,571 mm (101.2 in)
Unladen Weight 1,363 kg (2,920 lb)
Fuel tank capacity 15 Gallons
BODY
Two-door coupe bodystyle with standard 2 seat or optional 2+2 seating
Lightweight, extruded aluminium bonded structure
Composite GRP Composite or optional carbon fiber body
Bi-Xenon headlights with integrated direction indicators
LED rear lamps with integrated direction indicators
Electronic door mirrors
SUSPENSION
Independent forged aluminium double wishbone suspension with anti-roll bars, front and rear
Bilstein high performance gas dampers, front and rear
STEERING
Rack and pinion, Lotus tuned hydraulically-assisted power steering
Steering column adjustment for height and rake
BRAKES
Servo assisted ventilated discs, 350mm front, 332 mm rear cross drilled
BOSCH tuned ABS system
Hydraulic Brake Assist [HBA]
Electronic Brake Distribution [EBD]
Cornering Brake Control [CBC]
Electronic Dynamic Performance Management [DPM]
WHEELS
All Carbon Fiber Wheels 19" front and 19" rear
Optional Forged Aluminum 20" front and 20" rear wheels
Front Michelin Super Sport 245/40 ZR20
Rear Michelin Super Sport2 95/35 ZR20
Mid Engine Layout
PERFORMANCE
Engine Power 505 HP
ENGINE
TRANSMISSION
DIMENSIONS
BODY
SUSPENSION
STEERING
BRAKES
WHEELS
Looks like an AM to me
Received 6,470 Likes
Hmmm.....this is nice!
09-25-2015 06:14 PM
