Go Back  AcuraZine - Acura Enthusiast Community > Automotive Discussion > Automotive News
Reload this Page >
Buick: Regal News **2018 GS Revealed (page 10)**
Notices
Old 06-20-2011, 10:30 AM
  #281
dom
dom's Avatar
Originally Posted by pttl View Post
330 hp and big torque to the front wheels? :thumbsdow
dom is offline
Old 06-20-2011, 12:06 PM
  #282
Fahrvergnügen'd
charliemike's Avatar
Received 1,408 Likes on 874 Posts
The Insignia VXR was 320hp and AWD and it was definitely a competitive car.
charliemike is offline
Old 06-20-2011, 11:08 PM
  #283
I disagree with unanimity
sho_nuff1997's Avatar
Originally Posted by dom View Post
I believe that was in reference to Costco's post...
sho_nuff1997 is offline
Old 06-20-2011, 11:50 PM
  #284
My first Avatar....
pttl's Avatar
Received 2,581 Likes on 1,505 Posts
Yes. Plus, torque steer would be ridiculous with 330hp and high torque to the wheels.
pttl is offline
Old 06-21-2011, 12:03 AM
  #285
Agreed. But like Costco said, the HiPer strut suspension supposedly does a pretty good job of combating torque steer.
HiPer Strut was produced to address four specific issues: eliminate torque steer, reduce sensitivity to rotating assembly imbalance, reduce steering wheel kickback and improve steering feel. Actually, that last bit is a happy benefit of HiPer Strut, but let’s answer the question of what the heck it is. On a typical McPherson strut setup, the points of contact for the spindle (the piece that holds the wheel bearings) would be on the spindles strut mount and lower control arm ball joint. Some applications mount the ball joint directly to the strut itself. If you look at the photos and diagrams, though, you’ll notice the top of the spindle attaches to the strut via a ball-joint and the bottom of the spindle mounts to the lower control arm by what Buick calls a revolute joint. This joint and the ball-joint fixes the location and orientation of the spindle.
It works by decoupling the relationship between the spindle and strut via the upper ball-joint. This allows for a shorter spindle length, which means you can have a more upright kingpin angle. A shorter spindle length means the wheel has a shorter moment arm in which to impact the rest of the steering gear while decreasing the KPA reduces steering effort. In other words, the system doesn’t actually remove torque steer, but it significantly reduces it to the point where a manufacturer will no longer need to resort to torque-mitigation to limit it.
We had a chance to try it out on the winding, hilly roads near Middleburg, Virginia, a quaint town located about an hour west of Washington DC. First impression is excellent, and I have to say that it works exactly as described. If you’ve ever driven a high-powered front wheel drive car, in this case a Buick LaCrosse CXS with its standard 3.6 liter V-6 producing 280 horsepower and 259 lb-ft of torque, you’ll know that getting on the throttle while in a turn that crests a hill is a recipe for torque steer, but but in this case, there was virtually no difference in steering effort as the individual front wheels lightened up. Coming out of tight corners, you could floor the throttle and feel the car just turn, with only road feedback. It was moderately unnerving, at first, but the more I drove it, I could the nuances of the steering itself, versus the motor tugging the steering wheel via the tire.
As a high-end option, expect only CXS trim-level LaCrosse’s to have them by May of this year. Most assuring, though, was hearing Buick folk speaking seriously about performance, ride quality, and design.
http://blog.roadandtrack.com/buicks-...n-hiper-strut/
Granted they tested on a heavier vehicle with less tq, but it will still be interesting to hear the reviews on whether it makes a difference on the GS.
  #286
Old 06-21-2011, 01:01 AM
  #287
Received 2,242 Likes on 1,334 Posts
Throw in the turbocharged V6 and AWD.... that means another 2-300 lbs, easy. And that upgraded hardware ain't gonna be cheap. I'm not saying I like the fact that GM went with a FWD turbocharged 4-cylinder powertrain, but with the guesses being around $36-38k to start, you'd probably be looking at $41-43k with AWD and a V6T, on the conservative side.
Also consider the V6 TSX, which starts around $35k compared to $29.5k for the base TSX. IIRC the reason for the big price jump is because the TSX is made in Japan while the V6 itself is made in Ohio, requiring multiple shipments.
I'm starting to get into SSFTSX mode with all these figures but assuming the Regal GS is made in Canada and the turbocharged V6 itself is made in Germany (since the Opel/Vauxhall it's found in is made in Germany) I have to expect that my conservative estimate will fall short.
Then the problem at that point is, "there's no way I'd get a Buick for X amount of money over X car"
Costco is online now
Old 06-21-2011, 06:33 AM
  #288
Registered Member
biker's Avatar
^ I've looked at dealer inventory recently and there seems to be a mix of source for the car - most cars start with a W in the VIN (from Germany) and while the rest start with a 2 (Canada).
The problem for Buick, sounding like SSFTSX here, is that it is pitting the Regal against the TSX but it doesn't seem to have any kind of adavntage. The price is no better, the performance isn't and neither is the fuel mileage.
biker is offline
Old 06-21-2011, 07:44 AM
  #289
F23A4's Avatar
GM has been building big torque FWD cars on and off for a while. (The original STS, Pontiac Grand Prix GTP/GTX, Impala SS (L67 and LS4) and prior Regal GS come to mind.) So, this is nothing new for them and should not come as any surprise to us.
While I agree that the GS would be more attractive with AWD, it's still a sweet looking package. The fact that is comes with a 6MT makes it more attractive as a driver's car than the TSX V6 and the base TL.
F23A4 is online now
Old 06-21-2011, 11:33 AM
  #290
Fahrvergnügen'd
Fortunately, the Buick is a better looking car. Probably a better car to drive too.
The TSX looks like it's really a facelifted 3G TL that's almost eight years old now.
Old 06-21-2011, 01:49 PM
  #291
^as well as having a 6MT in their upscale trim (Buick)... TSX only comes with a 5AT coupled to the V6. Being a car designed from the outset to handle a powerful engine with a FWD platform, I too think the Regal GS will be a better driver.
I may be mistaken but I'm not sure if the 2G TSX was meant to have a V6... it shows in the reviews. I think only the US is the only market to get the V6 TSX, while the "Euro" Accord is sold basically all over the world.
Old 06-21-2011, 07:35 PM
  #292
Registered Member
biker's Avatar
Biker, who has a feeling a certain poster is furiously scouring the net to come up with numbers to refute this.
biker is offline
Old 06-22-2011, 03:11 AM
  #293
Costco, who thinks he knows who Biker is thinking of
Old 06-27-2011, 12:46 PM
  #294
I love me some Curry...!
wassystyle's Avatar
Buick Regal wagon spy shots – Click above for high-res image gallery
One year ago, a Buick Regal wagon was deemed "unlikely." However, General Motors is reportedly looking to expand the Regal lineup, not just with a rumored coupe, but with the estate seen here. Sources within GM say that the Regal wagon could debut as early as the end of this year, making it a 2012 model year vehicle.
In addition to these live photos (note the "turbo" script on its rump), our spies are offering up a rendering of what the production version of the Regal Wagon could look like, complete with the larger 19-inch wheels from the Regal Turbo sedan. If produced, the Regal wagon would aim squarely at the recently introduced Acura TSX Sport Wagon.
If the Regal wagon is indeed set to debut this year, the Los Angeles Auto Show is probably a safe bet. We'll keep our ears to the ground for more details in the coming months.
autoblog.com
wassystyle is offline
Old 06-27-2011, 02:46 PM
  #295
Hmm.
Not nearly as good looking as the TSX wagon. It looks vanilla as well for some reason.
Old 06-27-2011, 03:12 PM
  #296
Your Friendly Canadian
Aman's Avatar
Received 1,038 Likes on 798 Posts
Methinks the bumbuklatz is a little ugly, but it looks great from the front quarters.
Aman is offline
Old 06-27-2011, 07:06 PM
  #297
Registered Member
biker's Avatar
To all the wagon naysayers Buick says
I can't see Buick chasing the TSX with this - they must have some reason to offer a wagon.
biker is offline
Old 06-28-2011, 12:34 AM
  #298
Aman's Avatar
Really? It seems to me like it's aimed squarely at the TSX.
Aman is offline
Old 06-28-2011, 09:12 AM
  #299
Fahrvergnügen'd
Just as a reminder of what this wagon COULD look like :)
Old 06-28-2011, 11:50 AM
  #300
Registered Member
You dont need the internet for some thing so obvious. No Buick or that matter any other car can manage this fuel economy with such heat/airconditioning.
http://s396.photobucket.com/albums/p...t=CIMG0406.jpg
SSFTSX is offline
Old 06-28-2011, 12:11 PM
  #301
My first Avatar....
pttl's Avatar
pttl is offline
Old 06-28-2011, 03:12 PM
  #302
Registered Member
biker's Avatar
Unlike the sedan, Buick would be chasing a TSX wagon that sells maybe 400/mo. No, I think either Buick sees the wagon market growing or it thinks it can compete with the BMW and Audi wagons (which may or may not endure in the US).
biker is offline
Old 06-28-2011, 03:19 PM
  #303
dom
dom's Avatar
Please don't feed the troll.
dom is offline
Old 06-28-2011, 04:52 PM
  #304
Fahrvergnügen'd
But he looks so ... hungry ...
Old 06-29-2011, 01:31 AM
  #305
I like it, but I think where it all goes wrong is those taillights. Maybe that chrome strip below the rear window too. They bug me a lot for some reason. On the OPC/Regal GS sedan, they're distinctive looking... but on the wagon, even the OPC variant it looks so plain.
Hell even looking at it now, the TSX wagon's tails bother me a bit too. But still they look less like a big red blob a la Regal wagon.
+1
I love how it has absolutely no relevance to what was quoted. The thought process is like this....
1. Quote random post
2. Forget original purpose of quote
3. Insert random, irrelevant pictures/specifications/observations, such as ground clearance, side mirror styling, etc.
4. Claim that Honda > everything because of ^
5. Collect kickbacks from Honda Motor Company
I'm contemplating taking this guy off my ignore list.... he is just too amusing to miss out on sometimes.
Old 08-05-2011, 12:34 AM
  #306
Fahrvergnügen'd
2012 GS to have 270hp, start at $35,310
Originally Posted by Autoblog
The 2012 Regal GS will be the top model in the sedan's range, with pricing starting at $35,310 (also including the $860 destination charge). For the GS, Buick has boosted the output of its 2.0-liter turbocharged engine, producing 270 horsepower and 295 pound-feet of torque in this application. The Regal GS will launch exclusively with a six-speed manual transmission, though a six-speed automatic unit will be available later in the model year.
That's right in line with an A4 Premium ... I don't think it's badly priced at all.
Old 08-05-2011, 01:24 AM
  #307
My first Avatar....
pttl's Avatar
Where is the A4 Premium priced?
pttl is offline
Old 08-05-2011, 07:06 AM
  #308
Registered Member
biker's Avatar
http://content.usatoday.com/communit...ybrid-models/1
The eAssist (Drive On still thinks they need a new name for this that doesn't sound like something for senior citizens) will start at $29,530 with shipping.
That makes the eAssist system, in fact, a $2,000 option on the base Regal with the 2.4-liter four without the system. Unlike the LaCrosse, which is dropping the cheaper, non-eAssist model for 2012, Buick will continue to offer the Regal base model without eAssist as well as the 2.0-liter turbo (Drive On's preference).
As with the LaCrosse, the Regal eAssist package includes improved aerodynamics, different tires, start-stop technology, energy-capturing regenerative brakes, a lithium-ion battery and a small electric motor. In the Regal it will be 25 mpg city, 36 highway. Also in the package is an Eco gauge and powerflow graphics for driver biofeedback.
biker is offline
Old 08-05-2011, 07:08 AM
  #309
Registered Member
biker's Avatar
^ that 2K option is pretty decent (compared to the typical 4-5K hybrid markup) given the mileage improvements. It is yet to be seen how realistic those EPA numbers are.
biker is offline
Old 08-05-2011, 10:09 AM
  #310
Fahrvergnügen'd
The base A4 starts at $32k ... I don't have a list of what the GS will have in it but I would imagine the features are at least at the A4 Premium Plus level which is $37k with CVT and FWD.
I'm very interested to see what the reviews are like because I think the car is decently priced. Though I wish it was the 321hp and AWD, it's clear that car would have been $42-45k.
Old 08-05-2011, 10:11 AM
  #311
אני עומד עם ישראל
Hapa DC5's Avatar
Atleast we know what SSFTSX looks like. Asian dude in the middle flanked by Indian FOB and Russian FOB.
Hapa DC5 is offline
Old 08-05-2011, 10:25 AM
  #312
Fahrvergnügen'd
So he's part of a trolling multinational conglomerate. They've got Tata, Sprayfoam cars, and Honda/Acura covered.
They just need to get someone from the Middle East to cover all the POS Lada rebadges they build there.
Old 08-05-2011, 12:24 PM
  #313
Registered Member
biker's Avatar
Lada is from Russia.
biker is offline
Old 08-05-2011, 12:27 PM
  #314
Fahrvergnügen'd
You must have missed the TG where they talked about the Egyptian remake of the Lada/Fiat.
I think it was in the Best Communist Car episode.
Old 08-05-2011, 12:44 PM
  #315
Registered Member
biker's Avatar
I lived in Cairo for 3 years and know there are a ton of Niva and 124 Ladas there - but as far as I know they still came from Russia. There are a few transplants there - including BMW 5 series (small assembly plant outside Cairo).
Anyway, the Regal should do well as long as the on the lot units are not optioned too high.
biker is offline
Old 08-06-2011, 10:08 PM
  #316
Registered Member
http://www.motortrend.com/roadtests/...ive/index.html
This car should corner well with 19" or 20' wheels.
DeMAN is offline
Old 08-08-2011, 04:23 PM
  #317
fsttyms1's Avatar
Received 3,005 Likes on 2,085 Posts
And with 18's it wont???
fsttyms1 is offline
Old 08-09-2011, 07:36 AM
  #318
Registered Member
Not quite as well.
DeMAN is offline
Old 08-09-2011, 09:27 AM
  #319
Fahrvergnügen'd
Not quite as well.
In their test they ran 19s with all-seasons and 20s with summer tires.
I'd like to see a comparison of both because I have a feeling the 19s with summer tires would be faster around a track than the 20s.
Especially considering the 20s aren't going to be lightweight forged wheels.
Old 12-22-2011, 10:05 AM
  #320
Fahrvergnügen'd
Pricing announced:
$35,310 with destination. Sunroof is $1000, 20" wheels are $700, and Navigation is $1,145. With all three it comes to $38,480. $1000 rebate on the car (stupid GM rebate reliance).
$38,480 puts it in line with an A4 Premium Plus with no options, a 328i with the Sport Package and no other options, an IS250 AWD with no options, or a G37x w/no options.
Given that the Regal is a FWD and two of the other three are AWD, I still think that if a person can get over the idea of paying $38k for a Buick, the Regal is a pretty interesting alternative.
It really depends on how it drives and looks inside but it definitely has the goods on the outside.
Quick Reply: Buick: Regal News **2018 GS Revealed (page 10)**
