BMW: i4 News
Old 11-15-2019, 01:08 PM
Received 5,464 Likes on 3,734 Posts
BMW: i4 News
https://www.autoblog.com/2019/11/15/...etails-report/
BMW's answer to the Tesla Model 3 will arrive in the early 2020s, likely wearing the i4 nameplate. Previewed by the polarizing i Vision Dynamics concept (pictured), it will be an electric-only sedan packed with forward-thinking tech features, and built with composite materials to keep weight in check. We have a better idea of what to expect from its specifications sheet thanks to a recent report.
The i4 will come with an 80-kilowatt-hour, lithium-ion battery pack in its standard configuration, and it will offer 530 horsepower, according to unnamed sources who spoke to Roadshow. That's enough for a four-second sprint from 0-62 mph, and its top speed will be electronically limited to 120 mph
New battery technology will help keep range anxiety in check. The i4 will drive for up to 373 miles on a single charge, though that figure was obtained using the optimistic WLTP testing cycle. Plugging it into a 150-kilowatt DC quick charger will juice its battery pack with an 80 percent charge in 35 minutes; alternatively, it will take about six minutes to channel 62 miles of range into the pack.
Roadshow learned additional variants — including some with more power, and/or more range — will join the line-up a little bit later in the production run, so the i4 could reach M5-like levels of power. All of them will be built on the same modular platform found under the new 3 Series. It was developed with multiple drivetrains in mind to save the firm from designing separate architectures for gasoline- and electric-powered vehicles. The next-generation 4 Series will also use this foundation.
BMW is expected to reveal the i4 — assuming that's what it will be called — in late 2020, and production will begin in Munich, Germany, during the first half of 2021. When it lands, it will join the iX3 (which is, as its name implies, an electric variant of the current X3) and the production version of the battery-powered iNext concept in showrooms.
Old 11-15-2019, 02:42 PM
Azine Jabroni
kurtatx's Avatar
Received 2,159 Likes on 1,387 Posts
Does it come in a non-ugly model?
RPhilMan1 (11-18-2019)
Old 03-03-2020, 09:44 PM
2014 RDX AWD Tech
Comfy's Avatar
BMW i4 Concept First Look: A New Direction for the BMW i Brand
Yes, they managed to keep the Ugliness. Its likely more expensive than Model S, but has shorter range and performance (well okay it's better than base Model 3), sure, looks like a winner to me.
https://www.motortrend.com/news/bmw-...ook-review/The BMW Concept 4 that made its debut at the 2019 Frankfurt Motor Show didn't win over many fans with its massive kidney grille, and the i4 concept here likely faces a similar challenge. It features an equally large pair of rodentlike teeth up front, but if you glance at the i4 and write it off as another failed piece of BMW design, you'd be missing the point entirely. The Concept i4 is the start of a new chapter for BMW, and in a world that's quickly moving toward electrification, the car is a big deal for one of the automotive world's oldest marques.
MotorTrend got an early look at the Concept i4 in January, and when we asked Kai Langer, the head of BMW i Design, about the concept's borderline offensive styling, we were met with a confident smile. BMW's designers know full well what they're doing is going to ruffle a few feathers, but it doesn't bother them at all. Their aim is to push BMW into the future, and they can't do that by catering to those who want every BMW to look like an E28 5 Series. They aren't sorry about the way this car looks.
[img]data:image/svg+xml,%3Csvg fill='none' height='24' viewBox='0 0 24 24' width='24' xmlns='http://www.w3.org/2000/svg'%3E%3Cpath clip-rule='evenodd' d='m8 2h12c1.1 0 2 .9 2 2v12c0 1.1-.9 2-2 2h-12c-1.1 0-2-.9-2-2v-12c0-1.1.9-2 2-2zm12 14v-12h-12v12zm-8.5-4.33 1.69 2.26 2.48-3.1 3.33 4.17h-10zm-9.5 8.33v-14h2v14h14v2h-14c-1.1 0-2-.9-2-2z' fill='%23fff' fill-rule='evenodd'/%3E%3C/svg%3E[/img]SEE ALL 37 PHOTOSSpeaking of the future, the i4 signals a big shift for the i brand. Instead of making a carbon-fiber hybrid sports car and a little city car, BMW has taken aim squarely at Tesla with its latest concept. The i4 concept's range is 373 miles on the European WLTP cycle (WLTP numbers are more generous than EPA figures, but the long-range Model S has a similar WLTP rating), and BMW says the powertrain makes up to 530 hp. The i4 concept is estimated to do the 0-60 sprint in 4 seconds and continue on to a top speed of 124 mph. Those numbers aren't Taycan Turbo-rivaling, but this isn't a sports car.
Because the i4 doesn't have a combustion engine to cool, the grille is now what BMW calls the "intelligence panel," which houses a range of visual sensors. Radar, lidar, and other sensors needed to facilitate autonomous driving reside behind those huge dual kidneys. As cool as that sounds, we worry that this will make a low-speed frontal impact a lot more expensive to repair than it would be on a car without an "intelligence panel."
On the inside, the i4 features a curved screen angled toward the driver—much like what we've already seen in the new Cadillac Escalade. The huge display is connected to the dashboard via small stilts, and it looks as though it's floating on the dash. There are almost no physical buttons on the inside of the i4, and everything is either controlled via the infotainment display or by touch buttons on the steering wheel or in the center stack.
[img]data:image/svg+xml,%3Csvg fill='none' height='24' viewBox='0 0 24 24' width='24' xmlns='http://www.w3.org/2000/svg'%3E%3Cpath clip-rule='evenodd' d='m8 2h12c1.1 0 2 .9 2 2v12c0 1.1-.9 2-2 2h-12c-1.1 0-2-.9-2-2v-12c0-1.1.9-2 2-2zm12 14v-12h-12v12zm-8.5-4.33 1.69 2.26 2.48-3.1 3.33 4.17h-10zm-9.5 8.33v-14h2v14h14v2h-14c-1.1 0-2-.9-2-2z' fill='%23fff' fill-rule='evenodd'/%3E%3C/svg%3E[/img]SEE ALL 37 PHOTOSThe seats are a combination of vegan leather and microfiber cloth, and the interior is extremely minimalist. BMW said it considered only what was deemed essential when designing the interior of the i4. The air vents match the design of the rest of the car, the iDrive controller is made of crystal (though BMW said that likely won't make production), and the car's bronzed tone is carried over from the outside. Most of the metallic surfaces on the inside match the Frozen Bronze color of the exterior. The car bears some resemblance to the i Vision Dynamics concept of 2017, which was said to preview the i4, but clearly the design has gone through some revisions over the past three years.
As is typical with BMWs these days, the i4 Concept has three driving modes: Core, Sport, and Efficient. The modes change the way information is displayed to the driver. In Core mode, the widgets are arranged on the instrument cluster and in the infotainment display in a manner that best suits normal driving. In Sport, the widgets rearrange to create a more focused view and display more information about the road ahead. In Efficient, the displays show an "Assisted Driving View" and relays to the driver what the sensors in the "intelligence panel" are seeing.
[img]data:image/svg+xml,%3Csvg fill='none' height='24' viewBox='0 0 24 24' width='24' xmlns='http://www.w3.org/2000/svg'%3E%3Cpath clip-rule='evenodd' d='m8 2h12c1.1 0 2 .9 2 2v12c0 1.1-.9 2-2 2h-12c-1.1 0-2-.9-2-2v-12c0-1.1.9-2 2-2zm12 14v-12h-12v12zm-8.5-4.33 1.69 2.26 2.48-3.1 3.33 4.17h-10zm-9.5 8.33v-14h2v14h14v2h-14c-1.1 0-2-.9-2-2z' fill='%23fff' fill-rule='evenodd'/%3E%3C/svg%3E[/img]SEE ALL 37 PHOTOSBMW plans to bring a production version of the concept i4 to life by next year and is in the process of retooling its main plant in Germany to incorporate i4 production. The company has committed to investing more than $200 million in said plant to help jump-start production of the i4. BMW hasn't given an official estimate as to when we might see the production version of the i4 concept, but it's safe to assume it's not too far away.
Old 03-04-2020, 12:11 AM
Sanest Florida Man
#1 STUNNA's Avatar
Received 10,390 Likes on 6,299 Posts
Cybertruck > i4
Comfy (03-04-2020)
Old 03-04-2020, 07:25 AM
Azine Jabroni
kurtatx's Avatar
The new logo is awful
Old 03-04-2020, 08:46 AM
Costco's Avatar
Received 3,489 Likes on 2,089 Posts
Everyone else: "EVs don't need grille openings as big as ICE vehicles, we can make smaller openings to reduce drag and increase efficiency"
BMW: "EVEN BIGGER KIDNEYS"
The following 2 users liked this post by Costco:
#1 STUNNA (03-17-2021), Comfy (03-04-2020)
Old 04-19-2020, 01:29 PM
2014 RDX AWD Tech
Comfy's Avatar
BMW i3 won't make it to the US and apparently Ford Mach E is to blame.
They claim that there is very little demand for EVs in US, but we know the fact that they cannot produce a competitive alternative to Mach E or Model 3/ Y in terms of performance and range at present.
Right now Tesla and Ford are kicking the German's asses.
Funny how they "ICED" their plans. Whatever, ...it's their loss.
https://www.autonews.com/sales/finic...rossover-evBMW has iced plans to bring its first electric crossover to the U.S. for now. The BMW iX3 was scheduled to arrive in the first half of 2021.
"At this time we do not have plans to bring the iX3 to the U.S. market," a spokesman confirmed to Automotive News, declining to elaborate on the reasons for the decision.
BMW, like its German rival Mercedes-Benz, is grappling with the realization that the world's second-largest auto market remains half-hearted in its embrace of electric vehicles. Despite their proclamations of interest in battery-powered vehicles, few automakers other than Tesla have made much traction in the U.S. market with EVs.
Complicating their calculations, regulatory pressures in Europe and China are creating urgent need for EVs in those markets. Automakers face hefty fines in Europe next year if they fail to cut their fleet CO2 emissions to an average 95 grams per kilometer.
As a result, the German automakers are recalibrating their EV ambitions in the U.S. — diverting production supply to markets that are more receptive to the new technology, and biding their time for America's interest to kindle.
In December, Mercedes-Benz told dealers it would delay the U.S. launch of its EQC electric crossover by at least a year, pushing it to 2021. Mercedes pinned the decision on strong demand for the EQC in Europe.
"We had to make a little bit of a tough choice," Daimler CEO Ola Källenius told reporters in January at CES in Las Vegas. "Demand [from Europe] by far outstrips supply, even though we are ramping up and adding additional battery lines to the production."
Limited rangeIn late January, BMW informed dealers at a meeting in Boca Raton, Fla., of its decision to not introduce the iX3 in the United States next year.
The crossover is an electric version of the brand's best-selling vehicle, the X3. BMW sold 70,110 X3s in the U.S. last year, up 14 percent from 2018. With the iX3, the X3 will become BMW's first model available with a conventional combustion engine, a plug-in hybrid or a pure electric system.
But the planned EV was shaping up to be an underperformer in the U.S. An EPA estimate of the iX3's driving range has not been disclosed. Unless the vehicle has a range of at least 300 miles, "it's not worth bringing to the table," said one retailer who asked not to be identified.
That is not a given with the new product.
Manufactured in China, the iX3 is powered by a 74-kWh lithium ion battery. That is smaller than the beefier batteries in luxury electric crossovers currently on U.S. roads. The Jaguar i-Pace crossover, for instance, has an EPA range of 234 miles per charge, and it uses a larger 90-kWh battery. The Audi e-tron carries a 95-kWh battery that manages to eke out only 204 miles. Both of those models are selling slowly in the U.S.
The BMW iX3 isn't going to cut it in the U.S. market, said Sam Abuelsamid, principal analyst at Navigant Research.
"To be competitive, you really want to have closer to at least 240 to 250 miles of EPA range," Abuelsamid said. "Anything less than that and I think you're going to be struggling in the marketplace."
Competitive?Another U.S. challenge for the iX3 is that BMW planned to launch it only with rear-wheel drive, limiting its appeal to American crossover buyers seeking the flexibility of all-while drive.
The BMW iX3 is tailored for the China market, where extended range is not a customer priority, said Sam Fiorani, vice president at AutoForecast Solutions.
"Why push a vehicle with limited appeal into North America only to come up short next to a Tesla Model Y or Ford Mustang Mach-E?" Fiorani said. He believes BMW will have a more competitive chance for a U.S. iX3 when the automaker develops the next-generation X3 platform.
"With better batteries and all-wheel drive, the next generation would make a proper entry into this very competitive segment," Fiorani said.
The BMW iX3, made by joint venture BMW Brilliance Automotive in Shenyang, China, features the fifth generation of BMW's eDrive technology, with the drive unit combining the electric motor, system electronics and transmission into a central housing, reducing its weight and footprint.
The iX3 is part of BMW's ambitious target to have 25 electrified models on the road by 2023. And despite its reversal on the iX3, the Bavarian automaker is sticking to a plan to bring two EVs to the U.S. in the next couple of years.
First is the iNext crossover, which goes into production in the middle of 2021. That will be followed by the i4 sedan, which begins production toward the end of 2021. The i4 and iNext have a range of more than 370 miles, compared with the iX3's 273-mile range, based on the European emissions test cycle.
"With the two longer-range models coming, we don't need the limited range, rear-wheel drive iX3 right now," another dealer said.
Old 02-10-2021, 06:30 PM
biker's Avatar
We are just months away from the official unveiling of the first ever production sedan from BMW to be powered exclusively by electricity, with the upcoming i4 being the electric twin of the second-generation 4 Series Gran Coupe.
19 photos
According to official sources, the model will also get an M Performance version, but despite the hefty output don’t expect either of them to become drag strip kings like the Tesla Model S, the Porsche Taycan or even the recently unveiled Audi e-tron GT.
Don’t think of the i4 as an all-round competitor for the previously mentioned EVs either, as BMW will first try to steal a slice of the Tesla Model 3 market before going all-in with a full-size luxury EV called the i7.
Previewed by the BMW Concept i4, which was a powerful yet single-motor and rear-wheel-drive electric model, the production i4 is expected to first feature a single-motor version as well in the quest for better efficiency and a longer range.
The concept was powered by a 530-horsepower motor sending all motive power to the rear wheels, so despite being brawnier than a BMW M3 or M4, it could only do 0 to 100 kph (62 mph) in 4 seconds flat.
Unless the i4 M performance gets two electric motors, which is not that unlikely going forward, expect the production model to have similar numbers as the concept.
The model should get its juice from a lithium-ion battery that can store up to 80 kWh of energy, which should be more than enough to give the i4 a range as high as 600 km (373 miles) in the WLTP cycle.
Latest rumors suggest both the i4 and the M Performance version should feature the single-motor setup, with the sportier version getting better brakes, stiffer suspension settings and an M Performance body kit.
The car is expected to be unveiled later this year, possibly just after the second-generation 4 Series Gran Coupe. Both models will look almost identical, with the i4 being mostly differentiated by the lack of tailpipes, other wheels, less air intakes and some blue accents spread around the body.
2022 BMW i4 Prototype Shows Its Flush Door Handles for the First Time - autoevolution
Old 03-17-2021, 08:04 AM
https://www.netcarshow.com/bmw/2022-i4/
At the 2021 BMW Group Annual Conference the upcoming BMW i4 was revealed. "With its sporty looks, best in class driving dynamics and zero local emissions, the BMW i4 is a true BMW. It makes the heart of the BMW brand now beat fully electric," said Pieter Nota, member of the Board of Management of BMW AG responsible for Customer, Brands, Sales.
The BMW i4 is a fully electric 4-door Gran Coupé and will enter the market during the course of 2021, including a BMW M Performance model. Its refined balance of BMW typical sportiness, comfort and sustainable performance are unique in its segment.
The BMW i4 model line will be available in different versions covering ranges of up to 590km (WLTP) and up to 300 miles (EPA). With a power output of up to 390kW / 530HP the BMW i4 can accelerate from zero to 100km/h in around 4 seconds.
Old 03-17-2021, 08:12 PM
Azine Jabroni
kurtatx's Avatar
Definitely something I would consider after my Model 3 lease. I'm not saying it's better but it's good to have more options.
Comfy (03-20-2021)
Old 03-18-2021, 12:30 AM
2014 RDX AWD Tech
Comfy's Avatar
Good for the world to have more EV options. I don’t see any mention of price. I’m guessing it’s gonna be close to $70k. Hope they make it sooner.
Old 03-18-2021, 09:32 AM
Received 6,065 Likes on 3,985 Posts
..but the face...
Side bar question, did you lease through Tesla or third party?
Old 03-18-2021, 09:48 AM
TSX69's Avatar
Received 1,400 Likes on 704 Posts
Arrow Cnn
https://www.cnn.com/2021/03/17/succe...car/index.html
BMW unveils a new electric car, but says it isn't counting out gas engines just yet
By Peter Valdes-Dapena, CNN Business
Updated 12:05 AM ET, Thu March 18, 2021
(CNN) On Wednesday, BMW unveiled the i4, the latest addition to its line of electric cars. And while the luxury automaker plans to add more electric vehicles to its lineup, it made clear that it will still make cars with gas engines for the foreseeable future.
BMW chairman Oliver Zipse said in an online press conference, the company will keep developing, building and selling cars with internal combustion engines, including plug-in hybrids.
"If there are no customers [for these vehicles] in our 140 markets, we will stop producing them," he said.
The BMW i4 is an all-electric sedan and the latest addition to the automaker's EV lineup.
This is a departure from some of the other major automakers. While not firmly committing itself,
General Motors has said it plans to sell only zero-emission vehicles by 2035. Volvo announced recently it will become a fully electric car brand by 2030. BMW, however, is not putting any timeline on when, or if, it will become an all-electric carmaker.But at some point, it may have very little choice.Some countries and states have said they plan to ban sales of internal combustion-powered cars in the not-very-distant future. Great Britan and the US state of California haveproposed bans on sales of internal combustion-powered vehicles, including hybrids, by 2035. Norway wants all new passenger cars and vans sold in that country to be zero-emissions by 2025.The BMW i4 will be available in versions that offer a driving range of up to 300 miles.
BMW's strategy has long been to maintain flexibility in its engineering as it develops new vehicles so that its factories can shift quickly and easily from producing purely internal combustion cars to producing plug-in hybrids or electric cars as market demand shifts. The underlying engineering architectures for BMW vehicles is designed to make it easy for them to be built with electric, hybrid or purely internal combustion power.
"We are much more flexible than the world thinks we are," Zipse said.
BMW released few details about its new i4 electric sedan, beyond images of the exterior. It's a four-door car similar in profile to the petroleum-powered BMW 4-series. It will be available in versions with up to about 300 miles of US EPA-estimated driving range and can produce up to 530 horsepower.
Last November, BMW unveiled the iX, an all-electric SUV intended as the top model for the brand's "i" electric vehicle sub-brand. The iX is expected to go into production later this year. The i4 is also expected to go on sale in Europe later this year and in the US early next year, a BMW spokesman said.
BMW will offer electric models in 90% of the market segments it competes in by 2023, the company said in an announcement. By 2030, the company expects roughly half its global sales to be electric vehicles.
Volkswagen and Audi are starting to challenge Tesla
But there is at least one brand in theBMW Group that is going all electric. BMW's Mini division will offer only electric cars by the mid-2030s, the company announced.
Mini's small cars, which are frequently driven short distances in urban environments, are well suited to electric car buyers, Zipse said. Mini currently offers one fully electric model, the Mini Cooper SE. A next-generation version of the Mini Countryman SUV, which will go into production in 2023, will also be available in an electric version.
BMW also owns Rolls-Royce, the British ultra-luxury brand that sells cars like the Rolls-Royce Ghost and Phantom, which costhundreds of thousands of dollars. There are no plans to make Rolls-Royce an electric-only brand, but an electric model is coming soon, Zipse said.
"There will be an electric Rolls-Royce in this decade and probably not late in this decade," Zipse said.
Old 03-18-2021, 12:08 PM
Azine Jabroni
kurtatx's Avatar
Originally Posted by SamDoe1
..but the face...
Tesla
I probably shouldn't have because they hold their value so well but lesson learned.
The Y is financed through a credit union.
Old 06-01-2021, 08:45 PM
biker's Avatar
While BMW sales are now dominated by crossovers, there's no denying that the brand's history and fanfare are dominated by sedans. That makes the 2022 BMW i4 revealed today with full specs and photos the most important electrified Bimmer yet.
In a way, you could think of it as an all-electric 4 Series Gran Coupe. Its name and interior design would back that up, as would its coupe-like body that stretches just a bit longer than the 3 Series sedan's at 188.3 inches versus 182.7. It's also an inch wider (72.9) and 0.6 inch taller (57.0). Despite a loftier height, its skateboard-style battery pack results in a center of gravity that's either 1.3 or 2.1 inches lower depending on the flavor of i4 you choose.
Speaking of which, there will be two models: the i4 eDrive40 and i4 M50. They share a common 81.5-kilowatt (usable) battery pack, but their motors differ. The base eDrive40 has a single rear motor with integrated single speed transmission that produces 335 horsepower and 317 pound-feet of torque. The M50 has motors front and rear for effective all-wheel drive. The front motor, again with an integrated one-speed transmission, has 255 hp, while the rear motor has 308. Together, they produce a total system output of 536 hp and 586 lb-ft. The M50's Sport Boost function can then provide a 10-second jolt of 67 extra horses and 48 more pound-feet – and in a feature slightly comparable to Mario Kart, you can keep on pressing the Sport Boost button as long as the battery allows.
Launch control is standard on both, resulting in 0-100 km/h (62 mph) times of 3.9 seconds for the M50 and 5.7 seconds for the eDrive40. Shave off a tenth or two for a good-old American 0-60 time.
BMW estimates the eDrive40 will travel 300 miles on a charge, while the i4 M50 will go 245 miles. These are comparable to the Ford Mustang Mach-E as one example, but are less than a Tesla Model 3. Both models have a DC fast charging capacity of up to 200 kW that can gain 90 miles in 10 minutes. You can also recharge using a Level 2 charger from totally empty to full in 8 hours.
Drivers will have a choice of three levels of regenerative braking, including a high setting comparable to what electrified BMWs have provided going back to the original electric Mini Cooper. If you're a fan of one-pedal driving (we are), the i4 should make you happy. However, it also offers a coasting function for those so inclined and ups the ante with an adaptive brake energy recuperation function that takes into account myriad inputs to vary recuperation and braking according. Frankly, BMW's description of this feature is confusing and is probably something better described once we get a chance to try it out in person. The same goes for the i4's Level 2 driver assistance system, which integrates speed limits and navigation route guidance inputs into the optional adaptive cruise control system.
To make up for the lack of zesty internal combustion noises, the i4 features "an unmistakable, model-specific acoustic experience" from startup to full throttle, developed in collaboration between BMW and Academy Award-winning film composer Hans Zimmer. We'll see if "BMW i4" shows up after "No Time to Die" in his IMDb profile.
In terms of old-fashioned BMW concerns like "handling" and "steering," every i4 includes a double-joint spring strut front axle, a five-link rear, load-leveling rear air suspension and an adaptive "lift-related" shock system. The latter is a speed-dependent system that reduces body motions and vibrations. The adaptive M suspension standard on M50 and optional on eDrive40 is a driver-selectable system with different modes, much as you'd find in most other BMWs. Steering is speed-sensitive with two settings of Comfort and Sport, while the variable sport steering upgrade (standard M50, optional eDrive40) is a speed-sensitive variable ratio system.
As the first fully electric car tuned by BMW M GmbH, the M50 features additional upgrades over the eDrive40, including an additional brace fitted between the two strut towers, special anti-roll bars, M Sport brakes and lighter-weight wheels measuring 19 or 20 inches. It's also tuned to be rear-biased in its power delivery despite having the front motor, and its weight distribution is closer to the 50/50 BMW ideal at 48.1/51.9 (versus 45.1/54.9). Visually, the M50 differs with a unique front bumper and Cerium Grey trim applied to the grille, mirror caps and rear bumper. Other bits and pieces are painted gloss black, while the trunk lid gets an M-specific spoiler.
As for the overall design, the i4 obviously descends from the beaver branch of the evolutionary tree. Without a trace of irony, the press release proudly declares that the "BMW kidney grille … is largely blocked off due to the small amount of cooling air required by the electric drive components." For that small amount of cooling, an active air flap adjusts in 10 stages to provide air precisely to the areas that need it.
The interior is basically the same as a regular 3/4 Series but with the hatchback trunk lid of a Gran Coupe and the iX's enormous, curved infotainment display applied to the dash. Consisting of a 14.9-inch central display and 12.3-inch information display behind the wheel, the two are connected behind a single frameless glass surface. A head-up display is also included and is apparently better integrated with the main displays below. All are controlled via the next-generation iDrive 8 interface (the 3/4 Series has iDrive 7), which includes new displays, controls and data processing. It also has new natural speed recognition voice commands and over-the-air updates.
Other features include a new climate control system that can automatically integrate the heated and ventilated seats into your temperature selection, and that also considers the number of passengers aboard and where they're sitting. The glass roof comes standard and features a slide/tilt sunroof portion up front, while optional ambient lighting helps spruce the cabin up beyond what is otherwise a rather disappointing recycle of the 3/4 Series.
The 2022 BMW i4 will go on sale in early 2022 with a starting price of $56,395 for the eDrive40 and $66,895 for the M50 (both include the $995 destination charge). BMW still has EV tax credits available to it, so you can basically slash $7,500 from those figures plus other state-level incentives.
It's also worth noting that BMW went out of its way to make the i4 eco friendly in more ways than just its lack of burning gasoline. To ensure high environmental, sustainability and human rights standards, BMW directly obtains the cobalt used in its battery packs before turning it over to suppliers, while also monitoring where the lithium is sourced. The company also says the electric motors do not use rare earth metals and that recycled plastics are used for many components. Finally, BMW is partnering with EVgo fast charging network that relies on 100% renewable energy. Buyers and leasees of the i4 will receive $100 in EVgo charging credits.
2022 BMW i4 performance, range and other specs revealed with new pictures | Autoblog
Old 06-02-2021, 06:30 AM
Again, apart from the beaver teeth, looks good.
Old 06-02-2021, 10:32 AM
A-TSX Oldie
BurnabyTSX's Avatar
Maybe I've been Stockholm-syndromed, but saw a few of the new 4's around lately, and at least with the front plates on, it kinda looks ... not too bad. The i4 overall looks very nice, but then again, the 4GC is a very beautiful car.
Old 06-02-2021, 10:42 AM
Chief F1 Fan's Avatar
Received 7,148 Likes on 3,635 Posts
It's an abomination to refer to a 4 series as a Gran Coupe IMO.
Old 06-08-2021, 09:18 PM
biker's Avatar
BMW is getting into the EV game for real now—years after testing the waters with the i3 and the i8—and its newest battery-electric models are coming here in a matter of months. If you've been waiting for an electric 3-Series, you'll be able to buy... an electric 4-Series Gran Coupe when two versions of the i4 land here in the first quarter of 2022, offering a little extra versatility compared to the standard sedan body style. The i4 is perhaps destined to be endlessly compared to the Tesla Model 3 in all aspects, but as we'll see, it could end up targeting a slightly different niche in the market.
Here are 5 things to know about the 2022 BMW i4.
BMW didn't completely reinvent the look of the car in creating the i4, but it should still be easy to distinguish one of these from their gas-engined siblings once you seen it in traffic for the first time. The automaker used the profile of the 4-Series Gran Coupe as the starting point, giving the i4 unique exterior details while keeping the frameless windows. Featuring short overhangs and a relatively long wheelbase, the i4 majors in aerodynamic efficiency, with the i4 eDrive40 boasting a drag coefficient of 0.24, while the i4 M50 offers a coefficient of 0.25.
"All areas of the body have been crafted according to aerodynamic principles, from the front bumper to the exterior mirrors to the tailgate's integral spoiler lip," the automaker notes. "The high-voltage battery housing, the motor compartment shielding and the cover for the torsion struts form a continuous surface with seamless transitions to improve air flow along the underbody."
When it comes to design, the i4 sports BMW's latest version of the kidney grille, with active air flap control at the bottom working to reduce aerodynamic drag even more. The flaps can be positioned in a total of 10 stages, letting air in to cool the battery, brakes, air conditioning, and drive system in just the amounts needed. Tapered door handles are another unique detail found on this electric sedan, and even the standard light-alloy wheels were designed with aerodynamics in mind, as you may have guessed by now. A hockey stick-shaped blue element is there to remind others in traffic that the i4 is electric, with the blue accents extending to the frame of the kidney grille as well. Out back, the lightweight rear diffuser is actually made from textile-based raw materials, continuing with the theme of efficiency.
At launch, BMW plans to offer two flavors of the i4 in America: the i4 eDrive40 and the i4 M50. The eDrive40 will serve as the base model stateside and will be offered solely with rear-wheel drive, with a single motor producing 335 hp and 317 lb-ft of torque. This version of the i4 is expected to offer an EPA range of 300 miles, and 0-to-60-mph sprints in 5.7 seconds.
The more powerful half of the duo will be the i4 M50, offering all-wheel drive and 536 hp and 586 lb-ft of torque with the Sport Boost function, which adds an extra 67 hp and 48 lb-ft of torque for over 10 seconds. Even though it'll have the same battery as the eDrive40, it will trade some of that range for power, so it's expected to land with a 245-mile range. This version will make the sprint from 0 to 60 in just 3.9 seconds. Official EPA ranges for both versions will be published shortly, before the models' market debuts in a few months.
"To allow maximum power to be summoned in situations where the car's performance capabilities are being really put to the test, the Sport Boost function can be activated several times in succession if the high-voltage battery has enough charge," the automaker says. "Every time the driver accelerates, a fuel gauge-style icon in the instrument cluster shows how much extra power is available and for how long."
The single-motor eDrive40 and dual-motor M50 both use electrically excited synchronous motors, rather than ones driven by fixed permanent magnets. This approach eliminates the need to use rare earth metals, which would have been required for magnetic components, in their construction. These motors offer an efficiency factor of 93 percent, and were developed in-house by BMW.
The motors themselves are positioned in the axles, and the axles also house the one-speed transmissions.
Both versions of the i4 feature the same battery size, offering 83.9 kWh gross and 81.5 kWh net (but you'll likely see them referred to as 82-kWh in the media). The battery itself is composed of four modules with 72 cells each, and three more modules with 12 cells each, offering a volumetric density that is 40% higher than that offered in the BMW i3. The battery itself is only 4.3 inches tall, located low in the floor for better agility.
This positioning gives the i4 M50 a center of gravity that is 1.3 inches lower than in a 3-Series, or 2.1 inches lower than a 3-Series in the case of the eDrive40, the automaker points out. The battery itself is also integrated into the body structure in order to increase torsional rigidity, with the battery enclosure being directly connected to the front axle subframe, while the battery pack is joined to the floor assembly with 22 bolts.
"The lithium required for battery cell production is likewise obtained under transparent conditions that are monitored by the BMW Group," the automaker says. "The BMW Group sources the lithium used in the high-voltage battery pack on board the BMW i4 from hard-rock deposits in Australia and passes it on to the battery cell makers. The company can therefore ensure that environmental and sustainability standards are observed during the extraction and processing of cobalt and lithium and that there are no violations of human rights."
With DC fast-charging, the i4 can charge at up to 200 kW, with BMW pointing out that just 10 minutes of charging at this speed will give the car 90 miles worth of juice. Using a Level 2 wall box with AC power and a charging rate of 11 kW, the i4 can recharge its battery from a completely depleted state to 100% in under eight hours, according to BMW. (Of course, we don't recommending depleting the battery down to 0% to begin with).
BMWThe cabin of the i4 is a mix of the familiar and the new, mixing some sci-fi aesthetics with a layout that longtime BMW buyers should find recognizable. The EV genre demands large screens, and that's exactly what the i4 will offer in the form of a 12.3-inch information display and 14.9-inch control display forming one large, curved screen surface spanning more than half of the available dash space. BMW angled the screen toward the driver, but the screen is not really integrated itself; rather, it sits like a tablet or an open book, leaning slightly against the dash.
"The BMW Curved Display in the BMW i4 is held in place by a supporting structure that is concealed from the occupants’ view and appears to be free standing in the cockpit," the automaker notes. "The anti-reflective glass used makes it possible to dispense with the customary binnacle for shielding the readouts from sunlight, giving the cockpit area a remarkably tidy and airy appearance."
Current BMW owners will be pleased to learn that a modern BMW gear shifter has not been traded for some kind of setting in the screen's sub menus, even though it now has blue accents and a blue start button next to it. And the iDrive rotary knob is still there as well. Those who've been in a 3-Series or 4-Series will find the proportions of the interior almost prosaic and businesslike, with BMW keeping reminders of the car's electric drivetrain to a minimum, offering a sports steering wheel with multifunction buttons and sports seats as standard items in this model. Three-zone climate control will be standard as well, in addition to acoustic glazing for the windshield. Another standard item is a slide/tilt sunroof covering 3.6 square feet. Ambient lighting will be optional (but really required if you're buying an electric BMW).
When it comes to the sound system, the i4 will offer a 10-speaker audio system with a 205-Watt amplifier as standard, while a Harman Kardon system with 16 speakers with a digital seven-channel amplifier will be optional equipment.
The i4 will land here in the first quarter of 2022, with the i4 eDrive40 set to start at $56,395, while the i4 M50 will weight in at $66,895, before any federal or local incentives.
Among other things, this means that the price premium for the performance-flavored M50 model will be just $10,000. This will also be the price premium if you need all-wheel drive, as the eDrive40 is solely a rear-wheel drive model.
These two main versions of the i4—while being far from an exhaustive alineup given the many versions of the 3-Series you can get in Europe—should still offer enough variety for BMW buyers looking at electric models.
Price-wise, especially once optioned, the i4 will really lean closer to competing with the Tesla Model S than the Model 3. It will really be positioned (and priced) like a 5-Series. In time, this positioning will likely shift a bit as more electric models arrive and the lineup gets really fleshed out, but when it comes to competition in the actual car marketplace, it's likely to occupy a bit of an odd spot for a while above the Model 3.
5 Things to Know about the BMW i4 (autoweek.com)
Old 08-25-2021, 12:30 PM
Old Man Yelling at Clouds
1Louder's Avatar
Received 7,362 Likes on 3,906 Posts
Old 08-26-2021, 10:27 PM
2014 RDX AWD Tech
Comfy's Avatar
Old 08-27-2021, 08:32 AM
1Louder's Avatar
Originally Posted by Comfy
Curious why? This looks like a great car.
Old 08-27-2021, 11:40 AM
2014 RDX AWD Tech
Comfy's Avatar
With optional upgrades and dealership markups you are looking at $70-80k, at which point it doesn’t make any sense given it’s inferior specs compared to any Teslas in that price. Yes some people (who only care about badge snobbery and are rich) will still buy it, but it won’t be in any meaningful numbers.
Old 08-27-2021, 12:45 PM
1Louder's Avatar
Not every EV buyer is making a selection solely on 0-60 time. And I built my own e40 on their site and nicely equipped it was $55k. So not sure where 70-80 is coming from, but I suspect the M50 may get into high 60's. However I bet the fit, finish and handling of the BMW is going to be superior. Remains to be seen but those are clearly strong suits of the brand. We're on our second BMW and my only knock on them is they are in fact more expensive to maintain, but aside from that they are superior examples of design and engineering. No "badge snobbery" needed. They deliver the goods. And without the expensive engine-related maintenance issues, I bet owning one will be far more on par with any other EV in the category.
Old 08-28-2021, 11:31 AM
1Louder's Avatar
Over $90k now for a Model S long range. No rich brand snobbery going on there. None at all...
https://www.caranddriver.com/news/a3...ce-adjustment/
And I was mistaken about the i4 build but not on price. The pre orders for the 40 are $55k base price, but even if you added options it could be nearly all offset by the $7500 tax credit. M50 is $66k base.
Old 08-28-2021, 05:03 PM
2014 RDX AWD Tech
Comfy's Avatar
Did you forget the dealership add ons…. Unless this is a model which no one wants to buy?
And if that is the final price, will they be making any profit from that?
Remember when BMW made fun of Tesla after a complete tear down of Model 3 and declared that this car will never be profitable since they estimated the car costs 90% of the price to manufacture. Elon replied at that time that this was the “best analysis to date”.
Old 08-28-2021, 07:42 PM
Dealership add ons are optional.
Old 08-29-2021, 01:33 AM
SSFTSX's Avatar
Germanic industry will be well integrated with Asia. with direct plants built by Asians in Europe and direct supply of parts from Asia to Europe through trains.
speed of delivery is much faster than using ships and ports congestion.
display panels, batteries etc for autos are all Asia strong points. which is replacing traditional Europe strength in transmissions/engines.
https://www.handelsblatt.com/english...y4ko7Xojts-ap1
Germany’s big (Chinese-made) battery plant to dwarf Tesla’s Gigafactory
The e-car battery plant in the city of Erfurt, built by Chinese company CATL, will likely be much larger: It could be three times the size of Tesla’s US plant.
Xi'an launches first special train for South Korean LG Group as "Chang'an" China-Europe freight trains help China to open up
It is estimated that these semi-finished goods and raw materials such as LCD panels, electrodes, and aluminum foil papers produced by the South Korean LG Group will arrive in Slawkow, Poland in about 10 days.
Old 08-29-2021, 06:52 AM
2014 RDX AWD Tech
Comfy's Avatar
That’s great news for the EV industry.
Old 10-13-2021, 09:50 AM
https://www.caranddriver.com/reviews...-i4-m50-drive/
A mere look at the i4 M50 doesn't hint at its significance. There's little to distinguish it from the like-sized 4-series Gran Coupe four-door it's based on. But this is BMW's first EV to wear the storied M badge, even if it's an M50 moniker and not a full-blown M.
It earns the M badge, too, as its power and range are a massive leap beyond BMW's previous i-subbrand offerings. The i4 uses the same 255-hp front and 308-hp rear motors as the iX, but with a higher peak output of 536 horsepower and 586 pound-feet of torque, thanks to a battery that is smaller in capacity but stronger in output. That's more power than the current M3 and M4 Competition models. Smacking the go pedal brings hard and instant thrust, causing the front end to rise up dramatically as the i4 hurtles ahead. Holding down both pedals when stopped activates launch control, during which it pulses the motors, giving the impression that the car is champing at the bit. Acceleration to 60 mph is expected to be in the three-second range, or as quick as an M3/M4.
The i4 M50's $66,895 starting price makes it a bit of a bargain in the BMW lineup—that's less than you'll pay for even the base M3. There's also a $56,385 335-hp eDrive40 model with the same 80.7-kWh battery capacity.
Adding audio to the experience is a whirring soundtrack whose tone rises and falls with motor speed and gets louder and softer depending on the rate of acceleration or deceleration. Select Sport mode and the sound is overbearing. Switching it off left us marveling at the i4's silence. There's no whine from the motors or high-voltage electronics that are usually present in EVs. This is one of the subjectively quietest EVs we've ever driven.
The i4 is nearly 1000 pounds heavier than an all-wheel-drive M3, yet the additional mass isn't obvious when you're driving. Weight distribution leans rearward, and the center of gravity is 1.5 inches lower than in the 3-series. Like the 3-series, the i4's steering is light on feedback. Mostly you notice massive grip from the 20-inch Pirelli P Zero PZ4 Elect tires. As in the iX, a curved panel housing two screens dominates the i4's interior, a setup that will soon proliferate through the BMW lineup.
At the rate it sucked energy on a blast from Munich to the Bavarian Alps, the i4 won't travel much farther than 200 miles. Then again, a Tesla Model 3 Performance, its most obvious competitor, doesn't do much better.
Old 10-13-2021, 10:09 AM
1Louder's Avatar
I wish the eDrive40 would come in AWD. It's not an easy pill to swallow to jump up to the M50 just to get AWD particularly if you aren't interested in that kind of performance. And it will easily be in the $80's after options.
But I think they got it all right with the look and interior.
Old 10-13-2021, 10:41 AM
I'd be curious to see what the standard feature set of this is. If it comes pretty well featured from the get go (as it should because its competitor does) then it probably won't tack on much in options. I'd pay a small premium over the M3P for the i4 M50. Excited to see what the inevitable Mi4 will be!
Old 10-13-2021, 11:04 AM
A-TSX Oldie
BurnabyTSX's Avatar
One of the reviews mentioned that BMW will not be differentiating between the real "M" and the "M-performance-whatever" line for the i4. So the M50 is essentially the Mi4.
Beautiful car. Only thing that bugs me is that weight and the annoying driveline tunnel; but otherwise the perfect car.
Old 10-13-2021, 12:13 PM
1Louder's Avatar
I agree - if those prices are well equipped that puts the M50 in striking distance. I was assuming the eDrive40 might need 10k worth of options like other BMWs. Will be interesting to see. Maybe because these will be lower volume cars they will be incentivized to minimize the number of different configs and offer more standard.
Old 10-15-2021, 01:15 PM
Liquid Ice
LiQiCE's Avatar
Lots of "first drive" reviews have come out about the i4 M50. My M340i lease is up next year already (with the pandemic, it feels like I just picked up the car) - was considering the M3, but the i4 M50 sounds really cool too.
All of the first drive reviews say the car drives really well and the acceleration is good although not as fast as a Model 3 Performance (3.1s 0-60) or an M3 xDrive (2.9s 0-60) - the i4 M50 on paper does 0-60 in 3.9s but videos have been recorded of it doing a 3.6s 0-60.
0-60 video from Car Wow:
Fairly In depth review from Autogefuhl:
Will be interesting to see how much BMW will discount these too - pre-pandemic, 10% off MSRP was not out of the question for a non-M car (and this isn't a full fledged M car). If they discount a decent amount on the i4 M50, it could be very price competitive with Tesla which doesn't discount at all.
Old 10-15-2021, 01:42 PM
Whats up with RDX owners?
civicdrivr's Avatar
Received 8,366 Likes on 4,921 Posts
I love that this is an EV that doesn't look lame like the majority of EVs on the road.
I just wish there was a frunk and the m50 had maybe 50mi more range.
Old 12-01-2021, 03:02 AM
biker's Avatar
The Munich-based automaker held an event over the weekend at BMW Welt in its home city, handing over the first examples of the fully electric BMW i4 to new owners, three months earlier than expected. The battery-electric Gran Coupe entered production just a month ago, with the first examples rolling out of a plant nearing the 100-year mark, and that currently produces the BMW 3-Series sedan and Touring models, the BMW M3 and the BMW 4-Series Gran Coupe.
Aimed at the Tesla Model 3 and the Polestar 2, the BMW i4 will make it stateside early next year in two main flavors at launch: the single-motor, rear-wheel-drive i4 eDrive40 will be the entry model, starting at $56,395, while the dual-motor all-wheel-drive i4 M50 will be the sportier performance version with 469 hp and 538 lb-ft of torque on tap, starting at $66,895.
The base model will serve up about 300 miles of range, BMW has indicated, though concrete EPA numbers won't be known until a few weeks before its US launch.
"It is a very special moment for us when we hand over brand new models to customers for the first time," said Bernhard Kuhnt, senior vice president BMW Group Market Germany. "The BMW i4 shows in an emotional way how well fully electric mobility and sporty driving dynamics fit together. For us, it is therefore clear: the BMW i4 will offer our customers a whole new dimension of driving pleasure."
BMW is in slightly uncharted territory here with the i4, and could face an uphill battle against Tesla in its home market where the American sedan has become an unexpected hit, just ahead of the start of production at new Tesla plant outside Berlin. So the first deliveries of the i4 are happening against the kind of backdrop that would have been difficult to imagine even five years ago—German automakers having to catch up to an American import sedan.
The i4 will face an admittedly small cast of competitors at launch, as for now only Tesla and Polestar offer vehicles that could be considered vaguely similar, with BMW's offering landing a bit north of both cars in price even given the recent (of several) price hikes of the Model 3. The Tesla Model 3 currently starts at $46,190 for the base, rear-wheel-drive single-motor version, while the Polestar 2 starts at $47,200 for the long-range, single-motor version.
It will be some time before more midsize premium or luxury electric sedans arrive, as most of the competition has focused on fielding crossovers and SUVs in this particular price range, in addition to luxury sedans priced much higher. This is also the reason why it took so long for competitors to the Model 3 to actually arrive on the market: Automakers saw greener pastures in other segments, and with good cause.
Speaking of those other segments, deliveries of another electric BMW model are not far behind.
"With the BMW i4, we have absolutely struck a chord," Kuhnt added. "You can see this from the very high demand for this car. We are delighted to be expanding our electrified product lineup with this sporty, fully electric Gran Coupé at exactly the right time and to present the first vehicles to our customers today—three months earlier than originally planned. The first delivery of a BMW i4 today, and the first BMW iX in about a week, are further milestones for the BMW Group on the road to electromobility."
BMW i4 Deliveries Begin Three Months Early (autoweek.com)
Old 12-01-2021, 10:04 AM
Just did the build your own thing online and mine comes out to ~$74k for the i4 M50i. Take out the $7500 in rebates (for now, maybe more) and it might be a wash to sell the Tesla and get this...
Old 12-01-2021, 10:16 AM
Go from no nose to pig nose....
Old 12-01-2021, 10:17 AM
I'd be ok with that. The snout has started to grow on me.
Quick Reply: BMW: i4 News
