Acura: TLX News
Old 05-25-2017, 12:20 PM
  #11921
oonowindoo's Avatar
Received 4,273 Likes on 3,050 Posts
Originally Posted by iforyou
Hmmm, I think it's 3% just for the dampers...not sure what the total effect is with all the changes combined together.
Unfortunately those aren't summer tires, just MXM4. Still better than the Goodyear tires though.
Those are the upgraded A Spec tires???
Old 05-25-2017, 12:51 PM
  #11922
You'll Never Walk Alone
iforyou's Avatar
Yup. The A-spec tires are MXM4's based on the videos and photos I've seen.
We Canadians are more lucky though. We get Michelin Pilot Sport A/S 3 which are ultra-high performance all season tires as opposed to grand touring ones.
Old 05-25-2017, 03:46 PM
  #11923
I feel the need...
Fibonacci's Avatar
lol 3% doesn't sound like a lot but it seems like most reviewers enjoy driving the new A-spec. Perhaps the overall setup, including the dampers, steering ratio, larger rims, wider tires, stiffer suspension components etc all contribute to the overall improvement.
Meh, not compelling enough reason for me to return to a TLX V6 SH-AWD. Same mediocre ZF 9AT slush box. Same weak brakes. No bump in power. Slight to barely noticeable handling improvement.
Acura can put adjustable dampers in the 7 passenger family hauler, but they can't find a way to put it in their supposed sports sedan? Does not compute.
Add back the 6MT, increase the braking surface by 15%, insert adjustable dampers from the MDX, tweak the powerband. Call it a Type-S, then I'll be back.
Old 05-25-2017, 04:23 PM
  #11924
_
AZuser's Avatar
Received 3,097 Likes on 1,867 Posts
Trash talking about the awesomely wonderful TLX. . . . Saintor will report you to the moderators if he sees this.
The following 4 users liked this post by AZuser:
Costco (05-25-2017), crazyasiantl (05-26-2017), TacoBello (05-26-2017), ttribe (05-26-2017)
Old 05-26-2017, 11:37 AM
  #11925
iforyou's Avatar
Agreed on the brakes and power. But from the reviews I've read and watched so far, most seem to be praising the updated ZF 9AT and noticeably improved handling (A-spec trim). Many are claiming that the A-spec is actually fun to drive now.
Old 05-26-2017, 03:13 PM
  #11926
Saintor's Avatar
You obviously never tried the 2016+ ZF9 - it is at least very good. Car&Driver even praises it.
Originally Posted by Car&Driver
Ratios are stacked tightly, making it fun to employ the wheel-mounted paddle shifters. Sport+ switches to manual mode with the first tug of a lever and holds it until the driver instructs otherwise; it also allows for double downshifts. In the less aggressive settings, the transmission returns to drive after a few moments of inactivity. Numerous algorithms run in the background, optimizing transmission operation to suppress upshifts during spirited cornering and to hold gears while climbing and descending steep grades. If it sounds like a lot of electronic tomfoolery that will only try to put a lid on the fun, we’re here to tell you that’s not the case.
Old 05-26-2017, 03:22 PM
  #11927
Azine Jabroni
kurtatx's Avatar
Received 2,158 Likes on 1,386 Posts
ZF 9 is such a let down compared to the DCT in all the competitors. Heck, the 4 cylinder TLX has a DCT.
Old 05-26-2017, 04:27 PM
  #11928
oonowindoo's Avatar
the issue with ZF was never about how it performs.
Old 05-26-2017, 06:03 PM
  #11929
iforyou's Avatar
Well, how it performs was part of the issue - sluggish and delayed gear changes,unexpected downshifts, lack of kickdown, etc. But there were also the reliability issues of vibration, randomly shifting to neutral, and wrong gear indication (light shows P, but the car is actually in N).
My understanding is that the aforementioned reliability issues mainly affected 2015 TLX. On the other hand, the performance issues were improved, but not completely fixed. With that said, it seems like Acura and/or ZF has fixed these performance issues for the 2018 model.
Old 05-26-2017, 06:23 PM
  #11930
oonowindoo's Avatar
I don't consider sluggish and lack of kickdowns issues. You can just call it a sucky auto tranny and there are plenty of those out there.
It's just because it is ZF and ZF8 is arguably the best AT out there, only they know how they messed up the ZF9 so badly when compared to ZF8.
When the car moves by itself when parked, that is an issue.
Old 05-26-2017, 07:23 PM
  #11931
Saintor's Avatar
Care to explain?
The ZF9 is just fine, acts very much like a ZF8. It is butter-smooth and shifts crisply; I much prefer it to any DCT I drove. Not surprised that Audi hasn't put a DCT in their 2018 S4. I still think that the ZF8 is a notch above the ZF9, but the ZF9 has a least 90% of the goodness.
Old 05-26-2017, 08:46 PM
  #11932
TacoBello's Avatar
Received 4,416 Likes on 3,322 Posts
Old 05-26-2017, 09:34 PM
  #11933
nanxun's Avatar
Received 3,262 Likes on 2,026 Posts
Power unit needs some updating, and can't believe the exhaust tips aren't even connected to the actual tailpipes....
And that grille?
Old 05-29-2017, 01:25 PM
  #11934
iforyou's Avatar
Care to explain?
Car and Driver has an article on the ZF9 issues:
ZF 9-speed Automatic Problems Mount, Chrysler Releases Third Update for Cherokee - News - Car and Driver | Car and Driver Blog
Again both reliability issues and performance issues are mostly for the 2015 vehicles. Since then, things have gotten a whole lot better. Still not at ZF8 level, but it's decent now.
Hmm, exhaust tips not connected is more common than you think, check out this $100k Mercedes:
Audi R8:
Bugatti Chiron:
Costco (05-30-2017)
Old 05-29-2017, 01:32 PM
  #11935
TacoBello's Avatar
Yup, I was going to say- it's the norm these days for the exhaust tips to be separate- and it's not really a bad thing. If you ever have to replace a muffler, you can just get any aftermarket one that fits the car- you don't have to go to the dealership or wrecker to get a specific exhaust muffler. I guess the tip could just be welded on, but I dunno. Personally, I don't have an issue with the pipes being like that.
Old 05-29-2017, 01:43 PM
  #11936
nanxun's Avatar
Huh, whaddya know. Hadn't ever noticed that. Seems "wrong" to me (sorta like artificial engine noise being piped into the cabin), but (as noted by TacoBello) makes practical sense, I suppose.
Old 05-29-2017, 01:44 PM
  #11937
iforyou's Avatar
Never thought about that but that's a great point.
Yea it doesn't bother me either.
Old 05-29-2017, 01:47 PM
  #11938
TacoBello's Avatar
I think automakers do that for a few reasons.
1. It likely doesn't require much, if any centering of the exhaust tips, so that they look even. The muffler and plain muffler tip behind the fascia barely have to line up to work as intended.
2. Replacement is likely easier and cheaper, for the consumer. (This one throws me off, because since when do automakers care about the cost to a consumer for replacing stuff?)
3. It might be quicker assembly at the factory too.
Old 05-29-2017, 05:50 PM
  #11939
iforyou's Avatar
#1 is especially true for cars like the Audi R8. If those exhaust tips were actually connected to the exhaust, aligning them would be really difficult...And I'd imagine there could be vibration and some movement that could cause rattling noise as the tips hit the edge of the holes all the time....
Old 05-29-2017, 05:55 PM
  #11940
TacoBello's Avatar
Yes, agreed on the vibrations, also.
Old 05-30-2017, 02:13 PM
  #11941
Costco's Avatar
Received 3,489 Likes on 2,089 Posts
I remember when people were going apeshit over the IS-F having fake tips way back then.
neuronbob (06-16-2017)
Old 05-30-2017, 05:41 PM
  #11942
iforyou's Avatar
haha yes that was like 10 years ago now.....damn....where did the time go.
Old 06-01-2017, 08:22 AM
  #11943
F23A4's Avatar
Received 1,659 Likes on 926 Posts
LOL! So true! People went all 'scorched earth' about IS-F exhaust tips (and the MS6, to a lesser degree). Things got quiet fast once makes like Audi went this route.
Old 06-02-2017, 11:16 PM
  #11944
RPF1+RS3 FTW
AnthraciteAspec's Avatar
Not a huge fan of the fake tips, I guess I am old school. Most of them don't bother me too much, I prefer the tips on the TLX now to having no tips at all, but this I don't like...
The following 2 users liked this post by AnthraciteAspec:
Costco (06-05-2017), RPhilMan1 (06-05-2017)
Old 06-04-2017, 09:06 PM
  #11945
oonowindoo's Avatar
LOL that is FAKE to another level... wtf
I don't understand... Audi took the time and designed the outlet but they actually have to do more work to make it "fake".... i dont get it.
Old 06-05-2017, 12:44 PM
  #11946
2024 Honda Civic Type R
RPhilMan1's Avatar
Received 1,454 Likes on 923 Posts
I don't like that at all either. Ugly.
Old 06-05-2017, 01:33 PM
  #11947
Received 5,293 Likes on 3,627 Posts
Clearly it's just a trim ring, shame on you for mistaking it for an exhaust
Agreed, Definitely not a fan of that, at least make it open with the tip just behind
Old 06-05-2017, 01:59 PM
  #11948
Costco's Avatar
It would look a lot better without that aluminum trim in the middle connecting the faux quad tips.
Putting holes in the faux tips adds a tinge of authenticity but then you can see the real exhaust pipe behind that sometimes, which looks goofy.
Old 06-05-2017, 03:21 PM
  #11949
The prior-gen AMG package S-Class was the same, small diameter tip in a faux-opening in the bumper.
But the turn-down behind an opening would be worse.
Old 06-05-2017, 03:55 PM
  #11950
F23A4's Avatar
Effectively, these are all examples of exhaust outlet trim as opposed to tips. The lack of true exhaust outlet 'aesthetics' is the only glaring negative with the appearance of my 15 MDX/16 TLX.
Acura definitely peaked in this segment with the 07-08 TL-S tips.
Old 06-05-2017, 04:40 PM
  #11951
iforyou's Avatar
LOL nice find. Didn't know that until now. Gotta show my friend who's considering getting a SQ5.
Old 06-05-2017, 05:25 PM
  #11952
oonowindoo's Avatar
I assume that silver piece trim on the SQ5 is not metal, so you can't even cut out the exhaust openings on your own.
Someone should make a metal replacement for aftermarket exhaust. There should be a big market for it....
Old 06-07-2017, 03:02 PM
  #11953
Midnight Marauder
jwong77's Avatar
Wow that SQ5 setup is beyond lame. For all the effort, its not even aesthetically pleasing.
Old 06-08-2017, 04:40 PM
  #11954
nanxun's Avatar
Rocky Mountain High: 500-HP Acura TLX and Aero-Clad Acura NSX Prepare to Scale Pikes Peak
Old 06-08-2017, 04:49 PM
  #11955
iforyou's Avatar
500hp FWD eh?
RPhilMan1 (06-09-2017)
Old 06-08-2017, 04:54 PM
  #11956
oonowindoo's Avatar
It is RWD if you put it in reverse.
kurtatx (06-11-2017)
Old 06-08-2017, 04:58 PM
  #11957
iforyou's Avatar
Good point. The side mirrors will need to be flipped then for maximum downforce.
Old 06-08-2017, 05:04 PM
  #11958
MSZ
Lola
MSZ's Avatar
It has a LSD though, it would be nice if the production car has that as an option too.
TacoBello (06-08-2017)
Old 06-08-2017, 07:13 PM
  #11959
oonowindoo's Avatar
fuk side mirrors, they are for losers who dont drive fast enough.... a RWD TLX with upgraded tires dont need side mirrors.
iforyou (06-09-2017)
Old 06-08-2017, 07:15 PM
  #11960
oonowindoo's Avatar
The production car does not have enough power or enough handling characteristics to require a LSD.... Ditch those all season tires first before installing a LSD.
The following 2 users liked this post by oonowindoo:
RPhilMan1 (06-09-2017), SamDoe1 (06-10-2017)
Quick Reply: Acura: TLX News
