Your thoughts on my Ideas...
From what I have read so far about the factory bose system I have figured that I will not even mess with ANY of the factory wiring. I hear it is strait wire not braided and you would get noise.
Right now I have nothing for a system But I am planning and researching "the perfect SQ system". When I do the Install I will not use any wire already in my car. I am going to run fresh (12ga)pos(to the batt), neg (to the chasis), and ignition (to the ignition switch) for the Head Unit. I do not want ANY noise in my system!
From the headunit I am planing to run RCA's to my amps, and run new 12ga or 10ga wires for each speaker. Could I use Cat5 cable for the speakers bacuase of its design to keep out noise? I am plannning on only having a front stage and subs. (because that is the way SQ systems are set up, or thats what i'm told).
Now here is what I was planning on running:
Panasonic GHOST cd player (for now)(free) I can't remember the model.
Run a new alternator wire to the battery (4ga).
Add a Yellow top Optima battery.
0 guage power to the trunk.
For Highs and mids: MB Quart PCE 216's
http://www.mbquart.com/2003/en_US/pr...&model=PCE+216
And I would power the tweeters using a JL Audio 300/2
and the Mid's by another JL 300/2 using the amp's built in crossover.
http://www.jlaudio.com/amps/3002.html
For Subs: 2 12" Orion XTR Pro's (already have)
Powered by a JBL BP1200.1 (already have)
http://www.jbl.com/car/products/prod...er=POS&cat=AMP
Would all of this make sense to do?
Does anyone have any suggestions?
-S namyaC-
Re: Your thoughts on my Ideas...
I have read this post :
http://www.acura-cl.com/forums/showt...se+factory+amp
Which gave me the thought bypassing all stock wiring would be better. The time that it would take doesn't matter. Why would it hurt to run all new wires?
I guess I could use the new tsunami twisted wire anyway. Not a big deal. I just don't want to redo anything over if it was not good enough. What components would you suggest if the MB Quarts are not good enough?
I do listen to the stereo often without the car on, thats why I figured the Yellow top. I had one before and it never died while being tortured so I was planning on getting another.
Later on I will look at an alternator. But not as of this moment. As for a capacitor, I techinically shouldn't need one since I am not going for SPL. Would it still be worth it? What about those "BatCap's" hear anything about those?
-S namyaC-
[B]I have read this post :
One more thing, do you plan to compete? Even if you are not, you need an EQ to tailor the sound. A 1/2 din 5 band should do pretty well, altho if you plan to compete you should consider a dual 31 (or close) band.
Image Dynamics has a specific "mid--bass driver" If Iwould add one of these to the front stage for the mid bass that you say I am lacking will it sound better? I have heard the JL XR components agains the MB Quart discus speakers; I thought the MB Quarts were muchh more realistic but they did seem to have more lower end. I was figuring they may be lacking in a range where the subs would come in, if tuned correctly.
http://www.imagedynamicsusa.com/webs...s/midbass.html
I have an MA Audio cap that is a few years old but when I sold my car I took it out and It sounded like it was filled with liquid. I was wondering if it was like that when i installed it or if I toasted it over the years?
I do eventually plan to compete. I do not have enough knowledge with EQ's Is there any you would suggest to look at? Could you tell me what I am exactly looking for In one also?
Thanks for your help.
I am all about JL's subs... but I heard the MB Quart Discus speakers against JL's XR650. I was impressed with JL's overall sound, but it sounded like it may be picking up too much lows. I was thinging if you would do only components and no subs the JL's would rock. But I thought the MB's sounded more real. I was thinking with a sub it sould fill in the empty area. Or am I all wrong about this?
MB Quart's PCE216 has:
Frequency Response 38 – 32.000
JL XR650CS has:
Frequency Response: 48 Hz - 25 KHz ± 3 dB
So souldn't the MB have a lower end? If I am wrong about this can someone help me red speaker specs and help me understand what makes a speaker good?
JL XR650CS has:
East Coast Boost.!
I'm trying to get go SQ also. Kick panels are the way to go. Unfortunately, I can't have them because I need my dead pedal.
I'm going to be running:
MB Quart Q series front and back. Powered by a 100x4
Kicker 8" Midbass drivers, powered by a 200x2
(1) 12L72 powered by 750x1
Amps are Hifonics
(2) RF Caps
Yellow Top
Right now I'm running the stuff in my seg through a Alpine ERA-G320. I plan on using a PXA-H700, forgive me if the model number is wrong, too lazy to look it up.
I've done a lot of thinking about my system and talked to a lot fo the gusy I work with. This seems to be a good setup for a reasonable price. Compare what you have to mine and see if you feel you are missing anything.
proaudio22, what do you think?
Amps are Hifonics
(2) RF Caps
Yellow Top
-S namyaC-
Sorry krz4runner and Titand19. I've been busy lately. I gotta run now too, but I read your last tow posts. krz4runner, it's not just about low freq extention, I'll explain later. Titand19, that doesn't sound bad. I'll post more later, I'm just pressed for time now.
WESTK
i know it is played out already, but you cant go wrong with quart for highs, and jl for bass. 1 -12"w7 on a 500 watt amp would slam way louder than xtrs. Use big power cable 4gauge minimum, and also good rcas, monster cable, etc. Shit would be rollin.
Those mb quarts with one jl amp will rock. You'd be even better off with the q series. You don't need rear fill. Rear fills will add more sound for rear seat passengers at the cost of your stereo imaging.
-S namyaC-
JL XR650CS has:
JL XR650CS has:
-S namyaC-
Originally posted by Titand19
[B]I'm trying to get go SQ also. Kick panels are the way to go. Unfortunately, I can't have them because I need my dead pedal.
Amps are Hifonics
(2) RF Caps
Yellow Top
Amps are Hifonics
(2) RF Caps
Yellow Top
My setup in the CL is gonna be close to this:
5.25" components, either Crossfire X series or Boston Pro (maybe 6.5s, depends on what fits right. I really like smaller drivers in the upper mids)
6.5" Crossfire midbass drivers
Probably somthing in the rear for a tad of rear fill
12" Crossfire BMF12 (I really like the sound of this thing)
5 ch Crossfire amp, 50/100x4, and 300x1
The whole point is fairly good SQ, plus the ability to bump a lil if I want. Seeing what some of the other guys in the shop got, I should be able to get around 140db with just that one 12" and 300 watts. It's all about placement (sealed to the cabin) and the box. I really like the sound of the Crossfire pieces, and cost on them is fairly reasonable.
-S namyaC-
Re: Re: Your thoughts on my Ideas...
