Why does my kenwood say "PROTECT" ???
today got my harness and the adapter for my deck(kenwood kdc-mp435u). me and a friend follows the steps and turn it on...... it pop up "PROTECT" does any1 know what the problem is?? its a used deck and i think it fuck up or something... lol
Protect means it has shut down to PROTECT it from burning out.
If it were security related it would say CODE or SECURITY.
Here is the manual:
http://inform3.kenwoodusa.com/manuals%5CKDC-MP435U.pdf
Pages 29, 34 & 35 cover this, all but one refer you to the speaker wiring, one is saying teh CD player is over 140f.
Here is the manual:
Here is the manual:
Here is the manual:
!!!PROBLEM SOLVED!!!
they will walk u through a button sequence or something, so have your radio wired in CORRECTLY!!!
Yeah kenwoods just do that to protect themselves from a short. See if you have a short to ground on a speaker lead with a multimeter on continuity. Also check each speaker to see if you are getting proper resistance between 3-6 ohms. I have seen the kenwoods throw protect for 1-3 ohm loads on the speaker channels. I see 3 as the "iffy" area with them, generally I get 3 when the car has infinity speakers installed which are 2ohm. They will play fine with those but any other speaker that is 3 or below seems to cause problems.
That year/era of Kenwood's seems to have a problem with protecting. I had an MP638U and it went into protect for absolutely no reason. One time, I had it sitting on the roof of my car on top of a sweatshirt at a competition (sweatshirt folded over the top as well) and only 4 wires were hooked up on the harness and it went into protect. Pulled the harness, plugges it back in and it worked fine for about 10 minutes for the rest of the comp. I sent mine back into Kenwood and got it warrantied. Took about 7 weeks, but whatever.
Pegon95
09-15-2015 01:54 PM
