Where Is Stock Amp?
2400 Watts in a TL...Why?
1 Post
you have to take the rear seat off and it is behind the rear seat on the passenger side..
To take it off you'll need a 8mm socket with an extension.
there are black 8mm bolts beside the seatbelt bolts, you don't need to take the seatbelt bolts out just the small 8mm ones. I think there is 4 or five.. after the botls are out the bottom seat will pull up and the rear will also slid up 6 inches and you can pull it out.. doesn't take too long..Enjoy
here is some pics of the amp and the wiring diagram for the amp. Sorry for the size I have the pic alot bigger but for some reason that is the only pic I have had that I can't get in a larger view on car domain....wierd...
InFaMouSLink
10-30-2015 09:43 AM
