What sub wattage should i get if I connect in parallel to get 2ohm??????
Quick question:
If I connect 2 4ohm sub in parallel to get the 2ohm setup to an MA Audio HC1002 bridged to 1 channel, what sub power (Watts) should i get???
The amp power rating
@ 4ohm bridge is 1x360W
@ 2ohm bridge is 1X600W
Is 2 12" 4ohm 700W a good match? MA Audio Sub any good?
This how i plan to connect
___________________
AMP SUB SUB
|_________|_________|
___________________
AMP SUB SUB
f-a-b-o-l-o-u-s
if bridged, your amp will see 1 ohm.
4 ohm x 2 parallel = 2 ohms/2 bridge = 1 ohm
I hope for your sake that the amp is 1 ohm stable. In reality if you wanted to run a 2 ohm config, you should have purchased two 8 ohm subs.
navtool.com
31
11-16-2015 08:30 PM
InFaMouSLink
10-30-2015 09:43 AM
