Want to install system, but had a question about the stock unit
So I'm wondering if the back of the stock unit has a wire for the Remote Wire and RCA cable. can someone confirm?
It's actually called a Line Output Converter (LOC) and you splice your speaker wires into the inputs on the LOC before your factory amp. Or, you can by a high signal LOC, and you can splice it in after the factory amp. Your call. Then you run RCA's from the LOC to your aftermarket amp... If you search, you would've found this... This is like the 6th time I've typed this exact information...
Skirmich
09-15-2015 06:41 PM
yahelou
09-06-2015 09:12 PM
