Viper 791xv Question
NO BP FUEL IN MY
Okay you alarm gurus, I have a Viper 791xv with remote start installed on my TL for a couple years now.
When I run the remote start in the winter, i try to unlock the doors while the car is running, and it doesn't always work. I've had to open with a key, make the remote start shut off by hitting the brake.
It only happens in the cold weather.. What is this?!?! 791 doesnt like the cold?
Thanks in advance.
Lou
Thanks in advance.
Lou
what you're saying is, you hit the "unlock" button on the viper remote and the lights don't flash and the doors are not unlock?? have you try reseting it? i've installed many 791 units and never had that problem before. why do you have to hit the brakes to shut off the car if you gonna drive it off. why can't you just put the key in and turn it to on then put it in gear and drive?
NO BP FUEL IN MY
Sorry I was alittle unclear with that part of the explanation.
When I remote start the car, the unlock won't do anything(only when its cold). So I use my key to open, and since the alarm wasn't turned off, it sets it off. I hit the brake without the key in the switch (which shuts off the car), then I'm able to deactivate the alarm with the unlock button.
I hope this makes sense, I know it kinda sounds all over the place.
try resetting it or unplug the alarm or the battery of the car for 30 minutes. see if that helps if not then you have a bad unit. oh try posting this in www.the12volt.com i'm sure you will get alot more replies there.
Originally Posted by TlsNavi03
Definately wouldnt go back there. wasn't a fan.
Reseting, you mean unplug harness then replug? Would I need to reprogram remotes?
And thanks for the responses by the way gents.
Keep us up to date.
Viper 791
its possible that the contacts inside the key fab have become corroded or become loose. i dont know if that has anything to do with the temp. try twisting the remote a little while pushing the unlock. also try spraying some electronics cleaner/alcohol on the fab and let it dry completely.
other than that man i couldnt tell you, first time ive heard of that also
Viper 791XV
Also I changed the location of the antenna. It's already a week, but no problem now.
navtool.com
31
11-16-2015 08:30 PM
DerrickW
11-15-2015 05:52 PM
