under construction
I've found a new home for my 4 12's while still keeping the 18"btl in the trunk. I want some opinons about my choice of placement before doing any glass work or finishing.Working on the side pannels now.http://memimage.cardomain.com/ride_i...090_medium.jpghttp://memimage.cardomain.com/ride_i...091_medium.jpghttp://memimage.cardomain.com/ride_i...087_medium.jpg
Damn that's a lot of subs you got going on man. I'm sure it'll bump like no other. Interesting choice to mount the subs to the side panels though.
just a lil bit of fyi usually it's best not to mix sub sizes. Build a proper box for the 18" and beat like crazy the 12's are kinda on the trash line of subs (no offense). But hey it's ur ride if ur happy then go for it
please post a vid of this in action
Originally Posted by Rajca
(Post 10904279)
Ridiculously insane and crazy... :shakehead
I like everything about it.. Very creative. Keep us updated.. |
You crazy Bastard
Lmao Keep us posted |
So I fully wired the subs today only with the 1 1600w amp that I have "for now".the amp is wired @.6ohm.It pounds hard.Ive gotten back some of the body flex that I lost when I installed the edead.Also got more front and rear window flex.Just from 2 songs today the piece that sticks on the windsheild beheind the mirrior almost came all the way off.Cant wait for another amp. I've striped the back seat to the frame.cut the frame to fit around the center box to fit perfect.put foam back on so I cant see where to cut.Then I'm gonna try to use the leather and rewrap if it dont look stupid.If it does,Then I might trying fiberglassing right on the foam so I have a well contoured base to start with.I just dont know if the glass will stick.Any one know if fiberglass will stick to the foam? I'll put a video up tommorow.My batterys are charging.
I really hope you have enough electrical to power the amps that you need to properly power all these subs... You should probably be running the 1600 to just the 12's, then get something around 3kw for the 18... For that much current draw, you're going to need at least 1 alt (probably in the 250A range) or 2 alts in the 200A range. Then you're going to need a bank of batteries, probably 2-3 group 31's in the trunk along with the stocker (or aftermarket equivalent) in the front. You're also looking at ~2-3 runs of 1/0 power and ground each. I really hope you get the right amps/electrical to properly power all these subs...
Originally Posted by mattastick
(Post 10925113)
Here's my crappy video.And my car has basically been a work shop for the last 2 weeks so it looks like crap to.But I will put a better video tommorow.But this set up rattles everything.You really cant tell from the video besides the grill rattling.In person it sounds like it's gonna break off.I will get some window flexing next video.I should have another amp by next weekend.http://www.youtube.com/watch?v=iEy7liuUjuc
meh... Not that impressive for the amount of cone area you have... I have about the same amount of air movement from a single 12... And I still need more power for my sub...
(Post 10925391)
More power !!!
I cant really see much because my internet is slow but when you get your other amps I want to see close ups of the back glass Sounds good though |
wow imo its over kill but w/e you like
to be honest with u, sounds like shit. get all the rattles fixed. its not gonna be easy or cheap, and i know u wont get all of them, but u can get the ones that rattle the most.
Me personally I dont care about the rattle as long as i cant hear it inside the car
Originally Posted by richardparker
(Post 10925435)
Yea I agree,But I bet It will be very impressive,with a second amp.You got to remember that one amp is trying to power 5 subs.And one is a 18 That is probally getting less than half of its rms watts.Even as it sits it hits hard.
(Post 10925690)
(Post 10925786)
Yeah... And for that reason, I wouldn't even put it together... I don't do something unless I'm going to do it right... :2cents:
(Post 10925861)
I like this comment.I don't do something unless I'm going to do it right... :2cents:.Well I know thats not true,because you started your build with a 1st gen.
(Post 10925870)
Do you really want to get into this? I can point out many mistakes in your install... If you want, I'll start a list... If not, drop it...
My build log: http://www.caraudioclassifieds.org/f...ead.php?t=5536
There's a small one on here, but neither are completely up to date... I'm working on changing things up right now. Should be an interesting new build... |
(Post 10925959)
(Post 10926015)
I dont have ANYTHING good to say about that.But, are rides are definitly not on the same level,thats for sure.Still think your alright man.but theres no need for you to try chopping on somebody ,when all your weilding is a butterknife.
(Post 10926037)
Let's leave it at this: to each his own...
Like the supportive foam? The stuff that makes your seats soft? If that's what you mean, I doubt it, but I dunno... One way to find out...
I know fiberglass sticks to stuff like the blue painters tape, or aluminum foil, so I would think that it could/would stick to the foam. The one problem I see with it is that it's very porous and that might cause the foam to absorb the resin, and it not go into hardening the glass. I really have no idea, just throwing out there what I do, and a possible problem I see. Best way to find out it to find a small area that isn't always visible or can be covered up and try it out... |
(Post 10925861)
Wow really ur gonna go there?? I've got a 1st gen cl why cuz it was free, also have a 08 chrysler 300. But do I go raggin others cars no. This is no place for that high school shit man I thought everyone here was above that. I must say I am pretty dissapointed |
Originally Posted by on1wheel01
(Post 10926169)
eh its not bad really put about 10 down my boy has a 05 rl paid 6k for it but salvage title you'd never know it the shit is bad ass
Just took another clip of some roof flex.This setup is loud.I just ordered another 1600w BXI 1608 tonight,thats gonna be crazy. Also went to a uplosterer today that said he'll only charge 200 to rewrap my rear back seat cushion to wrap around the box so that I can slide the box in or out to where I want it to mount. http://www.youtube.com/watch?v=K2HeBx0f7vE
Richard I believe It will stick to foam
That blazer guy always has a comment Nice sound system BTW richard, I like it I want to see whats next with the upolstry and what not Matt I like your setup very functional sounds pretty good to althought its hard to tell sound quality over the net ( easy to hear loudness) were talking about our cars I got 05 magnum rt 03 rav 4 88 300zx 80 indy pace car trans (fully restored by me) 01 cls |
With all that done, i still can't believe you haven't upgraded your HU yet.
(Post 10925861)
grow up if you want people to help you around here. |
and i agree w/ '03TL-S, upgrade your HU. that should've been the first thing you did. plus, you better have some high end components in there or you won't be hearing shit
Originally Posted by '03TL-S
(Post 10946547)
(Post 10946711)
x2... But like I've said before, it's your build, your call...
Btw I love your setup looks really good Trunk could look a little nicer but under the hood and the wiring looks really good to bad we cant really hear the SQ (and im being serious) |
Originally Posted by MrFluffy
(Post 10946851)
I thank you will agree with me there are two kinds of builds there is sound quality and there is just plain loud now to each there own but me personally I think im going def
Btw I love your setup looks really good Trunk could look a little nicer but under the hood and the wiring looks really good to bad we cant really hear the SQ (and im being serious) Where you at? If you're anywhere near Southwest Ohio, hit me up. We can meet up and you can hear it. Now or when I finish the new build... |
One warning to everyone.. Take it down a notch..
