Tuning For Dummies
Future Seminole
1 Post
Tuning For Dummies
im sure there are a lot of people out there just like me letting the potential of their, in my case at least, half-ass system set up go by. if anyone is able to help out on this thread please do. today i went out and played with my mp for about 5 minutes trying to see if i could it for my sub to get any better...didnt work. one of my problems was that i dont know what features affect what kind of sound will be produced; which leads me to the purpose of this thread.
maybe this is a tall order, but if anyone could just define in joe schmo terms what each of these things do when tweaked, it would benefit all us not smart but wish they were audio guys...
terms in question
Input - including 1 ch or 2 ch selection, adjusting input level, gain adjustment
Low Pass Filter - what on/off does, what adjusting will do
Subsonic Filter - what on/off does, what adjusting frequency does
Parametric Equalizer - what on/off does, adjusting the frequency does, what adjusting the width does, what adjusting the level does
Bass Compensation - what having on/off does
Time Correction - what having on/off does, what adjusting delay time will do
Phase - what does this do
im sure this amp has great features, but i dont know what they do so i cant get my moneys worth. i bet theres a lot of people like me that just deal with whats given without ever knowing what they can really do.... any help at all in explaining these things would be greatly appreciated by all the submissees of the amp tuning world
terms in question
2004 CG TSX w/ At & NAV
put the input on 1ch and adjust the gain to sound at a good level for the normal volume u listen at. dont use the gain to increase bass
low pass filter on -this will make only the low freq come to the subs, adjusting it will tell the amp what freq to cut off the bass at
subsonic and parametric eq sound like alipne specifics. leave the parametric off and play around with the sub sonic on
try bass comp off and see how it sounds. (i thinkin this is for 2ch mode and doors)
Time correction off.....
Phase - what are ur options. leave at the amp default
Future Seminole
1 Post
awesome, thanx for the help. when i have a good amount of time ill play around with it to see what sounds best. it was just hard tweaking things without knowing what they do and if they could cause any kinda harm
Originally Posted by acuratsx03
terms in question
Assuming you're using sealed box, no coils, then you want the low pass filter on, this is your crossover...Not knowing what type of music you listen too, I'd say start at 90Hz, and move it up and down from there, listening to the music you like...
Phase is when you wire your amp to sub, positive to positive and negative to negative(generally known as the correct way) you are "in-phase"....if you wire your sub backwards pos to neg...you will be "out-of-phase".....this is easy to see if you have 2 subs next to each other and one is wired in and the other wired out, then you'll see one sub push at the same time the other sub pulls... SO basically what this will do will flip the phase for you...so if either you wired your sub wrong and didn't feel like pulling it back out to fix the wires, you could just flip it in the amp(180), OR sometimes people purposely run speakers out-of-phase. but that's more then you need explained right now...So basically, if your subs are wired correctly, just run "in-phase" or "0"..
MrHeeltoe
20
02-23-2023 01:54 PM
ExcelerateRep
10-14-2015 08:20 AM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
