TSX front door, largest speaker?
Old Feb 1, 2008 | 08:19 PM
White92's Avatar
I've been searching forever, but can't seem to find this answer. What is the largest speaker that will fit in the front door of a TSX, with a spacer? Specifically, will a speaker with a mounting depth of 2.65 inches and a mounting hole diam. of 5.56 inches fit? Or more specifically, will the JL Audio ZR650-CSi fit?
Old Feb 1, 2008 | 09:36 PM
wong05tsx's Avatar
Need more room in
i have 2.75" depth speaker, fits fine with a 3/4mdf spacer, i don't know about the 5.56 hole dia, i didn't have any problems with mine
Old Feb 1, 2008 | 10:45 PM
Reach's Avatar
I haven't heard of a 6.5" speaker NOT fitting yet. (assuming the use of a common spacer)
The honda accord universal plastic spacers fit all the TSX doors and are cheap and easy to use.
Old Feb 2, 2008 | 09:22 AM
White92's Avatar
Good to know. Thanks guys. I know I could always use a spacer if the depth was too deep so I didn't hit the inside of the door skin. But I didn't want to run into problems with having to use a spacer that was too think and then run into problems with hitting the grill in the door.
Old Feb 2, 2008 | 09:25 AM
madmanmax3000's Avatar
Professional Newbie
pretty much any speaker will fit, just keep the magnet down to 3" maybe 4" and obviously the slimmer the better.
As long as you're not afraid to drill into your door, you can put pretty much anything in there using a custom spacer.
Old Feb 2, 2008 | 12:55 PM
wong05tsx's Avatar
Need more room in
more importantly, you don't want the window to hit the magnet when you roll it down :o
Old Feb 5, 2008 | 06:32 PM
Michael921's Avatar
Be careful with speakers that have mounting diameters over 5.5". I installed some MB Quart RVF216 and they are labeled 6.5" speakers but their mounting diameters are closer to that of 6.75" speakers. Even with the Accord speaker adapters I had trouble with the fancy brackets around the magnet clearing the adapter so I had to custom fit a spacer onto the adapter which I dont recommend doing.
FIY - most normal 6.5" speakers will have ~5" mounting diameters which should fit just fine. PM if you need me to clarify my explanation.
Old Feb 6, 2008 | 10:55 AM
Reach's Avatar
I mounted 6.75" Kappas no problem. Most 6.5" speakers have >6" mounting diameters, I have no idea where you're pulling that from.
There are tons of great 5.5" speakers too, which will have... 5" - 6" mounting diameters.
Old Feb 6, 2008 | 12:37 PM
zidenx's Avatar
i had to cut my door a little bit to fit my speakers in there with a 3/4 mdf spacer.
Old Feb 7, 2008 | 10:46 AM
White92's Avatar
With what speakers?
Feb 25, 2020 09:57 AM
handsom-hustla
Nov 13, 2015 05:04 PM
sockr1
Oct 1, 2015 01:31 AM
DiamondJoeQuimby
Sep 10, 2015 11:40 AM
08 NBP TL
Sep 8, 2015 08:49 PM
