Trying to jam the most I can into my trunk
I am trying to put as much bass into my car as I can with the subs I have. No need for trunk space.And I could even remove rear seat back while retaining botom seat cushings. I have 4 12" subs that need aleast 1 cube sealed 1.6 ported.and 3 18's that need atleast 5 cubes ported.My thoughts were so far. 1 18 and 2 12's,in the trunk. 1 18 and 4 12's in the trunk.Or 3 18's for monster lows. 1 in the rear seat 2 in the trunk. Any other idea's,or maybe sketches ,pics...
You might be able to squeeze 1 18 in there... If you're really lucky and are good at fiberglassing, you might be able to squeeze 2 18's in there... What are the subs? Once we know what subs you have, and what kind of amps you're working with, then we can make better suggestions...
Yea 2 18" btl's are killer. But they need 7 cubes each I'd just take out the spare and fiberglass the trunk. Go with one 18" if you like deep bass, maybe 2-4 12's for faster hard hitting.
The 18's need 5 min.10max so I guess your 7 would be a reccomended #.Right now I'm running 4 12's, with 400w rms going to each sub.and thats all they can handle.there in min cube sealed boxes and sound pretty good for how much they cost.the specs say that if ported to recomended size I'll gain 3 db per sub and if ported to the max size,It will gain 5db per sub.Now, If you have your mouth slightly open it will rattle your teeth together.If proply ported I really would'nt need any more subs.just,Theres a kid at my work that thinks he has the loudest subs in the world.(2 15"l7's)in a sealed box and 2 1000w memphis amps.I'm just trying show him his set up is far from the best.He gets loud but, low volume sounds like crap.Thats why I'm trying to squeze some 18's into the mix
Give (or sell, your call) the 12's to your girl. Sell the 18's, buy a single 12 or 15 (or even a couple 10's if you feel like building a whale of a box), a beastly amp, a couple batts, and go show the kid up...
Well I had a l7 15 but sold it quick(1st system in the cl)(only had her a few months and have had 3 set ups in her i'm never happy) and my old dd 9515 out hit it in every way. I am hoping my dc 12's out do the dd. It's all about quality get a good pair of 12's or 15's and out slam him.
even if you went with the smallest recommended size, you would need 10 cubes before port and sub displacement..
i don't even think 6 cubes would fit in a cl.
i personally think 1 installed correctly with clean power would be enough. you could easily hit 140's with one 18
I figured the 4 12's would be louder. I think it's the boxes that are hurting you. This is what 1 15 in my car did( I also had A blown coil that I did not know about so I wasnt doin full potential), all the dynamatting I've been doing should help with rattle.http://s79.photobucket.com/albums/j1...t=DSCI0012.flv
I highly doubt that... I know of a dude with 1 in a Saturn (trunk car) with a XXX10000 powering it, and he's only doing 147.8... In an SUV with enough room for a big box, yeah it's doable... But I doubt it from a trunk...
Here's a vid of my 12's it dont look that impressive cuz with all my sound deadening theres not that much flexing anymore.And there a terribile plate rattle that I've taking care of with about 3-4 pounds of edead on the back of the plate and in between the frame.http://www.youtube.com/watch?v=3pdyvCdx1C0
I'll let you take a look at it, and see if you can do better: http://www.freewebs.com/ohiobasssociety/dougspage.htm
It's basically the best he can do and still be a trunk car... I'm guessing you couldn't get any more space out of your trunk than him... Also, this setup is on the way out, he's working on a couple of 18's in the back seat area... That's going to be very fun... I suspect he will blow out his rear window at sometime if he gets what we talked about earlier done (doubling up with 2 of those amps)... That should be really interesting...
It takes A LOT of work to get a trunk car into the 150s...and a pair of properly installed 18" BTLs will take a A LOT of work to pull off in a CL. Not saying it can't be done, but if I was going to run a pair of BTLs I would build a wall
you might be able to get that kind of space with some serious fiberglass work (which means a huge investment in said fiberglass) and bracing... If you can do it, more power to you, and I'd love to see it... More than likely though, you're not going to be able to pull it off...
Decided to build a single sub box myself since the guy wanted to charge me 1600 plus.These pics are before fully caulked and speaker mounted.Just want to show my first ported box.carpet job not perfect since I was building it on a concrete slab.and when I was in the house cats also was using it for a straching post.Havent tunned amp yet but It definitly give the 4 12's a run,with the same amp and sounds beter while doing so.Cant wait for a bigger amp...box is tuned to 32hz.
