CL: Too Many amplifiers ?
Get 2 volt gauges, and attach 1 to each amp... Then you'll be able to see what kind of voltage drop you're getting... That's the best way to make sure you're not tearing shit up... Then, you'll also be able to tell how much of a difference batt/alt upgrades make...
http://www.hifisoundconnection.com/S...id/0/SFV/30046
Anything like that would work... Just make sure it's set correctly using a DMM. You should be alright into the 11's, but if your voltage is dropping out of the 12's, turn it down!!!! I personally didn't run my amp below like 13.5 when I had everything hooked up
Soul_Deamon
11-13-2018 04:44 PM
4drviper
09-23-2015 09:00 PM
